commit fa9dd599b4dae841924b022768354cfde9affecb upstream.
Having a pure_initcall() callback just to permanently enable BPF
JITs under CONFIG_BPF_JIT_ALWAYS_ON is unnecessary and could leave
a small race window in future where JIT is still disabled on boot.
Since we know about the setting at compilation time anyway, just
initialize it properly there. Also consolidate all the individual
bpf_jit_enable variables into a single one and move them under one
location. Moreover, don't allow for setting unspecified garbage
values on them.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[bwh: Backported to 4.14 as dependency of commit 2e4a30983b0f
"bpf: restrict access to core bpf sysctls":
- Adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
emit_ldx_r() and emit_a32_mov_i() were both using TMP_REG_1 and
clashing with each other. Using TMP_REG_2 in emit_ldx_r() fixes
the issue.
Fixes: ec19e02b343 ("ARM: net: bpf: fix LDX instructions")
Cc: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr>
[ Upstream commit 68565a1af9f7012e6f2fe2bdd612f67d2d830c28 ]
The names for BPF_ALU64 | BPF_ARSH are emit_a32_arsh_*,
the names for BPF_ALU64 | BPF_LSH are emit_a32_lsh_*, but
the names for BPF_ALU64 | BPF_RSH are emit_a32_lsr_*.
For consistence reason, let's rename emit_a32_lsr_* to
emit_a32_rsh_*.
This patch also corrects a wrong comment.
Fixes: 39c13c204bb1 ("arm: eBPF JIT compiler")
Signed-off-by: Wang YanQing <udknight@gmail.com>
Cc: Shubham Bansal <illusionist.neo@gmail.com>
Cc: linux@armlinux.org.uk
commit 091f02483df7b56615b524491f404e574c5e0668 upstream.
As per 90caccdd8cc0 ("bpf: fix bpf_tail_call() x64 JIT"), the index used
for array lookup is defined to be 32-bit wide. Update a misleading
comment that suggests it is 64-bit wide.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit ec19e02b343db991d2d1610c409efefebf4e2ca9 upstream.
When the source and destination register are identical, our JIT does not
generate correct code, which leads to kernel oopses.
Fix this by (a) generating more efficient code, and (b) making use of
the temporary earlier if we will overwrite the address register.
commit 02088d9b392f605c892894b46aa8c83e3abd0115 upstream.
When an eBPF program tail-calls another eBPF program, it enters it after
the prologue to avoid having complex stack manipulations. This can lead
to kernel oopses, and similar.
Resolve this by always using a fixed stack layout, a CPU register frame
pointer, and using this when reloading registers before returning.
commit 0005e55a79cfda88199e41a406a829c88d708c67 upstream.
The stack layout documentation incorrectly suggests that the BPF JIT
scratch space starts immediately below BPF_FP. This is not correct,
so let's fix the documentation to reflect reality.
commit 70ec3a6c2c11e4b0e107a65de943a082f9aff351 upstream.
Move the stack documentation towards the top of the file, where it's
relevant for things like the register layout.
commit d1220efd23484c72c82d5471f05daeb35b5d1916 upstream.
As per 2dede2d8e925 ("ARM EABI: stack pointer must be 64-bit aligned
after a CPU exception") the stack should be aligned to a 64-bit boundary
on EABI systems. Ensure that the eBPF JIT appropraitely aligns the
stack.
commit f4483f2cc1fdc03488c8a1452e545545ae5bda93 upstream.
