When compiling a GPU module without CONFIG_MULTI_CACHE enabled, the
compiler prompt warning which says symbol v7_dma_map_area and
v7_dma_flush_area not exported. And when insmod GPU module, it also
warns the above two symbols not found, which cause insmod module failed.
This patch export these dma access functions and fix these issues.
Signed-off-by: Shawn Xiao <b49994@freescale.com>
cpu_set_pte_ext is only guaranteed to be defined when CONFIG_MMU, so
don't export it to modules otherwise.
... and rename the function since it no longer operates on just
pages.
There is not enough users to warrant its existence, and it is actually
an obstacle to progress with the new DMA API which cannot cover this
case properly.
To keep backward compatibility, let's perform the necessary custom
cache maintenance locally in the only driver affected.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Now required for libsas:
Kernel: arch/arm/boot/Image is ready
Kernel: arch/arm/boot/zImage is ready
Building modules, stage 2.
MODPOST 1096 modules
ERROR: "xscale_flush_kern_dcache_page" [drivers/scsi/libsas/libsas.ko] undefined!
Without this, the pxa2xx-flash driver cannot be used as a module.
Reported-by: Chris Lawrence <chrisdl@netspace.net.au>
For similar reasons as copy_user_page(), we want to avoid the
additional kmap_atomic if it's unnecessary.
We used to override the copy_user_page() function. However, this
is not only inefficient, it also causes additional complexity for
highmem support, since we convert from a struct page to a kernel
direct mapped address and back to a struct page again.
Moreover, with highmem support, we end up pointlessly setting up
kmap entries for pages which we're going to remap. So, push the
kmapping down into the copypage implementation files where it's
required.
The __cpu_{clear|copy}_user_page functions are not defined for the
MMU-less case and therefore should not be exported.
L_PTE_ASID is not really required to be stored in every PTE, since we
can identify it via the address passed to set_pte_at(). So, create
set_pte_ext() which takes the address of the PTE to set, the Linux
PTE value, and the additional CPU PTE bits which aren't encoded in
the Linux PTE value.
Patch from George G. Davis
As reported by various folks on the ARM Linux kernel mailing list,
the video-buf.ko driver has undefined references on all ARM machines
which use it as observed during `make modules`:
Warning: "v4wb_clear_user_page" [drivers/media/video/video-buf.ko] undefined!
Similar warnings exist for all ARM machines which use this driver.
So this change adds the missing EXPORT_SYMBOLs to allow using this
driver as a module.
Signed-off-by: George G. Davis <gdavis@mvista.com>
infrastructure for it.
Let it rip!
