[ Upstream commit 2125801ccce19249708ca3245d48998e70569ab8 ]
clang warns about statically defined DMA masks from the DMA_BIT_MASK
macro with length 64:
arch/arm/mach-iop13xx/setup.c:303:35: error: shift count >= width of type [-Werror,-Wshift-count-overflow]
static u64 iop13xx_adma_dmamask = DMA_BIT_MASK(64);
include/linux/dma-mapping.h:141:54: note: expanded from macro 'DMA_BIT_MASK'
#define DMA_BIT_MASK(n) (((n) == 64) ? ~0ULL : ((1ULL<<(n))-1))
The ones in iop shouldn't really be 64 bit masks, so changing them
to what the driver can support avoids the warning.
Fix indentation in iop3xx_std_desc
Signed-off-by: Jungseung Lee <js07.lee@samsung.com>
Migrate iop driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Now that we can specify which PMU variant we're likely to deal with, do
so in the iop board code. This will allow us to split the ARMv6, ARMv7,
and XScale PMU drivers.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Olof Johansson <olof@lixom.net>
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is
a useless habit.
They are non-exported variables; therefore they are always empty
whenever descending into each subdirectory.
(Moreorver, obj-y and obj-m are also set to empty at the beginning
of scripts/Makefile.build)
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Peter Foley <pefoley2@pefoley.com>
This patch removes the use of the IRQF_DISABLED flag
from miscellaneous code in mach-xxx and plat-xxx
This flag is a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Acked-by: Greg Ungerer <gerg@uclinux.org>
From Stephen Boyd:
* soc/sched_clock:
ARM: versatile: Switch to sched_clock_register()
ARM: orion: Switch to sched_clock_register()
ARM: OMAP: Switch to sched_clock_register()
ARM: iop: Switch to sched_clock_register()
ARM: u300: Switch to sched_clock_register()
ARM: sa1100: Switch to sched_clock_register()
ARM: pxa: Switch to sched_clock_register()
ARM: OMAP2+: Switch to sched_clock_register()
ARM: OMAP1: Switch to sched_clock_register()
ARM: msm: Switch to sched_clock_register()
ARM: mmp: Switch to sched_clock_register()
ARM: IXP4xx: Switch to sched_clock_register()
ARM: integrator: Switch to sched_clock_register()
ARM: imx: Switch to sched_clock_register()
ARM: davinci: Switch to sched_clock_register()
ARM: clps711x: Switch to sched_clock_register()
ARM: timer-sp: Switch to sched_clock_register()
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The 32 bit sched_clock interface now supports 64 bits. Upgrade to
the 64 bit function to allow us to remove the 32 bit registration
interface.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Move the IOP GPIO driver to live with its siblings in the
GPIO subsystem.
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Pull timer core updates from Thomas Gleixner:
"The timer changes contain:
- posix timer code consolidation and fixes for odd corner cases
- sched_clock implementation moved from ARM to core code to avoid
duplication by other architectures
- alarm timer updates
- clocksource and clockevents unregistration facilities
- clocksource/events support for new hardware
- precise nanoseconds RTC readout (Xen feature)
- generic support for Xen suspend/resume oddities
- the usual lot of fixes and cleanups all over the place
The parts which touch other areas (ARM/XEN) have been coordinated with
the relevant maintainers. Though this results in an handful of
trivial to solve merge conflicts, which we preferred over nasty cross
tree merge dependencies.
The patches which have been committed in the last few days are bug
fixes plus the posix timer lot. The latter was in akpms queue and
next for quite some time; they just got forgotten and Frederic
collected them last minute."
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits)
hrtimer: Remove unused variable
hrtimers: Move SMP function call to thread context
clocksource: Reselect clocksource when watchdog validated high-res capability
posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting
posix_timers: fix racy timer delta caching on task exit
posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule()
selftests: add basic posix timers selftests
posix_cpu_timers: consolidate expired timers check
posix_cpu_timers: consolidate timer list cleanups
posix_cpu_timer: consolidate expiry time type
tick: Sanitize broadcast control logic
tick: Prevent uncontrolled switch to oneshot mode
tick: Make oneshot broadcast robust vs. CPU offlining
x86: xen: Sync the CMOS RTC as well as the Xen wallclock
x86: xen: Sync the wallclock when the system time is set
timekeeping: Indicate that clock was set in the pvclock gtod notifier
timekeeping: Pass flags instead of multiple bools to timekeeping_update()
xen: Remove clock_was_set() call in the resume path
hrtimers: Support resuming with two or more CPUs online (but stopped)
timer: Fix jiffies wrap behavior of round_jiffies_common()
There have never been any real users of MEMSET operations since they
have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine:
refactor dmaengine around dma_async_tx_descriptor"). Therefore remove
support for them for now, it can be always brought back when needed.
[sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Acked-by: Dan Williams <djbw@fb.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Kevin Hilman <khilman@linaro.org>
Nothing about the sched_clock implementation in the ARM port is
specific to the architecture. Generalize the code so that other
architectures can use it by selecting GENERIC_SCHED_CLOCK.
[jstultz: Merge minor collisions with other patches in my tree]
Signed-off-by: John Stultz <john.stultz@linaro.org>
The clockevent core is able to figure out the best mult and shift,
calculate min_delta_ns and max_delta_ns, with the necessary info passed
into clockevents_config_and_register(). Use this combined configure
and register function where possible to make the codes less error prone
and gain some positive diff stat.
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Tested-by: Roland Stigge <stigge@antcom.de>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: David Brown <davidb@codeaurora.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Barry Song <baohua.song@csr.com>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Jason Cooper <jason@lakedaemon.net>
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into next/cleanup
From Will Deacon:
Bunch of perf updates for the ARM backend that pave the way for
big.LITTLE support in the future. The separation of CPU and PMU code
is also the start of being able to move some of this stuff under
drivers/.
* tag 'arm-perf-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/will/linux:
ARM: perf: move irq registration into pmu implementation
ARM: perf: move CPU-specific PMU handling code into separate file
ARM: perf: prepare for moving CPU PMU code into separate file
ARM: perf: probe devicetree in preference to current CPU
ARM: perf: remove mysterious compiler barrier
ARM: pmu: remove arm_pmu_type enumeration
ARM: pmu: remove unused reservation mechanism
ARM: perf: add devicetree bindings for 11MPcore, A5, A7 and A15 PMUs
ARM: PMU: Add runtime PM Support
The arm_pmu_type enumeration was initially introduced to identify
different PMU types in the system, the usual one being that on the CPU
(ARM_PMU_DEVICE_CPU). With the removal of the PMU reservation code and
the introduction of devicetree bindings for the CPU PMU, the enumeration
is no longer required.
This patch removes the enumeration and updates the various CPU PMU
platform devices so that they no longer pass an .id field referring
to identify the PMU type.
Cc: Pawel Moll <pawel.moll@arm.com>
Acked-by: Jon Hunter <jon-hunter@ti.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Signed-off-by: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com>
[will: cosmetic edits and actual removal of the enum type]
Move iop33x and iop32x PCI to fixed i/o mapping and remove io.h. This
changes the PCI bus addresses from the cpu address to 0 based. It appears
that there is translation h/w for this, but its untested.
Not sure what to do with io_offset. I think it should always be 0.
AFAICT, PCI setup is skipped if the ATU is already setup.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Most PCI implementations perform simple root bus scanning. Rather than
having each group of platforms provide a duplicated bus scan function,
provide the PCI configuration ops structure via the hw_pci structure,
and call the root bus scanning function from core ARM PCI code.
Acked-by: Krzysztof Hałasa <khc@pm.waw.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for ARM.
cc: Russell King <linux@arm.linux.org.uk>
cc: linux-arm-kernel@lists.infradead.org
Tell the PCI core about host bridge address translation so it can take
care of bus-to-resource conversion for us.
CC: Russell King <linux@arm.linux.org.uk>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits)
x86/PCI: Expand the x86_msi_ops to have a restore MSIs.
PCI: Increase resource array mask bit size in pcim_iomap_regions()
PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES
PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT)
PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB
x86/PCI: amd: factor out MMCONFIG discovery
PCI: Enable ATS at the device state restore
PCI: msi: fix imbalanced refcount of msi irq sysfs objects
PCI: kconfig: English typo in pci/pcie/Kconfig
PCI/PM/Runtime: make PCI traces quieter
PCI: remove pci_create_bus()
xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources
x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus()
x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented()
x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan
sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources
sparc/PCI: convert to pci_create_root_bus()
sh/PCI: convert to pci_scan_root_bus() for correct root bus resources
powerpc/PCI: convert to pci_create_root_bus()
powerpc/PCI: split PHB part out of pcibios_map_io_space()
Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due
to the same patches being applied in other branches.
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus
resource fixups. This fixes the problem of "early" and "header" quirks
seeing incorrect root bus resources.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
arch/arm/mach-exynos/cpu.c
The changes to arch/arm/mach-exynos/cpu.c were moved to
mach-exynos/common.c.
Hook these platforms restart code into the arm_pm_restart hook rather
than using arch_reset().
In doing so, we split out the n2100 platform specific restart handler
into the n2100 platform file.
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
sched_clock() is yet another blocker on the road to the single
image. This patch implements an idea by Russell King:
http://www.spinics.net/lists/linux-omap/msg49561.html
Instead of asking the platform to implement both sched_clock()
itself and the rollover callback, simply register a read()
function, and let the ARM code care about sched_clock() itself,
the conversion to ns and the rollover. sched_clock() uses
this read() function as an indirection to the platform code.
