Keep the machine vectors in its own domain to avoid software based
user access control from making the vector code inaccessible, and
thereby deadlocking the machine.
The chain of of_address_to_resource() and ioremap() can be replaced
with of_iomap().
Acked-by: Olof Johansson <olof@lixom.net>
Add early fixmap support, initially to support permanent, fixed
mapping support for early console. A temporary, early pte is
created which is migrated to a permanent mapping in paging_init.
This is also needed since the attributes may change as the memory
types are initialized. The 3MiB range of fixmap spans two pte
tables, but currently only one pte is created for early fixmap
support.
Re-add FIX_KMAP_BEGIN to the index calculation in highmem.c since
the index for kmap does not start at zero anymore. This reverts
4221e2e6b316 ("ARM: 8031/1: fixmap: remove FIX_KMAP_BEGIN and
FIX_KMAP_END") to some extent.
Cc: Mark Salter <msalter@redhat.com>
Cc: Laura Abbott <lauraa@codeaurora.org>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Rob Herring <robh@kernel.org>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Coccinelle cleanup to replace open coded sg to physical address
translations. This is in preparation for introducing scatterlists that
reference __pfn_t.
// sg_phys.cocci: convert usage page_to_phys(sg_page(sg)) to sg_phys(sg)
// usage: make coccicheck COCCI=sg_phys.cocci MODE=patch
virtual patch
struct scatterlist *sg;
- page_to_phys(sg_page(sg)) + sg->offset
+ sg_phys(sg)
+ sg_phys(sg) & PAGE_MASK
Signed-off-by: Jens Axboe <axboe@fb.com>
This patch allows the use of CMA for DMA coherent memory allocation.
At the moment if the input parameter "is_coherent" is set to true
the allocation is not made using the CMA, which I think is not the
desired behaviour.
The patch covers the allocation and free of memory for coherent
DMA.
Signed-off-by: Lorenzo Nava <lorenx4@gmail.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
The dmac_* functions are private to the ARM DMA API implementation, and
should not be used by drivers. In order to discourage their use, remove
their prototypes and macros from asm/*.h.
We have to leave dmac_flush_range() behind as Exynos and MSM IOMMU code
use these; once these sites are fixed, this can be moved also.
Add an extension to the heavy barrier code to allow a SoC specific
memory barrier function to be provided. This is needed for platforms
where the interconnect has weak ordering, and thus needs assistance
to ensure that memory writes are properly visible in the correct order
to other parts of the system.
Acked-by: Richard Woodruff <r-woodruff2@ti.com>
The existing memory barrier macro causes a significant amount of code
to be inserted inline at every call site. For example, in
gpio_set_irq_type(), we have this for mb():
c0344c08: f57ff04e dsb st
c0344c0c: e59f8190 ldr r8, [pc, #400] ; c0344da4 <gpio_set_irq_type+0x230>
c0344c10: e3590004 cmp r9, #4
c0344c14: e5983014 ldr r3, [r8, #20]
c0344c18: 0a000054 beq c0344d70 <gpio_set_irq_type+0x1fc>
c0344c1c: e3530000 cmp r3, #0
c0344c20: 0a000004 beq c0344c38 <gpio_set_irq_type+0xc4>
c0344c24: e50b2030 str r2, [fp, #-48] ; 0xffffffd0
c0344c28: e50bc034 str ip, [fp, #-52] ; 0xffffffcc
c0344c2c: e12fff33 blx r3
c0344c30: e51bc034 ldr ip, [fp, #-52] ; 0xffffffcc
c0344c34: e51b2030 ldr r2, [fp, #-48] ; 0xffffffd0
c0344c38: e5963004 ldr r3, [r6, #4]
Moving the outer_cache_sync() call out of line reduces the impact of
the barrier:
c0344968: f57ff04e dsb st
c034496c: e35a0004 cmp sl, #4
c0344970: e50b2030 str r2, [fp, #-48] ; 0xffffffd0
c0344974: 0a000044 beq c0344a8c <gpio_set_irq_type+0x1b8>
c0344978: ebf363dd bl c001d8f4 <arm_heavy_mb>
c034497c: e5953004 ldr r3, [r5, #4]
This should reduce the cache footprint of this code. Overall, this
results in a reduction of around 20K in the kernel size:
10773970 667392 10369656 21811018 14ccf4a ../build/imx6/vmlinux-old
10754219 667392 10369656 21791267 14c8223 ../build/imx6/vmlinux-new
Another advantage to this approach is that we can finally resolve the
issue of SoCs which have their own memory barrier requirements within
multiplatform kernels (such as OMAP.) Here, the bus interconnects
need additional handling to ensure that writes become visible in the
correct order (eg, between dma_map() operations, writes to DMA
coherent memory, and MMIO accesses.)
