path: root/arch/arm/nwfpe
2019-05-24treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 61Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not write to the free software foundation inc 675 mass ave cambridge ma 02139 usa extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 441 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190520071858.739733335@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-09treewide: Switch printk users from %pf and %pF to %ps and %pS, respectivelySakari Ailus
%pF and %pf are functionally equivalent to %pS and %ps conversion specifiers. The former are deprecated, therefore switch the current users to use the preferred variant. The changes have been produced by the following command: git grep -l '%p[fF]' | grep -v '^\(tools\|Documentation\)/' | \ while read i; do perl -i -pe 's/%pf/%ps/g; s/%pF/%pS/g;' $i; done And verifying the result. Link: http://lkml.kernel.org/r/20190325193229.23390-1-sakari.ailus@linux.intel.com Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: linux-arm-kernel@lists.infradead.org Cc: sparclinux@vger.kernel.org Cc: linux-um@lists.infradead.org Cc: xen-devel@lists.xenproject.org Cc: linux-acpi@vger.kernel.org Cc: linux-pm@vger.kernel.org Cc: drbd-dev@lists.linbit.com Cc: linux-block@vger.kernel.org Cc: linux-mmc@vger.kernel.org Cc: linux-nvdimm@lists.01.org Cc: linux-pci@vger.kernel.org Cc: linux-scsi@vger.kernel.org Cc: linux-btrfs@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: linux-mm@kvack.org Cc: ceph-devel@vger.kernel.org Cc: netdev@vger.kernel.org Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com> Acked-by: David Sterba <dsterba@suse.com> (for btrfs) Acked-by: Mike Rapoport <rppt@linux.ibm.com> (for mm/memblock.c) Acked-by: Bjorn Helgaas <bhelgaas@google.com> (for drivers/pci) Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-03sched/headers: Move task_struct::signal and task_struct::sighand types and ↵Ingo Molnar
accessors into <linux/sched/signal.h> task_struct::signal and task_struct::sighand are pointers, which would normally make it straightforward to not define those types in sched.h. That is not so, because the types are accompanied by a myriad of APIs (macros and inline functions) that dereference them. Split the types and the APIs out of sched.h and move them into a new header, <linux/sched/signal.h>. With this change sched.h does not know about 'struct signal' and 'struct sighand' anymore, trying to put accessors into sched.h as a test fails the following way: ./include/linux/sched.h: In function ‘test_signal_types’: ./include/linux/sched.h:2461:18: error: dereferencing pointer to incomplete type ‘struct signal_struct’ ^ This reduces the size and complexity of sched.h significantly. Update all headers and .c code that relied on getting the signal handling functionality from <linux/sched.h> to include <linux/sched/signal.h>. The list of affected files in the preparatory patch was partly generated by grepping for the APIs, and partly by doing coverage build testing, both all[yes|mod|def|no]config builds on 64-bit and 32-bit x86, and an array of cross-architecture builds. Nevertheless some (trivial) build breakage is still expected related to rare Kconfig combinations and in-flight patches to various kernel code, but most of it should be handled by this patch. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-09ARM: swpan: fix nwfpe for uaccess changesRussell King
NWFPE needs to access userspace to check whether the next instruction is another FP instruction. Allow userspace access for this read. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-03-29ARM: 8322/1: keep .text and .fixup regions closer togetherArd Biesheuvel
This moves all fixup snippets to the .text.fixup section, which is a special section that gets emitted along with the .text section for each input object file, i.e., the snippets are kept much closer to the code they refer to, which helps prevent linker failure on large kernels. Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-11-21ARM: drop nwfpe initialisation message from warning to info levelRussell King
nwfpe's initialisation message is not a warning, it is purely informational. Print it at the appropriate message level. Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-11-21ARM: convert printk(KERN_* to pr_*Russell King
Convert many (but not all) printk(KERN_* to pr_* to simplify the code. We take the opportunity to join some printk lines together so we don't split the message across several lines, and we also add a few levels to some messages which were previously missing them. Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-07-18ARM: convert all "mov.* pc, reg" to "bx reg" for ARMv6+Russell King
