path: root/arch/arm/plat-mxc
2012-12-17ARM: imx: Move platform-mx2-emma to arch/arm/mach-imx/devicesFabio Estevam
Move platform-mx2-emma to arch/arm/mach-imx/devices and fix the following build error: make[2]: *** No rule to make target `arch/arm/mach-imx/devices/platform-mx2-emma.o', needed by `arch/arm/mach-imx/devices/built-in.o'. Stop. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-11-16ARM : i.MX27 : split code for allocation of ressources of camera and eMMAGaëtan Carlier
This is to prepare addition of m2m-emmapp driver otherwise IMX_HAVE_PLATFORM_MX2_CAMERA must be declared even if only Post-Processor is needed. IMX_HAVE_PLATFORM_MX2_EMMA define has been added. Changes since v1: - Add "select IMX_HAVE_PLATFORM_MX2_EMMA" for MACH_IMX27_VISSTRIM_M10 platform due to pending patch in linux-media tree that will call imx27_add_mx2_emmaprp(). Signed-off-by: Gaëtan Carlier <gcembed@gmail.com> Acked-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-10-15ARM: imx: merge plat-mxc into mach-imxShawn Guo
It's really unnecessary to have plat-mxc, and let's merge it into mach-imx. It's pretty much just a bunch of file renaming and Kconfig/Makefile merge. To make the change less invasive, we keep using Kconfig symbol CONFIG_ARCH_MXC for mach-imx sub-architecture. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: move platform device code into mach-imxShawn Guo
It moves platform device code from plat-mxc into mach-imx. Along with that, header devices-common.h gets moved from plat-mxc/include/mach/ into mach-imx/devices/. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: move iomux drivers and headers into mach-imxShawn Guo
The board files in mach-imx are the only users of iomux drivers and headers. Move them into mach-imx from plat-mxc. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: include board headers in the same folderShawn Guo
The headers that are only used by board files do not necessarily need to be in plat-mxc/include/mach. Move them to the same place as those board files. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-13ARM: config: sort select statements alphanumericallyRussell King
As suggested by Andrew Morton: This is a pet peeve of mine. Any time there's a long list of items (header file inclusions, kconfig entries, array initalisers, etc) and someone wants to add a new item, they *always* go and stick it at the end of the list. Guys, don't do this. Either put the new item into a randomly-chosen position or, probably better, alphanumerically sort the list. lets sort all our select statements alphanumerically. This commit was created by the following perl: while (<>) { while (/\\\s*$/) { $_ .= <>; } undef %selects if /^\s*config\s+/; if (/^\s+select\s+(\w+).*/) { if (defined($selects{$1})) { if ($selects{$1} eq $_) { print STDERR "Warning: removing duplicated $1 entry\n"; } else { print STDERR "Error: $1 differently selected\n". "\tOld: $selects{$1}\n". "\tNew: $_\n"; exit 1; } } $selects{$1} = $_; next; } if (%selects and (/^\s*$/ or /^\s+help/ or /^\s+---help---/ or /^endif/ or /^endchoice/)) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } undef %selects; } print; } if (%selects) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } } It found two duplicates: Warning: removing duplicated S5P_SETUP_MIPIPHY entry Warning: removing duplicated HARDIRQS_SW_RESEND entry and they are identical duplicates, hence the shrinkage in the diffstat of two lines. We have four testers reporting success of this change (Tony, Stephen, Linus and Sekhar.) Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-10-09Merge tag 'disintegrate-mtd-20121009' of ↵David Woodhouse
git://git.infradead.org/users/dhowells/linux-headers UAPI Disintegration 2012-10-09 Conflicts: MAINTAINERS arch/arm/configs/bcmring_defconfig arch/arm/mach-imx/clk-imx51-imx53.c drivers/mtd/nand/Kconfig drivers/mtd/nand/bcm_umi_nand.c drivers/mtd/nand/nand_bcm_umi.h drivers/mtd/nand/orion_nand.c
2012-10-07Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "The first part of the media updates for Kernel 3.7. This series contain: - A major tree renaming patch series: now, drivers are organized internally by their used bus, instead of by V4L2 and/or DVB API, providing a cleaner driver location for hybrid drivers that implement both APIs, and allowing to cleanup the Kconfig items and make them more intuitive for the end user; - Media Kernel developers are typically very lazy with their duties of keeping the MAINTAINERS entries for their drivers updated. As now the tree is more organized, we're doing an effort to add/update those entries for the drivers that aren't currently orphan; - Several DVB USB drivers got moved to a new DVB USB v2 core; the new core fixes several bugs (as the existing one that got bitroted). Now, suspend/resume finally started to work fine (at least with some devices - we should expect more work with regards to it); - added multistream support for DVB-T2, and unified the API for DVB-S2 and ISDB-S. Backward binary support is preserved; - as usual, a few new drivers, some V4L2 core improvements and lots of drivers improvements and fixes. There are some points to notice on this series: 1) you should expect a trivial merge conflict on your tree, with the removal of Documentation/feature-removal-schedule.txt: this series would be adding two additional entries there. I opted to not rebase it due to this recent change; 2) With regards to the PCTV 520e udev-related breakage, I opted to fix it in a way that the patches can be backported to 3.5 even without your firmware fix patch. This way, Greg doesn't need to rush backporting your patch (as there are still the firmware cache and firmware path customization issues to be addressed there). I'll send later a patch (likely after the end of the merge window) reverting the rest of the DRX-K async firmware request, fully restoring its original behaviour to allow media drivers to initialize everything serialized as before for 3.7 and upper. 