Add new API dma_ops->map_pages() for performance
bug 1286500
Change-Id: Ib8bbcad53024225173be765358af03d0961f8af0
(cherry picked from commit 1e3b6ee46a5defaa8e1fcc97fc5d9b619c481c41)
Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/234137
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
This is necessary for iova_alloc_at(). On high order allocation, the
lower bit of base was ignored, and it returns incorrect IOVA address.
bug 1286500
Change-Id: I0be96b97c8036f8a5bc1c35a1c85e04593021a2b
(cherry picked from commit from 578a5333d43b2c9a78f0a234d391c2f8f5382b5d)
Reviewed-on: http://git-master/r/234136
Need the counter part of arm_iommu_attach_device().
bug 1286500
Change-Id: I7663075ba56e0cf7a0762927247bfb5b884cd750
(cherry picked from commit 96425941ba18e0aa68e22cdd476bd3e521aa8256)
Reviewed-on: http://git-master/r/234133
Bug 1198897
Change-Id: I2099a4ee8660fc8333cb9a6c54b9329a7e66d4e8
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/172090
(cherry picked from commit 55059981bc97372c34bed0901feada4ad9054f65)
Reviewed-on: http://git-master/r/224595
Reviewed-by: Abhinav Sinha <absinha@nvidia.com>
GVS: Gerrit_Virtual_Submit
(TLBI/DSB operations)""
This reverts commit c7cc6aa56f184389203f380df1e39e94e2e2d6f5.
Change-Id: Ia481c2f0d9f49e7f05eb2b3fe9a65d7cb4302326
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: http://git-master/r/222643
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
ASID-capable CPUs"""
This reverts commit 450e0659ea22b0122c8f48acd2f058a46486b826.
Change-Id: I88a1148a0293d7c95b2af18ae4f42e97e7572f02
Reviewed-on: http://git-master/r/222642
Change-Id: I43f2a3e267307e532eeb109714f53386213193b4
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/216913
(cherry picked from commit 87a811d83af81872fa0e98a5184cb4729a4abd78)
Reviewed-on: http://git-master/r/218138
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
CPUs""
This reverts commit 5d04ad58c35de6289072aad40cdc90abf8534faf.
Change-Id: I73c136e3b0c5e7eb329fe2264b95a003f77cae52
Reviewed-on: http://git-master/r/217077
Reviewed-by: Gary Zhang <garyz@nvidia.com>
Tested-by: Joshua Widen <jwiden@nvidia.com>
operations)"
This reverts commit e11ccb30b44fc55ba0576f5082e5e17e9a1d1854.
Change-Id: Ic96a1b8629778470de0fea1df9bac950ab98bf1f
Reviewed-on: http://git-master/r/217076
This patch adds DMA_ATTR_SKIP_CPU_SYNC attribute to the DMA-mapping
subsystem.
This is the counter part of map_page_at() which just maps the
pre-allocate iova to a page. With this attribute, unmap_page() unmap
the link between iova and a page, leaving iova allocated.
bug 1235233
bug 1263718
Change-Id: Id5535b73e0ca212a045dd0b0ff57de8432e7cf13
Reviewed-on: http://git-master/r/204468
(cherry picked from commit 77374aee027c51c4e887eaaa3e6b8540f9f6ea87)
Reviewed-on: http://git-master/r/215465
Tested-by: Sandeep Shinde <sashinde@nvidia.com>
On Cortex-A15 (r0p0..r3p2) the TLBI/DSB are not adequately shooting down
all use of the old entries. This patch implements the erratum workaround
which consists of:
1. Dummy TLBIMVAIS and DSB on the CPU doing the TLBI operation.
2. Send IPI to the CPUs that are running the same mm (and ASID) as the
one being invalidated (or all the online CPUs for global pages).
3. CPU receiving the IPI executes a DMB and CLREX (part of the exception
return code already).