When a tail call fails, it is documented that the tail call should
continue execution at the following instruction. An example tail call
sequence is:
12: (85) call bpf_tail_call#12
13: (b7) r0 = 0
14: (95) exit
The ARM assembler for the tail call in this case ends up branching to
instruction 14 instead of instruction 13, resulting in the BPF filter
returning a non-zero value:
178: ldr r8, [sp, #588] ; insn 12
17c: ldr r6, [r8, r6]
180: ldr r8, [sp, #580]
184: cmp r8, r6
188: bcs 0x1e8
18c: ldr r6, [sp, #524]
190: ldr r7, [sp, #528]
194: cmp r7, #0
198: cmpeq r6, #32
19c: bhi 0x1e8
1a0: adds r6, r6, #1
1a4: adc r7, r7, #0
1a8: str r6, [sp, #524]
1ac: str r7, [sp, #528]
1b0: mov r6, #104
1b4: ldr r8, [sp, #588]
1b8: add r6, r8, r6
1bc: ldr r8, [sp, #580]
1c0: lsl r7, r8, #2
1c4: ldr r6, [r6, r7]
1c8: cmp r6, #0
1cc: beq 0x1e8
1d0: mov r8, #32
1d4: ldr r6, [r6, r8]
1d8: add r6, r6, #44
1dc: bx r6
1e0: mov r0, #0 ; insn 13
1e4: mov r1, #0
1e8: add sp, sp, #596 ; insn 14
1ec: pop {r4, r5, r6, r7, r8, sl, pc}
For other sequences, the tail call could end up branching midway through
the following BPF instructions, or maybe off the end of the function,
leading to unknown behaviours.
commit e9062481824384f00299971f923fecf6b3668001 upstream.
Avoid the 'bx' instruction on CPUs that have no support for Thumb and
thus do not implement this instruction by moving the generation of this
opcode to a separate function that selects between:
bx reg
and
mov pc, reg
according to the capabilities of the CPU.
The JIT compiler emits ARM 32 bit instructions. Currently, It supports
eBPF only. Classic BPF is supported because of the conversion by BPF core.
This patch is essentially changing the current implementation of JIT compiler
of Berkeley Packet Filter from classic to internal with almost all
instructions from eBPF ISA supported except the following
BPF_ALU64 | BPF_DIV | BPF_K
BPF_ALU64 | BPF_DIV | BPF_X
BPF_ALU64 | BPF_MOD | BPF_K
BPF_ALU64 | BPF_MOD | BPF_X
BPF_STX | BPF_XADD | BPF_W
BPF_STX | BPF_XADD | BPF_DW
Implementation is using scratch space to emulate 64 bit eBPF ISA on 32 bit
ARM because of deficiency of general purpose registers on ARM. Currently,
only LITTLE ENDIAN machines are supported in this eBPF JIT Compiler.
Tested on ARMv7 with QEMU by me (Shubham Bansal).
Testing results on ARMv7:
1) test_bpf: Summary: 341 PASSED, 0 FAILED, [312/333 JIT'ed]
2) test_tag: OK (40945 tests)
3) test_progs: Summary: 30 PASSED, 0 FAILED
4) test_lpm: OK
5) test_lru_map: OK
Above tests are all done with following flags enabled discreatly.
1) bpf_jit_enable=1
a) CONFIG_FRAME_POINTER enabled
b) CONFIG_FRAME_POINTER disabled
2) bpf_jit_enable=1 and bpf_jit_harden=2
See Documentation/networking/filter.txt for more information.
Signed-off-by: Shubham Bansal <illusionist.neo@gmail.com>
set_memory_* functions have moved to set_memory.h. Switch to this
explicitly
Link: http://lkml.kernel.org/r/1488920133-27229-3-git-send-email-labbott@redhat.com
Signed-off-by: Laura Abbott <labbott@redhat.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
The LSR instruction cannot be used to perform a zero right shift since a
0 as the immediate value (imm5) in the LSR instruction encoding means
that a shift of 32 is perfomed. See DecodeIMMShift() in the ARM ARM.
Make the JIT skip generation of the LSR if a zero-shift is requested.
This was found using american fuzzy lop.
Signed-off-by: Rabin Vincent <rabin@rab.in>
The SKF_AD_ALU_XOR_X ancillary is not like the other ancillary data
instructions since it XORs A with X while all the others replace A with
some loaded value. All the BPF JITs fail to clear A if this is used as
the first instruction in a filter. This was found using american fuzzy
lop.
Add a helper to determine if A needs to be cleared given the first
instruction in a filter, and use this in the JITs. Except for ARM, the
rest have only been compile-tested.
