path: root/arch/arm/mm
2008-04-29arm: Export empty_zero_page for ZERO_PAGE usage in modules.Aneesh Kumar K.V
ext4 uses ZERO_PAGE(0) to zero out blocks. We need to export different symbols in different arches for the usage of ZERO_PAGE in modules. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-29Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (26 commits) [ARM] pxa: fix 1c104e0e4f6ab396960c058e95e18bdedcac945b [ARM] serial: s3c2410: platform_get_irq() may return signed unnoticed [ARM] am79c961a: platform_get_irq() may return signed unnoticed [ARM] Feroceon: Feroceon-specific WA-cache compatible {copy,clear}_user_page() [ARM] Feroceon: fix function alignment in proc-feroceon.S [ARM] Orion: catch a couple more alternative spellings of PCIe [ARM] Orion: fix orion-ehci platform resource end addresses [ARM] Orion: fix ->map_irq() PCIe bus number check [ARM] Orion: fix ioremap() optimization [ARM] feroceon: remove CONFIG_CPU_CACHE_ROUND_ROBIN check [ARM] feroceon: remove CONFIG_CPU_DCACHE_WRITETHROUGH check kprobes/arm: fix decoding of arithmetic immediate instructions kprobes/arm: fix cache flush address for instruction stub [ARM] 5022/1: Race in ARM MMCI PL18x driver, V2 [ARM] 5021/1: at91: buildfix for sam9263 + PM [ARM] 5018/1: RealView: Fix the ARM11MPCore Oprofile compilation [ARM] 5016/1: AT91: typo in mci configuration for at91cap at91sam9263 [ARM] 5017/1: pxa3xx: Report unsupported wakeup sources in pxa3xx_set_wake() [ARM] 5020/1: magician: remove __devinit marker from pasic3_leds_info [ARM] 5014/1: Cleanup reset state before entering suspend or resetting. ...
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28[ARM] Feroceon: Feroceon-specific WA-cache compatible {copy,clear}_user_page()Lennert Buytenhek
This patch implements a set of Feroceon-specific {copy,clear}_user_page() routines that perform more optimally than the generic implementations. This also deals with write-allocate caches (Feroceon can run L1 D in WA mode) which otherwise prevents Linux from booting. [nico: optimized the code even further] Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Sylver Bruneau <sylver.bruneau@googlemail.com> Tested-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-04-28[ARM] Feroceon: fix function alignment in proc-feroceon.SNicolas Pitre
One overzealous .align 10 fixed, and a few .align5 added. Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-04-28[ARM] feroceon: remove CONFIG_CPU_CACHE_ROUND_ROBIN checkLennert Buytenhek
Since the Feroceon cache replacement policy is always pseudorandom (and the relevant control register bit is ignored), remove the CONFIG_CPU_CACHE_ROUND_ROBIN check from proc-feroceon.S. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-04-28[ARM] feroceon: remove CONFIG_CPU_DCACHE_WRITETHROUGH checkLennert Buytenhek
Since the Feroceon doesn't have a global WT override bit like ARM926 does, remove all code relating to this mode of operation from proc-feroceon.S. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-04-24[ARM] fix 48d7927bdf071d05cf5d15b816cf06b0937cb84fCatalin Marinas
The proc-*.S files have the _prefetch_abort pointer placed at the end of the processor structure but the cpu-multi32.h defines it in the second position. The patch also fixes the support for XSC3 and the MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19Merge branches 'arm', 'at91', 'ep93xx', 'iop', 'ks8695', 'misc', 'mxc', ↵Russell King
'ns9x', 'orion', 'pxa', 'sa1100', 's3c' and 'sparsemem' into devel
2008-04-19[ARM] remove redundant display of free swap space in show_mem()Johannes Weiner
Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-18Allow the L2X0 outer cache support to be configurableCatalin Marinas
By default, this option was selected by the platform Kconfig. This patch adds "depends on" to L2X0 so that it can be enabled/disabled manually. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-04-18RealView: Add the configuration and build changes for PB1176Bahadir Balban