The switch_mm() code includes a DMB operation since the IPI is only sent
to CPUs running the same ASID.
Change-Id: Ideb7f479910f7d4bf25182c84eb5e71691c42a93
Reviewed-on: http://git-master/r/209830
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
This reverts commit 7fec1b57b8a925d83c194f995f83d9f8442fd48e.
Change-Id: I3e2a4ed4e3dcb52368ec42e10819316078323ea4
Reviewed-on: http://git-master/r/209829
This reverts commit e323969ccda2d69f02e047c08b03faa09215c72a.
Change-Id: I0f44f33b4848ec8e326bd356545903ca14d0da9a
Reviewed-on: http://git-master/r/209827
This reverts commit 45b95235b0ac86cef2ad4480b0618b8778847479.
Will Deacon reports that:
In 52af9c6c ("ARM: 6943/1: mm: use TTBR1 instead of reserved context ID")
I updated the ASID rollover code to use only the kernel page tables
whilst updating the ASID.
Unfortunately, the code to restore the user page tables was part of a
later patch which isn't yet in mainline, so this leaves the code
quite broken.
We're also in the process of eliminating __ARCH_WANT_INTERRUPTS_ON_CTXSW
from ARM, so lets revert these until we can properly sort out what we're
doing with the context switching.
(cherry picked from commit a0a54d37b4b1d1f55d1e81e8ffc223bb85472fa3)
Change-Id: Id3bd7c795bb84269b646e6a1344d1974d85bf094
Reviewed-on: http://git-master/r/209825
extended period may not work correctly
This workaround is for ARM errata 799270 which is applicable to
Cortex-A15 up to revision R2P4. The workaround is to read from
a device register and create a data dependency between this read
and the modification of ACTLR.
Change-Id: I26813f17a8a9c6a90446ddeb943ef318e3c69770
Reviewed-on: http://git-master/r/212770
Reviewed-by: Bobby Meeker <bmeeker@nvidia.com>
Bug 1243631
Change-Id: I915826047b2e20f0ad0a7d75df295c6cbf6e5b0a
This is not required since cache is invalidated by HW in the reset
sequence. Bootloader is supposed to do the same before it hands
over control to kernel.
Change-Id: I0991de3ba1015a32f2c49a0333fd0b17a51a4f31
Reviewed-on: http://git-master/r/197028
Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Tested-by: Antti Miettinen <amiettinen@nvidia.com>
Cortex-A15 flush L2 cache after reset, there is no need to do this
in software, if L2 is already invalidated in bootloader and
cache is disabled. For secondary startup, there is no reason to
flush L2 as well.
This change assumes the setup code is always entered as the result
of CPU reset.
Change-Id: I6d58f8b4a638b70acfb35b97c87a09266aceef41
Reviewed-on: http://git-master/r/170563
(cherry picked from commit 26e7a8ea22abe09852fa1ce36b6cec8dc8fc5978)
Reviewed-on: http://git-master/r/196044
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream.
Subhash Jadavani reported this partial backtrace:
Now consider this call stack from MMC block driver (this is on the ARMv7
based board):
[<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c)
[<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c)
[<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114)
This is caused by incrementing the struct page pointer, and running off
the end of the sparsemem page array. Fix this by incrementing by pfn
instead, and convert the pfn to a struct page.
Suggested-by: James Bottomley <JBottomley@Parallels.com>
Tested-by: Subhash Jadavani <subhashj@codeaurora.org>
Disable A15's L2 prefetch throttle mechanism to improve performance.
bug 1212902
Change-Id: I03a27518b26da3cbf1e7aad96ff2d67187a1ebf6
Reviewed-on: http://git-master/r/188788
(cherry picked from commit 246ebe8a6a2761a453341478599d66549fc9b734)
Change-Id: If9fbd7043600c092c3aa23020e5500276fca6ab6
Reviewed-on: http://git-master/r/191049
commit 864aa04cd02979c2c755cb28b5f4fe56039171c0 upstream.