Fixes: 3480593131e0 ("net: filter: get rid of BPF_S_* enum")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
During review I noticed that the icache range we're flushing should
start at header already and not at ctx.image.
Reason is that after 55309dd3d4cd ("net: bpf: arm: address randomize
and write protect JIT code"), we also want to make sure to flush the
random-sized trap in front of the start of the actual program (analogous
to x86). No operational differences from user side.
Tested-by: Nicolas Schichan <nschichan@freebox.fr>
Cc: Alexei Starovoitov <ast@kernel.org>
drivers/net/usb/asix_common.c
net/ipv4/inet_connection_sock.c
net/switchdev/switchdev.c
In the inet_connection_sock.c case the request socket hashing scheme
is completely different in net-next.
The other two conflicts were overlapping changes.
For ARMv7 with UDIV instruction support, generate an UDIV instruction
followed by an MLS instruction.
For other ARM variants, generate code calling a C wrapper similar to
the jit_udiv() function used for BPF_ALU | BPF_DIV instructions.
Some performance numbers reported by the test_bpf module (the duration
per filter run is reported in nanoseconds, between "jitted:<x>" and
"PASS":
ARMv7 QEMU nojit: test_bpf: #3 DIV_MOD_KX jited:0 2196 PASS
ARMv7 QEMU jit: test_bpf: #3 DIV_MOD_KX jited:1 104 PASS
ARMv5 QEMU nojit: test_bpf: #3 DIV_MOD_KX jited:0 2176 PASS
ARMv5 QEMU jit: test_bpf: #3 DIV_MOD_KX jited:1 1104 PASS
ARMv5 kirkwood nojit: test_bpf: #3 DIV_MOD_KX jited:0 1103 PASS
ARMv5 kirkwood jit: test_bpf: #3 DIV_MOD_KX jited:1 311 PASS
Without this patch, if the only instructions using r_X are of the
BPF_LD | BPF_IND type, r_X would not be reset to 0, using whatever
value was there when entering the jited code. With this patch, r_X
will be correctly marked as used so it will be reset to 0 in the
prologue code.
This fix also makes the test "LD_IND byte default X" pass in the
test_bpf module when the ARM JIT is enabled.
As we need to add further flags to the bpf_prog structure, lets migrate
both bools to a bitfield representation. The size of the base structure
(excluding insns) remains unchanged at 40 bytes.
Add also tags for the kmemchecker, so that it doesn't throw false
positives. Even in case gcc would generate suboptimal code, it's not
being accessed in performance critical paths.
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
This makes BPF_ANC | SKF_AD_VLAN_TAG and BPF_ANC | SKF_AD_VLAN_TAG_PRESENT
have the same behaviour as the in kernel VM and makes the test_bpf LD_VLAN_TAG
and LD_VLAN_TAG_PRESENT tests pass.
Previously, the JIT would reject negative offsets known during code
generation and mishandle negative offsets provided at runtime.
Fix that by calling bpf_internal_load_pointer_neg_helper()
appropriately in the jit_get_skb_{b,h,w} slow path helpers and by forcing
the execution flow to the slow path helpers when the offset is
negative.
To check whether the load should take the fast path or not, the code
would check that (r_skb_hlen - load_order) is greater than the offset
of the access using an "Unsigned higher or same" condition. For
halfword accesses and an skb length of 1 at offset 0, that test is
valid, as we end up comparing 0xffffffff(-1) and 0, so the fast path
is taken and the filter allows the load to wrongly succeed. A similar
issue exists for word loads at offset 0 and an skb length of less than
4.
Fix that by using the condition "Signed greater than or equal"
condition for the fast path code for load orders greater than 0.
Four minor merge conflicts:
1) qca_spi.c renamed the local variable used for the SPI device
from spi_device to spi, meanwhile the spi_set_drvdata() call
got moved further up in the probe function.
2) Two changes were both adding new members to codel params
structure, and thus we had overlapping changes to the
initializer function.