We must invalidate the L1 cache before enabling coherency, otherwise
secondary CPUs can inject invalid cache lines into the coherent CPU
cluster, which could then be migrated to other CPUs. This fixes a
recent regression with SoCFPGA randomly failing to boot.
Fixes: 02b4e2756e01 ("ARM: v7 setup function should invalidate L1 cache")
nr_bitmaps member of mapping structure stores the number of already
allocated bitmaps and it is interpreted as loop iterator (it starts from
0 not from 1), so a comparison against number of possible bitmap
extensions should include this fact. This patch fixes this by changing
the extension failure condition. This issue has been introduced by
commit 4d852ef8c2544ce21ae41414099a7504c61164a0 ("arm: dma-mapping: Add
support to extend DMA IOMMU mappings").
Reported-by: Hyungwon Hwang <human.hwang@samsung.com>
Reviewed-by: Hyungwon Hwang <human.hwang@samsung.com>
Cc: stable@vger.kernel.org # v3.15+
"CoreLink Level 2 Cache Controller L2C-310", p. 2-15, section 2.3.2
Shareable attribute" states:
"The default behavior of the cache controller with respect to the
shareable attribute is to transform Normal Memory Non-cacheable
transactions into:
- cacheable no allocate for reads
- write through no write allocate for writes."
Depending on the system architecture, this may cause memory corruption
in the presence of bus mastering devices (e.g. OHCI). To avoid such
corruption, the default behavior can be disabled by setting the Shared
Override bit in the Auxiliary Control register.
Currently the Shared Override bit can be set only using C code:
- by calling l2x0_init() directly, which is deprecated,
- by setting/clearing the bit in the machine_desc.l2c_aux_val/mask
fields, but using values differing from 0/~0 is also deprecated.
Hence add support for an "arm,shared-override" device tree property for
the l2c device node. By specifying this property, affected systems can
indicate that non-cacheable transactions must not be transformed.
Then, it's up to the OS to decide. The current behavior is to set the
"shared attribute override enable" bit, as there may exist kernel linear
mappings and cacheable aliases for the DMA buffers, even if CMA is
enabled.
See also commit 1a8e41cd672f894b ("ARM: 6395/1: VExpress: Set bit 22 in
the PL310 (cache controller) AuxCtlr register"):
"Clearing bit 22 in the PL310 Auxiliary Control register (shared
attribute override enable) has the side effect of transforming
Normal Shared Non-cacheable reads into Cacheable no-allocate reads.
Coherent DMA buffers in Linux always have a Cacheable alias via the
kernel linear mapping and the processor can speculatively load
cache lines into the PL310 controller. With bit 22 cleared,
Non-cacheable reads would unexpectedly hit such cache lines leading
to buffer corruption."
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Convert the ioremap*() preprocessor macros to real functions, moving
them out of line. This allows us to kill off __arm_ioremap(), and
__arm_iounmap() helpers, and remove __arm_ioremap_pfn_caller() from
global view.
Add a nmessage to suggest that HIGHMEM is enabled when physical memory
is truncated due to lack of virtual address space to map it in the low
memory mapping.
