On MX51 the address space length for SSI is 16KB.
The imx25 sdma script only gets TO1 version, so there is no need
to encode "to1" in the variable name.
The value 0 is not a valid TO version number. With the current
code, imx-sdma driver will try to load firmware sdma-imx25-to0.bin,
which is obviously not a good name. Instead, sdma-imx25-to1.bin
makes much more sense.
The sdma on soc imx25 is not a V1 but V2 block.
The sdma on all imx soc gets 16K IO space not 4K.
Fix the following warning:
CC arch/arm/plat-mxc/iomux-v1.o
arch/arm/plat-mxc/iomux-v1.c: In function 'mxc_gpio_setup_multiple_pins':
arch/arm/plat-mxc/iomux-v1.c:160: warning: 'ret' may be used uninitialized in this function
arch/arm/plat-mxc/iomux-v1.c:160: note: 'ret' was declared here
When setting the IOMUX of multiple pins via mxc_gpio_setup_multiple_pins, gpio_request
is called and this prevents subsequent calls of gpio_request done by drivers to succeed.
Remove gpio_request call from mxc_gpio_setup_multiple_pins function.
As gpio_request is removed from mxc_gpio_setup_multiple_pins, there is no need to have
mxc_gpio_release_multiple_pins anymore, so remove this function.
Tested on a mx27_3ds board and after applying this patch it is possible to define all the
IOMUX setup in a static array
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
MX53 has 4 chip selects (CS0 - CS3) and the valid combinations are:
- CS0 (128MB)
- CS0 (64MB), CS1 (64MB)
- CS0 (64MB), CS1 (32MB), CS2 (32MB)
- CS0 (32MB), CS1 (32MB), CS2 (32MB) , CS3 (32MB)
Fix these addresses and also take into account all the four possibilities.
MX53_PAD_PATA_DATA6 can have the following alternate modes:
PATA_DATA_6: mode 0
GPIO2_6: mode 1
EMI_NANDF_D_6: mode 3
ESDHC4_DAT6 mode 4
GPU3d_GPU_DEBUG_OUT_6 mode 5
IPU_DIAG_BUS_6 mode 6
Fix the modes accordingly.
Signed-off-by: Dinh Nguyen <dinh.nguyen@freescale.com>
Acked-by: Olof Johansson <olof@lixom.net>
Platforms provide an empty irq_prio_table macro, and as nothing uses
this macro, it can simply be removed.
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
The patch makes necessary changes on gpio-mxc as below to turn it
into an upstanding gpio driver.
* Add a list to save all mx2 ports references, so that
mx2_gpio_irq_handler can walk through all interrupt status
registers
* Use readl/writel to replace mach-specific accessors
__raw_readl/__raw_writel
* Change mxc_gpio_init into mxc_gpio_probe function
* Move "struct mxc_gpio_port" into gpio-mxc.c, as it needs not to
be public at all, and also make some other cleanup on
plat-mxc/include/mach/gpio.h at the same time
And the patch then migrates mach-imx and mach-mx5 to the updated
driver by adding corresponding platform devices.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
GPIO drivers are getting moved to drivers/gpio for cleanup and
consolidation. This patch moves the plat-mxc driver. Follow up
patches will clean it up and make it a fine upstanding gpio driver.
Check the MX51 chip revision in run-time so that the correct SDMA firmware can
be loaded.
While at it also remove the silicon revision from the sdma_script_start_addrs
structure name for MX51. All the MX51 revisions share the same SDMA start addresses.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (137 commits)
ARM: bcmring: convert to use sp804 clockevents
ARM: bcmring: convert to sp804 clocksource
ARM: 6912/1: bcmring: Add clkdev table in init_early
clockevents: ARM sp804: obtain sp804 timer rate via clks
clockevents: ARM sp804: allow clockevent name to be specified
clocksource: ARM sp804: obtain sp804 timer rate via clks
clocksource: ARM sp804: allow clocksource name to be specified
clocksource: convert OMAP1 to 32-bit down counting clocksource
clocksource: convert MXS timrotv2 to 32-bit down counting clocksource
clocksource: convert SPEAr platforms 16-bit up counting clocksource
clocksource: convert Integrator/AP 16-bit down counting clocksource
clocksource: convert W90x900 24-bit down counting clocksource
clocksource: convert ARM 32-bit down counting clocksources
clocksource: convert ARM 32-bit up counting clocksources
clocksource: add common mmio clocksource
ARM: update sa1100 to reflect PXA updates
ARM: omap1: convert to using readl/writel instead of volatile struct
ARM: omap1: delete useless interrupt handler
ARM: s5p: consolidate selection of timer register
ARM: 6939/1: fix missing 'cpu_relax()' declaration
arch/arm/Kconfig
arch/arm/mach-ns9xxx/include/mach/uncompress.h
Convert SP804, MXC, Nomadik and Orion 32-bit down-counting clocksources
to generic mmio clocksource infrastructure.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Alessandro Rubini <rubini@unipv.it>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300
to use the generic mmio clocksource recently introduced.