This patch enables the building of Linux for the PB1176 platform. Signed-off-by: Bahadir Balban <bahadir.balban@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-04-18RealView: Enable the configuration options for PB11MPCoreBahadir Balban
This patch adds the PB11MPCore support to the corresponding Kconfig and Makefile to enable building. Signed-off-by: Bahadir Balban <bahadir.balban@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-04-18RealView: Allow ARMv7 support for RealView/EBCatalin Marinas
This patch changes the CPU_V7 configuration dependency to allow MACH_REALVIEW_EB. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-04-18RealView: Move the SCU initialisation out of __v6_setupCatalin Marinas
This patch moves the SCU initialisation from __v6_setup to the smp_prepare_cpus() function as it relies on platform-specific settings. Changes to get_core_count() are mainly for allowing cleaner code with the upcoming PB11MPCore patches. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-04-18Add a prefetch abort handlerPaul Brook
This patch adds a prefetch abort handler similar to the data abort one and renames the latter for consistency. Initial implementation by Paul Brook with some renaming by Catalin Marinas. Signed-off-by: Paul Brook <paul@codesourcery.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-04-18ARMv7: Add support for the ThumbEE state saving/restoringCatalin Marinas
This patch adds the detection and handling of the ThumbEE extension on ARMv7 CPUs. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-03-27Orion: orion -> orion5x renameLennert Buytenhek
Do a global s/orion/orion5x/ of the Orion 5x-specific bits (i.e. not the plat-orion bits.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Reviewed-by: Tzachi Perelstein <tzachi@marvell.com> Acked-by: Saeed Bishara <saeed@marvell.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-03-20[ARM] 4864/1: Enable write buffer coalescing on IOPArnaud Patard
Some bootloaders are disabling write buffer coalescing. Enable it back under linux. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-01[ARM] Fix freeing of page tables for ARM in free_pgd_slowUwe Kleine-König
Since 2f569af (CONFIG_HIGHPTE vs. sub-page page tables.) pte_free() calls pte_lock_deinit() and dec_zone_page_state(). So free_pgd_slow must not call the latter two when calling the first. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-29[ARM] 4839/1: fixes kernel Oops in /dev/mem device driver for memory map ↵Alexandre Rusev
with PHYS_OFF "cat /dev/mem" may cause kernel Oops for boards with PHYS_OFFSET != 0 because character device is mapped to addresses starting from zero and there is no protection against such situation. Patch just add this. Signed-off-by: Alexandre Rusev <arusev@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28Merge branch 'orion' into develRussell King
* orion: (26 commits) [ARM] Orion: implement power-off method for QNAP TS-109/209 [ARM] Orion: add support for QNAP TS-109/TS-209 [ARM] Orion: I2C support [I2C] i2c-mv64xxx: Don't set i2c_adapter.retries [I2C] Split mv643xx I2C platform support [ARM] Orion: enable CONFIG_RTC_DRV_M41T80 for D-Link DNS-323 [ARM] Orion defconfig [ARM] Orion: add support for Orion/MV88F5181 based D-Link DNS-323 [ARM] Orion: MV88F5181 support bits [ARM] Orion: Buffalo/Revogear Kurobox Pro support [ARM] OrionNAS RD board support [ARM] Orion: support for Marvell Orion-2 (88F5281) Development Board [ARM] Orion: common platform setup for Gigabit Ethernet port [ARM] Orion: platform device registration for UART, USB and NAND [ARM] Orion: system timer support [ARM] Orion edge GPIO IRQ support [ARM] Orion: IRQ support [ARM] Orion: provide GPIO method for enabling hardware assisted blinking [ARM] Orion: GPIO support [ARM] Orion: programable address map support ... Conflicts: arch/arm/Kconfig arch/arm/Makefile Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Merge branches 'at91', 'ep93xx', 'iop', 'kprobes', 'ks8695', 'misc', 'msm', ↵Russell King
