path: root/arch/arm/plat-mxc/include/mach/mx2x.h
2012-10-15ARM: imx: merge plat-mxc into mach-imxShawn Guo
It's really unnecessary to have plat-mxc, and let's merge it into mach-imx. It's pretty much just a bunch of file renaming and Kconfig/Makefile merge. To make the change less invasive, we keep using Kconfig symbol CONFIG_ARCH_MXC for mach-imx sub-architecture. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-07-01ARM: imx: enable SPARSE_IRQ for imx platformShawn Guo
As all irqchips on imx have been changed to allocate their irq_descs, and all unneeded mach/irqs.h inclusions on imx have been cleaned up, now it's time to select SPARSE_IRQ for imx/mxc. The SPARSE_IRQ support forces irqs allocation starting from 16. All those static irq number definition for SoCs need to shift 16 to keep non-DT boot works. With all those static IRQ number and start definitions removed from mach/irqs.h, the header becomes just a container of a couple of mach-imx specific irq/fiq calls. Since mach/irqs.h is not included by asm/irq.h now, the users of mxc_set_irq_fiq needs to explicitly include mach/irqs.h themselves. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-11-17ARM: imx: remove deprecated symbols as all users are gone nowUwe Kleine-König
2010-11-17ARM: imx/debug-macro: rework using the new io mapping macroUwe Kleine-König
This gets rid of the last user of IMX_NEEDS_DEPRECATED_SYMBOLS. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-11-17ARM: imx: change static io mapping to use a functionUwe Kleine-König
Now only the virtual addresses [0xf4000000, 0xf5ffffff] are used for static per-SoC mappings. The few mappings of whole chip selects are moved accordingly. The now wrong defines for virtual base addresses are removed. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-01-08imx: properly protect mach/mx{1,[25][157x]}.h from multiple inclusionUwe Kleine-König
Some headers have used (now) wrong names or havn't had protection at all. This is needed before adding static inline functions to the headers. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Holger Schurig <hs4233@mail.mn-solutions.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Daniel Mack <daniel@caiaq.de>
2010-01-08imx: only define deprecated symbols conditionallyUwe Kleine-König
Define deprecated symbols in an #ifdef IMX_NEEDS_DEPRECATED_SYMBOLS ... All files that still depend on the old definitions get -DIMX_NEEDS_DEPRECATED_SYMBOLS passed to the compiler. When all remaining users are fixed this allows including the soc specific headers unconditionally. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Eric Benard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Alan Carvalho de Assis <acassis@gmail.com> Cc: Daniel Mack <daniel@caiaq.de> Cc: Alberto Panizzo <maramaopercheseimorto@gmail.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Holger Schurig <hs4233@mail.mn-solutions.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Magnus Lilja <lilja.magnus@gmail.com>
2009-11-26ARM: fix "offest" -> "offset" typoUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-18imx: add namespace prefixes for symbols in mx2x.hUwe Kleine-König
The old names are still defined using the new names. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2009-11-18imx: reorder mx2x.hUwe Kleine-König
2009-08-07MXC gpio interrupt support: move register definitions to .c fileSascha Hauer
2009-08-07mxc: remove do not include directlySascha Hauer
Everyone should be free to include the files he actually needs. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-13arm/imx2x: split i.MX21/i.MX27 register definitionsHolger Schurig
* define new CONFIG_ARCH_MX21 (this one is currently mutually exclusive to CONFIG_ARCH_MX27, but this might change) * splits one header file. Memory definitions, interrupt sources, DMA channels are split into common part, i.MX27 specific and i.MX21 specific. * guard access to UART5/UART6, which don't exist on i.MX21 Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
