path: root/arch/arm/mm/vmregion.c
2011-02-23ARM: DMA: top-down allocation in DMA coherent regionRussell King
Achieve better usage of the DMA coherent region by doing top-down allocation rather than bottom up. If we ask for a 128kB allocation, this will be aligned to 128kB and satisfied from the very bottom address. If we then ask for a 600kB allocation, this will be aligned to 1MB, and we will have a 896kB hole. Performing top-down allocation resolves this by allocating the 128kB at the very top, and then the 600kB can come in below it without any unnecessary wastage. This problem was reported by Janusz Krzysztofik, who had 2 x 128kB + 1 x 640kB allocations which wouldn't fit into 1MB. Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: DMA coherent allocator: align remapped addressesRussell King
The DMA coherent remap area is used to provide an uncached mapping of memory for coherency with DMA engines. Currently, we look for any free hole which our allocation will fit in with page alignment. However, this can lead to fragmentation of the area, and allows small allocations to cross L1 entry boundaries. This is undesirable as we want to move towards allocating sections of memory. Align allocations according to the size, limiting the alignment between the page and section sizes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-24ARM: dma-mapping: split out vmregion code from dma coherent mapping codeRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org>