ARMv6 and greater introduced a new instruction ("bx") which can be used to return from function calls. Recent CPUs perform better when the "bx lr" instruction is used rather than the "mov pc, lr" instruction, and this sequence is strongly recommended to be used by the ARM architecture manual (section A.4.1.1). We provide a new macro "ret" with all its variants for the condition code which will resolve to the appropriate instruction. Rather than doing this piecemeal, and miss some instances, change all the "mov pc" instances to use the new macro, with the exception of the "movs" instruction and the kprobes code. This allows us to detect the "mov pc, lr" case and fix it up - and also gives us the possibility of deploying this for other registers depending on the CPU selection. Reported-by: Will Deacon <will.deacon@arm.com> Tested-by: Stephen Warren <swarren@nvidia.com> # Tegra Jetson TK1 Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> # mioa701_bootresume.S Tested-by: Andrew Lunn <andrew@lunn.ch> # Kirkwood Tested-by: Shawn Guo <shawn.guo@freescale.com> Tested-by: Tony Lindgren <tony@atomide.com> # OMAPs Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> # Armada XP, 375, 385 Acked-by: Sekhar Nori <nsekhar@ti.com> # DaVinci Acked-by: Christoffer Dall <christoffer.dall@linaro.org> # kvm/hyp Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> # PXA3xx Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> # Xen Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> # ARMv7M Tested-by: Simon Horman <horms+renesas@verge.net.au> # Shmobile Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-08Merge branch 'master' into for-nextJiri Kosina
Merge with latest Linus' tree, as I have incoming patches that fix code that is newer than current HEAD of for-next. Conflicts: drivers/net/ethernet/realtek/r8169.c
2012-04-05arm: Use vsprintf extention %pf with builtin_return_addressJoe Perches
Emit the function name not the address when possible. builtin_return_address() gives an address. When building a kernel with CONFIG_KALLSYMS, emit the actual function name not the address. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2011-12-13ARM: 7207/1: Use generic ARM instruction set condition code checks for nwfpe.Leif Lindholm
This patch changes the nwfpe implementation to use the new generic ARM instruction set condition code checks, rather than a local implementation. It also removes the existing condition code checking, which has been used for the generic support (in kernel/opcodes.{ch}). This code has not been tested beyond building, linking and booting. Signed-off-by: Leif Lindholm <leif.lindholm@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-18Update broken web addresses in arch directory.Justin P. Mattock
The patch below updates broken web addresses in the arch directory. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-24ARM: arch/arm/nwfpe/fpsr.h: Checkpatch cleanupAndrea Gelmini
arch/arm/nwfpe/fpsr.h:33: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-24ARM: arch/arm/nwfpe/ChangeLog: Checkpatch cleanupAndrea Gelmini
arch/arm/nwfpe/ChangeLog:75: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-05-15ARM: nwfpe: allow debugging output to be configured at runtimeRussell King
Enabling CONFIG_USER_DEBUG allows NWFPE to complain about every FP exception, which with some programs can cause the kernel message log to fill with NWFPE debug, swamping out other messages. This change allows NWFPE debugging to be configured at run time. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-21ARM: fix build error in arch/arm/kernel/process.cRussell King
/tmp/ccJ3ssZW.s: Assembler messages: /tmp/ccJ3ssZW.s:1952: Error: can't resolve `.text' {.text section} - `.LFB1077' This is caused because: .section .data .section .text .section .text .previous does not return us to the .text section, but the .data section; this makes use of .previous dangerous if the ordering of previous sections is not known. Fix up the other users of .previous; .pushsection and .popsection are a safer pairing to use than .section and .previous. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-15[ARM] nwfpe: fix 'floatx80_is_nan' sparse warningBen Dooks
The symbol 'floatx80_is_nan' prototype was defined locally in fpa11_cprt.c when it was built outside the file in softfloat-specialisze. Move this into softfloat.h to fix the following sparse warning: softfloat-specialize:276:6: warning: symbol 'floatx80_is_nan' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-15[ARM] nwfpe: Add decleration for ExtendedCPDOBen Dooks
Add header file decleration for 'ExtendedCPDO' in fpa11.h to stop the following sparse warning: extended_cpdo.c:90:14: warning: symbol 'ExtendedCPDO' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-09-06[ARM] Convert asm/uaccess.h to linux/uaccess.hRussell King
2008-08-02[ARM] move include/asm-arm to arch/arm/include/asmRussell King
Move platform independent header files to arch/arm/include/asm, leaving those in asm/arch* and asm/plat* alone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18Replace __attribute_pure__ with __pureRalf Baechle
To be consistent with the use of attributes in the rest of the kernel replace all use of __attribute_pure__ with __pure and delete the definition of __attribute_pure__. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[ARM] 4581/1: Fix the conditional execution of the NWFPE instructionsCatalin Marinas
Starting with ARMv7-A, conditional execution of undefined instructions can trigger an exception even if the condition check fails. This patch modifies the NWFPE support to check the condition before emulating the instruction. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] "extern inline" -> "static inline"Adrian Bunk
"extern inline" will have different semantics with gcc 4.3. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-31Remove the arm26 portAdrian Bunk
