At boot time we round the memblock limit down to section size in an
attempt to ensure that we will have mapped this RAM with section
mappings prior to allocating from it. When mapping RAM we iterate over
PMD-sized chunks, creating these section mappings.
Section mappings are only created when the end of a chunk is aligned to
section size. Unfortunately, with classic page tables (where PMD_SIZE is
2 * SECTION_SIZE) this means that if a chunk is between 1M and 2M in
size the first 1M will not be mapped despite having been accounted for
in the memblock limit. This has been observed to result in page tables
being allocated from unmapped memory, causing boot-time hangs.
This patch modifies the memblock limit rounding to always round down to
PMD_SIZE instead of SECTION_SIZE. For classic MMU this means that we
will round the memblock limit down to a 2M boundary, matching the limits
on section mappings, and preventing allocations from unmapped memory.
For LPAE there should be no change as PMD_SIZE == SECTION_SIZE.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reported-by: Stefan Agner <stefan@agner.ch>
Tested-by: Stefan Agner <stefan@agner.ch>
Acked-by: Laura Abbott <labbott@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
Cc: Steve Capper <steve.capper@linaro.org>
Cc: stable@vger.kernel.org
Now local variables kernel_x_start and kernel_x_end defined using
'unsigned long' type which is wrong because they represent physical
memory range and will be calculated wrongly if LPAE is enabled.
As result, all following code in map_lowmem() will not work correctly.
For example, Keystone 2 boot is broken because
kernel_x_start == 0x0000 0000
kernel_x_end == 0x0080 0000
instead of
kernel_x_start == 0x0000 0008 0000 0000
kernel_x_end == 0x0000 0008 0080 0000
and as result whole low memory will be mapped with MT_MEMORY_RW
permissions by code (start > kernel_x_end):
} else if (start >= kernel_x_end) {
map.pfn = __phys_to_pfn(start);
map.virtual = __phys_to_virt(start);
map.length = end - start;
map.type = MT_MEMORY_RW;
create_mapping(&map);
Hence, fix it by using phys_addr_t type for variables kernel_x_start
and kernel_x_end.
Tested-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@linaro.org>
set_memory_* functions have same implementation
except memory attribute.
This patch makes to use common function for these, and pull out
the functions into arch/arm/mm/pageattr.c like arm64 did.
It will reduce code size and enhance the readability.
Signed-off-by: Jungseung Lee <js07.lee@gmail.com>
Modern ARMv7-A/R cores optionally implement below new
hardware feature:
- PXN:
Privileged execute-never(PXN) is a security feature. PXN bit
determines whether the processor can execute software from
the region. This is effective solution against ret2usr attack.
On an implementation that does not include the LPAE, PXN is
optionally supported.
This patch set PXN bit on user page table for preventing
user code execution with privilege mode.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Convert many (but not all) printk(KERN_* to pr_* to simplify the code.
We take the opportunity to join some printk lines together so we don't
split the message across several lines, and we also add a few levels
to some messages which were previously missing them.
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Felipe Balbi <balbi@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux into devel-stable
generic fixmaps
ARM support for CONFIG_DEBUG_RODATA
Adds CONFIG_ARM_KERNMEM_PERMS to separate the kernel memory regions
into section-sized areas that can have different permisions. Performs
the NX permission changes during free_initmem, so that init memory can be
reclaimed.
This uses section size instead of PMD size to reduce memory lost to
padding on non-LPAE systems.
Based on work by Brad Spengler, Larry Bassel, and Laura Abbott.
Tested-by: Laura Abbott <lauraa@codeaurora.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
This is used from set_fixmap() and clear_fixmap() via asm-generic/fixmap.h.
Also makes sure that the fixmap allocation fits into the expected range.
Based on patch by Rabin Vincent.
Cc: Rabin Vincent <rabin@rab.in>
With commit a05e54c103b0 ("ARM: 8031/2: change fixmap mapping region to
support 32 CPUs"), the fixmap region was expanded to 2MB, but it
precluded any other uses of the fixmap region. In order to support other
uses the fixmap region needs to be expanded beyond 2MB. Fortunately, the
adjacent 1MB range 0xffe00000-0xfff00000 is availabe.