3) 'net' was making a fix to sk_release_kernel() which is
completely removed in 'net-next'.
4) In net_namespace.c, the rtnl_net_fill() call for GET operations
had the command value fixed, meanwhile 'net-next' adjusted the
argument signature a bit.
This also matches example merge resolutions posted by Stephen
Rothwell over the past two days.
value can't fit into 12bits.
The ARM JIT code emits "ldr rX, [pc, #offset]" to access the literal
pool. #offset maximum value is 4095 and if the generated code is too
large, the #offset value can overflow and not point to the expected
slot in the literal pool. Additionally, when overflow occurs, bits of
the overflow can end up changing the destination register of the ldr
instruction.
Fix that by detecting the overflow in imm_offset() and setting a flag
that is checked for each BPF instructions converted in
build_body(). As of now it can only be detected in the second pass. As
a result the second build_body() call can now fail, so add the
corresponding cleanup code in that case.
Using multiple literal pools in the JITed code is going to require
lots of intrusive changes to the JIT code (which would better be done
as a feature instead of fix), just delegating to the kernel BPF
interpreter in that case is a more straight forward, minimal fix and
easy to backport.
Fixes: ddecdfcea0ae ("ARM: 7259/3: net: JIT compiler for packet filters")
In that case, emit_udiv() will be called with rn == ARM_R0 (r_scratch)
and loading rm first into ARM_R0 will result in jit_udiv() function
being called the same dividend and divisor. Fix that by loading rn
first into ARM_R1 and then rm into ARM_R0.
Cc: <stable@vger.kernel.org> # v3.13+
Fixes: aee636c4809f (bpf: do not use reciprocal divide)
Acked-by: Mircea Gherzan <mgherzan@gmail.com>
Will Deacon pointed out, that the currently used opcode for filling holes,
that is 0xe7ffffff, seems not robust enough ...
$ echo 0xffffffe7 | xxd -r > test.bin
$ arm-linux-gnueabihf-objdump -m arm -D -b binary test.bin
0: e7ffffff udf #65535 ; 0xffff
... while for Thumb, it ends up as ...
0: ffff e7ff vqshl.u64 q15, <illegal reg q15.5>, #63
... which is a bit fragile. The ARM specification defines some *permanently*
guaranteed undefined instruction (UDF) space, for example for ARM in ARMv7-AR,
section A5.4 and for Thumb in ARMv7-M, section A5.2.6.
Similarly, ptrace, kprobes, kgdb, bug and uprobes make use of such instruction
as well to trap. Given mentioned section from the specification, we can find
such a universe as (where 'x' denotes 'don't care'):
ARM: xxxx 0111 1111 xxxx xxxx xxxx 1111 xxxx
Thumb: 1101 1110 xxxx xxxx
We therefore should use a more robust opcode that fits both. Russell King
suggested that we can even reuse a single 32-bit word, that is, 0xe7fddef1
which will fault if executed in ARM *or* Thumb mode as done in f928d4f2a86f
("ARM: poison the vectors page"). That will still hold our requirements:
$ echo 0xf1defde7 | xxd -r > test.bin
$ arm-unknown-linux-gnueabi-objdump -m arm -D -b binary test.bin
0: e7fddef1 udf #56801 ; 0xdde1
$ echo 0xf1defde7f1defde7f1defde7 | xxd -r > test.bin
$ arm-unknown-linux-gnueabi-objdump -marm -Mforce-thumb -D -b binary test.bin
0: def1 udf #241 ; 0xf1
2: e7fd b.n 0x0
4: def1 udf #241 ; 0xf1
6: e7fd b.n 0x4
8: def1 udf #241 ; 0xf1
a: e7fd b.n 0x8
So on ARM 0xe7fddef1 conforms to the above UDF pattern, and the low 16 bit
likewise correspond to UDF in Thumb case. The 0xe7fd part is an unconditional
branch back to the UDF instruction.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Reported by Mikulas Patocka, kmemcheck currently barks out a
false positive since we don't have special kmemcheck annotation
for bitfields used in bpf_prog structure.
