include/linux/dmaengine.h
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@haskernel@
#include <linux/kernel.h>
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
// </smpl>
There are two 64 MB outbound memory windows at bus addresses
0x80000000..0x83ffffff and 0x84000000..0x87ffffff for PCI
memory. Currently, on iop32x, only the lower window is available for
allocations, limiting the available space to 64 MB. On iop33x the full
128 MB can be allocated, but the translation value is wrong for the
upper window.
The patch enables the full 128 MB space on iop32x and corrects the
initialization of OMWTVR1. Redundant definitions are deleted. Tested
using a Thecus N2100 board with a graphics adapter in the expansion
slot. Both windows are in use:
00:05.0 VGA compatible controller: XGI Technology Inc. (eXtreme Graphics
Innovation) Volari Z7 (prog-if 00 [VGA controller])
Region 0: Memory at 80000000 (32-bit, prefetchable) [size=64M]
Region 1: Memory at 84080000 (32-bit, non-prefetchable) [size=256K]
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
'zero_sum' does not properly describe the operation of generating parity
and checking that it validates against an existing buffer. Change the
name of the operation to 'val' (for 'validate'). This is in
anticipation of the p+q case where it is a requirement to identify the
target parity buffers separately from the source buffers, because the
target parity buffers will not have corresponding pq coefficients.
Reviewed-by: Andre Noll <maan@systemlinux.org>
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
Mikael Pettersson reported:
The 2.6.28-rc kernels fail to detect PCI device 0000:00:01.0
(the first ethernet port) on my Thecus n2100 XScale box.
There is however still a strange "ghost" device that gets partially
detected in 2.6.28-rc2 vanilla.
The IOP321 manual says:
The user designates the memory region containing the OCCDR as
non-cacheable and non-bufferable from the IntelR XScaleTM core.
This guarantees that all load/stores to the OCCDR are only of
DWORD quantities.
Ensure that the OCCDR is so mapped.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
There are 43 includes of asm/mach-types.h by files that don't
reference anything from that file. Remove these unnecessary
includes.
This patch brings support for gpio/gpiolib framework to Intel IOP3xx
platforms.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Platforms like iq80321 and iq80331 which may be host-bus-adapters
require 'iop3xx_init_atu=y' to be specified on the kernel command line.
The outbound translate registers should be programmed with the bus
addresses that are defined in the header files, rather than the
physical address.
Currently it doesn't matter because they're identical, but the headers
currently allow them to be different, and not using the right macros
here means that people are in for a surprise if they change them.
outbound window settings
... otherwise we end up trying to access peripherals using wrong PCI
addresses.
Make the inbound and outbound memory windows debugging meaningful to
those who don't know what the register names for the ATU mean. IOW,
use plain english rather than register jargon.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
move update_process_times() out from under xtime_lock.
In order for this driver to be shared across the iop architectures the
iop3xx and iop13xx header files are modified to present a common interface
for the iop_wdt driver.
Details:
* iop13xx supports disabling the timer while iop3xx does not. This requires
a few 'compatibility' definitions in include/asm-arm/hardware/iop3xx.h to
preclude adding #ifdef CONFIG_ARCH_IOP13XX blocks to the driver code.
* The heartbeat interval is derived from the internal bus clock rate, so this
this patch also exports the tick rate to the iop_wdt driver.
Cc: Curt Bruns <curt.e.bruns@intel.com>
Cc: Peter Milne <peter.milne@d-tacq.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Adds the platform device definitions and the architecture specific support
routines (i.e. register initialization and descriptor formats) for the
iop-adma driver.
