Expose clock debug information to debugfs, which makes it easier for clock
system debug by using tools like powerdebug developed by Linaro power
management group.
For long term, this can go into common clock framework, but so far it depends
on the process of common clk API development. Once the common clk API is
ready in upstream, the clock debug information will be based on it too.
The implementation based on common clk API had also been finished and
reviewed with Jeremy.
ARM: iMX5x: fix clock debug enable_count error
Signed-off-by: Yong Shen <yong.shen@linaro.org>
Signed-off-by: Richard Zhao <richard.zhao@freescale.com>
Signed-off-by: Jason Chen <b02280@freescale.com>
imx51_babbage:
imx53_smd: add i2c device
imx53_smd: add i2c board device info
imx53_smd: add esdhc device support
imx53_smd: Add SRTC devices
imx53_smd: enable the AHCI SATA
imx53_smd: Add GPIO Keypad support
imx53_ard: enable ARD board bootup
imx53_ard: add ethernet pin mux
imx53_ard: add smsc911x device
imx53_loco: add i2c device
imx53_loco: change sii902x i2c device
imx53_loco: register v4l2 output device
imx53_loco: add srtc device
imx53_loco: enable the AHCI SATA
imx53_loco: Add GPIO Keypad support
imx53_evk: add evk and arm2 boards io setting and set up display
imx5: add ipu\vpu
imx5: clock.c: remove RATE_PROPAGATES
imx5: Add clock, dvfs, busfreq, sdram_autogating support.
imx5: fix warnings on boot
imx5: add v4l2 device
imx5: add board_is_rev support
imx5: Add sdma support for i.Mx53 and i.Mx51
imx5: add p1003
imx5: add ipuv3
imx5: add sata
imx5: add pmic board files
imx5: add pm function
imx5: add iram config
imx5: add gpu
imx5: fix clock debug enable_count error
imx53: add gpio irq support for mx53
imx53: change PWM backlight device register method to dynamic
imx53: change v4l2 device register method to dynamic
imx53: add vpu devices support
imx53: add dvfs-core and busfreq devices register method
imx53: Add usb devices
imx53: add i2c pad settings
imx53: add ssi support
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
Signed-off-by: Richard Zhu <r65037@freescale.com>
Signed-off-by: Zhou Jingyu <Jingyu.Zhou@freescale.com>
Signed-off-by: Zhang Yan <b34916@freescale.com>
COMMON_CLKDEV is used on all imx platforms, so this isn't used.
This patch only adds general clkdev support without actually switching
any MXC architecture to clkdev.
We had 3 versions of this function in clock support for MX1/2/3
Use a single one instead. I picked the one from the MX3 as it seems
to calculate more accurate as the other ones. Also, on MX27 and MX31 mfn
can be negative, this hasn't been handled correctly on MX27 since now.
This patch has been tested on MX27 and MX31 and produces the same clock
frequencies for me.
Fix some base address declaration by adding a cast.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
This just leaves include/asm-arm/plat-* to deal with.
