path: root/arch/arm/plat-iop
2015-02-06arm: iop: specify PMUs are for XScale CPUsMark Rutland
Now that we can specify which PMU variant we're likely to deal with, do so in the iop board code. This will allow us to split the ARMv6, ARMv7, and XScale PMU drivers. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-02kbuild: remove unnecessary variable initializaionsMasahiro Yamada
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is a useless habit. They are non-exported variables; therefore they are always empty whenever descending into each subdirectory. (Moreorver, obj-y and obj-m are also set to empty at the beginning of scripts/Makefile.build) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-03-12ARM: 8000/1: misc: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch removes the use of the IRQF_DISABLED flag from miscellaneous code in mach-xxx and plat-xxx This flag is a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-06Merge branch 'soc/sched_clock' into next/socKevin Hilman
From Stephen Boyd: * soc/sched_clock: ARM: versatile: Switch to sched_clock_register() ARM: orion: Switch to sched_clock_register() ARM: OMAP: Switch to sched_clock_register() ARM: iop: Switch to sched_clock_register() ARM: u300: Switch to sched_clock_register() ARM: sa1100: Switch to sched_clock_register() ARM: pxa: Switch to sched_clock_register() ARM: OMAP2+: Switch to sched_clock_register() ARM: OMAP1: Switch to sched_clock_register() ARM: msm: Switch to sched_clock_register() ARM: mmp: Switch to sched_clock_register() ARM: IXP4xx: Switch to sched_clock_register() ARM: integrator: Switch to sched_clock_register() ARM: imx: Switch to sched_clock_register() ARM: davinci: Switch to sched_clock_register() ARM: clps711x: Switch to sched_clock_register() ARM: timer-sp: Switch to sched_clock_register() Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-11-21ARM: iop: Switch to sched_clock_register()Stephen Boyd
The 32 bit sched_clock interface now supports 64 bits. Upgrade to the 64 bit function to allow us to remove the 32 bit registration interface. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-09-20ARM: plat-iop: move the GPIO driver to drivers/gpioLinus Walleij
Move the IOP GPIO driver to live with its siblings in the GPIO subsystem. Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-06Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner: "The timer changes contain: - posix timer code consolidation and fixes for odd corner cases - sched_clock implementation moved from ARM to core code to avoid duplication by other architectures - alarm timer updates - clocksource and clockevents unregistration facilities - clocksource/events support for new hardware - precise nanoseconds RTC readout (Xen feature) - generic support for Xen suspend/resume oddities - the usual lot of fixes and cleanups all over the place The parts which touch other areas (ARM/XEN) have been coordinated with the relevant maintainers. Though this results in an handful of trivial to solve merge conflicts, which we preferred over nasty cross tree merge dependencies. The patches which have been committed in the last few days are bug fixes plus the posix timer lot. The latter was in akpms queue and next for quite some time; they just got forgotten and Frederic collected them last minute." * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits) hrtimer: Remove unused variable hrtimers: Move SMP function call to thread context clocksource: Reselect clocksource when watchdog validated high-res capability posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting posix_timers: fix racy timer delta caching on task exit posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule() selftests: add basic posix timers selftests posix_cpu_timers: consolidate expired timers check posix_cpu_timers: consolidate timer list cleanups posix_cpu_timer: consolidate expiry time type tick: Sanitize broadcast control logic tick: Prevent uncontrolled switch to oneshot mode tick: Make oneshot broadcast robust vs. CPU offlining x86: xen: Sync the CMOS RTC as well as the Xen wallclock x86: xen: Sync the wallclock when the system time is set timekeeping: Indicate that clock was set in the pvclock gtod notifier timekeeping: Pass flags instead of multiple bools to timekeeping_update() xen: Remove clock_was_set() call in the resume path hrtimers: Support resuming with two or more CPUs online (but stopped) timer: Fix jiffies wrap behavior of round_jiffies_common() ...