Changelog:
* add support for > 1k zero sum buffer sizes
* added dma/aau platform devices to iq80321 and iq80332 setup
* fixed the calculation in iop_desc_is_aligned
* support xor buffer sizes larger than 16MB
* fix places where software descriptors are assumed to be contiguous, only
hardware descriptors are contiguous for up to a PAGE_SIZE buffer size
* convert to async_tx
* add interrupt support
* add platform devices for 80219 boards
* do not call platform register macros in driver code
* remove switch() statements for compatible register offsets/layouts
* change over to bitmap based capabilities
* remove unnecessary ARM assembly statement
* checkpatch.pl fixes
* gpl v2 only correction
* phys move to dma_async_tx_descriptor
* master.kernel.org:/home/rmk/linux-2.6-arm: (22 commits)
[ARM] spelling fixes
[ARM] at91_adc parenthesis balance
[ARM] 4400/1: S3C24XX: Add high-speed MMC device definition
[ARM] 4399/2: S3C2443: Fix SMDK2443 nand timings
[ARM] 4398/1: S3C2443: Fix watchdog IRQ number
[ARM] 4397/1: S3C2443: remove SDI0/1 IRQ ambiguity
[ARM] 4396/1: S3C2443: Add missing HCLK clocks
[ARM] 4395/1: S3C24XX: add include of <linux/sysdev.h> to relevant machines
[ARM] 4388/1: no need for arm/mm mmap range checks for non-mmu
[ARM] 4387/1: fix /proc/cpuinfo formatting for pre-ARM7 parts
[ARM] ARMv6: add CPU_HAS_ASID configuration
[ARM] integrator: fix pci_v3 compile error with DEBUG_LL
[ARM] gic: Fix gic cascade irq handling
[ARM] Silence OMAP kernel configuration warning
[ARM] Update ARM syscalls
[ARM] 4384/1: S3C2412/13 SPI registers offset correction
[ARM] 4383/1: iop: fix usage of '__init' and 'inline' in iop files
[ARM] 4382/1: iop13xx: fix msi support
[ARM] Remove Integrator/CP SMP platform support
[ARM] 4378/1: KS8695: Serial driver fix
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
Spelling fixes in arch/arm/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
WARNING: arch/arm/mach-iop13xx/built-in.o - Section mismatch: reference to
.init.text:iop13xx_pcie_map_irq from .text between 'iop13xx_pci_setup' (at
offset 0x7fc) and 'iop13xx_map_pci_memory'
While fixing this warning I also recalled Adrian Bunk's recommendation to
not use inline in .c files, as 'iop13xx_map_pci_memory' is needlessly
inlined.
Removing 'inline' uncovered some dead code so that is cleaned up as well.
Add IRQF_IRQPOLL for each timer interrupt.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
'ns9xxx', 'omap', 'pxa', 'rpc', 's3c' and 'sa1100' into devel
__ioremap() took a set of page table flags (specifically the cacheable
and bufferable bits) to control the mapping type. However, with
the advent of ARMv6, this is far too limited.
Replace the page table flags with a memory type index, so that the
desired attributes can be selected from the mem_type table.
Finally, to prevent silent miscompilation due to the differing
arguments, rename the __ioremap() and __ioremap_pfn() functions.
Currently the iop3xx platform support code assumes that RedBoot is the
bootloader and has already initialized the ATU. Linux should handle this
initialization for three reasons:
1/ The memory map that RedBoot sets up is not optimal (page_to_dma and
virt_to_phys return different addresses). The effect of this is that using
the dma mapping API for the internal bus dma units generates pci bus
addresses that are incorrect for the internal bus.
2/ Not all iop platforms use RedBoot
3/ If the ATU is already initialized it indicates that the iop is an add-in
card in another host, it does not own the PCI bus, and should not be
re-initialized.
Changelog:
* rather than change nr_controllers to zero, simply do not call
pci_common_init
Fix a typo which causes a necessary cpwait to be missed on iop3xx, Michael
Brunner <mibru@gmx.de>
Save a register in the assembly routine, rmk
* architecture specific details are handled in asm/arch/time.h
* ARCH_IOP13XX now selects PLAT_IOP
* as suggested by Lennert use ifdef CONFIG_XSCALE to skip the cp_wait on
XSC3
This functionality is replaced by cp6_trap
Enable svc access to cp6 via an undefined instruction hook. Do not enable
access for usr code.
This patch also makes iop13xx select PLAT_IOP, this requires a small change
to drivers/i2c/busses/i2c-iop3xx.c.
Per Lennert Buytenhek's note, the cp6 trap routine is moved to arch/arm/plat-iop
Per Nicolas Pitre's note, the cp_wait is skipped since the latency to
return to the faulting function is longer than cp_wait.
Implement a custom ioremap implementation for iop3xx. This saves
establishing new mappings. It also cleans up the PCI IO resource to be a
physical address rather than a virtual address as Russell pointed out on
the original iop13xx port.
Untested, but this should fix up the bulk of the totally mechanical
issues, and should make the actual detail fixing easier.
Since the iop32x code isn't iop321-specific, and the iop33x code isn't
iop331-specfic, do a s/iop321/iop32x/ and s/iop331/iop33x/, and tidy up
the code to conform to the coding style guidelines somewhat better.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Implement the gpio_line_{config,get,set} API for iop3xx.
Add CP6 enable/disable sequences to the timekeeping code and the IRQ
code. As a result, we can't depend on CP6 access being enabled when
we enter get_irqnr_and_base anymore, so switch the latter over to
using memory-mapped accesses for now.
Merge and rewrite the iop32x/iop33x time code to do lost jiffy
tracking properly, and put the result in plat-iop/time.c.
Merge the iop32x PCI code and iop33x PCI code into plat-iop/pci.c.
Move the i2c bits shared between iop32x and iop33x to plat-iop/i2c.c
and include/asm-arm/hardware/iop3xx.h.
Introduce the arch/arm/plat-iop directory, for code shared between the
iop32x and iop33x, and move the common memory map setup bits there.