The memblock limit is currently used in find_limits
to find the bounds for ZONE_NORMAL. The memblock
limit may need to be rounded down a PMD size to ensure
allocations are fully mapped though. This has the side
effect of reducing the amount of memory in ZONE_NORMAL.
Once all lowmem is mapped, it's safe to change the memblock
limit back to include the unaligned section. Adjust the
memblock limit after lowmem mapping is complete.
Before:
# cat /proc/zoneinfo | grep managed
managed 62907
managed 424
After:
managed 63331
Signed-off-by: Laura Abbott <labbott@fedoraproject.org>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
Pull ARM updates from Russell King:
"Bigger items included in this update are:
- A series of updates from Arnd for ARM randconfig build failures
- Updates from Dmitry for StrongARM SA-1100 to move IRQ handling to
drivers/irqchip/
- Move ARMs SP804 timer to drivers/clocksource/
- Perf updates from Mark Rutland in preparation to move the ARM perf
code into drivers/ so it can be shared with ARM64.
- MCPM updates from Nicolas
- Add support for taking platform serial number from DT
- Re-implement Keystone2 physical address space switch to conform to
architecture requirements
- Clean up ARMv7 LPAE code, which goes in hand with the Keystone2
changes.
- L2C cleanups to avoid unlocking caches if we're prevented by the
secure support to unlock.
- Avoid cleaning a potentially dirty cache containing stale data on
CPU initialisation
- Add ARM-only entry point for secondary startup (for machines that
can only call into a Thumb kernel in ARM mode). Same thing is also
done for the resume entry point.
- Provide arch_irqs_disabled via asm-generic
- Enlarge ARMv7M vector table
- Always use BFD linker for VDSO, as gold doesn't accept some of the
options we need.
- Fix an incorrect BSYM (for Thumb symbols) usage, and convert all
BSYM compiler macros to a "badr" (for branch address).
- Shut up compiler warnings provoked by our cmpxchg() implementation.
- Ensure bad xchg sizes fail to link"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (75 commits)
ARM: Fix build if CLKDEV_LOOKUP is not configured
ARM: fix new BSYM() usage introduced via for-arm-soc branch
ARM: 8383/1: nommu: avoid deprecated source register on mov
ARM: 8391/1: l2c: add options to overwrite prefetching behavior
ARM: 8390/1: irqflags: Get arch_irqs_disabled from asm-generic
ARM: 8387/1: arm/mm/dma-mapping.c: Add arm_coherent_dma_mmap
ARM: 8388/1: tcm: Don't crash when TCM banks are protected by TrustZone
ARM: 8384/1: VDSO: force use of BFD linker
ARM: 8385/1: VDSO: group link options
ARM: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
ARM: remove __bad_xchg definition
ARM: 8369/1: ARMv7M: define size of vector table for Vybrid
ARM: 8382/1: clocksource: make ARM_TIMER_SP804 depend on GENERIC_SCHED_CLOCK
ARM: 8366/1: move Dual-Timer SP804 driver to drivers/clocksource
ARM: 8365/1: introduce sp804_timer_disable and remove arm_timer.h inclusion
ARM: 8364/1: fix BE32 module loading
ARM: 8360/1: add secondary_startup_arm prototype in header file
ARM: 8359/1: correct secondary_startup_arm mode
ARM: proc-v7: sanitise and document registers around errata
ARM: proc-v7: clean up MIDR access
Pull ARM SoC cleanups from Kevin Hilman:
"A relatively small setup of cleanups this time around, and similar to
last time the bulk of it is removal of legacy board support:
- OMAP: removal of legacy (non-DT) booting for several platforms
- i.MX: remove some legacy board files"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (36 commits)
ARM: fix EFM32 build breakage caused by cpu_resume_arm
ARM: 8389/1: Add cpu_resume_arm() for firmwares that resume in ARM state
mach-omap2: Remove use of deprecated marco, PTR_RET in devices.c
ARM: OMAP2+: Remove calls to deprecacted marco,PTR_RET in the files,fb.c and pmu.c
ARM: OMAP2+: Constify irq_domain_ops
ARM: OMAP2+: use symbolic defines for console loglevels instead of numbers
ARM: at91: remove useless Makefile.boot
ARM: at91: remove at91rm9200_sdramc.h
ARM: at91: remove mach/at91_ramc.h and mach/at91rm9200_mc.h
ARM: at91/pm: use the atmel-mc syscon defines
pcmcia: at91_cf: Use syscon to configure the MC/smc
ARM: at91: declare the at91rm9200 memory controller as a syscon
mfd: syscon: Add Atmel MC (Memory Controller) registers definition
ARM: at91: drop sam9_smc.c
ata: at91: use syscon to configure the smc
ARM: ux500: delete static resource defines
ARM: ux500: rename ux500_map_io
ARM: ux500: look up PRCMU resource from DT
ARM: ux500: kill off L2CC static map
Currently we have many duplicates in definitions of huge_pmd_unshare. In
all architectures this function just returns 0 when
CONFIG_ARCH_WANT_HUGE_PMD_SHARE is N.