We currently have jited:1, len:31 and thus when accessing len
while CONFIG_KMEMCHECK enabled, kmemcheck throws a warning that
we're reading uninitialized memory.
As we don't need the whole bit universe for pages member, we
can just split it to u16 and use a bool flag for jited instead
of a bitfield.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
This is the ARM variant for 314beb9bcab ("x86: bpf_jit_comp: secure bpf
jit against spraying attacks").
It is now possible to implement it due to commits 75374ad47c64 ("ARM: mm:
Define set_memory_* functions for ARM") and dca9aa92fc7c ("ARM: add
DEBUG_SET_MODULE_RONX option to Kconfig") which added infrastructure for
this facility.
Thus, this patch makes sure the BPF generated JIT code is marked RO, as
other kernel text sections, and also lets the generated JIT code start
at a pseudo random offset instead on a page boundary. The holes are filled
with illegal instructions.
JIT tested on armv7hl with BPF test suite.
Reference: http://mainisusuallyafunction.blogspot.com/2012/11/attacking-hardened-linux-systems-with.html
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
With eBPF getting more extended and exposure to user space is on it's way,
hardening the memory range the interpreter uses to steer its command flow
seems appropriate. This patch moves the to be interpreted bytecode to
read-only pages.
In case we execute a corrupted BPF interpreter image for some reason e.g.
caused by an attacker which got past a verifier stage, it would not only
provide arbitrary read/write memory access but arbitrary function calls
as well. After setting up the BPF interpreter image, its contents do not
change until destruction time, thus we can setup the image on immutable
made pages in order to mitigate modifications to that code. The idea
is derived from commit 314beb9bcabf ("x86: bpf_jit_comp: secure bpf jit
This is possible because bpf_prog is not part of sk_filter anymore.
After setup bpf_prog cannot be altered during its life-time. This prevents
any modifications to the entire bpf_prog structure (incl. function/JIT
image pointer).
Every eBPF program (including classic BPF that are migrated) have to call
bpf_prog_select_runtime() to select either interpreter or a JIT image
as a last setup step, and they all are being freed via bpf_prog_free(),
including non-JIT. Therefore, we can easily integrate this into the
eBPF life-time, plus since we directly allocate a bpf_prog, we have no
performance penalty.
Tested with seccomp and test_bpf testsuite in JIT/non-JIT mode and manual
inspection of kernel_page_tables. Brad Spengler proposed the same idea
via Twitter during development of this patch.
Joint work with Hannes Frederic Sowa.
Suggested-by: Brad Spengler <spender@grsecurity.net>
clean up names related to socket filtering and bpf in the following way:
- everything that deals with sockets keeps 'sk_*' prefix
- everything that is pure BPF is changed to 'bpf_*' prefix
split 'struct sk_filter' into
struct sk_filter {
atomic_t refcnt;
struct rcu_head rcu;
struct bpf_prog *prog;
and
struct bpf_prog {
u32 jited:1,
len:31;
struct sock_fprog_kern *orig_prog;
unsigned int (*bpf_func)(const struct sk_buff *skb,
const struct bpf_insn *filter);
union {
struct sock_filter insns[0];
struct bpf_insn insnsi[0];
struct work_struct work;
so that 'struct bpf_prog' can be used independent of sockets and cleans up
'unattached' bpf use cases
split SK_RUN_FILTER macro into:
SK_RUN_FILTER to be used with 'struct sk_filter *' and
BPF_PROG_RUN to be used with 'struct bpf_prog *'
__sk_filter_release(struct sk_filter *) gains
__bpf_prog_release(struct bpf_prog *) helper function
also perform related renames for the functions that work
with 'struct bpf_prog *', since they're on the same lines:
sk_filter_size -> bpf_prog_size
sk_filter_select_runtime -> bpf_prog_select_runtime
sk_filter_free -> bpf_prog_free
sk_unattached_filter_create -> bpf_prog_create
sk_unattached_filter_destroy -> bpf_prog_destroy
sk_store_orig_filter -> bpf_prog_store_orig_filter
sk_release_orig_filter -> bpf_release_orig_filter
__sk_migrate_filter -> bpf_migrate_filter
__sk_prepare_filter -> bpf_prepare_filter
API for attaching classic BPF to a socket stays the same:
sk_attach_filter(prog, struct sock *)/sk_detach_filter(struct sock *)
and SK_RUN_FILTER(struct sk_filter *, ctx) to execute a program
which is used by sockets, tun, af_packet
API for 'unattached' BPF programs becomes:
bpf_prog_create(struct bpf_prog **)/bpf_prog_destroy(struct bpf_prog *)
and BPF_PROG_RUN(struct bpf_prog *, ctx) to execute a program
which is used by isdn, ppp, team, seccomp, ptp, xt_bpf, cls_bpf, test_bpf
This patch finally allows us to get rid of the BPF_S_* enum.