When updating the page protection map after calculating the user_pgprot
value, the base protection map is temporarily stored in an unsigned long
type, causing truncation of the protection bits when LPAE is enabled.
This effectively means that calls to mprotect() will corrupt the upper
page attributes, clearing the XN bit unconditionally.
This patch uses pteval_t to store the intermediate protection values,
preserving the upper bits for 64-bit descriptors.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Do an external device read to start L2 clock, then change
SMP bit in ACTLR. The ACTLR change needs to be done immediately
after the device read is done since there are only 256 clock cycles
maximum available before the L2 clock can be gated again.
bug 1208654
bug 1195192
Change-Id: Ide1c0476d629cbea07f585013ed3b7e79a67c86e
Reviewed-on: http://git-master/r/189712
Tested-by: Sang-Hun Lee <sanlee@nvidia.com>
Change-Id: I2433e53175e79d558d76a7c37b10de9175d7b1b0
Reviewed-on: http://git-master/r/167385
Reviewed-by: Simone Willett <swillett@nvidia.com>
Change-Id: If966ee69f1d5e4314f79685238ecff3c44eadac0
Reviewed-on: http://git-master/r/167879
Change-Id: I4b9faea7252399c598619460dee27990ad6474ca
Reviewed-on: http://git-master/r/163722
Reviewed-by: Alex Waterman <alexw@nvidia.com>
This is cortex-a15 specific
bug 1178938
Change-Id: Id695d89dbe1411d277f2c1296c74586ca9c1584e
Reviewed-on: http://git-master/r/164168
The work around for ARM erratum 752520 was applied for all revisions
upto r2p8. But this erratum is present only on r2p0 to r2p8 versions
while T20 has r1p1 revision. Making this change to enable the WAR
only for revisions from r2p0 to r2p8.
Bug 853428
Bug 1045637
Reviewed-on: http://git-master/r/43962
(cherry picked from commit 57a0028d94c7ad71acab0c9ee29f5472e46c55bf)
Reviewed-on: http://git-master/r/44540
(cherry picked from commit d7f06b0a1b247f2a1444b3b78bc7dc8b21a5b7dd)
Reviewed-on: http://git-master/r/161949
(cherry picked from commit f84777eadee307e605f3accdfbf7114917e5a51c)
Change-Id: Id3ab36cb757d45ab9bddfa5b08c0643a00765bb2
Signed-off-by: Vishal Annapurve <vannapurve@nvidia.com>
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/165948
Reviewed-by: Sumeet Gupta <sumeetg@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Specifically, this change saves and restores registers controlling
user space access of ARM performance monitoring unit registers and
for PMU interrupt enables.
Change-Id: Iac88df17112e2ef2ccf53674c3fa3a74d2d4221f
Reviewed-on: http://git-master/r/162149
Introduce configurable cache_maint_{inner,outer}_threshold via debugfs.
Bug 1158336
Change-Id: I7bb94adadbc41ff65dbd9992920c938df2449b06
Reviewed-on: http://git-master/r/161209
This hack was introduced in Main to enable booting of
dalmore/pluto.
Revert this hack because it is no longer needed.
Bug 1166538
This reverts commit 1fba4c801566639db74d117f1233bb790d1748aa.
Change-Id: I950f056d254e32f8e49967c015bf3ecea44c19db
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/159867
This patch renames jump labels in v7_flush_dcache_all in order to define
a specific flush cache levels entry point.
Change-Id: If84ff442617cec67419dbc75fe1c6daa153ce537
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Reviewed-on: http://git-master/r/147782
Reviewed-by: Bo Yan <byan@nvidia.com>
Tested-by: Bo Yan <byan@nvidia.com>
ARM v7 architecture introduced the concept of cache levels and related
control registers. New processors like A7 and A15 embed an L2 unified cache
controller that becomes part of the cache level hierarchy. Some operations in
the kernel like cpu_suspend and __cpu_disable do not require a flush of the
entire cache hierarchy to DRAM but just the cache levels belonging to the
Level of Unification Inner Shareable (LoUIS), which in most of ARM v7 systems
correspond to L1.