Remove fixmap_page_table ptr and lookup the page table via the virtual
address so that the fixmap region can span more that one pmd. The 2nd
pmd is already created since it is shared with the vector page.
Signed-off-by: Rob Herring <robh@kernel.org>
[kees: fixed CONFIG_DEBUG_HIGHMEM get_fixmap() calls]
[kees: moved pte allocation outside of CONFIG_HIGHMEM]
Use the more common pr_warn.
Other miscellanea:
o Coalesce formats
o Realign arguments
Add further comments to the early page table remap code to explain what
the code is doing, why it is doing it, but more importantly to explain
that the code is not architecturally compliant and is squarely in
"UNPREDICTABLE" behaviour territory.
Add a warning and tainting of the kernel too.
This does the same as the previous commit, but for the S bit, which also
needs to match the initial value which the assembly code used for the
same reasons. Again, we add a check for SMP to ensure that the page
tables are correctly setup for SMP.
Fix a long standing bug where, for ARMv6+, we don't fully ensure that
the C code sets the same cache policy as the assembly code. This was
introduced partially by commit 11179d8ca28d ([ARM] 4497/1: Only allow
safe cache configurations on ARMv6 and later) and also by adding SMP
support.
This patch sets the default cache policy based on the flags used by the
assembly code, and then ensures that when a cache policy command line
argument is used, we verify that on ARMv6, it matches the initial setup.
adjust_cr() is not used anymore, so let's get rid of it.
Keep all bits of alignment handling together.
Several places open-code this manipulation, let's consolidate this.
memblock is now fully integrated into the kernel and is the prefered
method for tracking memory. Rather than reinvent the wheel with
meminfo, migrate to using memblock directly instead of meminfo as
an intermediate.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
dsb st can be used to ensure completion of pending cache maintenance
operations, so use it for the v7 cache maintenance operations.
In 32-bit ARM systems, the fixmap mapping region can support no more
than 14 CPUs(total: 896k; one CPU: 64K). And we can configure NR_CPUS
up to 32. So there is a mismatch.
This patch moves fixmapping region downwards to region 0xffc00000-
0xffe00000. Then the fixmap mapping region can support up to 32 CPUs.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Liu Hua <sdu.liu@huawei.com>
'unstable/sa11x0' into for-next
CPU_32v6 currently selects CPU_USE_DOMAINS if CPU_V6 and MMU. This is
because ARM 1136 r0pX CPUs lack the v6k extensions, and therefore do
not have hardware thread registers. The lack of these registers requires
the kernel to update the vectors page at each context switch in order to
write a new TLS pointer. This write must be done via the userspace
mapping, since aliasing caches can lead to expensive flushing when using
kmap. Finally, this requires the vectors page to be mapped r/w for
kernel and r/o for user, which has implications for things like put_user
which must trigger CoW appropriately when targetting user pages.
The upshot of all this is that a v6/v7 kernel makes use of domains to
segregate kernel and user memory accesses. This has the nasty
side-effect of making device mappings executable, which has been
observed to cause subtle bugs on recent cores (e.g. Cortex-A15
performing a speculative instruction fetch from the GIC and acking an
interrupt in the process).
This patch solves this problem by removing the remaining domain support
from ARMv6. A new memory type is added specifically for the vectors page
which allows that page (and only that page) to be mapped as user r/o,
kernel r/w. All other user r/o pages are mapped also as kernel r/o.
Patch co-developed with Russell King.
Cc: <stable@vger.kernel.org>
The stage-2 memory attributes are distinct from the Hyp memory
attributes and the Stage-1 memory attributes. We were using the stage-1
memory attributes for stage-2 mappings causing device mappings to be
mapped as normal memory. Add the S2 equivalent defines for memory
attributes and fix the comments explaining the defines while at it.
Add a prot_pte_s2 field to the mem_type struct and fill out the field
for device mappings accordingly.
