path: root/arch/arm/plat-mxc/ssi-fiq.S
2010-01-17ASoC: Add a new imx-ssi sound driverSascha Hauer
The old driver has the number of SSI units in the system hardcoded, does not make use of the device model and works only on i.MX21/27. This driver replaces it. It works in DMA mode on i.MX21/27 and using an FIQ handler on other systems. It also supports AC97 mode of the SSI units. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Javier Martin <javier.martin@vista-silicon.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
