path: root/arch/arm/mm/proc-arm940.S
2008-04-24[ARM] fix 48d7927bdf071d05cf5d15b816cf06b0937cb84fCatalin Marinas
The proc-*.S files have the _prefetch_abort pointer placed at the end of the processor structure but the cpu-multi32.h defines it in the second position. The patch also fixes the support for XSC3 and the MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Include asm/elf.h instead of asm/procinfo.hRussell King
These files want to provide/access ELF hwcap information, so should be including asm/elf.h rather than asm/procinfo.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] nommu: abort handler fixup for !CPU_CP15_MMU cores.Hyok S. Choi
There is no FSR/FAR register on no-CP15 or MPU cores. This patch adds a dummy abort handler which returns zero for the base restored Data Abort model !CPU_CP15_MMU cores. The abort-lv4t.S is still used with the fix-up for the base updated Data Abort model cores. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: add ARM940T core supportHyok S. Choi
This patch adds ARM940T core support which has 4KB D-cache, 4KB I-cache and a MPU. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