Currently, the code performs unnecessary encode and decode
workarounds in seccomp and filter migration itself when a filter
is being attached in order to overcome BPF_S_* encoding which
is not used anymore by the new interpreter resp. JIT compilers.
Keeping it around would mean that also in future we would need
to extend and maintain this enum and related encoders/decoders.
We can get rid of all that and save us these operations during
filter attaching. Naturally, also JIT compilers need to be updated
by this.
Before JIT conversion is being done, each compiler checks if A
is being loaded at startup to obtain information if it needs to
emit instructions to clear A first. Since BPF extensions are a
subset of BPF_LD | BPF_{W,H,B} | BPF_ABS variants, case statements
for extensions can be removed at that point. To ease and minimalize
code changes in the classic JITs, we have introduced bpf_anc_helper().
Tested with test_bpf on x86_64 (JIT, int), s390x (JIT, int),
arm (JIT, int), i368 (int), ppc64 (JIT, int); for sparc we
unfortunately didn't have access, but changes are analogous to
the rest.
Joint work with Alexei Starovoitov.
Acked-by: Chema Gonzalez <chemag@gmail.com>
This patch adds a jited flag into sk_filter struct in order to indicate
whether a filter is currently jited or not. The size of sk_filter is
not being expanded as the 32 bit 'len' member allows upper bits to be
reused since a filter can currently only grow as large as BPF_MAXINSNS.
Therefore, there's enough room also for other in future needed flags to
reuse 'len' field if necessary. The jited flag also allows for having
alternative interpreter functions running as currently, we can only
detect jit compiled filters by testing fp->bpf_func to not equal the
address of sk_run_filter().
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
The packet hash can be considered a property of the packet, not just
on RX path.
This patch changes name of rxhash and l4_rxhash skbuff fields to be
hash and l4_hash respectively. This includes changing uses of the
field in the code which don't call the access functions.
Signed-off-by: Tom Herbert <therbert@google.com>
Cc: Mahesh Bandewar <maheshb@google.com>
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
arch/arm/include/asm/atomic.h
arch/arm/include/asm/hardirq.h
arch/arm/kernel/smp.c
Use <asm/opcodes.h> to correctly transform instruction byte ordering
into in-memory ordering.
