path: root/arch/arm/mm/proc-arm940.S
2014-07-18ARM: convert all "mov.* pc, reg" to "bx reg" for ARMv6+Russell King
ARMv6 and greater introduced a new instruction ("bx") which can be used to return from function calls. Recent CPUs perform better when the "bx lr" instruction is used rather than the "mov pc, lr" instruction, and this sequence is strongly recommended to be used by the ARM architecture manual (section A.4.1.1). We provide a new macro "ret" with all its variants for the condition code which will resolve to the appropriate instruction. Rather than doing this piecemeal, and miss some instances, change all the "mov pc" instances to use the new macro, with the exception of the "movs" instruction and the kprobes code. This allows us to detect the "mov pc, lr" case and fix it up - and also gives us the possibility of deploying this for other registers depending on the CPU selection. Reported-by: Will Deacon <will.deacon@arm.com> Tested-by: Stephen Warren <swarren@nvidia.com> # Tegra Jetson TK1 Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> # mioa701_bootresume.S Tested-by: Andrew Lunn <andrew@lunn.ch> # Kirkwood Tested-by: Shawn Guo <shawn.guo@freescale.com> Tested-by: Tony Lindgren <tony@atomide.com> # OMAPs Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> # Armada XP, 375, 385 Acked-by: Sekhar Nori <nsekhar@ti.com> # DaVinci Acked-by: Christoffer Dall <christoffer.dall@linaro.org> # kvm/hyp Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> # PXA3xx Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> # Xen Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> # ARMv7M Tested-by: Simon Horman <horms+renesas@verge.net.au> # Shmobile Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-07-14arm: delete __cpuinit/__CPUINIT usage from all ARM usersPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) and are flagged as __cpuinit -- so if we remove the __cpuinit from the arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit related content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the ARM uses of the __cpuinit macros from C code, and all __CPUINIT from assembly code. It also had two ".previous" section statements that were paired off against __CPUINIT (aka .section ".cpuinit.text") that also get removed here. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Russell King <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-09-25ARM: mm: implement LoUIS API for cache maintenance opsLorenzo Pieralisi
ARM v7 architecture introduced the concept of cache levels and related control registers. New processors like A7 and A15 embed an L2 unified cache controller that becomes part of the cache level hierarchy. Some operations in the kernel like cpu_suspend and __cpu_disable do not require a flush of the entire cache hierarchy to DRAM but just the cache levels belonging to the Level of Unification Inner Shareable (LoUIS), which in most of ARM v7 systems correspond to L1. The current cache flushing API used in cpu_suspend and __cpu_disable, flush_cache_all(), ends up flushing the whole cache hierarchy since for v7 it cleans and invalidates all cache levels up to Level of Coherency (LoC) which cripples system performance when used in hot paths like hotplug and cpuidle. Therefore a new kernel cache maintenance API must be added to cope with latest ARM system requirements. This patch adds flush_cache_louis() to the ARM kernel cache maintenance API. This function cleans and invalidates all data cache levels up to the Level of Unification Inner Shareable (LoUIS) and invalidates the instruction cache for processors that support it (> v7). This patch also creates an alias of the cache LoUIS function to flush_kern_all for all processor versions prior to v7, so that the current cache flushing behaviour is unchanged for those processors. v7 cache maintenance code implements a cache LoUIS function that cleans and invalidates the D-cache up to LoUIS and invalidates the I-cache, according to the new API. Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Tested-by: Shawn Guo <shawn.guo@linaro.org>
2012-05-02ARM: 7408/1: cacheflush: return error to userspace when flushing syscall failsWill Deacon
The cacheflush syscall can fail for two reasons: (1) The arguments are invalid (nonsensical address range or no VMA) (2) The region generates a translation fault on a VIPT or PIPT cache This patch allows do_cache_op to return an error code to userspace in the case of the above. The various coherent_user_range implementations are modified to return 0 in the case of VIVT caches or -EFAULT in the case of an abort on v6/v7 cores. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-06ARM: proc-*.S: place cpu_reset functions into .idmap.text sectionWill Deacon
The CPU reset functions disable the MMU and therefore must be executed with an identity mapping in place. This patch places the CPU reset functions into the .idmap.text section, causing the idmap code to include them as part of the identity mapping. Acked-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2011-07-07ARM: mm: proc-arm940: Use the new processor struct macrosDave Martin
Signed-off-by: Dave Martin <dave.martin@linaro.org>
2011-02-22ARM: pm: add generic CPU suspend/resume supportRussell King
This adds core support for saving and restoring CPU coprocessor registers for suspend/resume support. This contains support for suspend with ARM920, ARM926, SA11x0, PXA25x, PXA27x, PXA3xx, V6 and V7 CPUs. Tested on Assabet and Tegra 2. Tested-by: Colin Cross <ccross@android.com> Tested-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-28ARM: 6466/1: implement flush_icache_all for the rest of the CPUsMika Westerberg