The arm26 port has been in a state where it was far from even compiling for quite some time. Ian Molton agreed with the removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-30[ARM] 4416/1: NWFPE: fix undeclared symbolsBen Dooks
Fix the undeclared symbols sparse is warning about. arch/arm/nwfpe/softfloat.c:1727:7: warning: symbol 'float64_to_uint32' was not declared. Should it be static? arch/arm/nwfpe/softfloat.c:1753:7: warning: symbol 'float64_to_uint32_round_to_zero' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-13[ARM] 3729/3: EABI padding rules necessitate the packed attribute of floatx80Koen Kooi
Patch from Koen Kooi EABI padding rules necessitate the packed attribute of floatx80, otherwise nwfpe complains about invalid structure sizes. Signed-off-by: Koen Kooi <koen@dominion.kabel.utwente.nl> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove MODE_(SVC|IRQ|FIQ|USR) and DEFAULT_FIQRussell King
DEFAULT_FIQ was entirely unused. MODE_* are just redefinitions of *_MODE. Use *_MODE instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] Add thread_notify infrastructureRussell King
Some machine classes need to allow VFP support to be built into the kernel, but still allow the kernel to run even though VFP isn't present. Unfortunately, the kernel hard-codes VFP instructions into the thread switch, which prevents this being run-time selectable. Solve this by introducing a notifier which things such as VFP can hook into to be informed of events which affect the VFP subsystem (eg, creation and destruction of threads, switches between threads.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3111/2: old ABI compat: adjust NWFPE to be operational within an EABI ↵Nicolas Pitre
kernel Patch from Nicolas Pitre We need NWFPE if we want to support execution of legacy binaries with an EABI kernel. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[ARM] 3118/1: fix and reenable nwfpe extended precision emulation for big-endianLennert Buytenhek
Patch from Lennert Buytenhek nwfpe extended precision emulation used to be broken on big-endian and was therefore disabled. This patch fixes nwfpe so that it copies extended precision floats to/from userspace in the proper word order (similar to patch #2046, see the description of that patch for an explanation) and reenables the Kconfig option. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[ARM] 3117/1: nwfpe kernel memory info leakLennert Buytenhek
Patch from Lennert Buytenhek The routine that nwfpe uses for converting floats/doubles to extended precision fails to zero two bytes of kernel stack. This is not immediately obvious, as the floatx80 structure has 16 bits of implicit padding (by design.) These two bytes are copied to userspace when an stfe is emulated, causing a possible info leak. Make the padding explicit and zero it out in the relevant places. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-12[ARM] 2978/1: nwfpe - clean up sparse errorsBen Dooks
Patch from Ben Dooks The NWFPE is producing a number of errors from sparse due to not defining a number of functions in the header files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-09kbuild: arm - use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted stuff from arch Makefile and rename constants.h to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-08-23[PATCH] qualifiers in return types - easy casesAl Viro
a bunch of functions switched from volatile to __attribute__((noreturn)) and from const to __attribute_pure__ Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-15[PATCH] ARM: 2851/1: Fix NWFPE extended precision exception handlingRichard Purdie
Patch from Richard Purdie The exception handling code fails to compile if the extended precision mode is enabled. This patch fixes those compile errors and also stops _quiet functions from incorrectly raising exceptions. Reported-by: Ralph Siemsen <ralphs@netwinder.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-03[PATCH] ARM: 2837/2: Re: ARM: Make NWFPE preempt safeRichard Purdie
Patch from Richard Purdie NWFPE used global variables which meant it wasn't safe for use with preemptive kernels. This patch removes them and communicates the information between functions in a preempt safe manner. Generation of some exceptions was broken and this has also been corrected. Tests with glibc's maths test suite show no change in the results before/after this patch. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-17[PATCH] ARM: Remove global nwfpe register variableRussell King
Recent changes to nwfpe broke the build with some gcc versions: In file included from arch/arm/nwfpe/softfloat.c:33: arch/arm/nwfpe/fpa11.h:32: global register variable follows a function definition make[1]: *** [arch/arm/nwfpe/softfloat.o] Error 1 Since we now ensure that the kernel stack is empty when returning to user space, we can now access the userspace registers with reference to the kernel stack using current_thread_info(), rather than remembering the stack pointer at the time nwfpe was called. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-11[PATCH] ARM: remove linux/version.h include from arch/armOlaf Hering
Changing CONFIG_LOCALVERSION rebuilds too much, for no appearent reason. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-23[PATCH] ARM: 2722/1: remove reliance on udivdi3 for nwfpeNicolas Pitre
Patch from Nicolas Pitre Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