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
on x86 system with net.core.bpf_jit_enable = 1
sudo tcpdump -i eth1 'tcp port 22'
causes the warning:
[ 56.766097] Possible unsafe locking scenario:
[ 56.766097]
[ 56.780146] CPU0
[ 56.786807] ----
[ 56.793188] lock(&(&vb->lock)->rlock);
[ 56.799593] <Interrupt>
[ 56.805889] lock(&(&vb->lock)->rlock);
[ 56.812266]
[ 56.812266] *** DEADLOCK ***
[ 56.812266]
[ 56.830670] 1 lock held by ksoftirqd/1/13:
[ 56.836838] #0: (rcu_read_lock){.+.+..}, at: [<ffffffff8118f44c>] vm_unmap_aliases+0x8c/0x380
[ 56.849757]
[ 56.849757] stack backtrace:
[ 56.862194] CPU: 1 PID: 13 Comm: ksoftirqd/1 Not tainted 3.12.0-rc3+ #45
[ 56.868721] Hardware name: System manufacturer System Product Name/P8Z77 WS, BIOS 3007 07/26/2012
[ 56.882004] ffffffff821944c0 ffff88080bbdb8c8 ffffffff8175a145 0000000000000007
[ 56.895630] ffff88080bbd5f40 ffff88080bbdb928 ffffffff81755b14 0000000000000001
[ 56.909313] ffff880800000001 ffff880800000000 ffffffff8101178f 0000000000000001
[ 56.923006] Call Trace:
[ 56.929532] [<ffffffff8175a145>] dump_stack+0x55/0x76
[ 56.936067] [<ffffffff81755b14>] print_usage_bug+0x1f7/0x208
[ 56.942445] [<ffffffff8101178f>] ? save_stack_trace+0x2f/0x50
[ 56.948932] [<ffffffff810cc0a0>] ? check_usage_backwards+0x150/0x150
[ 56.955470] [<ffffffff810ccb52>] mark_lock+0x282/0x2c0
[ 56.961945] [<ffffffff810ccfed>] __lock_acquire+0x45d/0x1d50
[ 56.968474] [<ffffffff810cce6e>] ? __lock_acquire+0x2de/0x1d50
[ 56.975140] [<ffffffff81393bf5>] ? cpumask_next_and+0x55/0x90
[ 56.981942] [<ffffffff810cef72>] lock_acquire+0x92/0x1d0
[ 56.988745] [<ffffffff8118f52a>] ? vm_unmap_aliases+0x16a/0x380
[ 56.995619] [<ffffffff817628f1>] _raw_spin_lock+0x41/0x50
[ 57.002493] [<ffffffff8118f52a>] ? vm_unmap_aliases+0x16a/0x380
[ 57.009447] [<ffffffff8118f52a>] vm_unmap_aliases+0x16a/0x380
[ 57.016477] [<ffffffff8118f44c>] ? vm_unmap_aliases+0x8c/0x380
[ 57.023607] [<ffffffff810436b0>] change_page_attr_set_clr+0xc0/0x460
[ 57.030818] [<ffffffff810cfb8d>] ? trace_hardirqs_on+0xd/0x10
[ 57.037896] [<ffffffff811a8330>] ? kmem_cache_free+0xb0/0x2b0
[ 57.044789] [<ffffffff811b59c3>] ? free_object_rcu+0x93/0xa0
[ 57.051720] [<ffffffff81043d9f>] set_memory_rw+0x2f/0x40
[ 57.058727] [<ffffffff8104e17c>] bpf_jit_free+0x2c/0x40
[ 57.065577] [<ffffffff81642cba>] sk_filter_release_rcu+0x1a/0x30
[ 57.072338] [<ffffffff811108e2>] rcu_process_callbacks+0x202/0x7c0
[ 57.078962] [<ffffffff81057f17>] __do_softirq+0xf7/0x3f0
[ 57.085373] [<ffffffff81058245>] run_ksoftirqd+0x35/0x70
cannot reuse jited filter memory, since it's readonly,
so use original bpf insns memory to hold work_struct
defer kfree of sk_filter until jit completed freeing
tested on x86_64 and i386
Follow-up on module_free()/vfree() that takes care of the rest, so no
longer this workaround with work_struct needed.
If bpf_jit_enable > 1, then we dump the emitted JIT compiled image
after creation. Currently, only SPARC and PowerPC has similar output
as in the reference implementation on x86_64. Make a small helper
function in order to reduce duplicated code and make the dump output
uniform across architectures x86_64, SPARC, PPC, ARM (e.g. on ARM
flen, pass and proglen are currently not shown, but would be
interesting to know as well), also for future BPF JIT implementations
on other archs.
Cc: Eric Dumazet <eric.dumazet@google.com>
k is u32 which never < 0, need type cast, or cause issue.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
The original code was generating an lsl instructions using the value
of ARM_R8 (skb_headlen, possibly uninitialized if no skb_headlen
access was required) as a shift amount.