3) I'm planning to work on this weekend to test the DMABUF patches for V4L2. The patches are on my queue for several Kernel cycles, but, up to now, there is/was no way to test the series locally. I have some concerns about this particular changeset with regards to security issues, and with regards to the replacement of the old VIDIOC_OVERLAY ioctl's that is broken on modern systems, due to GPU drivers change. The Overlay API allows direct PCI2PCI transfers from a media capture card into the GPU framebuffer, but its API is crappy. Also, the only existing X11 driver that implements it requires a XV extension that is not available anymore on modern drivers. The DMABUF can do the same thing, but with it is promising to be a properly-designed API. If I can successfully test this series and be happy with it, I should be asking you to pull them next week." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (717 commits) em28xx: regression fix: use DRX-K sync firmware requests on em28xx drxk: allow loading firmware synchrousnously em28xx: Make all em28xx extensions to be initialized asynchronously [media] tda18271: properly report read errors in tda18271_get_id [media] tda18271: delay IR & RF calibration until init() if delay_cal is set [media] MAINTAINERS: add Michael Krufky as tda827x maintainer [media] MAINTAINERS: add Michael Krufky as tda8290 maintainer [media] MAINTAINERS: add Michael Krufky as cxusb maintainer [media] MAINTAINERS: add Michael Krufky as lg2160 maintainer [media] MAINTAINERS: add Michael Krufky as lgdt3305 maintainer [media] MAINTAINERS: add Michael Krufky as mxl111sf maintainer [media] MAINTAINERS: add Michael Krufky as mxl5007t maintainer [media] MAINTAINERS: add Michael Krufky as tda18271 maintainer [media] s5p-tv: Report only multi-plane capabilities in vidioc_querycap [media] s5p-mfc: Fix misplaced return statement in s5p_mfc_suspend() [media] exynos-gsc: Add missing static storage class specifiers [media] exynos-gsc: Remove <linux/version.h> header file inclusion [media] s5p-fimc: Fix incorrect condition in fimc_lite_reqbufs() [media] s5p-tv: Fix potential NULL pointer dereference error [media] s5k6aa: Fix possible NULL pointer dereference ...
2012-10-01Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc multiplatform enablement from Olof Johansson: "This is a pretty significant branch. It's the introduction of the first multiplatform support on ARM, and with this (and the later branch) merged, it is now possible to build one kernel that contains support for highbank, vexpress, mvebu, socfpga, and picoxcell. More platforms will be convered over in the next few releases. Two critical last things had to be done for this to be practical and possible: * Today each platform has its own include directory under mach-<mach>/include/mach/*, and traditionally that is where a lot of driver/platform shared definitions have gone, such as platform data structures. They now need to move out to a common location instead, and this branch moves a large number of those out to include/linux/platform_data. * Each platform used to list the device trees to compile for its boards in mach-<mach>/Makefile.boot. Both of the above changes will mean that there are some merge conflicts to come (and some to resolve here). It's a one-time move and once it settles in, we should be good for quite a while. Sorry for the overhead." Fix conflicts as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits) ARM: add v7 multi-platform defconfig ARM: msm: Move core.h contents into common.h ARM: highbank: call highbank_pm_init from .init_machine ARM: dtb: move all dtb targets to common Makefile ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ...
2012-10-01Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc device tree updates from Olof Johansson: "Device tree conversion and enablement branch. Mostly a bunch of new bindings and setup for various platforms, but the Via/Winchip VT8500 platform is also converted over from being 100% legacy to now use device tree for probing. More of that will come for 3.8." Trivial conflicts due to removal of vt8500 files, and one documentation file that was added with slightly different contents both here and in the USb tree. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (212 commits) arm: vt8500: Fixup for missing gpio.h ARM: LPC32xx: LED fix in PHY3250 DTS file ARM: dt: mmp-dma: add binding file arm: vt8500: Update arch-vt8500 to devicetree support. arm: vt8500: gpio: Devicetree support for arch-vt8500 arm: vt8500: doc: Add device tree bindings for arch-vt8500 devices arm: vt8500: clk: Add Common Clock Framework support video: vt8500: Add devicetree support for vt8500-fb and wm8505-fb serial: vt8500: Add devicetree support for vt8500-serial rtc: vt8500: Add devicetree support for vt8500-rtc arm: vt8500: Add device tree files for VIA/Wondermedia SoC's ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support ARM: tegra: Add Avionic Design Medcom-Wide support ARM: tegra: Add Avionic Design Plutux support ARM: tegra: Add Avionic Design Tamonten support ARM: tegra: dts: Add pwm label ARM: ux500: Fix SSP register address format ARM: ux500: Apply tc3589x's GPIO/IRQ properties to HREF's DT ARM: ux500: Remove redundant #gpio-cell properties from Snowball DT ARM: ux500: Add all encompassing sound node to the HREF Device Tree ...
