path: root/arch/arm/plat-iop/time.c
2016-12-25clocksource: Use a plain u64 instead of cycle_tThomas Gleixner
There is no point in having an extra type for extra confusion. u64 is unambiguous. Conversion was done with the following coccinelle script: @rem@ @@ -typedef u64 cycle_t; @fix@ typedef cycle_t; @@ -cycle_t +u64 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: John Stultz <john.stultz@linaro.org>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17ARM/iop/time: Migrate to new 'set-state' interfaceViresh Kumar
Migrate iop driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2014-03-12ARM: 8000/1: misc: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch removes the use of the IRQF_DISABLED flag from miscellaneous code in mach-xxx and plat-xxx This flag is a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-11-21ARM: iop: Switch to sched_clock_register()Stephen Boyd
The 32 bit sched_clock interface now supports 64 bits. Upgrade to the 64 bit function to allow us to remove the 32 bit registration interface. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-06-12sched_clock: Make ARM's sched_clock generic for all architecturesStephen Boyd
Nothing about the sched_clock implementation in the ARM port is specific to the architecture. Generalize the code so that other architectures can use it by selecting GENERIC_SCHED_CLOCK. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> [jstultz: Merge minor collisions with other patches in my tree] Signed-off-by: John Stultz <john.stultz@linaro.org>
2013-01-14ARM: use clockevents_config_and_register() where possibleShawn Guo
The clockevent core is able to figure out the best mult and shift, calculate min_delta_ns and max_delta_ns, with the necessary info passed into clockevents_config_and_register(). Use this combined configure and register function where possible to make the codes less error prone and gain some positive diff stat. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Tested-by: Roland Stigge <stigge@antcom.de> Acked-by: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: David Brown <davidb@codeaurora.org> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Barry Song <baohua.song@csr.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-18ARM: 7205/2: sched_clock: allow sched_clock to be selected at runtimeMarc Zyngier
sched_clock() is yet another blocker on the road to the single image. This patch implements an idea by Russell King: http://www.spinics.net/lists/linux-omap/msg49561.html Instead of asking the platform to implement both sched_clock() itself and the rollover callback, simply register a read() function, and let the ARM code care about sched_clock() itself, the conversion to ns and the rollover. sched_clock() uses this read() function as an indirection to the platform code. If the platform doesn't provide a read(), the code falls back to the jiffy counter (just like the default sched_clock). This allow some simplifications and possibly some footprint gain when multiple platforms are compiled in. Among the drawbacks, the removal of the *_fixed_sched_clock optimization which could negatively impact some platforms (sa1100, tegra, versatile and omap). Tested on 11MPCore, OMAP4 and Tegra. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Ben Dooks <ben-linux@fluff.org> Tested-by: Jamie Iles <jamie@jamieiles.com> Tested-by: Tony Lindgren <tony@atomide.com> Tested-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-31arm: Add export.h to ARM specific files as required.Paul Gortmaker
These files all make use of one of the EXPORT_SYMBOL variants or the THIS_MODULE macro. So they will need <linux/export.h> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-10ARM: Remove duplicate linux/sched.h include from arch/arm/plat-iop/time.cJesper Juhl
There's no need to include linux/sched.h more than once in arch/arm/plat-iop/time.c Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-05Merge branch 'clksrc' into develRussell King
Conflicts: arch/arm/mach-vexpress/v2m.c arch/arm/plat-omap/counter_32k.c arch/arm/plat-versatile/Makefile
2010-12-22ARM: iop: convert sched_clock() to use new infrastructureRussell King
Convert iop platforms to use the new sched_clock() infrastructure for extending 32bit counters to full 64-bit nanoseconds. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: ensure all sched_clock() implementations are notrace markedRussell King
ftrace requires sched_clock() to be notrace. Ensure that all implementations are so marked. Also make sure that they include linux/sched.h Also ensure OMAP clocksource read functions are marked notrace as they're used for sched_clock() too. Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Eric Miao <eric.y.miao@gmail.com> Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: iop: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-19ARM: clockevents: fix IOP clock events initializationRussell King
Ensure that no interrupt is pending before registering the clock event device, and properly initialize the periodic tick in the ->set_mode callback. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-04ARM: 6523/1: iop: ensure sched_clock() is notraceRabin Vincent