The current cache flushing API used in cpu_suspend and __cpu_disable,
flush_cache_all(), ends up flushing the whole cache hierarchy since for
v7 it cleans and invalidates all cache levels up to Level of Coherency
(LoC) which cripples system performance when used in hot paths like hotplug
and cpuidle.
Therefore a new kernel cache maintenance API must be added to cope with
latest ARM system requirements.
This patch adds flush_cache_louis() to the ARM kernel cache maintenance API.
This function cleans and invalidates all data cache levels up to the
Level of Unification Inner Shareable (LoUIS) and invalidates the instruction
cache for processors that support it (> v7).
This patch also creates an alias of the cache LoUIS function to flush_kern_all
for all processor versions prior to v7, so that the current cache flushing
behaviour is unchanged for those processors.
v7 cache maintenance code implements a cache LoUIS function that cleans and
invalidates the D-cache up to LoUIS and invalidates the I-cache, according
to the new API.
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Change-Id: Id758abd2f67ee46da91e8372cd3a09d6ae3a2608
Reviewed-on: http://git-master/r/147781
commit 7253b85cc62d6ff84143d96fe6cd54f73736f4d7 upstream.
arm: Add ARM ERRATA 775420 workaround
Workaround for the 775420 Cortex-A9 (r2p2, r2p6,r2p8,r2p10,r3p0) erratum.
In case a date cache maintenance operation aborts with MMU exception, it
might cause the processor to deadlock. This workaround puts DSB before
executing ISB if an abort may occur on cache maintenance.
Based on work by Kouei Abe and feedback from Catalin Marinas.
Signed-off-by: Kouei Abe <kouei.abe.cp@rms.renesas.com>
[ horms@verge.net.au: Changed to implementation
suggested by catalin.marinas@arm.com ]
Signed-off-by: Simon Horman <horms@verge.net.au>
Reviewed-on: http://git-master/r/133635
(cherry picked from commit 644a8fcb8be8f6a6a2f882d854974fce40e2c744)
Change-Id: I00d12c1a40a56d300396538080eefc68c6ccca9e
Reviewed-on: http://git-master/r/143108
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Reviewed-on: http://git-master/r/133170
(cherry picked from commit 44f72b181421900ae61eb165477ba104a359f9e8)
Change-Id: I366109e0991cf10cc4ff9fc8bc4140c67cfda5bb
Reviewed-on: http://git-master/r/143061
Implement interface for getting size of outer cache.
bug 983964
Change-Id: If855f32d3eaa4c673c132b1964a46fe1c15b4dfe
Signed-off-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-on: http://git-master/r/140024
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
commit a849088aa1552b1a28eea3daff599ee22a734ae3 upstream.