This patch puts the default implementation in mm/hugetlb.c and lets these
architectures use the common code.
Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: James Yang <James.Yang@freescale.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
"Mostly refactoring/clean-up:
- CPU ops and PSCI (Power State Coordination Interface) refactoring
following the merging of the arm64 ACPI support, together with
handling of Trusted (secure) OS instances
- Using fixmap for permanent FDT mapping, removing the initial dtb
placement requirements (within 512MB from the start of the kernel
image). This required moving the FDT self reservation out of the
memreserve processing
- Idmap (1:1 mapping used for MMU on/off) handling clean-up
- Removing flush_cache_all() - not safe on ARM unless the MMU is off.
Last stages of CPU power down/up are handled by firmware already
- "Alternatives" (run-time code patching) refactoring and support for
immediate branch patching, GICv3 CPU interface access
- User faults handling clean-up
And some fixes:
- Fix for VDSO building with broken ELF toolchains
- Fix another case of init_mm.pgd usage for user mappings (during
ASID roll-over broadcasting)
- Fix for FPSIMD reloading after CPU hotplug
- Fix for missing syscall trace exit
- Workaround for .inst asm bug
- Compat fix for switching the user tls tpidr_el0 register"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (42 commits)
arm64: use private ratelimit state along with show_unhandled_signals
arm64: show unhandled SP/PC alignment faults
arm64: vdso: work-around broken ELF toolchains in Makefile
arm64: kernel: rename __cpu_suspend to keep it aligned with arm
arm64: compat: print compat_sp instead of sp
arm64: mm: Fix freeing of the wrong memmap entries with !SPARSEMEM_VMEMMAP
arm64: entry: fix context tracking for el0_sp_pc
arm64: defconfig: enable memtest
arm64: mm: remove reference to tlb.S from comment block
arm64: Do not attempt to use init_mm in reset_context()
arm64: KVM: Switch vgic save/restore to alternative_insn
arm64: alternative: Introduce feature for GICv3 CPU interface
arm64: psci: fix !CONFIG_HOTPLUG_CPU build warning
arm64: fix bug for reloading FPSIMD state after CPU hotplug.
arm64: kernel thread don't need to save fpsimd context.
arm64: fix missing syscall trace exit
arm64: alternative: Work around .inst assembler bugs
arm64: alternative: Merge alternative-asm.h into alternative.h
arm64: alternative: Allow immediate branch as alternative instruction
arm64: Rework alternate sequence for ARM erratum 845719
http://ftp.arm.linux.org.uk/pub/armlinux/kernel/git-cur/linux-2.6-arm into next/cleanup
* 'for-arm-soc' of http://ftp.arm.linux.org.uk/pub/armlinux/kernel/git-cur/linux-2.6-arm:
arch/arm/kernel/head.S
These options make it possible to overwrites the data and instruction
prefetching behavior of the arm pl310 cache controller.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
When dma-coherent transfers are enabled, the mmap call must
not change the pg_prot flags in the vma struct.