's3c2410', 'sa1100' and 'vfp' into devel * at91: (24 commits) [ARM] 4615/4: sam926[13]ek buttons updated [ARM] 4765/1: [AT91] AT91CAP9A-DK board support [ARM] 4764/1: [AT91] AT91CAP9 core support [ARM] 4738/1: at91sam9261: Remove udc pullup enabling in board initialisation [ARM] 4761/1: [AT91] Board-support for NEW_LEDs [ARM] 4760/1: [AT91] SPI CS0 errata on AT91RM9200 [ARM] 4759/1: [AT91] Buttons on CSB300 [ARM] 4758/1: [AT91] LEDs [ARM] 4757/1: [AT91] UART initialization [ARM] 4756/1: [AT91] Makefile cleanup [ARM] 4755/1: [AT91] NAND update [ARM] 4754/1: [AT91] SSC library support [ARM] 4753/1: [AT91] Use DMA_BIT_MASK [ARM] 4752/1: [AT91] RTT, RTC and WDT peripherals on SAM9 [ARM] 4751/1: [AT91] ISI peripheral on SAM9263 [ARM] 4750/1: [AT91] STN LCD displays on SAM9261 [ARM] 4734/1: at91sam9263ek: include IRQ for Ethernet PHY [ARM] 4646/1: AT91: configurable HZ, default to 128 [ARM] 4688/1: at91: speed-up irq processing [ARM] 4657/1: AT91: Header definition update ... * ep93xx: [ARM] 4671/1: ep93xx: remove obsolete gpio_line_* operations [ARM] 4670/1: ep93xx: implement IRQT_BOTHEDGE gpio irq sense type [ARM] 4669/1: ep93xx: simplify GPIO code and cleanups [ARM] 4668/1: ep93xx: implement new GPIO API * iop: [ARM] 4770/1: GLAN Tank: correct physmap_flash_data width field [ARM] 4732/1: GLAN Tank: register rtc-rs5c372 i2c device [ARM] 4708/1: iop: update defconfigs for 2.6.24 * kprobes: ARM kprobes: let's enable it ARM kprobes: special hook for the kprobes breakpoint handler ARM kprobes: prevent some functions involved with kprobes from being probed ARM kprobes: don't let a single-stepped stmdb corrupt the exception stack ARM kprobes: add the kprobes hook to the page fault handler ARM kprobes: core code ARM kprobes: instruction single-stepping support * ks8695: [ARM] 4603/1: KS8695: debugfs interface to view pin state [ARM] 4601/1: KS8695: PCI support * misc: [ARM] remove duplicate includes [ARM] CONFIG_DEBUG_STACK_USAGE [ARM] 4689/1: small comment wrap fix [ARM] 4687/1: Trivial arch/arm/kernel/entry-common.S comment fix [ARM] 4666/1: ixp4xx: fix sparse warnings in include/asm-arm/arch-ixp4xx/io.h [ARM] remove reference to non-existent MTD_OBSOLETE_CHIPS [SERIAL] 21285: Report baud rate back via termios [ARM] Remove pointless casts from void pointers, [ARM] Misc minor interrupt handler cleanups [ARM] Remove at91_lcdc.h [ARM] ARRAY_SIZE() cleanup [ARM] Update mach-types * msm: [ARM] msm: dma support for MSM7X00A [ARM] msm: board file for MACH_HALIBUT (QCT MSM7200A) [ARM] msm: irq and timer support for ARCH_MSM7X00A [ARM] msm: core platform support for ARCH_MSM7X00A * s3c2410: (33 commits) [ARM] 4795/1: S3C244X: Add armclk and setparent call [ARM] 4794/1: S3C24XX: Comonise S3C2440 and S3C2442 clock code [ARM] 4793/1: S3C24XX: Add IRQ->GPIO pin mapping function [ARM] 4792/1: S3C24XX: Remove warnings from debug-macro.S [ARM] 4791/1: S3C2412: Make fclk a parent of msysclk [ARM] 4790/1: S3C2412: Fix parent selection for msysclk. [ARM] 4789/1: S3C2412: Add missing CLKDIVN register values [ARM] 4788/1: S3C24XX: Fix paramet to s3c2410_dma_ctrl if S3C2410_DMAF_AUTOSTART used. [ARM] 4787/1: S3C24XX: s3c2410_dma_request() should return the allocated channel number [ARM] 4786/1: S3C2412: Add SPI FIFO controll constants [ARM] 4785/1: S3C24XX: Add _SHIFT definitions for S3C2410_BANKCON registers [ARM] 4784/1: S3C24XX: Fix GPIO restore glitches [ARM] 4783/1: S3C24XX: Add s3c2410_gpio_getpull() [ARM] 4782/1: S3C24XX: Define FIQ_START for any FIQ users [ARM] 4781/1: S3C24XX: DMA suspend and resume support [ARM] 4780/1: S3C2412: Allow for seperate DMA channels for TX and RX [ARM] 4779/1: S3C2412: Add s3c2412_gpio_set_sleepcfg() call [ARM] 4778/1: S3C2412: Add armclk and init from DVS state [ARM] 4777/1: S3C24XX: Ensure clk_set_rate() checks the set_rate method for the clk [ARM] 4775/1: s3c2410: fix compilation error if only s3c2442 cpu is selected ... * sa1100: [ARM] sa1100: add clock source support * vfp: [ARM] 4584/2: ARMv7: Add Advanced SIMD (NEON) extension support [ARM] 4583/1: ARMv7: Add VFPv3 support [ARM] 4582/2: Add support for the common VFP subarchitecture