Cc: <stable@vger.kernel.org> [3.9+]
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
The CMA region was being marked executable:
0xdc04e000-0xdc050000 8K RW x MEM/CACHED/WBRA
0xdc060000-0xdc100000 640K RW x MEM/CACHED/WBRA
0xdc4f5000-0xdc500000 44K RW x MEM/CACHED/WBRA
0xdcce9000-0xe0000000 52316K RW x MEM/CACHED/WBRA
This is mainly due to the badly worded MT_MEMORY_DMA_READY symbol, but
there are also a few other places in dma-mapping which should be
corrected to use the right constant. Fix all these places:
0xdc04e000-0xdc050000 8K RW NX MEM/CACHED/WBRA
0xdc060000-0xdc100000 640K RW NX MEM/CACHED/WBRA
0xdc280000-0xdc300000 512K RW NX MEM/CACHED/WBRA
0xdc6fc000-0xe0000000 58384K RW NX MEM/CACHED/WBRA
Other architectures define various set_memory functions to allow
attributes to be changed (e.g. set_memory_x, set_memory_rw, etc.)
Currently, these functions are missing on ARM. Define these in an
appropriate manner for ARM.
Add basic NX support for kernel lowmem mappings. We mark any section
which does not overlap kernel text as non-executable, preventing it
from being used to write code and then execute directly from there.
This does not change the alignment of the sections, so the kernel
image doesn't grow significantly via this change, so we can do this
without needing a config option.
Document the permissions which the various MT_MEMORY* mapping types
will provide.
ECC policy can be applied to the whole system
when this bit is implemented by SoC vendor
(IMP - bit 9 - in L1 page table entry format).
When this bit is not implemented by SoC vendor
it doesn't mean that system has no other way
how to do ECC.
This patch ensures to show this message only when ECC
is requested via cmd line ecc=on and runs on
appropriate ARM core.
This patch adds a step in the init sequence, in order to recreate
the kernel code/data page table mappings prior to full paging
initialization. This is necessary on LPAE systems that run out of
a physical address space outside the 4G limit. On these systems,
this implementation provides a machine descriptor hook that allows
the PHYS_OFFSET to be overridden in a machine specific fashion.
Signed-off-by: R Sricharan <r.sricharan@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
If kuser helpers are not provided by the kernel, disable user access to
the vectors page. With the kuser helpers gone, there is no reason for
this page to be visible to userspace.
Move the machine vector stubs into the page above the vector page,
which we can prevent from being visible to userspace. Also move
the reset stub, and place the swi vector at a location that the
'ldr' can get to it.
This hides pointers into the kernel which could give valuable
information to attackers, and reduces the number of exploitable
instructions at a fixed address.
struct machine_desc records are defined everywhere as a 'const'
structure, but unfortuantely it loses its const-ness through the use of
linker magic - the symbols which surround the section are not declared
const so it becomes possible not to use 'const' for pointers to these
const structures.
Let's fix this oversight - all pointers to these structures should be
marked const too.
When map_lowmem() runs, and processes a memory bank whose start or end
is not section-aligned, memory must be allocated to store the 2nd-level
page tables. Those allocations are made by calling memblock_alloc().
At this point, the only memory that is free *and* mapped is memory which
has already been mapped by map_lowmem() itself. For this reason, we must
calculate the first point at which map_lowmem() will need to allocate
memory, and set the memblock allocation limit to a lower address, so that
memblock_alloc() is guaranteed to return memory that is already mapped.
This patch enhances sanity_check_meminfo() to calculate that memory
address, and pass it to memblock_set_current_limit(), rather than just
assuming the limit is arm_lowmem_limit.
The algorithm applied is:
* Default memblock_limit to arm_lowmem_limit in the absence of any other
limit; arm_lowmem_limit is the highest memory that is mapped by
map_lowmem().
* While walking the list of memblocks, if the start of a block is not
aligned, 2nd-level page tables will need to be allocated to map the
first few pages of the block. Hence, the memblock_limit must be before
the start of the block.
* Similarly, if the end of any block is not aligned, 2nd-level page
tables will need to be allocated to map the last few pages of the
block. Hence, the memblock_limit must point at the end of the block,
rounded down to section-alignment.
* The memory blocks are assumed to be sorted in address order, so the
first unaligned block start or end is used to set the limit.