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: "Hans J. Koch" <hjk@hansjkoch.de>
Acked-by: Colin Cross <ccross@android.com>
Cc: Erik Gilling <konkers@android.com>
Cc: Olof Johansson <olof@lixom.net>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
devel-stable
Fixing a few "please, no space before tabs" and "empty line at end of
file" warnings on the way.
LAKML-Reference: 1299271882-2130-6-git-send-email-u.kleine-koenig@pengutronix.de
LAKML-Reference: 1302464943-20721-6-git-send-email-u.kleine-koenig@pengutronix.de
To be able to compile e.g. i.MX31 and i.MX51 in a single kernel image
the ioremap quirk needs a runtime check.
While touching this code make the comment more understandable by adding
a sentence from the commit log that introduced it
(eadefef ([ARM] MX3: Use ioremap wrapper to map SoC devices nonshared)).
As mach/io.h now uses cpu_is_ some header reshuffling in mach/hardware.h
was necessary. (mach/mx27.h and mach/mx31.h #include <linux/io.h> which
#includes <mach/io.h>. So mach/mxc.h which provides the cpu_is_ macros
needs to be included before mach/mx27.h and mach/mx31.h.)
LAKML-Reference: 1302464943-20721-5-git-send-email-u.kleine-koenig@pengutronix.de
The two SoCs have different PHYS_OFFSETs so it's not (yet) possible to
compile a single (working) kernel for these.
LAKML-Reference: 1302464943-20721-4-git-send-email-u.kleine-koenig@pengutronix.de
The symbols in this choice should only be used to select between the
available machines that can be built into a single kernel. As these sets
(will) differ e.g. depending on ARM_PATCH_PHYS_VIRT and AUTO_ZRELADDR
letting them select other symbols makes the logic more complex and needs
to duplicate some things. So let the machines select the corresponding
symbols (indirectly via SOC_XYZ).
LAKML-Reference: 1302464943-20721-2-git-send-email-u.kleine-koenig@pengutronix.de
Since support for mxc91231 was introduced 2009 it only saw patches that
were part of (mxc or arm) global cleanups. The only supported machine
only had 4 devices (2x UART, sdhc, watchdog).
Cc: Dmitriy Taychenachev <dimichxp@gmail.com>
LAKML-Reference: 1302211482-17926-1-git-send-email-u.kleine-koenig@pengutronix.de
remove usage of CONFIG_ARCH_MX1. It's mostly unused anyway, replace
it with cpu_is_mx1() where necessary. Also, depend on
IMX_HAVE_PLATFORM_IMX_FB instead of the architectures directly.
LAKML-Reference: 20110303141244.GQ29521@pengutronix.de
Acked-by: Paul Mundt <lethal@linux-sh.org>
The platform id is used to determine the spi bus number, so it should
better be different to the ids used for imx51-ecspi. Otherwise it's not
possible to use both devices "imx51-cspi.0" and "imx51-ecspi.0".
Alternative approaches are to use dynamic bus numbering as offered by
the spi framework or let the machine code set the bus number. The
downside of both possibilities is that the bus number isn't fixed for
the same busses on different machines using i.MX51.
LAKML-Reference: 1302100716-21034-1-git-send-email-u.kleine-koenig@pengutronix.de
... together with the related devices "mx3_camera" and "mx3_sdc_fb".
"mx3_camera" doesn't fit the scheme of the other devices that just are
allocated and registered in a single function because it needs additional
care to get some dmaable memory. So currently imx31_alloc_mx3_camera
duplicates most of imx_add_platform_device_dmamask, but I'm not sure it's
worth to split the latter to be able to reuse more code.
This gets rid of mach-mx3/devices.[ch] and so several files need to be
adapted not to #include devices.h anymore.