Pull networking changes from David Miller:
1) Allow to dump, monitor, and change the bridge multicast database
using netlink. From Cong Wang.
2) RFC 5961 TCP blind data injection attack mitigation, from Eric
Dumazet.
3) Networking user namespace support from Eric W. Biederman.
4) tuntap/virtio-net multiqueue support by Jason Wang.
5) Support for checksum offload of encapsulated packets (basically,
tunneled traffic can still be checksummed by HW). From Joseph
Gasparakis.
6) Allow BPF filter access to VLAN tags, from Eric Dumazet and
Daniel Borkmann.
7) Bridge port parameters over netlink and BPDU blocking support
from Stephen Hemminger.
8) Improve data access patterns during inet socket demux by rearranging
socket layout, from Eric Dumazet.
9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and
Jon Maloy.
10) Update TCP socket hash sizing to be more in line with current day
realities. The existing heurstics were choosen a decade ago.
From Eric Dumazet.
11) Fix races, queue bloat, and excessive wakeups in ATM and
associated drivers, from Krzysztof Mazur and David Woodhouse.
12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions
in VXLAN driver, from David Stevens.
13) Add "oops_only" mode to netconsole, from Amerigo Wang.
14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also
allow DCB netlink to work on namespaces other than the initial
namespace. From John Fastabend.
15) Support PTP in the Tigon3 driver, from Matt Carlson.
16) tun/vhost zero copy fixes and improvements, plus turn it on
by default, from Michael S. Tsirkin.
17) Support per-association statistics in SCTP, from Michele
Baldessari.
And many, many, driver updates, cleanups, and improvements. Too
numerous to mention individually.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
net/mlx4_en: Add support for destination MAC in steering rules
net/mlx4_en: Use generic etherdevice.h functions.
net: ethtool: Add destination MAC address to flow steering API
bridge: add support of adding and deleting mdb entries
bridge: notify mdb changes via netlink
ndisc: Unexport ndisc_{build,send}_skb().
uapi: add missing netconf.h to export list
pkt_sched: avoid requeues if possible
solos-pci: fix double-free of TX skb in DMA mode
bnx2: Fix accidental reversions.
bna: Driver Version Updated to 3.1.2.1
bna: Firmware update
bna: Add RX State
bna: Rx Page Based Allocation
bna: TX Intr Coalescing Fix
bna: Tx and Rx Optimizations
bna: Code Cleanup and Enhancements
ath9k: check pdata variable before dereferencing it
ath5k: RX timestamp is reported at end of frame
ath9k_htc: RX timestamp is reported at end of frame
The offset must be multiplied by 4 to be sure to access the correct
32bit word in the stack scratch space.
For instance, a store at scratch memory cell #1 was generating the
following:
st r4, [sp, #1]
While the correct code for this is:
st r4, [sp, #4]
To reproduce the bug (assuming your system has a NIC with the mac
address 52:54:00:12:34:56):
echo 0 > /proc/sys/net/core/bpf_jit_enable
tcpdump -ni eth0 "ether[1] + ether[2] - ether[3] * ether[4] - ether[5] \
== -0x3AA" # this will capture packets as expected
echo 1 > /proc/sys/net/core/bpf_jit_enable
== -0x3AA" # this will not.
This bug was present since the original inclusion of bpf_jit for ARM
(ddecdfce: ARM: 7259/3: net: JIT compiler for packet filters).
Official prototype for kzalloc is:
void *kzalloc(size_t, gfp_t);
The ARM bpf_jit code was having the assumption that it was:
void *kzalloc(gfp_t, size);
This was resulting the use of some random GFP flags depending on the
size requested and some random overflows once the really needed size
was more than the value of GFP_KERNEL.
This patch is a follow-up for patch "net: filter: add vlan tag access"
to support the new VLAN_TAG/VLAN_TAG_PRESENT accessors in BPF JIT.
Signed-off-by: Daniel Borkmann <daniel.borkmann@tik.ee.ethz.ch>