Split the arm_dma_mmap into a common and specific parts,
and add a "arm_coherent_dma_mmap" implementation that does
not alter the page protection flags.
Tested on a topic-miami board (Zynq) using the ACP port
to transfer data between FPGA and CPU using the Dyplo
framework. Without this patch, byte-wise access to mmapped
coherent DMA memory was about 20x slower because of the
memory being marked as non-cacheable, and transfer speeds
would not exceed 240MB/s.
After this patch, the mapped memory is cacheable and the
transfer speed is again 600MB/s (limited by the FPGA) when
the data is in the L2 cache, while data integrity is being
maintained.
The patch has no effect on non-coherent DMA.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
This splits off the reservation of the memory occupied by the FDT
binary itself from the processing of the memory reservations it
contains. This is necessary because the physical address of the FDT,
which is needed to perform the reservation, may not be known to the
FDT driver core, i.e., it may be mapped outside the linear direct
mapping, in which case __pa() returns a bogus value.
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Vybrids has 112 peripheral interrupts which can be routed to the
Cortex-M4's NVIC interrupt controller.
arch/sparc/include/asm/topology_64.h
Document that r13 is not a stack in the initialisation function, in
case anyone gets other ideas.
Document the registers available for the errata workarounds, and
specifically which registers contain parts of the MIDR register, as
well as which registers must be preserved.
Lastly, use the lowest numbered available register (r0) rather than
r10 for temporary storage.
We already have the main ID register available in r9, there's no need
to refetch it. Use the saved value.
Rather than having a long sprawling __v7_setup function, which is hard
to maintain properly, move the CPU errata out of line.
While doing this, it was discovered that the Cortex-A15 errata had been
incorrectly added:
ldr r10, =0x00000c08 @ Cortex-A8 primary part number
teq r0, r10
bne 2f
/* Cortex-A8 errata */
b 3f
2: ldr r10, =0x00000c09 @ Cortex-A9 primary part number
teq r0, r10
bne 3f
/* Cortex-A9 errata */
3: ldr r10, =0x00000c0f @ Cortex-A15 primary part number
teq r0, r10
bne 4f
/* Cortex-A15 errata */
4:
This results in the Cortex-A15 test always being executed after the
Cortex-A8 and Cortex-A9 errata, which is obviously not what is intended.
The 'b 3f' labels should have been updated to 'b 4f'. The new structure
of:
/* Cortex-A8 Errata */
teq r0, r10
beq __ca8_errata
/* Cortex-A9 Errata */
teq r0, r10
beq __ca9_errata
/* Cortex-A15 Errata */
teq r0, r10
beq __ca15_errata
__errata_finish:
is much cleaner and easier to see that this kind of thing doesn't
happen.
Re-engineer the LPAE TTBR setup code. Rather than passing some shifted
address in order to fit in a CPU register, pass either a full physical
address (in the case of r4, r5 for TTBR0) or a PFN (for TTBR1).
This removes the ARCH_PGD_SHIFT hack, and the last dangerous user of
cpu_set_ttbr() in the secondary CPU startup code path (which was there
to re-set TTBR1 to the appropriate high physical address space on
Keystone2.)
Tested-by: Murali Karicheri <m-karicheri2@ti.com>
Eliminate the needless nommu version of this function, and get rid of
the proc_info_list structure argument - we no longer need this in order
to fix up the page table entries.
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Re-implement the physical address space switching to be architecturally
compliant. This involves flushing the caches, disabling the MMU, and
only then updating the page tables. Once that is complete, the system
can be brought back up again.
Since we disable the MMU, we need to do the update in assembly code.
Luckily, the entries which need updating are fairly trivial, and are
all setup by the early assembly code. We can merely adjust each entry
by the delta required.