2012-10-01Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc-specific updates from Olof Johansson: "Most notable here is probably the addition of basic support for the BCM2835, an SoC used in some of the Roku 2 players as well as the much-hyped Raspberry Pi, cleaned up and contributed by Stephen Warren. It's still early days on mainline support, with just the basics working. But it has to start somewhere! Beyond that there's some conversions of clock infrastructure on tegra to common clock, misc updates for several other platforms, and OMAP now has its own bus (under drivers/bus) to manage its devices through. This branch adds two new directories outside of arch/arm: drivers/irqchip for new irq controllers, and drivers/bus for the above OMAP bus. It's expected that some of the other platforms will migrate parts of their platforms to those directories over time as well." Fix up trivial conflicts with the clk infrastructure changes. * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (62 commits) ARM: shmobile: add new __iomem annotation for new code ARM: LPC32xx: Support GPI 28 ARM: LPC32xx: Platform update for devicetree completion of spi-pl022 ARM: LPC32xx: Board cleanup irqchip: fill in empty Kconfig ARM: SAMSUNG: Add check for NULL in clock interface ARM: EXYNOS: Put PCM, Slimbus, Spdif clocks to off state ARM: EXYNOS: Add bus clock for FIMD ARM: SAMSUNG: Fix HDMI related warnings ARM: S3C24XX: Add .get_rate callback for "camif-upll" clock ARM: EXYNOS: Fix incorrect help text ARM: EXYNOS: Turn off clocks for NAND, OneNAND and TSI controllers ARM: OMAP: AM33xx hwmod: fixup SPI after platform_data move MAINTAINERS: add an entry for the BCM2835 ARM sub-architecture ARM: bcm2835: instantiate console UART ARM: bcm2835: add stub clock driver ARM: bcm2835: add system timer ARM: bcm2835: add interrupt controller driver ARM: add infra-structure for BCM2835 and Raspberry Pi ARM: tegra20: add CPU hotplug support ...
2012-10-01Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc general cleanups from Olof Johansson: "This is a large branch that contains a handful of different cleanups: - Fixing up the I/O space remapping on PCI on ARM. This is a series from Rob Herring that restructures how all pci devices allocate I/O space, and it's part of the work to allow multiplatform kernels. - A number of cleanup series for OMAP, moving and removing some headers, sparse irq rework and in general preparation for multiplatform. - Final removal of all non-DT boards for Tegra, it is now device-tree-only! - Removal of a stale platform, nxp4008. It's an old mobile chipset that is no longer in use, and was very likely never really used with a mainline kernel. We have not been able to find anyone interested in keeping it around in the kernel. - Removal of the legacy dmaengine driver on tegra + A handful of other things that I haven't described above." Fix up some conflicts with the staging tree (and because nxp4008 was removed) * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (184 commits) ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6 ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus ARM: mmp: using for_each_set_bit to simplify the code ARM: tegra: harmony: fix ldo7 regulator-name ARM: OMAP2+: Make omap4-keypad.h local ARM: OMAP2+: Make l4_3xxx.h local ARM: OMAP2+: Make l4_2xxx.h local ARM: OMAP2+: Make l3_3xxx.h local ARM: OMAP2+: Make l3_2xxx.h local ARM: OMAP1: Move irda.h from plat to mach ARM: OMAP2+: Make hdq1w.h local ARM: OMAP2+: Make gpmc-smsc911x.h local ARM: OMAP2+: Make gpmc-smc91x.h local ARM: OMAP1: Move flash.h from plat to mach ARM: OMAP2+: Make debug-devices.h local ARM: OMAP1: Move board-voiceblue.h from plat to mach ARM: OMAP1: Move board-sx1.h from plat to mach ARM: OMAP2+: Make omap-wakeupgen.h local ARM: OMAP2+: Make omap-secure.h local ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local ...
2012-10-01Merge tag 'v3.6' into staging/for_v3.7Mauro Carvalho Chehab
Linux 3.6 * tag 'v3.6': (562 commits) Linux 3.6 vfs: dcache: fix deadlock in tree traversal mtdchar: fix offset overflow detection thp: avoid VM_BUG_ON page_count(page) false positives in __collapse_huge_page_copy iommu/amd: Fix wrong assumption in iommu-group specific code netdev: octeon: fix return value check in octeon_mgmt_init_phy() ALSA: snd-usb: fix next_packet_size calls for pause case inetpeer: fix token initialization qlcnic: Fix scheduling while atomic bug bnx2: Clean up remaining iounmap trivial select_parent documentation fix net: phy: smsc: Implement PHY config_init for LAN87xx smsc75xx: fix resume after device reset um: Preinclude include/linux/kern_levels.h um: Fix IPC on um netdev: pasemi: fix return value check in pasemi_mac_phy_init() team: fix return value check l2tp: fix return value check USB: Fix race condition when removing host controllers USB: ohci-at91: fix null pointer in ohci_hcd_at91_overcurrent_irq ...