2008-01-26ARM kprobes: prevent some functions involved with kprobes from being probedNicolas Pitre
2008-01-26ARM kprobes: add the kprobes hook to the page fault handlerNicolas Pitre
2008-01-26[ARM] Feroceon: support old cores with ARM926 IDTzachi Perelstein
This enables the usage of some old Feroceon cores for which the CPU ID is equal to the ARM926 ID. Relevant for Feroceon-1850 and old Feroceon-2850. Signed-off-by: Tzachi Perelstein <tzachi@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] Marvell Feroceon CPU core supportAssaf Hoffman
The Feroceon is a family of independent ARMv5TE compliant CPU core implementations, supporting a variable depth pipeline and out-of-order execution. The Feroceon is configurable with VFP support, and the later models in the series are superscalar with up to two instructions per clock cycle. This patch adds the initial low-level cache/TLB handling for this core. Signed-off-by: Assaf Hoffman <hoffman@marvell.com> Reviewed-by: Tzachi Perelstein <tzachi@marvell.com> Reviewed-by: Nicolas Pitre <nico@marvell.com> Reviewed-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4764/1: [AT91] AT91CAP9 core supportAndrew Victor
Add support for Atmel's AT91CAP9 Customizable Microcontroller family. <http://www.atmel.com/products/AT91CAP/Default.asp> Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] msm: core platform support for ARCH_MSM7X00ABrian Swetland
- core header files for arch-msm - Kconfig and Makefiles to enable ARCH_MSM7X00A builds - MSM7X00A specific arch_idle - peripheral iomap and irq number definitions Signed-off-by: Brian Swetland <swetland@google.com>
2007-11-11[ARM] remove useless setting of VM_RESERVEDRussell King
remap_pfn_range() takes care of setting the appropriate VM_* flags itself; there's no need for callers of remap_pfn_range() to set VM_RESERVED before it is called. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-31[ARM] Fix FIQ issue with ARM926Russell King
Jon Eibertzon writes: > We have noticed that the I-cache is disabled while waiting for > interrupt in cpu_arm926_do_idle in arch/arm/mm/proc-arm926.S > and we are curious to know why, because this causes us a great > performance hit when executing in FIQ-handlers. Is it assumed > here that every individual FIQ-handler re-enables the I-cache? The I-cache disable is an errata workaround, so the solution is to disable FIQs across the section with the I-cache disabled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-19Use helpers to obtain task pid in printks (arch code)Alexey Dobriyan
One of the easiest things to isolate is the pid printed in kernel log. There was a patch, that made this for arch-independent code, this one makes so for arch/xxx files. It took some time to cross-compile it, but hopefully these are all the printks in arch code. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16During VM oom condition, kill all threads in process groupWill Schmidt
We have had complaints where a threaded application is left in a bad state after one of it's threads is killed when we hit a VM: out_of_memory condition. Killing just one of the process threads can leave the application in a bad state, whereas killing the entire process group would allow for the application to restart, or be otherwise handled, and makes it very obvious that something has gone wrong. This change allows the entire process group to be taken down, rather than just the one thread. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15Merge branch 'pxa' into develRussell King
2007-10-15[ARM] pxa: PXA3xx base supporteric miao
Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] Rename consistent_sync() as dma_cache_maint()Russell King
consistent_sync() is used to handle the cache maintainence issues with DMA operations. Since we've now removed the misuse of this function from the two MTD drivers, rename it to prevent future mis-use. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: Make CPU_XSCALE depend on PXA25x or PXA27xRussell King