Include sched.h to ensure sched_clock() has the notrace annotation, and mark any functions it calls as notrace too. Include sched.h to ensure sched_clock() has the notrace annotation, and mark any functions it calls as notrace too. Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: 6159/1: Move IOP to use common mult/shift calculation codeLinus Walleij
Since the infrastructure for determining shift/mult values from a clock rate and a minimum programmable rate is now in the kernel, lets remove this custom code. Cc: Deepak Saxena <dsaxena@plexity.net> Acked-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-29iop: implement sched_clock()Mikael Pettersson
This adds a better sched_clock() to the IOP platform, implemented using its new clocksource support. Tested on n2100, compile-tested for all plat-iop machines. [dan.j.williams@intel.com: allow early cp6 access] Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-29iop: enable generic timeMikael Pettersson
This updates the IOP platform to use the kernel's generic time framework. With clockevent support in place, this reduces to selecting GENERIC_TIME and removing the platform's private timer ->offset() operation (iop_gettimeoffset). Tested on n2100, compile-tested for all plat-iop machines. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-29iop: clockevent supportMikael Pettersson
This updates the IOP platform to expose the interrupting timer 0 as a clockevent object. The timer interrupt handler is changed to call the clockevent ->event_handler() instead of timer_tick(), and ->set_next_event() and ->set_mode() operations are added to allow the mode of the timer to be updated (required for ONESHOT/NOHZ mode). Timer 0 must now be properly initialised, which requires a new write_tcr0() function from the mach-specific code. The mode of timer 0 must be read at the start of ->set_mode(), which requires a new read_tmr0() function from the mach- specific code. Initial setup of timer 0 is also rewritten to be more robust. Tested on n2100, compile-tested for all plat-iop machines. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-29iop: clocksource supportMikael Pettersson
This updates the IOP platform to expose the free-running timer 1 as a clocksource object. This timer is now also properly initialised, which requires a new write_tcr1() function from the mach-specific code. Apart from the explicit initialisation, there is no functional change in how timer 1 is programmed. Tested on n2100, compile-tested for all plat-iop machines. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-18arch/arm/plat-iop: Use DIV_ROUND_CLOSESTJulia Lawall
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d but is perhaps more readable. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ #include <linux/kernel.h> @depends on haskernel@ expression x,__divisor; @@ - (((x) + ((__divisor) / 2)) / (__divisor)) + DIV_ROUND_CLOSEST(x,__divisor) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] xtime_seqlock: fix more ARM machines for xtime deadlockingPeter Zijlstra
move update_process_times() out from under xtime_lock. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4495/1: iop: combined watchdog timer driver for iop3xx and iop13xxDan Williams
In order for this driver to be shared across the iop architectures the iop3xx and iop13xx header files are modified to present a common interface for the iop_wdt driver. Details: * iop13xx supports disabling the timer while iop3xx does not. This requires a few 'compatibility' definitions in include/asm-arm/hardware/iop3xx.h to preclude adding #ifdef CONFIG_ARCH_IOP13XX blocks to the driver code. * The heartbeat interval is derived from the internal bus clock rate, so this this patch also exports the tick rate to the iop_wdt driver. Cc: Curt Bruns <curt.e.bruns@intel.com> Cc: Peter Milne <peter.milne@d-tacq.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30[ARM] 4340/1: iop: fix iop_getttimeoffsetDan Williams
Fix a typo which causes a necessary cpwait to be missed on iop3xx, Michael Brunner <mibru@gmx.de> Save a register in the assembly routine, rmk Cc: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4187/1: iop: unify time implementation across iop32x, iop33x, and iop13xxDan Williams
* architecture specific details are handled in asm/arch/time.h * ARCH_IOP13XX now selects PLAT_IOP * as suggested by Lennert use ifdef CONFIG_XSCALE to skip the cp_wait on XSC3 Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4186/1: iop: remove cp6_enable/disable routinesDan Williams
This functionality is replaced by cp6_trap Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[ARM] 3832/1: iop3xx: coding style cleanupLennert Buytenhek
Since the iop32x code isn't iop321-specific, and the iop33x code isn't iop331-specfic, do a s/iop321/iop32x/ and s/iop331/iop33x/, and tidy up the code to conform to the coding style guidelines somewhat better. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3825/1: iop3xx: use cp6 enable/disable macrosLennert Buytenhek
Add CP6 enable/disable sequences to the timekeeping code and the IRQ code. As a result, we can't depend on CP6 access being enabled when we enter get_irqnr_and_base anymore, so switch the latter over to using memory-mapped accesses for now. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3822/1: iop3xx: rewrite time handlingLennert Buytenhek
Merge and rewrite the iop32x/iop33x time code to do lost jiffy tracking properly, and put the result in plat-iop/time.c. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