2013-07-03drivers/dma: remove unused support for MEMSET operationsBartlomiej Zolnierkiewicz
There have never been any real users of MEMSET operations since they have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine: refactor dmaengine around dma_async_tx_descriptor"). Therefore remove support for them for now, it can be always brought back when needed. [sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Vinod Koul <vinod.koul@intel.com> Acked-by: Dan Williams <djbw@fb.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Olof Johansson <olof@lixom.net> Cc: Kevin Hilman <khilman@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12sched_clock: Make ARM's sched_clock generic for all architecturesStephen Boyd
Nothing about the sched_clock implementation in the ARM port is specific to the architecture. Generalize the code so that other architectures can use it by selecting GENERIC_SCHED_CLOCK. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> [jstultz: Merge minor collisions with other patches in my tree] Signed-off-by: John Stultz <john.stultz@linaro.org>
2013-01-14ARM: use clockevents_config_and_register() where possibleShawn Guo
The clockevent core is able to figure out the best mult and shift, calculate min_delta_ns and max_delta_ns, with the necessary info passed into clockevents_config_and_register(). Use this combined configure and register function where possible to make the codes less error prone and gain some positive diff stat. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Tested-by: Roland Stigge <stigge@antcom.de> Acked-by: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: David Brown <davidb@codeaurora.org> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Barry Song <baohua.song@csr.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-04Merge tag 'arm-perf-3.7' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into next/cleanup From Will Deacon: Bunch of perf updates for the ARM backend that pave the way for big.LITTLE support in the future. The separation of CPU and PMU code is also the start of being able to move some of this stuff under drivers/. * tag 'arm-perf-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/will/linux: ARM: perf: move irq registration into pmu implementation ARM: perf: move CPU-specific PMU handling code into separate file ARM: perf: prepare for moving CPU PMU code into separate file ARM: perf: probe devicetree in preference to current CPU ARM: perf: remove mysterious compiler barrier ARM: pmu: remove arm_pmu_type enumeration ARM: pmu: remove unused reservation mechanism ARM: perf: add devicetree bindings for 11MPcore, A5, A7 and A15 PMUs ARM: PMU: Add runtime PM Support
2012-08-23ARM: pmu: remove arm_pmu_type enumerationSudeep KarkadaNagesha
The arm_pmu_type enumeration was initially introduced to identify different PMU types in the system, the usual one being that on the CPU (ARM_PMU_DEVICE_CPU). With the removal of the PMU reservation code and the introduction of devicetree bindings for the CPU PMU, the enumeration is no longer required. This patch removes the enumeration and updates the various CPU PMU platform devices so that they no longer pass an .id field referring to identify the PMU type. Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Olof Johansson <olof@lixom.net> Cc: Pawel Moll <pawel.moll@arm.com> Acked-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com> [will: cosmetic edits and actual removal of the enum type] Signed-off-by: Will Deacon <will.deacon@arm.com>
2012-07-26ARM: iop3xx: use fixed PCI i/o mappingRob Herring
Move iop33x and iop32x PCI to fixed i/o mapping and remove io.h. This changes the PCI bus addresses from the cpu address to 0 based. It appears that there is translation h/w for this, but its untested. Not sure what to do with io_offset. I think it should always be 0. AFAICT, PCI setup is skipped if the ATU is already setup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-05-13ARM: PCI: provide a default bus scan implementationRussell King
Most PCI implementations perform simple root bus scanning. Rather than having each group of platforms provide a duplicated bus scan function, provide the PCI configuration ops structure via the hw_pci structure, and call the root bus scanning function from core ARM PCI code. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-02-23arm/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-01-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits) x86/PCI: Expand the x86_msi_ops to have a restore MSIs. PCI: Increase resource array mask bit size in pcim_iomap_regions() PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT) PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB x86/PCI: amd: factor out MMCONFIG discovery PCI: Enable ATS at the device state restore PCI: msi: fix imbalanced refcount of msi irq sysfs objects PCI: kconfig: English typo in pci/pcie/Kconfig PCI/PM/Runtime: make PCI traces quieter PCI: remove pci_create_bus() xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus() x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented() x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources sparc/PCI: convert to pci_create_root_bus() sh/PCI: convert to pci_scan_root_bus() for correct root bus resources powerpc/PCI: convert to pci_create_root_bus() powerpc/PCI: split PHB part out of pcibios_map_io_space() ... Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due to the same patches being applied in other branches.