If the platform doesn't provide a read(), the code falls back
to the jiffy counter (just like the default sched_clock).
This allow some simplifications and possibly some footprint gain
when multiple platforms are compiled in. Among the drawbacks,
the removal of the *_fixed_sched_clock optimization which could
negatively impact some platforms (sa1100, tegra, versatile
and omap).
Tested on 11MPCore, OMAP4 and Tegra.
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Colin Cross <ccross@android.com>
Cc: Erik Gilling <konkers@android.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Alessandro Rubini <rubini@unipv.it>
Cc: STEricsson <STEricsson_nomadik_linux@list.st.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Tested-by: Jamie Iles <jamie@jamieiles.com>
Tested-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Krzysztof Halasa <khc@pm.waw.pl>
A generic version should replace this later.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
These files all make use of one of the EXPORT_SYMBOL variants
or the THIS_MODULE macro. So they will need <linux/export.h>
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow
multi-platform builds. This also removes the requirement for a platform to
have a mach/hardware.h.
The default values for i/o and mem are 0x1000 and 0x01000000, respectively.
Per Arnd Bergmann, other values are likely to be incorrect, but this commit
does not try to address that issue.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
The iop13xx_defconfig didn't build since the platform code uses
defines from <asm/ptrace.h>. Simply add the include so it
compiles.
There's no need to include linux/sched.h more than once
in arch/arm/plat-iop/time.c
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
arch/arm/mach-vexpress/v2m.c
arch/arm/plat-omap/counter_32k.c
arch/arm/plat-versatile/Makefile
Convert iop platforms to use the new sched_clock() infrastructure for
extending 32bit counters to full 64-bit nanoseconds.
ftrace requires sched_clock() to be notrace. Ensure that all
implementations are so marked. Also make sure that they include
linux/sched.h
Also ensure OMAP clocksource read functions are marked notrace as
they're used for sched_clock() too.
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Eric Miao <eric.y.miao@gmail.com>
Tested-by: Olof Johansson <olof@lixom.net>
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new
interfaces were added which simplify (and optimize) the selection of the
divisor shift/mult constants. Switch over to using this new interface.
Ensure that no interrupt is pending before registering the clock
event device, and properly initialize the periodic tick in the
->set_mode callback.
Include sched.h to ensure sched_clock() has the notrace
annotation, and mark any functions it calls as notrace
too.
too.
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Rabin Vincent <rabin@rab.in>
arch/arm/mm/init.c
Add one more parameter to hook_fault_code() to be able to set 'code'
field of struct fsr_info.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Since the infrastructure for determining shift/mult values from a
clock rate and a minimum programmable rate is now in the kernel,
lets remove this custom code.
Cc: Deepak Saxena <dsaxena@plexity.net>
Acked-by: Mikael Pettersson <mikpe@it.uu.se>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
This patch adds an initcall for the iop3xx platforms so that they
register their PMU IRQS with the PMU framework in the Kernel.
This allows the procfs vmallocinfo file to show who created the ioremap
regions. Note: __builtin_return_address(0) doesn't do what's expected
if its used in an inline function, so we leave __arm_ioremap callers
in such places alone.
This adds a better sched_clock() to the IOP platform,
implemented using its new clocksource support.
Tested on n2100, compile-tested for all plat-iop machines.
[dan.j.williams@intel.com: allow early cp6 access]
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
This updates the IOP platform to use the kernel's generic time
framework. With clockevent support in place, this reduces to
selecting GENERIC_TIME and removing the platform's private timer
->offset() operation (iop_gettimeoffset).
This updates the IOP platform to expose the interrupting
timer 0 as a clockevent object. The timer interrupt handler
is changed to call the clockevent ->event_handler() instead
of timer_tick(), and ->set_next_event() and ->set_mode()
operations are added to allow the mode of the timer to be
updated (required for ONESHOT/NOHZ mode).
Timer 0 must now be properly initialised, which requires
a new write_tcr0() function from the mach-specific code.
The mode of timer 0 must be read at the start of ->set_mode(),
which requires a new read_tmr0() function from the mach-
specific code.
Initial setup of timer 0 is also rewritten to be more robust.
This updates the IOP platform to expose the free-running
timer 1 as a clocksource object. This timer is now also
properly initialised, which requires a new write_tcr1()
function from the mach-specific code. Apart from the
explicit initialisation, there is no functional change
in how timer 1 is programmed.
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/xscaleiop
MAINTAINERS
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx into for-linus
Due to problems at cam.org, my nico@cam.org email address is no longer
valid. FRom now on, nico@fluxnic.net should be used instead.
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
No drivers currently implement these operation types, so they can be
deleted.