2012-09-22Merge branch 'cleanup/__iomem' into next/cleanupOlof Johansson
__iomem annotation cleanup branch from Arnd. * cleanup/__iomem: (21 commits) net: seeq: use __iomem pointers for MMIO video: da8xx-fb: use __iomem pointers for MMIO scsi: eesox: use __iomem pointers for MMIO serial: ks8695: use __iomem pointers for MMIO input: rpcmouse: use __iomem pointers for MMIO ARM: samsung: use __iomem pointers for MMIO ARM: spear13xx: use __iomem pointers for MMIO ARM: sa1100: use __iomem pointers for MMIO ARM: prima2: use __iomem pointers for MMIO ARM: nomadik: use __iomem pointers for MMIO ARM: msm: use __iomem pointers for MMIO ARM: lpc32xx: use __iomem pointers for MMIO ARM: ks8695: use __iomem pointers for MMIO ARM: ixp4xx: use __iomem pointers for MMIO ARM: iop32x: use __iomem pointers for MMIO ARM: iop13xx: use __iomem pointers for MMIO ARM: integrator: use __iomem pointers for MMIO ARM: imx: use __iomem pointers for MMIO ARM: ebsa110: use __iomem pointers for MMIO ARM: at91: use __iomem pointers for MMIO ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'multiplatform/platform-data' into next/multiplatformOlof Johansson
* multiplatform/platform-data: ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: nomadik: move platform_data definitions ARM: w90x900: move platform_data definitions ARM: vt8500: move platform_data definitions ARM: tegra: move sdhci platform_data definition ARM: sa1100: move platform_data definitions ARM: pxa: move platform_data definitions ARM: netx: move platform_data definitions ARM: msm: move platform_data definitions ARM: imx: move platform_data definitions ARM: ep93xx: move platform_data definitions ARM: davinci: move platform_data definitions ARM: at91: move platform_data definitions Conflicts due to removed files: arch/arm/mach-tegra/board-harmony.c arch/arm/mach-tegra/board-trimslice.c Conflicts due to code removal: arch/arm/mach-tegra/board-paz00.c Context conflicts in: drivers/mmc/host/sdhci-tegra.c drivers/net/irda/pxaficp_ir.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'multiplatform/smp_ops' into next/multiplatformOlof Johansson
* multiplatform/smp_ops: ARM: consolidate pen_release instead of having per platform definitions ARM: smp: Make SMP operations mandatory ARM: SoC: convert spear13xx to SMP operations ARM: SoC: convert imx6q to SMP operations ARM: SoC: convert highbank to SMP operations ARM: SoC: convert shmobile SMP to SMP operations ARM: SoC: convert ux500 to SMP operations ARM: SoC: convert MSM to SMP operations ARM: SoC: convert Exynos4 to SMP operations ARM: SoC: convert Tegra to SMP operations ARM: SoC: convert OMAP4 to SMP operations ARM: SoC: convert VExpress/RealView to SMP operations ARM: SoC: add per-platform SMP operations Conflicts due to file moves or removals in: arch/arm/mach-msm/board-msm8960.c arch/arm/mach-msm/board-msm8x60.c arch/arm/mach-tegra/board-harmony.c arch/arm/mach-tegra/board-trimslice.c Conflicts due to board file cleanup: arch/arm/mach-tegra/board-paz00.c Conflicts due to cpu hotplug addition: arch/arm/mach-tegra/hotplug.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-20Merge tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/multiplatform Enable initial ARM multi-platform support for highbank, mvebu, socfpga, picoxcell, and vexpress. Multi-platform support is dependent on mach/gpio.h removal and restructuring of DEBUG_LL and dtb build rules included in this branch. This has been built for all defconfigs, and booted on highbank with all 5 platforms enabled. By Rob Herring (18) and Arnd Bergmann (1) via Rob Herring * tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux: ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ARM: orion: move custom gpio functions to orion-gpio.h ARM: shmobile: move custom gpio functions to sh-gpio.h ARM: pxa: use gpio_to_irq for sharppm_sl net: pxaficp_ir: add irq resources usb: pxa27x_udc: remove IRQ_USB define staging: ste_rmi4: remove gpio.h include Conflicts due to addition of bcm2835 and removal of pnx4008 in: arch/arm/Kconfig arch/arm/Makefile Conflicts due to new dtb targets, moved to arch/arm/boot/dts/Makefile in: arch/arm/mach-imx/Makefile.boot arch/arm/mach-mxs/Makefile.boot arch/arm/mach-tegra/Makefile.boot Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-20Merge branch 'next/soc' into next/multiplatformOlof Johansson
* next/soc: (50 commits) ARM: OMAP: AM33xx hwmod: fixup SPI after platform_data move MAINTAINERS: add an entry for the BCM2835 ARM sub-architecture ARM: bcm2835: instantiate console UART ARM: bcm2835: add stub clock driver ARM: bcm2835: add system timer ARM: bcm2835: add interrupt controller driver ARM: add infra-structure for BCM2835 and Raspberry Pi ARM: tegra20: add CPU hotplug support ARM: tegra30: add CPU hotplug support ARM: tegra: clean up the common assembly macros into sleep.h ARM: tegra: replace the CPU CAR access code by tegra_cpu_car_ops ARM: tegra: introduce tegra_cpu_car_ops structures ARM: Tegra: Add smp_twd clock for Tegra20 ARM: AM33XX: clock: Add dcan clock aliases for device-tree ARM: OMAP2+: dpll: Add missing soc_is_am33xx() check for common functions ARM: OMAP: omap_device: idle devices with no driver bound ARM: OMAP: omap_device: don't attempt late suspend if no driver bound ARM: OMAP: omap_device: keep track of driver bound status ARM: OMAP3+: hwmod: Add AM33XX HWMOD data ARM: OMAP2+: hwmod: Hook-up am33xx support in omap_hwmod framework ... Change/remove conflict in arch/arm/mach-ux500/clock.c resolved. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-20Merge branch 'next/dt' into next/multiplatformOlof Johansson
