path: root/arch/arm/nwfpe/fpa11_cpdt.c
2008-09-06[ARM] Convert asm/uaccess.h to linux/uaccess.hRussell King
2005-11-07[ARM] 3118/1: fix and reenable nwfpe extended precision emulation for big-endianLennert Buytenhek
Patch from Lennert Buytenhek nwfpe extended precision emulation used to be broken on big-endian and was therefore disabled. This patch fixes nwfpe so that it copies extended precision floats to/from userspace in the proper word order (similar to patch #2046, see the description of that patch for an explanation) and reenables the Kconfig option. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-03[PATCH] ARM: 2837/2: Re: ARM: Make NWFPE preempt safeRichard Purdie
Patch from Richard Purdie NWFPE used global variables which meant it wasn't safe for use with preemptive kernels. This patch removes them and communicates the information between functions in a preempt safe manner. Generation of some exceptions was broken and this has also been corrected. Tests with glibc's maths test suite show no change in the results before/after this patch. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