2012-01-06arm/PCI: convert to pci_scan_root_bus() for correct root bus resourcesBjorn Helgaas
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus resource fixups. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: iop3xx: use new restart hookRussell King
Hook these platforms restart code into the arm_pm_restart hook rather than using arch_reset(). In doing so, we split out the n2100 platform specific restart handler into the n2100 platform file. Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-18ARM: 7205/2: sched_clock: allow sched_clock to be selected at runtimeMarc Zyngier
sched_clock() is yet another blocker on the road to the single image. This patch implements an idea by Russell King: http://www.spinics.net/lists/linux-omap/msg49561.html Instead of asking the platform to implement both sched_clock() itself and the rollover callback, simply register a read() function, and let the ARM code care about sched_clock() itself, the conversion to ns and the rollover. sched_clock() uses this read() function as an indirection to the platform code. If the platform doesn't provide a read(), the code falls back to the jiffy counter (just like the default sched_clock). This allow some simplifications and possibly some footprint gain when multiple platforms are compiled in. Among the drawbacks, the removal of the *_fixed_sched_clock optimization which could negatively impact some platforms (sa1100, tegra, versatile and omap). Tested on 11MPCore, OMAP4 and Tegra. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Ben Dooks <ben-linux@fluff.org> Tested-by: Jamie Iles <jamie@jamieiles.com> Tested-by: Tony Lindgren <tony@atomide.com> Tested-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-18ARM: plat-iop: remove arch specific special handling for ioremapNicolas Pitre
A generic version should replace this later. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-10-31arm: Add export.h to ARM specific files as required.Paul Gortmaker
These files all make use of one of the EXPORT_SYMBOL variants or the THIS_MODULE macro. So they will need <linux/export.h> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-12ARM: convert PCI defines to variablesRob Herring
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow multi-platform builds. This also removes the requirement for a platform to have a mach/hardware.h. The default values for i/o and mem are 0x1000 and 0x01000000, respectively. Per Arnd Bergmann, other values are likely to be incorrect, but this commit does not try to address that issue. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-06-21ARM: 6969/1: plat-iop: fix build errorLinus Walleij
The iop13xx_defconfig didn't build since the platform code uses defines from <asm/ptrace.h>. Simply add the include so it compiles. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-04-10ARM: Remove duplicate linux/sched.h include from arch/arm/plat-iop/time.cJesper Juhl
There's no need to include linux/sched.h more than once in arch/arm/plat-iop/time.c Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-05Merge branch 'clksrc' into develRussell King
Conflicts: arch/arm/mach-vexpress/v2m.c arch/arm/plat-omap/counter_32k.c arch/arm/plat-versatile/Makefile
2010-12-22ARM: iop: convert sched_clock() to use new infrastructureRussell King
Convert iop platforms to use the new sched_clock() infrastructure for extending 32bit counters to full 64-bit nanoseconds. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: ensure all sched_clock() implementations are notrace markedRussell King
ftrace requires sched_clock() to be notrace. Ensure that all implementations are so marked. Also make sure that they include linux/sched.h Also ensure OMAP clocksource read functions are marked notrace as they're used for sched_clock() too. Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Eric Miao <eric.y.miao@gmail.com> Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: iop: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-19ARM: clockevents: fix IOP clock events initializationRussell King
Ensure that no interrupt is pending before registering the clock event device, and properly initialize the periodic tick in the ->set_mode callback. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-04ARM: 6523/1: iop: ensure sched_clock() is notraceRabin Vincent
Include sched.h to ensure sched_clock() has the notrace annotation, and mark any functions it calls as notrace too. Include sched.h to ensure sched_clock() has the notrace annotation, and mark any functions it calls as notrace too. Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-31Merge branch 'misc' into develRussell King
Conflicts: arch/arm/mm/init.c
2010-07-27ARM: 6269/1: Add 'code' parameter for hook_fault_code()Kirill A. Shutemov
