The stack frame for Android is slightly different than that used
for vanilla Linux.
Bug 935536
Signed-off-by: Ryan V. Bissell <rbissell@nvidia.com>
Reviewed-on: http://git-master/r/82600
(cherry picked from commit bb6d1e211bdb41c129ee17489814327d7d8d2fb8)
Change-Id: Ie0e924d45398c7def58e3722035911d905614b6f
Reviewed-on: http://git-master/r/89507
Reviewed-by: Oleg Strikov <ostrikov@nvidia.com>
Reviewed-by: Janne Hellsten <jhellsten@nvidia.com>
Tested-by: Ryan Bissell <rbissell@nvidia.com>
commit 55205c916e179e09773d98d290334d319f45ac6b upstream.
This change fixes a linking problem, which happens if oprofile
is selected to be compiled as built-in:
`oprofile_arch_exit' referenced in section `.init.text' of
arch/arm/oprofile/built-in.o: defined in discarded section
`.exit.text' of arch/arm/oprofile/built-in.o
The problem is appeared after commit 87121ca504, which
introduced oprofile_arch_exit() calls from __init function. Note
that the aforementioned commit has been backported to stable
branches, and the problem is known to be reproduced at least
with 3.0.13 and 3.1.5 kernels.
Signed-off-by: Vladimir Zapolskiy <vladimir.zapolskiy@nokia.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: oprofile-list <oprofile-list@lists.sourceforge.net>
Link: http://lkml.kernel.org/r/20111222151540.GB16765@erda.amd.com
Change-Id: I6a8f198e5d3573276fba8efa3d2e006da5f02e1f
Reviewed-on: http://git-master/r/74197
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix text_poke_smp_batch() deadlock
perf tools: Fix thread_map event synthesizing in top and record
watchdog, nmi: Lower the severity of error messages
ARM: oprofile: Fix backtraces in timer mode
oprofile: Fix usage of CONFIG_HW_PERF_EVENTS for oprofile_perf_init and friends
Since tail is the previous fp - 1, we need to compare the new fp with tail + 1
to ensure that we don't end up passing in the same tail again, in order to
avoid a potential infinite loop in the perf interrupt handler (which has been
observed to occur). A similar fix seems to be needed in the OProfile code.
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Always allow backtraces when using oprofile on ARM, even if a PMU
isn't present. Restores functionality originally introduced in commit
1b7b56982fdcd9d85effd76f3928cf5d6eb26155 ("oprofile: Always allow
backtraces on ARM") by Richard Purdie.
It is not that obvious, but there is now only one oprofile_arch_init()
function. So the .backtrace callback is available also in timer mode.
Implemented by removing code and using stubs for oprofile_perf_{init,
exit} provided by <linux/oprofile.h>. This allows cleaning of other
architecture specific implementations too.
Cc: stable@kernel.org # 37.x
Signed-off-by: Ari Kauppi <kauppi@papupata.org>
Move the perf-events backend from arch/arm/oprofile into
drivers/oprofile so that the code can be shared between architectures.
This allows each architecture to maintain only a single copy of the PMU
accessor functions instead of one for both perf and OProfile. It also
becomes possible for other architectures to delete much of their
OProfile code in favour of the common code now available in
drivers/oprofile/oprofile_perf.c.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
Tested-by: Will Deacon <will.deacon@arm.com>
In preparation for moving the majority of this oprofile code into an
architecture-neutral place separate the architecture-independent code
into oprofile_perf_init() and oprofile_perf_exit().
In preparation for moving the generic functions out of this file, give
the functions more general names (e.g. remove "arm" from the names).
Make op_name_from_perf_id() global so that we have a way for each
architecture to construct an oprofile name for op->cpu_type. We need to
remove the argument from the function prototype so that we can hide all
implementation details inside the function.
The number of counters for the registered pmu is needed in a few places
so provide a helper function that returns this number.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
The pointers must be NULL'ed to avoid double-freeing the pointers in
rare cases during reinitialization.
Now that oprofile_arch_exit is only called when the OProfile module
is unloaded, it can assume that init completed successfully and not
have to worry about double frees or releasing NULL perf events.
This patch ensures that oprofile_arch_init fails gracefully on ARM
and simplifies the exit code based on the above.
Cc: Robert Richter <robert.richter@amd.com>
Cc: Matt Fleming <matt@console-pimps.org>
This is a reworking of an original patch posted by Aaro Koskinen:
oprofile does not work with PM, because sysdev_suspend() is done with
interrupts disabled and oprofile needs a mutex. Implementing oprofile
as a platform device solves this problem.
Cc: Aaro Koskinen <aaro.koskinen@nokia.com>
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Enable hardware perf-events if CPU_HAS_PMU and select
HAVE_OPROFILE if HAVE_PERF_EVENTS. If no hardware support
is present, OProfile will fall back to timer mode.
This patch also removes the old OProfile drivers in favour
of the code implemented by perf.
There are currently two hardware performance monitoring subsystems in
the kernel for ARM: OProfile and perf-events. This creates the
following problems:
1.) Duplicate PMU accessor code. Inevitable code drift may lead to
bugs in one framework that are fixed in the other.
