path: root/arch/arm/nwfpe
2010-10-18Update broken web addresses in arch directory.Justin P. Mattock
The patch below updates broken web addresses in the arch directory. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-24ARM: arch/arm/nwfpe/fpsr.h: Checkpatch cleanupAndrea Gelmini
arch/arm/nwfpe/fpsr.h:33: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-24ARM: arch/arm/nwfpe/ChangeLog: Checkpatch cleanupAndrea Gelmini
arch/arm/nwfpe/ChangeLog:75: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-05-15ARM: nwfpe: allow debugging output to be configured at runtimeRussell King
Enabling CONFIG_USER_DEBUG allows NWFPE to complain about every FP exception, which with some programs can cause the kernel message log to fill with NWFPE debug, swamping out other messages. This change allows NWFPE debugging to be configured at run time. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-21ARM: fix build error in arch/arm/kernel/process.cRussell King
/tmp/ccJ3ssZW.s: Assembler messages: /tmp/ccJ3ssZW.s:1952: Error: can't resolve `.text' {.text section} - `.LFB1077' This is caused because: .section .data .section .text .section .text .previous does not return us to the .text section, but the .data section; this makes use of .previous dangerous if the ordering of previous sections is not known. Fix up the other users of .previous; .pushsection and .popsection are a safer pairing to use than .section and .previous. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-15[ARM] nwfpe: fix 'floatx80_is_nan' sparse warningBen Dooks
The symbol 'floatx80_is_nan' prototype was defined locally in fpa11_cprt.c when it was built outside the file in softfloat-specialisze. Move this into softfloat.h to fix the following sparse warning: softfloat-specialize:276:6: warning: symbol 'floatx80_is_nan' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-15[ARM] nwfpe: Add decleration for ExtendedCPDOBen Dooks
Add header file decleration for 'ExtendedCPDO' in fpa11.h to stop the following sparse warning: extended_cpdo.c:90:14: warning: symbol 'ExtendedCPDO' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-09-06[ARM] Convert asm/uaccess.h to linux/uaccess.hRussell King
2008-08-02[ARM] move include/asm-arm to arch/arm/include/asmRussell King
Move platform independent header files to arch/arm/include/asm, leaving those in asm/arch* and asm/plat* alone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18Replace __attribute_pure__ with __pureRalf Baechle
To be consistent with the use of attributes in the rest of the kernel replace all use of __attribute_pure__ with __pure and delete the definition of __attribute_pure__. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[ARM] 4581/1: Fix the conditional execution of the NWFPE instructionsCatalin Marinas
Starting with ARMv7-A, conditional execution of undefined instructions can trigger an exception even if the condition check fails. This patch modifies the NWFPE support to check the condition before emulating the instruction. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] "extern inline" -> "static inline"Adrian Bunk
"extern inline" will have different semantics with gcc 4.3. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-31Remove the arm26 portAdrian Bunk
The arm26 port has been in a state where it was far from even compiling for quite some time. Ian Molton agreed with the removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-30[ARM] 4416/1: NWFPE: fix undeclared symbolsBen Dooks
Fix the undeclared symbols sparse is warning about. arch/arm/nwfpe/softfloat.c:1727:7: warning: symbol 'float64_to_uint32' was not declared. Should it be static? arch/arm/nwfpe/softfloat.c:1753:7: warning: symbol 'float64_to_uint32_round_to_zero' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-13[ARM] 3729/3: EABI padding rules necessitate the packed attribute of floatx80Koen Kooi
Patch from Koen Kooi EABI padding rules necessitate the packed attribute of floatx80, otherwise nwfpe complains about invalid structure sizes. Signed-off-by: Koen Kooi <koen@dominion.kabel.utwente.nl> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove MODE_(SVC|IRQ|FIQ|USR) and DEFAULT_FIQRussell King
DEFAULT_FIQ was entirely unused. MODE_* are just redefinitions of *_MODE. Use *_MODE instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] Add thread_notify infrastructureRussell King
Some machine classes need to allow VFP support to be built into the kernel, but still allow the kernel to run even though VFP isn't present. Unfortunately, the kernel hard-codes VFP instructions into the thread switch, which prevents this being run-time selectable. Solve this by introducing a notifier which things such as VFP can hook into to be informed of events which affect the VFP subsystem (eg, creation and destruction of threads, switches between threads.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3111/2: old ABI compat: adjust NWFPE to be operational within an EABI ↵Nicolas Pitre
kernel Patch from Nicolas Pitre We need NWFPE if we want to support execution of legacy binaries with an EABI kernel. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[ARM] 3118/1: fix and reenable nwfpe extended precision emulation for big-endianLennert Buytenhek
Patch from Lennert Buytenhek nwfpe extended precision emulation used to be broken on big-endian and was therefore disabled. This patch fixes nwfpe so that it copies extended precision floats to/from userspace in the proper word order (similar to patch #2046, see the description of that patch for an explanation) and reenables the Kconfig option. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[ARM] 3117/1: nwfpe kernel memory info leakLennert Buytenhek
Patch from Lennert Buytenhek The routine that nwfpe uses for converting floats/doubles to extended precision fails to zero two bytes of kernel stack. This is not immediately obvious, as the floatx80 structure has 16 bits of implicit padding (by design.) These two bytes are copied to userspace when an stfe is emulated, causing a possible info leak. Make the padding explicit and zero it out in the relevant places. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-12[ARM] 2978/1: nwfpe - clean up sparse errorsBen Dooks
Patch from Ben Dooks The NWFPE is producing a number of errors from sparse due to not defining a number of functions in the header files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-09kbuild: arm - use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted stuff from arch Makefile and rename constants.h to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-08-23[PATCH] qualifiers in return types - easy casesAl Viro
a bunch of functions switched from volatile to __attribute__((noreturn)) and from const to __attribute_pure__ Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-15[PATCH] ARM: 2851/1: Fix NWFPE extended precision exception handlingRichard Purdie
Patch from Richard Purdie The exception handling code fails to compile if the extended precision mode is enabled. This patch fixes those compile errors and also stops _quiet functions from incorrectly raising exceptions. Reported-by: Ralph Siemsen <ralphs@netwinder.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-03[PATCH] ARM: 2837/2: Re: ARM: Make NWFPE preempt safeRichard Purdie
Patch from Richard Purdie NWFPE used global variables which meant it wasn't safe for use with preemptive kernels. This patch removes them and communicates the information between functions in a preempt safe manner. Generation of some exceptions was broken and this has also been corrected. Tests with glibc's maths test suite show no change in the results before/after this patch. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-17[PATCH] ARM: Remove global nwfpe register variableRussell King
Recent changes to nwfpe broke the build with some gcc versions: In file included from arch/arm/nwfpe/softfloat.c:33: arch/arm/nwfpe/fpa11.h:32: global register variable follows a function definition make[1]: *** [arch/arm/nwfpe/softfloat.o] Error 1 Since we now ensure that the kernel stack is empty when returning to user space, we can now access the userspace registers with reference to the kernel stack using current_thread_info(), rather than remembering the stack pointer at the time nwfpe was called. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-11[PATCH] ARM: remove linux/version.h include from arch/armOlaf Hering
Changing CONFIG_LOCALVERSION rebuilds too much, for no appearent reason. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-23[PATCH] ARM: 2722/1: remove reliance on udivdi3 for nwfpeNicolas Pitre
Patch from Nicolas Pitre Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