Commit 81d11955bf0 ("ARM: 6405/1: Handle __flush_icache_all for CONFIG_SMP_ON_UP") added a new function to struct cpu_cache_fns: flush_icache_all(). It also implemented this for v6 and v7 but not for v5 and backwards. Without the function pointer in place, we will be calling wrong cache functions. For example with ep93xx we get following: Unable to handle kernel paging request at virtual address ee070f38 pgd = c0004000 [ee070f38] *pgd=00000000 Internal error: Oops: 80000005 [#1] PREEMPT last sysfs file: Modules linked in: CPU: 0 Not tainted (2.6.36+ #1) PC is at 0xee070f38 LR is at __dma_alloc+0x11c/0x2d0 pc : [<ee070f38>] lr : [<c0032c8c>] psr: 60000013 sp : c581bde0 ip : 00000000 fp : c0472000 r10: c0472000 r9 : 000000d0 r8 : 00020000 r7 : 0001ffff r6 : 00000000 r5 : c0472400 r4 : c5980000 r3 : c03ab7e0 r2 : 00000000 r1 : c59a0000 r0 : c5980000 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: c000717f Table: c0004000 DAC: 00000017 Process swapper (pid: 1, stack limit = 0xc581a270) [<c0032c8c>] (__dma_alloc+0x11c/0x2d0) [<c0032e5c>] (dma_alloc_writecombine+0x1c/0x24) [<c0204148>] (ep93xx_pcm_preallocate_dma_buffer+0x44/0x60) [<c02041c0>] (ep93xx_pcm_new+0x5c/0x88) [<c01ff188>] (snd_soc_instantiate_cards+0x8a8/0xbc0) [<c01ff59c>] (soc_probe+0xfc/0x134) [<c01adafc>] (platform_drv_probe+0x18/0x1c) [<c01acca4>] (driver_probe_device+0xb0/0x16c) [<c01ac284>] (bus_for_each_drv+0x48/0x84) [<c01ace90>] (device_attach+0x50/0x68) [<c01ac0f8>] (bus_probe_device+0x24/0x44) [<c01aad7c>] (device_add+0x2fc/0x44c) [<c01adfa8>] (platform_device_add+0x104/0x15c) [<c0015eb8>] (simone_init+0x60/0x94) [<c0021410>] (do_one_initcall+0xd0/0x1a4) __dma_alloc() calls (inlined) __dma_alloc_buffer() which ends up calling dmac_flush_range(). Now since the entries in the arm920_cache_fns are shifted by one, we jump into address 0xee070f38 which is actually next instruction after the arm920_cache_fns structure. So implement flush_icache_all() for the rest of the supported CPUs using a generic 'invalidate I cache' instruction. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-08ARM: hotplug cpu: Keep processor information, startup code & ↵Russell King
__lookup_processor_type When hotplug CPU is enabled, we need to keep the list of supported CPUs, their setup functions, and __lookup_processor_type in place so that we can find and initialize secondary CPUs. Move these into the __CPUINIT section. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: Factor out common code from cpu_proc_fin()Russell King
All implementations of cpu_proc_fin() start by disabling interrupts and then flush caches. Rather than have every processors proc_fin() implementation do this, move it out into generic code - and move the cache flush past setup_mm_for_reboot() (so it can benefit from having caches still enabled.) This allows cpu_proc_fin() to become independent of the L1/L2 cache types, and eventually move the L2 cache flushing into the L2 support code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: dma-mapping: remove dmac_clean_range and dmac_inv_rangeRussell King
These are now unused, and so can be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-02-15ARM: dma-mapping: provide per-cpu type map/unmap functionsRussell King
2009-12-14ARM: add size argument to __cpuc_flush_dcache_pageRussell King
... and rename the function since it no longer operates on just pages. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5727/1: Pass IFSR register to do_PrefetchAbort()Kirill A. Shutemov
Instruction fault status register, IFSR, was introduced on ARMv6 to provide status information about the last insturction fault. It needed for proper prefetch abort handling. Now we have three prefetch abort model: * legacy - for CPUs before ARMv6. They doesn't provide neither IFSR nor IFAR. We simulate IFSR with section translation fault status for them to generalize code; * ARMv6 - provides IFSR, but not IFAR; * ARMv7 - provides both IFSR and IFAR. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] Don't include asm/elf.h in asm codeRussell King
asm code really wants asm/hwcap.h, so include that instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] add proc-macros.S include to proc-arm940 and proc-arm946Russell King
... otherwise these fail to build. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-17[ARM] 5034/1: fix arm{925,926,940,946} dma_flush_range() in WT modeLennert Buytenhek
The CPU's dma_flush_range() operation needs to clean+invalidate the given memory area if the cache is in writeback mode, or do just the invalidate part if the cache is in writethrough mode, but the current proc-arm{925,926,940,946} (incorrectly) do a cache clean in the latter case. This patch fixes that. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-24[ARM] fix 48d7927bdf071d05cf5d15b816cf06b0937cb84fCatalin Marinas
The proc-*.S files have the _prefetch_abort pointer placed at the end of the processor structure but the cpu-multi32.h defines it in the second position. The patch also fixes the support for XSC3 and the MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Include asm/elf.h instead of asm/procinfo.hRussell King
These files want to provide/access ELF hwcap information, so should be including asm/elf.h rather than asm/procinfo.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] nommu: abort handler fixup for !CPU_CP15_MMU cores.Hyok S. Choi
There is no FSR/FAR register on no-CP15 or MPU cores. This patch adds a dummy abort handler which returns zero for the base restored Data Abort model !CPU_CP15_MMU cores. The abort-lv4t.S is still used with the fix-up for the base updated Data Abort model cores. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: add ARM940T core supportHyok S. Choi
This patch adds ARM940T core support which has 4KB D-cache, 4KB I-cache and a MPU. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