Not only does this fix the code to be architecturally compliant, but it
fixes a couple of bugs too:
1. The original code would only ever update the first L2 entry covering
a fraction of the kernel; the remainder were left untouched.
2. The L2 entries covering the DTB blob were likewise untouched.
This solution fixes up all entries.
The init_meminfo() method is not about initialising meminfo - it's about
fixing up the physical to virtual translation so that we use a different
physical address space, possibly above the 4GB physical address space.
Therefore, the name "init_meminfo()" is confusing.
Rename it to pv_fixup() instead.
There is no point platform code doing this, let's move it into the
generic code so it doesn't get duplicated.
Make the init_meminfo function return the offset to be applied to the
phys-to-virt translation constants. This allows us to move the update
into generic code, along with the requirements for this update.
This avoids platforms having to know the details of the phys-to-virt
translation support.
All ARMv5 and older CPUs invalidate their caches in the early assembly
setup function, prior to enabling the MMU. This is because the L1
cache should not contain any data relevant to the execution of the
kernel at this point; all data should have been flushed out to memory.
This requirement should also be true for ARMv6 and ARMv7 CPUs - indeed,
these typically do not search their caches when caching is disabled (as
it needs to be when the MMU is disabled) so this change should be safe.
ARMv7 allows there to be CPUs which search their caches while caching is
disabled, and it's permitted that the cache is uninitialised at boot;
for these, the architecture reference manual requires that an
implementation specific code sequence is used immediately after reset
to ensure that the cache is placed into a sane state. Such
functionality is definitely outside the remit of the Linux kernel, and
must be done by the SoC's firmware before _any_ CPU gets to the Linux
kernel.
Changing the data cache clean+invalidate to a mere invalidate allows us
to get rid of a lot of platform specific hacks around this issue for
their secondary CPU bringup paths - some of which were buggy.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Thierry Reding <treding@nvidia.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Tested-by: Michal Simek <michal.simek@xilinx.com>
Tested-by: Wei Xu <xuwei5@hisilicon.com>
The feroceon copypage implementation cannot be built when targetting an
ARMv4 CPU, so we need to pass the march=armv5te flag manually to gcc
when building this file. This is obviously safe since that code will
not be executed on ARMv4.
Atmel at91x40 is gone, so we no longer have any platform using
either of these two, and we get randconfig failures on NOMMU
kernels if they accidentally get enabled on something that conflicts
with ARMv4T.
This stops short of removing the entire CPU support for now,
but as nothing selects these, it is basically dead code.
the handler
Introduce faulthandler_disabled() and use it to check for irq context and
disabled pagefaults (via pagefault_disable()) in the pagefault handlers.
Please note that we keep the in_atomic() checks in place - to detect
whether in irq context (in which case preemption is always properly
disabled).
In contrast, preempt_disable() should never be used to disable pagefaults.
With !CONFIG_PREEMPT_COUNT, preempt_disable() doesn't modify the preempt
counter, and therefore the result of in_atomic() differs.
We validate that condition by using might_fault() checks when calling
might_sleep().
Therefore, add a comment to faulthandler_disabled(), describing why this
is needed.
faulthandler_disabled() and pagefault_disable() are defined in
linux/uaccess.h, so let's properly add that include to all relevant files.
This patch is based on a patch from Thomas Gleixner.
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: schwidefsky@de.ibm.com
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-7-git-send-email-dahi@linux.vnet.ibm.com
The existing code relies on pagefault_disable() implicitly disabling
preemption, so that no schedule will happen between kmap_atomic() and
kunmap_atomic().
Let's make this explicit, to prepare for pagefault_disable() not
touching preemption anymore.
Cc: hocko@suse.cz
Cc: mst@redhat.com
Link: http://lkml.kernel.org/r/1431359540-32227-5-git-send-email-dahi@linux.vnet.ibm.com
Avoid passing the auxiliary control register value through the enable
method. In the resume path, we have to read the value stored in
l2x0_saved_regs.aux_ctrl, only to have it immediately written back by
l2c_enable(). We can avoid this if we have __l2c_init() save the value
directly to l2x0_saved_regs.aux_ctrl before calling the specific enable
method.