With this algorithm, the start or end of almost any bank can be non-
section-aligned. The only exception is that the start of bank 0 must
be section-aligned, since otherwise memory would need to be allocated
when mapping the start of bank 0, which occurs before any free memory
is mapped.
[swarren, wrote commit description, rewrote calculation of memblock_limit]
Pull ARM fixes from Russell King:
"A few fixes for ARM, mostly just one liners with the exception of the
missing section specification. We decided not to rely on .previous to
fix this but to explicitly state the section we want the code to be
in."
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7778/1: smp_twd: twd_update_frequency need be run on all online CPUs
ARM: 7782/1: Kconfig: Let ARM_ERRATA_364296 not depend on CONFIG_SMP
ARM: mm: fix boot on SA1110 Assabet
ARM: 7781/1: mmu: Add debug_ll_io_init() mappings to early mappings
ARM: 7780/1: add missing linker section markup to head-common.S
Failure to add the mapping created in debug_ll_io_init() can lead
to the BUG_ON() triggering in lib/ioremap.c:27 if the static
virtual address decided for the debug_ll mapping overlaps with
another mapping that is created later. This happens because the
generic ioremap code has no idea there is a mapping there and it
tries to place a mapping in the same location and blows up when
it sees that there is a pte already present.
kernel BUG at lib/ioremap.c:27!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0-rc2-00042-g2af0c67-dirty #316
task: ef088000 ti: ef082000 task.ti: ef082000
PC is at ioremap_page_range+0x16c/0x198
LR is at ioremap_page_range+0xf0/0x198
pc : [<c04cb874>] lr : [<c04cb7f8>] psr: 20000113
sp : ef083e78 ip : af140000 fp : ef083ebc
r10: ef7fc100 r9 : ef7fc104 r8 : 000af174
r7 : 00000647 r6 : beffffff r5 : f004c000 r4 : f0040000
r3 : af173417 r2 : 16440653 r1 : af173e07 r0 : ef7fc8fc
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5787d Table: 8020406a DAC: 00000015
Process swapper/0 (pid: 1, stack limit = 0xef082238)
Stack: (0xef083e78 to 0xef084000)
3e60: 00040000 ef083eec
3e80: bf134000 f004bfff c0207c00 f004c000 c02fc120 f000c000 c15e7800 00040000
3ea0: ef083eec 00000647 c098ba9c c0953544 ef083edc ef083ec0 c021b82c c04cb714
3ec0: c09cdc50 00000040 ef0f1e00 ef1003c0 ef083f14 ef083ee0 c09535bc c021b7bc
3ee0: c0953544 c04d0c6c c094e2cc c1600be4 c07440c4 c09a6888 00000002 c0a15f00
3f00: ef082000 00000000 ef083f54 ef083f18 c0208728 c0953550 00000002 c1600bfc
3f20: c08e3fac c0839918 ef083f54 c1600b80 c09a6888 c0a15f00 0000008b c094e2cc
3f40: c098ba9c c098bab8 ef083f94 ef083f58 c094ea0c c020865c 00000002 00000002
3f60: c094e2cc 00000000 c025b674 00000000 c06ff860 00000000 00000000 00000000
3f80: 00000000 00000000 ef083fac ef083f98 c06ff878 c094e910 00000000 00000000
3fa0: 00000000 ef083fb0 c020efe8 c06ff86c 00000000 00000000 00000000 00000000
3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 c0595108
[<c04cb874>] (ioremap_page_range+0x16c/0x198) from [<c021b82c>] (__alloc_remap_buffer.isra.18+0x7c/0xc4)
[<c021b82c>] (__alloc_remap_buffer.isra.18+0x7c/0xc4) from [<c09535bc>] (atomic_pool_init+0x78/0x128)
[<c09535bc>] (atomic_pool_init+0x78/0x128) from [<c0208728>] (do_one_initcall+0xd8/0x198)
[<c0208728>] (do_one_initcall+0xd8/0x198) from [<c094ea0c>] (kernel_init_freeable+0x108/0x1d0)
[<c094ea0c>] (kernel_init_freeable+0x108/0x1d0) from [<c06ff878>] (kernel_init+0x18/0xf4)
[<c06ff878>] (kernel_init+0x18/0xf4) from [<c020efe8>] (ret_from_fork+0x14/0x20)
Code: e50b0040 ebf54b2f e51b0040 eaffffee (e7f001f2)
Fix it by telling generic layers about the static mapping via
iotable_init(). This also has the nice side effect of letting
you see the mapping in procfs' vmallocinfo file.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Pull ARM updates from Russell King:
"This contains the usual updates from other people (listed below) and
the usual random muddle of miscellaneous ARM updates which cover some
low priority bug fixes and performance improvements.