LAKML-Reference: 1299271882-2130-5-git-send-email-u.kleine-koenig@pengutronix.de
LAKML-Reference: 1299271882-2130-2-git-send-email-u.kleine-koenig@pengutronix.de
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
LAKML-Reference: cae1d71db47204ee2654eca7391cb656ed53566b.1300095569.git.baruch@tkos.co.il
Reported-by: Igor Trevisan <igt1972@gmail.com>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
LAKML-Reference: 1299786904-5494-1-git-send-email-w.sang@pengutronix.de
Having the silicon revision to appear on the boot log is a useful information.
MX31, MX35 and MX51 already show the silicon revision on boot.
Add support for displaying such information for MX53 as well.
Tested on a mx53loco board, where it shows:
CPU identified as i.MX53, silicon rev 2.0
LAKML-Reference: 1301068367-18937-1-git-send-email-fabio.estevam@freescale.com
devel-stable
To be able to relocate the .bss section at run time independently from
the rest of the code, we must make sure that no GOTOFF relocations are
used with .bss symbols. This usually means that no global variables can
be marked static unless they're also const.
Let's remove the static qualifier from current offenders, or turn them
into const variables when possible. Next commit will ensure the build
fails if one of those is reintroduced due to otherwise enforced coding
standards for the kernel.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Using C line continuation inside format strings is error prone.
Clean up the unintended whitespace introduced by misuse of \.
Neaten correctly used line continations as well for consistency.
drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well,
but arcmsr needs a lot more work and the driver should likely be
moved to staging instead.
The irq_set_wake() function of the gpio irq_chip calls
enable/disable_irq_wake() on the demultiplex interrupt. That leads to
a lockdep warning "INFO: possible recursive locking detected" because
irq_set_type() is called under irq_desc->lock and the *_irq_wake()
calls take irq_desc->lock of the demux interrupt.
Tell lockdep that the gpio irqs are in a different lock class.
Documentation/SubmitChecklist:
15: All codepaths have been exercised with all lockdep features enabled.
That's a non-optional requirement, AFAICT.
Reported-and-tested-by: Arnaud Patard <arnaud.patard@rtp-net.org>
LAKML-Reference: alpine.LFD.2.00.1104041416290.19945@localhost6.localdomain6
Directives such as .long and .word do not magically cause the
assembler location counter to become aligned in gas. As a
result, using these directives in code sections can result in
misaligned data words when building a Thumb-2 kernel
(CONFIG_THUMB2_KERNEL).
This is a Bad Thing, since the ABI permits the compiler to
assume that fundamental types of word size or above are word-
aligned when accessing them from C. If the data is not really
word-aligned, this can cause impaired performance and stray
alignment faults in some circumstances.
In general, the following rules should be applied when using
data word declaration directives inside code sections:
* .quad and .double:
.align 3
* .long, .word, .single, .float:
.align (or .align 2)
* .short:
No explicit alignment required, since Thumb-2
instructions are always 2 or 4 bytes in size.
immediately after an instruction.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
LAKML-Reference: 1289913217-8672-1-git-send-email-dave.martin@linaro.org
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits)
ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support
ARM: 6838/1: etm: fix section mismatch warning
ARM: 6837/1: remove unused pci_fixup_prpmc1100
ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC
Fix the broken build for Marvell Dove platform.
ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency
ARM: 6834/1: perf: reset counters on all CPUs during initialisation
ARM: 6833/1: perf: add required isbs() to ARMv7 backend
ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues
ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile
arm: mach-mx3: pcm043: add write-protect and card-detect for SD1
eukrea_mbimxsd51: add SD Card detect
eukrea_mbimxsd25-baseboard: add SD card detect
mx3/eukrea_mbimxsd-baseboard: add SD card detect support
mx3/eukrea_mbimxsd-baseboard: fix gpio request
ARM: mxs/mx28evk: add mmc device
ARM: mxs/mx23evk: add mmc device
ARM: mxs: dynamically allocate mmc device
ARM: mx51_efika: update platform data for new mfd changes
mx2/iomux: Set direction for CSPI2 pins
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Convert to the new function names. Automated with coccinelle.
Signed-off-by: Julien Boibessot <julien.boibessot@armadeus.com>
Implement code for MX51 that allows the SoC to enter WFI when
arch_idle is called.
This patch is also necessary for correctly suspending the system.
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
For MX50, the HW_ADADIG_DIGPROG register in the ANATOP module will
have the correct silicon revision:
Major Minor Description
0x50 0x0 TO1.0
0x50 0x1 TO1.1
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