2.) Locking issues. OProfile doesn't reprogram hardware counters
between profiling runs if the events to be monitored have not been
changed. This means that other profiling frameworks cannot use the
counters if OProfile is in use.
3.) Due to differences in the two frameworks, it may not be possible to
compare the results obtained by OProfile with those obtained by perf.
This patch removes the OProfile PMU driver code and replaces it with
calls to perf, therefore solving the issues mentioned above.
The only userspace-visible change is the lack of SCU counter support
for 11MPCore. This is currently unsupported by OProfile userspace tools anyway and therefore shouldn't cause any problems.
Cc: Jamie Iles <jamie.iles@picochip.com>
Cc: Jean Pihet <jpihet@mvista.com>
Make sure that we have access to the performance counters and
that they aren't being used by perf events or anything else.
Signed-off-by: Jamie Iles <jamie.iles@picochip.com>
On Oprofile ARMv7 the PMNC_D bit was set to lower the PMU IRQs
and so to decrease the risk of errata #628216 from appearing.
The effect of setting the PMNC_D bit is that the CCNT counter
is divided by 64, making the program counter events count
inaccurate.
The new OMAP3 r4 cores should have that errata fixed.
The PMNC_D bit should not be set, this patch fixes it.
Signed-off-by: Jean Pihet <jpihet@mvista.com>
add oprofile pmu support for bcmring.
Signed-off-by: Leo Hao Chen <leochen@broadcom.com>
The IRQ_* macros need to be made visible via the mach/irqs.h file but
without the additional macros defined in the board-*.h files.
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (422 commits)
[ARM] 5435/1: fix compile warning in sanity_check_meminfo()
[ARM] 5434/1: ARM: OMAP: Fix mailbox compile for 24xx
[ARM] pxa: fix the bad assumption that PCMCIA sockets always start with 0
[ARM] pxa: fix Colibri PXA300 and PXA320 LCD backlight pins
imxfb: Fix TFT mode
i.MX21/27: remove ifdef CONFIG_FB_IMX
imxfb: add clock support
mxc: add arch_reset() function
clkdev: add possibility to get a clock based on the device name
i.MX1: remove fb support from mach-imx
[ARM] pxa: build arch/arm/plat-pxa/mfp.c only when PXA3xx or ARCH_MMP defined
Gemini: Add support for Teltonika RUT100
Gemini: gpiolib based GPIO support v2
MAINTAINERS: add myself as Gemini architecture maintainer
ARM: Add Gemini architecture v3
[ARM] OMAP: Fix compile for omap2_init_common_hw()
MAINTAINERS: Add myself as Faraday ARM core variant maintainer
ARM: Add support for FA526 v2
[ARM] acorn,ebsa110,footbridge,integrator,sa1100: Convert asm/io.h to linux/io.h
[ARM] collie: fix two minor formatting nits
This patch changes the walk_stacktrace and its callers for easier
integration of stack unwinding. The arch/arm/kernel/stacktrace.h file is
also moved to arch/arm/include/asm/stacktrace.h.
Impact: cleanup, update to new cpumask API
Irq_desc.affinity and irq_desc.pending_mask are now cpumask_var_t's
so access to them should be using the new cpumask API.
Signed-off-by: Mike Travis <travis@sgi.com>
Impact: change existing irq_chip API
Not much point with gentle transition here: the struct irq_chip's
setaffinity method signature needs to change.
Fortunately, not widely used code, but hits a few architectures.
Note: In irq_select_affinity() I save a temporary in by mangling
irq_desc[irq].affinity directly. Ingo, does this break anything?
(Folded in fix from KOSAKI Motohiro)
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Acked-by: Ingo Molnar <mingo@redhat.com>
Cc: ralf@linux-mips.org
Cc: grundler@parisc-linux.org
Cc: jeremy@xensource.com
Add Oprofile kernel support for ARMv7.
Tested on OMAP3430 and OMAP3530 chipsets (Cortex-A8).
Add asm/cputype.h, moving functions and definitions from asm/system.h
there. Convert all users of 'processor_id' to the more efficient
read_cpuid_id() function.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
It's never used and the comments refer to nonatomic and retry
interchangably. So get rid of it.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
This patch fixes the Oprofile for ARM11MPCore compilation introduced by
changes to the RealView code. Only RealView/EB is supported.
All kobjects require a dynamically allocated name now. We no longer
need to keep track if the name is statically assigned, we can just
unconditionally free() all kobject names on cleanup.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Quoting Randy:
"It seems sad that this patch sources Kconfig.marker, a 7-line file,
20-something times. Yes, you (we) don't want to put those 7 lines into
20-something different files, so sourcing is the right thing.
However, what you did for avr32 seems more on the right track to me: make
_one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES,
and MARKERS and then use (source) that in all of the arches."
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
BUG: using smp_processor_id() in preemptible [00000001] code: opcontrol/427
Resolve this bug by ensuring that we're not using smp_processor_id() in
a preemptable context (by disabling preemption.)