I've started to put the pull request wording into the merge commits,
which are:
- NoMMU stuff:
This includes the following series sent earlier to the list:
- nommu-fixes
- R7 Support
- MPU support
I've left out the ARCH_MULTIPLATFORM/!MMU stuff that Arnd and I
were discussing today until we've reached a conclusion/that's had
some more review.
This is rebased (and re-tested) on your devel-stable branch because
otherwise there were going to be conflicts with Uwe's V7M work now
that you've merged that. I've included the fix for limiting MPU to
CPU_V7.
- Huge page support
These changes bring both HugeTLB support and Transparent HugePage
(THP) support to ARM. Only long descriptors (LPAE) are supported
in this series.
The code has been tested on an Arndale board (Exynos 5250).
- LPAE updates
Please pull these miscellaneous LPAE fixes I've been collecting for
a while now for 3.11. They've been tested and reviewed by quite a
few people, and most of the patches are pretty trivial. -- Will Deacon.
- arch_timer cleanups
Please pull these arch_timer cleanups I've been holding onto for a
while. They're the same as my last posting, but have been rebased
to v3.10-rc3.
- mpidr linearisation (multiprocessor id register - identifies which
CPU number we are in the system)
This patch series that implements MPIDR linearization through a
simple hashing algorithm and updates current cpu_{suspend}/{resume}
code to use the newly created hash structures to retrieve context
pointers. It represents a stepping stone for the implementation of
power management code on forthcoming multi-cluster ARM systems.
It has been tested on TC2 (dual cluster A15xA7 system), iMX6q,
OMAP4 and Tegra, with processors hitting low-power states requiring
warm-boot resume through the cpu_resume code path"
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (77 commits)
ARM: 7775/1: mm: Remove do_sect_fault from LPAE code
ARM: 7777/1: Avoid extra calls to the C compiler
ARM: 7774/1: Fix dtb dependency to use order-only prerequisites
ARM: 7770/1: remove residual ARMv2 support from decompressor
ARM: 7769/1: Cortex-A15: fix erratum 798181 implementation
ARM: 7768/1: prevent risks of out-of-bound access in ASID allocator
ARM: 7767/1: let the ASID allocator handle suspended animation
ARM: 7766/1: versatile: don't mark pen as __INIT
ARM: 7765/1: perf: Record the user-mode PC in the call chain.
ARM: 7735/2: Preserve the user r/w register TPIDRURW on context switch and fork
ARM: kernel: implement stack pointer save array through MPIDR hashing
ARM: kernel: build MPIDR hash function data structure
ARM: mpu: Ensure that MPU depends on CPU_V7
ARM: mpu: protect the vectors page with an MPU region
ARM: mpu: Allow enabling of the MPU via kconfig
ARM: 7758/1: introduce config HAS_BANDGAP
ARM: 7757/1: mm: don't flush icache in switch_mm with hardware broadcasting
ARM: 7751/1: zImage: don't overwrite ourself with a page table
ARM: 7749/1: spinlock: retry trylock operation if strex fails on free lock
ARM: 7748/1: oabi: handle faults when loading swi instruction from userspace
Pull ARM SoC cleanups from Arnd Bergmann:
"This contains cleanups as preparation for other branches adding new
features, we pulled 16 branches for 9 platforms into this one.
Most notable here is the removal of support for ATAGS based OMAP4
systems. Since all OMAP4 machines are fully functional with DT based
booting in 3.10, we can remove a lot of code here.
Also noteworthy is Maxime Ripard's cleanup of the machine descriptors,
which means we need no machine descriptors in a lot more cases and can
boot additional machines by just having the respective device drivers
enabled."