Add one more parameter to hook_fault_code() to be able to set 'code' field of struct fsr_info. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: 6159/1: Move IOP to use common mult/shift calculation codeLinus Walleij
Since the infrastructure for determining shift/mult values from a clock rate and a minimum programmable rate is now in the kernel, lets remove this custom code. Cc: Deepak Saxena <dsaxena@plexity.net> Acked-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-29ARM: 6048/1: ARM: iop3xx: register PMU IRQs during board initialisationWill Deacon
This patch adds an initcall for the iop3xx platforms so that they register their PMU IRQS with the PMU framework in the Kernel. Cc: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: Add caller information to ioremapRussell King
This allows the procfs vmallocinfo file to show who created the ioremap regions. Note: __builtin_return_address(0) doesn't do what's expected if its used in an inline function, so we leave __arm_ioremap callers in such places alone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-29iop: implement sched_clock()Mikael Pettersson
This adds a better sched_clock() to the IOP platform, implemented using its new clocksource support. Tested on n2100, compile-tested for all plat-iop machines. [dan.j.williams@intel.com: allow early cp6 access] Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-29iop: enable generic timeMikael Pettersson
This updates the IOP platform to use the kernel's generic time framework. With clockevent support in place, this reduces to selecting GENERIC_TIME and removing the platform's private timer ->offset() operation (iop_gettimeoffset). Tested on n2100, compile-tested for all plat-iop machines. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-29iop: clockevent supportMikael Pettersson
This updates the IOP platform to expose the interrupting timer 0 as a clockevent object. The timer interrupt handler is changed to call the clockevent ->event_handler() instead of timer_tick(), and ->set_next_event() and ->set_mode() operations are added to allow the mode of the timer to be updated (required for ONESHOT/NOHZ mode). Timer 0 must now be properly initialised, which requires a new write_tcr0() function from the mach-specific code. The mode of timer 0 must be read at the start of ->set_mode(), which requires a new read_tmr0() function from the mach- specific code. Initial setup of timer 0 is also rewritten to be more robust. Tested on n2100, compile-tested for all plat-iop machines. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-29iop: clocksource supportMikael Pettersson
This updates the IOP platform to expose the free-running timer 1 as a clocksource object. This timer is now also properly initialised, which requires a new write_tcr1() function from the mach-specific code. Apart from the explicit initialisation, there is no functional change in how timer 1 is programmed. Tested on n2100, compile-tested for all plat-iop machines. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-02Merge branch 'fixes' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/xscaleiop Conflicts: MAINTAINERS
2009-09-23Merge branch 'next' of ↵NeilBrown
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx into for-linus
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-08dmaengine: cleanup unused transaction typesDan Williams
No drivers currently implement these operation types, so they can be deleted. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08Merge branch 'md-raid6-accel' into ioat3.2Dan Williams
Conflicts: include/linux/dmaengine.h
2009-08-18arch/arm/plat-iop: Use DIV_ROUND_CLOSESTJulia Lawall
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d but is perhaps more readable. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ #include <linux/kernel.h> @depends on haskernel@ expression x,__divisor; @@ - (((x) + ((__divisor) / 2)) / (__divisor)) + DIV_ROUND_CLOSEST(x,__divisor) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-18iop3xx: ATU and PCI memory configuration correctedAaro Koskinen
There are two 64 MB outbound memory windows at bus addresses 0x80000000..0x83ffffff and 0x84000000..0x87ffffff for PCI memory. Currently, on iop32x, only the lower window is available for allocations, limiting the available space to 64 MB. On iop33x the full 128 MB can be allocated, but the translation value is wrong for the upper window. The patch enables the full 128 MB space on iop32x and corrects the initialization of OMWTVR1. Redundant definitions are deleted. Tested using a Thecus N2100 board with a graphics adapter in the expansion slot. Both windows are in use: 00:05.0 VGA compatible controller: XGI Technology Inc. (eXtreme Graphics Innovation) Volari Z7 (prog-if 00 [VGA controller]) [...] Region 0: Memory at 80000000 (32-bit, prefetchable) [size=64M] Region 1: Memory at 84080000 (32-bit, non-prefetchable) [size=256K] Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