Fix lockdep warnings, caused by 'set_affinity' being called without
the correct locks taken and local interrupts disabled:
[ INFO: inconsistent lock state ]
2.6.22-rc2 #1
inconsistent {in-hardirq-W} -> {hardirq-on-W} usage.
swapper/1 [HC0[0]:SC0[0]:HE1:SE1] takes:
(irq_controller_lock){++..}, at: [<c002be50>] gic_set_cpu+0x60/0xa0
{in-hardirq-W} state was registered at:
[<c005d9a8>] lock_acquire+0x58/0x6c
[<c0233068>] _spin_lock+0x40/0x50
[<c002c020>] gic_mask_irq+0x2c/0x6c
[<c0069c64>] handle_level_irq+0x11c/0x14c
[<c0020060>] asm_do_IRQ+0x60/0x84
[<c0020d2c>] __irq_svc+0x4c/0xc0
[<c000ed84>] __alloc_bootmem_nopanic+0x74/0x88
[<c000edb0>] __alloc_bootmem+0x18/0x3c
[<c000fa00>] alloc_large_system_hash+0x16c/0x200
[<c00108dc>] inode_init_early+0x5c/0xa4
[<c00106dc>] vfs_caches_init_early+0x24/0xa0
[<c0008e54>] start_kernel+0x220/0x2fc
[<00008078>] 0x8078
irq event stamp: 88438
hardirqs last enabled at (88438): [<c0020dc0>] preempt_return+0x20/0x2c
hardirqs last disabled at (88436): [<c00417bc>] __do_softirq+0xb0/0x138
softirqs last enabled at (88437): [<c0041810>] __do_softirq+0x104/0x138
softirqs last disabled at (88428): [<c0041d9c>] irq_exit+0x68/0x7c
no locks held by swapper/1.
stack backtrace:
[<c0025ecc>] (dump_stack+0x0/0x14) from [<c005b1e4>] (print_usage_bug+0x138/0x168)
[<c005b0ac>] (print_usage_bug+0x0/0x168) from [<c005be80>] (mark_lock+0x484/0x6a0)
[<c005b9fc>] (mark_lock+0x0/0x6a0) from [<c005cc48>] (__lock_acquire+0x3c0/0x10c8)
[<c005c888>] (__lock_acquire+0x0/0x10c8) from [<c005d9a8>] (lock_acquire+0x58/0x6c)
[<c005d950>] (lock_acquire+0x0/0x6c) from [<c0233068>] (_spin_lock+0x40/0x50)
[<c0233028>] (_spin_lock+0x0/0x50) from [<c002be50>] (gic_set_cpu+0x60/0xa0)
[<c002bdf0>] (gic_set_cpu+0x0/0xa0) from [<c01b04cc>] (em_route_irq+0x38/0x40)
[<c01b0494>] (em_route_irq+0x0/0x40) from [<c01b04ec>] (em_setup+0x18/0xa4)
[<c01b04d4>] (em_setup+0x0/0xa4) from [<c001570c>] (oprofile_arch_init+0x24/0xe8)
[<c00156e8>] (oprofile_arch_init+0x0/0xe8) from [<c0015640>] (oprofile_init+0x1c/0x64)
[<c0015624>] (oprofile_init+0x0/0x64) from [<c0008a20>] (kernel_init+0x154/0x368)
[<c00088cc>] (kernel_init+0x0/0x368) from [<c003ef34>] (do_exit+0x0/0x904)
oprofile: using arm/mpcore
Add support for stacktrace. Use the new stacktrace code with
oprofile instead of it's version; there's no point having
multiple versions of stacktracing in the kernel.
Always allow backtrace when using oprofile on ARM, even if a PMU
isn't present.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Add the glue for ARM11 SMP oprofile support, which also supports the
performance monitor in the coherency unit.
Add oprofile glue for ARM11 (ARMv6) oprofile support. This
connects the ARM11 core profiling support to the oprofile code
for uniprocessor configurations.
Add basic support for the ARM11 profiling hardware. This is shared
between the ARM11 UP and ARM11 SMP oprofile support code.
OP_MAX_COUNTER never referenced, and is a reminant of an earlier
oprofile implementation. Remove it.
Some ARM platforms were still broken as a result of the IRQ register
passing changes, mostly due to a missing linux/irq.h include.
Untested, but this should fix up the bulk of the totally mechanical
issues, and should make the actual detail fixing easier.
Remove the last trace of iop31x support from the kernel.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Since the iop32x code isn't iop321-specific, and the iop33x code isn't
iop331-specfic, do a s/iop321/iop32x/ and s/iop331/iop33x/, and tidy up
the code to conform to the coding style guidelines somewhat better.
Rename CONFIG_ARCH_IOP321 to CONFIG_ARCH_IOP32X and
CONFIG_ARCH_IOP331 to CONFIG_ARCH_IOP33X.
The irgflags consolidation did conflict with the ARM to generic IRQ
conversion and was not applied for ARM. Fix it up.
Use the new IRQF_ constants and remove the SA_INTERRUPT define
We need this to be zero initialised. Since this is an array, use kcalloc
rather than kzalloc or kmalloc.
op_arm_sem is being used as a mutex, so convert it to use
real mutexes.