Murali Nalajala reports a regression that ioremapping address zero
results in an oops dump:
Unable to handle kernel paging request at virtual address fa200000
pgd = d4f80000
[fa200000] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 Tainted: G W (3.4.0-g3b5f728-00009-g638207a #13)
PC is at msm_pm_config_rst_vector_before_pc+0x8/0x30
LR is at msm_pm_boot_config_before_pc+0x18/0x20
pc : [<c0078f84>] lr : [<c007903c>] psr: a0000093
sp : c0837ef0 ip : cfe00000 fp : 0000000d
r10: da7efc17 r9 : 225c4278 r8 : 00000006
r7 : 0003c000 r6 : c085c824 r5 : 00000001 r4 : fa101000
r3 : fa200000 r2 : c095080c r1 : 002250fc r0 : 00000000
Flags: NzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 25180059 DAC: 00000015
[<c0078f84>] (msm_pm_config_rst_vector_before_pc+0x8/0x30) from [<c007903c>] (msm_pm_boot_config_before_pc+0x18/0x20)
[<c007903c>] (msm_pm_boot_config_before_pc+0x18/0x20) from [<c007a55c>] (msm_pm_power_collapse+0x410/0xb04)
[<c007a55c>] (msm_pm_power_collapse+0x410/0xb04) from [<c007b17c>] (arch_idle+0x294/0x3e0)
[<c007b17c>] (arch_idle+0x294/0x3e0) from [<c000eed8>] (default_idle+0x18/0x2c)
[<c000eed8>] (default_idle+0x18/0x2c) from [<c000f254>] (cpu_idle+0x90/0xe4)
[<c000f254>] (cpu_idle+0x90/0xe4) from [<c057231c>] (rest_init+0x88/0xa0)
[<c057231c>] (rest_init+0x88/0xa0) from [<c07ff890>] (start_kernel+0x3a8/0x40c)
Code: c0704256 e12fff1e e59f2020 e5923000 (e5930000)
This is caused by the 'reserved' entries which we insert (see
19b52abe3c5d7 - ARM: 7438/1: fill possible PMD empty section gaps)
which get matched for physical address zero.
Resolve this by marking these reserved entries with a different flag.
Tested-by: Murali Nalajala <mnalajal@codeaurora.org>
commit 730a8128cd8978467eb1cf546b11014acb57d433 upstream.
Commit 5a783cbc4836 ("ARM: 7478/1: errata: extend workaround for erratum
#720789") added workarounds for erratum #720789 to the range TLB
invalidation functions with the observation that the erratum only
affects SMP platforms. However, when running an SMP_ON_UP kernel on a
uniprocessor platform we must take care to preserve the ASID as the
workaround is not required.
This patch ensures that we don't set the ASID to 0 when flushing the TLB
on such a system, preserving the original behaviour with the workaround
disabled.
commit 47f1204329237a0f8655f5a9f14a38ac81946ca1 upstream.
Swap entries are encoding in ptes such that !pte_present(pte) and
pte_file(pte). The remaining bits of the descriptor are used to identify
the swapfile and offset within it to the swap entry.
When writing such a pte for a user virtual address, set_pte_at
unconditionally sets the nG bit, which (in the case of LPAE) will
corrupt the swapfile offset and lead to a BUG:
[ 140.494067] swap_free: Unused swap offset entry 000763b4
[ 140.509989] BUG: Bad page map in process rs:main Q:Reg pte:0ec76800 pmd:8f92e003
This patch fixes the problem by only setting the nG bit for user
mappings that are actually present.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Avoid to overwrite a map, and warn it.
Change-Id: Ieef971bf8dc7e9719445b7b253daa55f4c109ae2
To allocate IOVA area at specified address
There are some cases that IOVA allocation and mapping have to be done
seperately, especially for perf optimization reasons. This patch
allows client modules to {alloc,free} IOVA space without backing up
actual pages for that area.
->iova>_get_free_total() returns the sum of available free areas.
->iova>_get_free_max() returns the largest available free area size.
Change-Id: I817ff46bea799a809e2e6b163b2e86cb737cf077
Skip cache maint for invalid page but warn it.
Change-Id: I780587d132fd9440767046877c0724939897889f
With many IOMMU'able devices, console gets noisy.
Tegra30 has a few dozen of IOMMU'able devices.
Change-Id: I031fd6b5e88d04d3d2ab117677ca9ab2535ba475
Skip unnecessary operations if order == 0. A little bit easier to
read.
Make use of the same atomic pool as DMA does, and skip a kernel page
mapping which can involve sleep'able operations at allocating a kernel
page table.
Change-Id: I72e62f521d2d357621aa5a7fd6f513ec941a49e2
Support atomic allocation in __iommu_get_pages().
Change-Id: I16f94a0ad9a54ffc53bac4e53c090336c4b5560d
