Disable dvfs-core before the reboot process starts since its possible that the
core voltage is at 0.85V when reboot command was issued. This will cause the
reboot to fail since the ROM code does not set the core voltage.
Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
This patch contains changes to mach-mx5 files.
Contains all checkpatch and copyright fixes.
Acked-by: Rob Herring <r.herring@freescale.com>
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
Signed-off-by: Dmitriy Taychenachev <dimichxp@gmail.com>
This patch adds arch_reset() function for all mxc platforms.
It also removes (unsused) arch/arm/mach-mx2/system.c file.
This patch has been tested on i.MX1/27/31/35
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