* next/dt: (182 commits) ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support ARM: tegra: Add Avionic Design Medcom-Wide support ARM: tegra: Add Avionic Design Plutux support ARM: tegra: Add Avionic Design Tamonten support ARM: tegra: dts: Add pwm label ARM: dt: tegra: whistler: configure power off ARM: mxs: m28evk: Disable OCOTP OUI loading ARM: imx6q: use pll2_pfd2_396m as the enfc_sel's parent ARM: dts: imx6q-sabrelite: add usbotg pinctrl support ARM: dts: imx23-olinuxino: Add USB host support ARM: dts: imx6q-sabrelite: add usbmisc device ARM: dts: mx23: Add USB resources ARM: dts: mxs: Add ethernetX to macX aliases ARM: msm: Remove non-DT targets from 8960 ARM: msm: Add DT support for 8960 ARM: msm: Move io mapping prototypes to common.h ARM: msm: Rename board-msm8x60 to signify its DT only status ARM: msm: Make 8660 a DT only target ARM: msm: Move 8660 to DT timer ARM: msm: Add DT support to msm_timer ...
2012-09-19ARM: imx: use __iomem pointers for MMIOArnd Bergmann
ARM is moving to stricter checks on readl/write functions, so we need to use the correct types everywhere. This found a bug in mach-armadillo5x0.c, where we attempt mmio on the MXC_CCM_RCSR address that is currently defined to 0xc and consequently causes an illegal address access. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Shawn Guo <shawn.guo@linaro.org>
2012-09-18ARM i.MX25: Make timer irq work againSascha Hauer
Since i.MX has SPARSE_IRQ enabled the i.MX25 timer is broken. This is because the internal irqs now start at an offset of NR_IRQS_LEGACY. The patch fixed this up, but missed the i.MX25 timer which used a hardcoded value instead of a define. This patch introduces a define for the timer irq and uses it. This is broken since introduced with 3.6-rc1: | commit 8842a9e2869cae14bbb8184004a42fc3070587fb | Author: Shawn Guo <shawn.guo@linaro.org> | Date: Thu Jun 14 11:16:14 2012 +0800 | | ARM: imx: enable SPARSE_IRQ for imx platform Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-09-14ARM: make mach/gpio.h headers optionalRob Herring
Most platforms don't need mach/gpio.h and it prevents multi-platform kernel images. Add CONFIG_NEED_MACH_GPIO_H and make platforns select it if they need gpio.h. This is platforms that define __GPIOLIB_COMPLEX or have lots of implicit includes pulled in by mach/gpio.h. at91 and omap have gpio clean-up pending and can drop CONFIG_NEED_MACH_GPIO_H once that is in. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-14ARM: imx: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the imx include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Sascha Hauer <kernel@pengutronix.de> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Dan Williams <djbw@fb.com> Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org> Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Alan Cox <alan@linux.intel.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Liam Girdwood <lrg@ti.com> Cc: Javier Martin <javier.martin@vista-silicon.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2012-09-14ARM: SoC: convert imx6q to SMP operationsMarc Zyngier
Convert the imx6q platform to use struct smp_operations to provide its SMP and CPU hotplug operations. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-09-12serial/imx: fix IMX UART macro usage to reflect correct processorOskar Schirmer
Platform dependant UART data refers to MX31 macro for MX35 machines. For all other machines, macro usage matches machine type. Though this compiles out to the same result, it looks much like a typo, so fix it to use the right macros instead. Signed-off-by: Oskar Schirmer <oskar@scara.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-09-12ARM: i.MX remove last leftovers from legacy clock supportSascha Hauer
This also removes mach/clock.h along the way Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Mike Turquette <mturquette@linaro.org>
2012-09-12ARM: i.MX clk pllv1: move mxc_decode_pll code to its userSascha Hauer
The only code using mxc_decode_pll is clk-pllv1.c, so move the code there. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Mike Turquette <mturquette@linaro.org>
2012-09-11ARM: imx51: decouple device tree boot from board filesShawn Guo
Now, imx51 device tree kernel calls pinctrl to set up pins. The function used to hook up non-DT pin setup is not needed for DT boot any more. Remove it from DT image. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-09-11ARM: imx53: remove unneeded files and functionsShawn Guo
Now imx53 is a device tree only platform, so the files and functions used only by non-DT kernel can be removed. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-09-11ARM: imx53: decouple device tree boot from board filesShawn Guo