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (76 commits)
ARM: picoxcell: remove .nr_irqs reference
ARM: s5p64x0: avoid build warning for uncompress.h
ARM: SAMSUNG: Remove unused plat/regs-watchdog.h header
ARM: SAMSUNG: Remove legacy watchdog reset code
ARM: SAMSUNG: Let platforms use the new watchdog reset driver
ARM: SAMSUNG: Add watchdog reset driver
ARM: SAMSUNG: Use local definitions of watchdog registers
watchdog: s3c2410_wdt: Use local register definitions
ARM: S5P64X0: Use common uncompress.h part for plat-samsung
ARM: SAMSUNG: Consolidate uncompress subroutine
ARM: at91: drop rm9200dk board support
ARM: dts: msm: Fix merge resolution
ARM: OMAP1: Remove dma.h
ARM: OMAP1: Remove legacy irda.h and irda setup from board files
ARM: OMAP1: Remove duplicated DMA channel definitions
ARM: OMAP1: Remove McBSP DMA channel definitions
ARM: OMAP2+: Remove dma.h
ARM: OMAP2+: hwmod: Remove remaining DMA channel definitions
ARM: OMAP2+: Remove duplicated DMA channel definitions
ARM: OMAP2+: Remove AES crypto device DMA channel definitions
arch/arm/Makefile
arch/arm/include/asm/glue-proc.h
This bug was introduced in commit e651eab0.
Some v4/v5 platforms failed to boot due to this.
Signed-off-by: Po-Yu Chuang <ratbert.chuang@gmail.com>
This patch cleans up the highmem sanity check code by simplifying the range
checks with a pre-calculated size_limit. This patch should otherwise have no
functional impact on behavior.
This patch also removes a redundant (bank->start < vmalloc_limit) check, since
this is already covered by the !highmem condition.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Subash Patel <subash.rp@samsung.com>
On Keystone platforms, physical memory is entirely outside the 32-bit
addressible range. Therefore, the (bank->start > ULONG_MAX) check below marks
the entire system memory as highmem, and this causes unpleasentness all over.
This patch eliminates the extra bank start check (against ULONG_MAX) by
checking bank->start against the physical address corresponding to vmalloc_min
instead.
In the process, this patch also cleans up parts of the highmem sanity check
code by removing what has now become a redundant check for banks that entirely
overlap with the vmalloc range.
This patch modifies the highmem sanity checking code to use physical addresses
instead. This change eliminates the wrap-around problems associated with the
original virtual address based checks, and this simplifies the code a bit.
The one constraint imposed here is that low physical memory must be mapped in
a monotonically increasing fashion if there are multiple banks of memory,
i.e., x < y must => pa(x) < pa(y).
This patch fixes the alloc_init_pud() function to use phys_addr_t instead of
unsigned long when passing in the phys argument.
This is an extension to commit 97092e0c56830457af0639f6bd904537a150ea4a (ARM:
pgtable: use phys_addr_t for physical addresses), which applied similar changes
elsewhere in the ARM memory management code.
More and more sub-architectures are using only the debug_ll_io_init
function as the map_io function. Make the core code call this function
if no function is specified in the machine description to remove some
boilerplate code.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
'smp-hotplug' into for-linus
tcm_init() call iotable_init() and it use early_alloc variants which
do memblock allocation. Directly using memblock allocation after
initializing bootmem should not permitted, because bootmem can't know
where are additinally reserved.
So move tcm_init() to a safe place before initalizing bootmem.
(On the U300)
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
With LPAE enabled, alloc_init_section() does not map the entire
address space for unaligned addresses.
The issue also reproduced with CMA + LPAE. CMA tries to map 16MB
with page granularity mappings during boot. alloc_init_pte()
is called and out of 16MB, only 2MB gets mapped and rest remains
unaccessible.
Because of this OMAP5 boot is broken with CMA + LPAE enabled.
Fix the issue by ensuring that the entire addresses are
mapped.
Cc: Christoffer Dall <chris@cloudcar.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Christoffer Dall <chris@cloudcar.com>