Some L2C caches have a bit which allows non-secure software to control
the cache lockdown. Some platforms are unable to set this bit. To
avoid receiving an abort while trying to unlock the cache lines, check
the state of this bit before unlocking. We do this by providing a new
method in the l2c_init_data to perform the unlocking.
l2c_configure() does not follow the pattern of other l2c_* functions.
Fix this so that it does to avoid future confusion.
Before calling the controller specific configuration function, write
the auxiliary control register first, so that bits shared with other
registers (such as the prefetch control register) are not overwritten
by the later write to the auxctrl register.
l2c_enable() is documented that it must not be called if the cache has
already been enabled. Unfortunately, commit 6b49241ac252 ("ARM: 8259/1:
l2c: Refactor the driver to use commit-like interface") changed this
without updating the comment, for very little reason. Revert this
change and restore the expected behaviour.
At boot time we round the memblock limit down to section size in an
attempt to ensure that we will have mapped this RAM with section
mappings prior to allocating from it. When mapping RAM we iterate over
PMD-sized chunks, creating these section mappings.
Section mappings are only created when the end of a chunk is aligned to
section size. Unfortunately, with classic page tables (where PMD_SIZE is
2 * SECTION_SIZE) this means that if a chunk is between 1M and 2M in
size the first 1M will not be mapped despite having been accounted for
in the memblock limit. This has been observed to result in page tables
being allocated from unmapped memory, causing boot-time hangs.
This patch modifies the memblock limit rounding to always round down to
PMD_SIZE instead of SECTION_SIZE. For classic MMU this means that we
will round the memblock limit down to a 2M boundary, matching the limits
on section mappings, and preventing allocations from unmapped memory.
For LPAE there should be no change as PMD_SIZE == SECTION_SIZE.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reported-by: Stefan Agner <stefan@agner.ch>
Tested-by: Stefan Agner <stefan@agner.ch>
Acked-by: Laura Abbott <labbott@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
Cc: Steve Capper <steve.capper@linaro.org>
BSYM() was invented to allow us to work around a problem with the
assembler, where local symbols resolved by the assembler for the 'adr'
instruction did not take account of their ISA.
Since we don't want BSYM() used elsewhere, replace BSYM() with a new
macro 'badr', which is like the 'adr' pseudo-op, but with the BSYM()
mechanics integrated into it. This ensures that the BSYM()-ification
is only used in conjunction with 'adr'.
Acked-by: Dave Martin <Dave.Martin@arm.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
multiarch
Looks like apps can be made to segfault easily on armhf distros
just by running cpuburn-a8 in the background, then starting apt
get update unless erratum 430973 workaround is enabled. This happens
on r3p2 also, which has 430973 fixed in hardware.
Turns out the reason for this is some bootloaders incorrectly
setting the auxilary register IBE bit, which probably causes us
to hit erratum 687067 on Cortex-A8 later than r1p2.
If the bootloader incorrectly sets the IBE bit in the auxilary control
register for Cortex-A8 revisions with 430973 fixed in hardware, we
need to call flush BTAC/BTB to avoid segfaults probably caused by
erratum 687067. So let's flush BTAC/BTB unconditionally for Cortex-A8.
It won't do anything unless the IBE bit is set.
Note that we keep the erratum 430973 Kconfig option still around and
disabled for multiarch as it may be unsafe to enable for some secure
SoC. It is known safe to be enabled for n900, but won't do anything
on n900 as the IBE bit needs to be set with SMC.
Also note that SoCs probably should also add checks and print warnings
for the misconfigured IBE bit depending on the Cortex-A8 revision
so the bootloaders can be fixed Cortex-A8 revisions later than
r1p2 to not set the IBE bit.
Tested-by: Sebastian Reichel <sre@kernel.org>