Now, imx53 device tree kernel calls pinctrl to set up pins. The functions used to hook up non-DT pin setup is not needed for DT boot any more. Remove them from DT image. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-08-28ARM i.MX mx2_camera: Remove MX2_CAMERA_SWAP16 and MX2_CAMERA_PACK_DIR_MSB flags.Javier Martin
These flags are not used any longer and can be safely removed since: | commit 8a76e5383fb5f58868fdd3a2fe1f4b95988f10a8 | Author: Javier Martin <javier.martin@vista-silicon.com> | Date: Wed Jul 11 17:34:54 2012 +0200 | | media: mx2_camera: Fix mbus format handling Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-08-22Merge tag 'v3.6-rc2' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux Having missed the merge window, update to 3.6-rc2 to avoid conflicts with new patches. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-08-13ARM: mxc: ssi-fiq: Make ssi-fiq.S Thumb-2 compatibleDave Martin
Because FIQ handlers get copied straight into the vectors page to the FIQ vector entry point, FIQ handlers in a Thumb-2 kernel must start in Thumb-2. A Thumb-2 kernel enters all exception vectors in Thumb-2. This patch adapts the mxc SSI FIQ code suitable for a Thumb-2 kernel. The code contained use of r13 (sp) which isn't allowed in Thumb-2. r11 and r13 have been swapped throughout the file to work around this. Currently, the way that the function to be copied is located using labels is a bit ugly: we cannot annotate the FIQ handler properly as a Thumb-2 function, because this would set bit 0 of the label address seen by the linker, causing off-by-one errors when copying the function. Ideally, the copy would be done with fncpy(), but this would require changes to the common set_fiq_handler() function. For now, we don't touch this. References to locally-defined global symbols with adr and ldr may not be accepted by the assembler in Thumb-2. Local shadow symbols are added to work around this. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-08-10ARM: plat-mxc: Remove unused imx_ioremapFabio Estevam
imx_ioremap is no longer used on imx platforms, so remove it. As the EXPORT_SYMBOL_GPL is removed, it is also safe to remove the module.h header. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-08-06[media] i.MX: coda: Add platform support for coda in i.MX27Javier Martin
i.MX27 SoC include a codadx6 codec that is able to encode and decode H.264, H.263 and MPEG4. Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-03arm imx31: add a few pinmux settings the tt01 needsTorben Hohn
These are the Pinmux Settings for the PP4 SSI Port multiplexible onto the first UART Pins. Signed-off-by: Torben Hohn <torbenh@linutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-08-02Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A few fixes for merge window fallout, and a bugfix for timer resume on PRIMA2." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: mmp: add missing irqs.h arm: mvebu: fix typo in .dtsi comment for Armada XP SoCs ARM: PRIMA2: delete redundant codes to restore LATCHED when timer resumes ARM: mxc: Include missing irqs.h header
2012-07-30Merge branch 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull PWM subsystem from Thierry Reding: "The new PWM subsystem aims at collecting all implementations of the legacy PWM API and to eventually replace it completely. The subsystem has been in development for over half a year now and many drivers have already been converted. It has been in linux-next for a couple of weeks and there have been no major issues so I think it is ready for inclusion in your tree." Arnd Bergmann <arnd@arndb.de>: "Very much Ack on the new subsystem. It uses the interface declarations as the previously separate pwm drivers, so nothing changes for now in the drivers using it, although it enables us to change those more easily in the future if we want to. This work is also one of the missing pieces that are required to eventually build ARM kernels for multiple platforms, which is currently prohibited (amongs other things) by the fact that you cannot have more than one driver exporting the pwm functions." Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sachin Kamat <sachin.kamat@linaro.org> Fix up trivial conflicts with other cleanups and DT updates. * 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits) pwm: pwm-tiehrpwm: PWM driver support for EHRPWM pwm: pwm-tiecap: PWM driver support for ECAP APWM pwm: fix used-uninitialized warning in pwm_get() pwm: add lpc32xx PWM support pwm_backlight: pass correct brightness to callback pwm: Use pr_* functions in pwm-samsung.c file pwm: Convert pwm-samsung to use devm_* APIs pwm: Convert pwm-tegra to use devm_clk_get() pwm: pwm-mxs: Return proper error if pwmchip_remove() fails pwm: pwm-bfin: Return proper error if pwmchip_remove() fails pwm: pxa: Propagate pwmchip_remove() error pwm: Convert pwm-pxa to use devm_* APIs pwm: Convert pwm-vt8500 to use devm_* APIs pwm: Convert pwm-imx to use devm_* APIs pwm: Conflict with legacy PWM API pwm: pwm-mxs: add pinctrl support pwm: pwm-mxs: use devm_* managed functions pwm: pwm-mxs: use global reset function stmp_reset_block pwm: pwm-mxs: encode soc name in compatible string pwm: Take over maintainership of the PWM subsystem ...
