It's for migrating to generic clk framework API.
Signed-off-by: Richard Zhao <richard.zhao@linaro.org>
According to imx pwm RM, the real period value should be
PERIOD value in PWMPR plus 2.
PWMO (Hz) = PCLK(Hz) / (period +2)
Signed-off-by: Jason Chen <jason.chen@linaro.org>
Cc: stable@kernel.org
Instead of adding the check for MX53 CPU type, use the negative logic and let
PWM to be configured for MX53 as well.
Cc: Sascha Hauer <kernel@pengutronix.de>
This patch is adding support for pwm1 and pwm2 devices found
on mx51.
[ this patch has been tested with pwm-backlight driver ]
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
- fix off-by-one error in divider calculation
- disable pwm in pwm_disable
* Kconfig enables now HAVE_PWM (this enables in turn the selection of
CONFIG_BACKLIGHT_PWM)
* changes CONFIG_ARCH_MXyy to CONFIG_MACH_MXyy
* fix some register names to match those of the reference manual
* write a stub code so that the PWM can be used to program the
LCD backlight
* convert from #ifdef CONFIG_ARCH_MXxx to cpu_is_mxXX()
* remove unneeded defines and fix 80-column "violations" of checkpatch.pl
Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de>
This driver has been tested on MX27/MX31. It should work on MX1/MX1
aswell, but the actual setting of the PWM is missing so far.