PXA3 SoCs are supported by the Xscale3 CPU code rather than the Xscale CPU code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-09-17[ARM] 4568/1: fix l2x0 cache invalidate handling of unaligned addressesRui Sousa
The l2x0_inv_range() function doesn't handle unaligned addresses correctly. It's necessary to clean the cache lines that are at the start and end of the invalidate range, if the addresses are not aligned, to prevent corruption of other data sharing the same cache line. Signed-off-by: Rui Sousa <rui.p.m.sousa@gmail.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (60 commits) [ARM] 4524/1: S3C: Move register out of include/asm-arm/arch-s3c2410 [ARM] 4523/1: S3C: Remove FIFO_MAX from uncompression headers [ARM] 4522/1: S3C: split include/asm-arm/arch/memory.h [ARM] 4521/2: S3C: Reorganise VA mapping headers [ARM] 4520/1: S3C: Remove old VA values from static map [ARM] 4519/1: S3C: split S3C2400 values out of S3C24XX map.h [ARM] 4518/1: S3C: Rename watchdog configuration options [ARM] 4517/1: S3C: Fix debug macros for ARM926 output [ARM] 4516/1: S3C: Fix uncompressor serial output for ARM926 [ARM] 4515/1: S3C: Move uncompress code to plat-s3c [ARM] 4514/1: S3C: Rename DEBUG_S3C2410_PORT and DEBUG_S3C_UART [ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT [ARM] 4512/1: S3C: rename the debug macros for per-cpu updates [ARM] 4511/1: S3C: updated LLSERIAL Kconfig defines for CPU support [ARM] 4510/1: S3C: split debug-macro support into plat-s3c [ARM] 4509/1: S3C: Create initial arch/arm/plat-s3c [ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3c [ARM] 4461/1: MXC platform and i.MX31ADS core support [ARM] 4507/1: pxa2xx clock_event_device [ARM] 4497/1: Only allow safe cache configurations on ARMv6 and later ...
2007-07-22Merge branches 'at91', 'imx', 'iop', 'ixp', 'ks8695', 'misc', 'ns9xxx', ↵Russell King
'pxa' and 's3c' into devel
2007-07-22[ARM] 4461/1: MXC platform and i.MX31ADS core supportQuinn Jensen
This patch adds the foundation pieces for the Freescale MXC platforms, including i.MX2 and i.MX3 based systems. The bare-bones MX31 support in this patch boots to the rootdev panic with 8250 serial console configured "console=ttyS0,115200". It assumes that Redboot is the boot loader. Signed-off-by: Quinn Jensen <quinn.jensen@freescale.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4497/1: Only allow safe cache configurations on ARMv6 and laterCatalin Marinas
Currently, Linux doesn't generate correct page tables for ARMv6 and later cores if the cache policy is different from the default one (it may lead to strongly ordered or shared device mappings). This patch disallows cache policies other than writeback and the CPU_[ID]CACHE_DISABLE options only affect the CP15 system control register rather than the page tables. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4503/1: nommu: Add noMMU support for ARMv7Catalin Marinas
This patch adds the necessary ifdef's to the proc-v7.S code and defines the v7wbi_tlb_fns macro in pgtable-nommu.h Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4498/1: ARMv7: Remove the L2 cache configuration via the aux ctrl registerCatalin Marinas
The auxiliary control and the L2 auxiliary control registers are Cortex-A8 specific. They need to be removed from the generic ARMv7 support code. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4504/1: nommu: Fix the ARMv6 support for MMU-less platformsCatalin Marinas
With this patch, Kconfig only selects CPU_HAS_ASID for the MMU case. It also corrects the typo in the v6wbi_tlb_fns definition in pgtable-nommu.h. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4502/1: nommu: Do not export the copy/clear user page functionsCatalin Marinas
The __cpu_{clear|copy}_user_page functions are not defined for the MMU-less case and therefore should not be exported. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4501/1: nommu: Select TLS register emulation if ARMv6 and not v6KCatalin Marinas
If not MMU and not v6K, access to the TLS register has to be emulated. MMU-less systems do not provide a high page for kuser helpers. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