2012-07-28ARM: mxc: Include missing irqs.h headerFabio Estevam
Include irqs.h in order to fix the following build error: arch/arm/plat-mxc/tzic.c:195:11: error: 'FIQ_START' undeclared (first use in this function) Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-07-28Merge branch 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linuxLinus Torvalds
Pull embedded i2c changes from Wolfram Sang: "Changes for the "embedded" part of the I2C subsystem: - lots of devicetree conversions of drivers (and preparations for that) - big cleanups for drivers for OMAP, Tegra, Nomadik, Blackfin - Rafael's struct dev_pm_ops conversion patches for I2C - usual driver cleanups and fixes All patches have been in linux-next for an apropriate time and all patches touching files outside of i2c-folders should have proper acks from the maintainers." * 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (60 commits) Revert "i2c: tegra: convert normal suspend/resume to *_noirq" I2C: MV64XYZ: Add Device Tree support i2c: stu300: use devm managed resources i2c: i2c-ocores: support for 16bit and 32bit IO V4L/DVB: mfd: use reg_shift instead of regstep i2c: i2c-ocores: Use reg-shift property i2c: i2c-ocores: DT bindings and minor fixes. i2c: mv64xxxx: remove EXPERIMENTAL tag i2c-s3c2410: Use plain pm_runtime_put() i2c: s3c2410: Fix pointer type passed to of_match_node() i2c: mxs: Set I2C timing registers for mxs-i2c i2c: i2c-bfin-twi: Move blackfin TWI register access Macro to head file. i2c: i2c-bfin-twi: Move TWI peripheral pin request array to platform data. i2c:i2c-bfin-twi: include twi head file i2c:i2c-bfin-twi: TWI fails to restart next transfer in high system load. i2c: i2c-bfin-twi: Tighten condition when failing I2C transfer if MEN bit is reset unexpectedly. i2c: i2c-bfin-twi: Break dead waiting loop if i2c device misbehaves. i2c: i2c-bfin-twi: Improve the patch for bug "Illegal i2c bus lock upon certain transfer scenarios". i2c: i2c-bfin-twi: Illegal i2c bus lock upon certain transfer scenarios. i2c-mv64xxxx: allow more than one driver instance ... Conflicts: drivers/i2c/busses/i2c-nomadik.c
2012-07-23Merge tag 'clk' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clk changes from Arnd Bergmann: "Clock support is moving to the clk subsystem. These tegra, omap and imx changes are for code that is still platform specific and not (yet) part of that subsystem." Fix up conflicts in arch/arm/mach-{imx/clk-imx51-imx53.c,omap2/Makefile} * tag 'clk' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits) ARM: imx: clk-imx31: Fix clock id for rnga driver ARM: imx: add missing item to the list of clock event modes ARM: i.MX5x CSPI: Fixed clock name for CSPI ARM: i.MX5x clocks: Fix GPT clocks ARM: i.MX5x clocks: Fix parent for PWM clocks ARM: i.MX5x clocks: Add EPIT support ARM: mx27: Reenable silicon version print ARM: clk-imx27: Fix rtc clock id ARM: tegra: Provide clock for only one PWM controller ARM: tegra: Fix PWM clock programming ARM: OMAP3+: clock33xx: Add AM33XX clock tree data ARM: OMAP3+: clock: Move common clksel_rate & clock data to common file ARM: tegra: dma: rename driver name for clock to "tegra-apbdma" ARM: tegra: Remove second instance of uart clk crypto: add clk_prepare/clk_unprepare ASoC: tegra: add clk_prepare/clk_unprepare staging: nvec: add clk_prepare/clk_unprepare spi/tegra: add clk_prepare/clk_unprepare Input: tegra-kbc - add clk_prepare/clk_unprepare USB: ehci-tegra: add clk_prepare/clk_unprepare ...
2012-07-23Merge tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc power management changes from Arnd Bergmann: "These are various power management related changes, mainly concerning cpuidle on i.MX and OMAP, as well as a the move of the omap smartreflex driver to live in the power subsystem." Fix up conflicts in arch/arm/mach-{imx/mach-imx6q.c,omap2/prm2xxx_3xxx.h} * tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits) ARM: OMAP2+: PM: fix IRQ_NOAUTOEN removal by mis-merge ARM: OMAP2+: do not allow SmartReflex to be built as a module ARM: OMAP2: Use hwmod to initialize mmc for 2420 ARM: OMAP3: PM: cpuidle: optimize the clkdm idle latency in C1 state ARM: OMAP3: PM: cpuidle: optimize the PER latency in C1 state ARM: OMAP3: PM: cpuidle: default to C1 in next_valid_state ARM: OMAP3: PM: cleanup cam_pwrdm leftovers ARM: OMAP3: PM: call pre/post transition per powerdomain ARM: OMAP2+: powerdomain: allow pre/post transtion to be per pwrdm ARM: OMAP3: PM: Remove IO Daisychain control from cpuidle ARM: OMAP3PLUS: hwmod: reconfigure IO Daisychain during hwmod mux ARM: OMAP3+: PRM: Enable IO wake up ARM: OMAP4: PRM: Add IO Daisychain support ARM: OMAP3: PM: Move IO Daisychain function to omap3 prm file ARM: OMAP3: PM: correct enable/disable of daisy io chain ARM: OMAP2+: PRM: fix compile for OMAP4-only build W1: OMAP HDQ1W: use runtime PM ARM: OMAP2+: HDQ1W: use omap_device W1: OMAP HDQ1W: use 32-bit register accesses W1: OMAP HDQ1W: allow driver to be built on all OMAP2+ ...
2012-07-23Merge tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc sparse IRQ conversion from Arnd Bergmann: "The I.MX platform is getting converted to use sparse IRQs. We are doing this for all platforms over time, because this is one of the requirements for building a multiplatform kernel, and generally a good idea." * tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: imx: select USE_OF ARM: imx: Fix build error due to missing irqs.h include ARM: imx: enable SPARSE_IRQ for imx platform ARM: fiq: change FIQ_START to a variable tty: serial: imx: remove the use of MXC_INTERNAL_IRQS ARM: imx: remove unneeded mach/irq.h inclusion i2c: imx: remove unneeded mach/irqs.h inclusion ARM: imx: add a legacy irqdomain for mx31ads ARM: imx: add a legacy irqdomain for 3ds_debugboard ARM: imx: pass gpio than irq number into mxc_expio_init ARM: imx: leave irq_base of wm8350_platform_data uninitialized dma: ipu: remove the use of ipu_platform_data ARM: imx: move irq_domain_add_legacy call into avic driver ARM: imx: move irq_domain_add_legacy call into tzic driver gpio/mxc: move irq_domain_add_legacy call into gpio driver ARM: imx: eliminate macro IRQ_GPIOx() ARM: imx: eliminate macro IOMUX_TO_IRQ() ARM: imx: eliminate macro IMX_GPIO_TO_IRQ()
2012-07-23Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc device tree description updates from Arnd Bergmann: "This branch contains two kinds of updates: Some platforms in the process of getting converted to device tree based booting, and the platform specific patches necessary for that are included here. Other platforms are already converted, so we just need to update the actual device tree source files and the binding documents to add support for new board and new drivers. In the future we will probably separate those into two branches, and in the long run, the plan is to move the device tree source files out of the kernel repository, but that has to wait until we have completed a much larger portion of the binding documents." Fix up trivial conflicts in arch/arm/mach-imx/clk-imx6q.c due to newly added clkdev registers next to a few removed unnecessary ones. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: LPC32xx: Add PWM to base dts file ARM: EXYNOS: mark the DMA channel binding for SPI as preliminary ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS5 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOS5 ARM: EXYNOS: Add spi clock support for EXYNOS5 ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS4 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOX4 ARM: EXYNOS: Fix the incorrect hierarchy of spi controller bus clock ARM: ux500: Remove PMU platform registration when booting with DT ARM: ux500: Remove temporary snowball_of_platform_devs enablement structure ARM: ux500: Ensure vendor specific properties have the vendor's identifier pinctrl: pinctrl-nomadik: Append sleepmode property with vendor specific prefixes ARM: ux500: Move rtc-pl031 registration to Device Tree when enabled ARM: ux500: Enable the AB8500 RTC for all DT:ed DB8500 based devices ARM: ux500: Correctly reference IRQs supplied by the AB8500 from Device Tree ARM: ux500: Apply ab8500-debug node do the db8500 DT structure ARM: ux500: Add a ab8500-usb Device Tree node for db8500 based devices ARM: ux500: Add db8500 Device Tree node for misc/ab8500-pwm ARM: ux500: Add db8500 Device Tree node for ab8500-sysctrl ARM: ux500: Enable LED heartbeat functionality on Snowbal via DT ...
2012-07-16ARM: imx: add missing item to the list of clock event modesUwe Kleine-König
This prevents an out-of-bounds access to the clock_event_mode_label when debugging. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-16ARM: i.MX5x CSPI: Fixed clock name for CSPIAlexander Shiyan
This patch also includes fix CSPI ID for i.MX53. ID should be 2, because IDs 0 and 1 are occupied by eCSPI. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-10ARM i.MX31: Add devicetree supportDenis 'GNUtoo' Carikli
This patch adds basic devicetree support for i.MX31 based SoCs. Only the UART and interrupts bindings are added. Signed-off-by: Denis 'GNUtoo' Carikli <GNUtoo@no-log.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-10i2c: imx: make bitrate an u32 typeWolfram Sang
sparse found this assignment of u32 to an int. Fix it: drivers/i2c/busses/i2c-imx.c:540:56: warning: incorrect type in argument 3 (different signedness) and also fix the type in platform_data. All current users use values which fit into the old and new type, so it is a safe change. Signed-off-by: Wolfram Sang <wolfram@the-dreams.de> Reviewed-by: Richard Zhao <richard.zhao@freescale.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-09ARM: imx: make ehci power/oc polarities configurableBenoît Thébaudeau
Make ehci power and overcurrent polarities configurable. If not set, these new configurartions keep the default register values so that existing board files do not have to be changed. Cc: Sascha Hauer <kernel@pengutronix.de> Cc: <linux-arm-kernel@lists.infradead.org> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
