With commit c334bc1 (ARM: make mach/io.h include optional), PCMCIA was
broken. PCMCIA depends on __io() returning a valid i/o address, and most
ARM platforms require IO_SPACE_LIMIT be set to 0xffffffff for PCMCIA. This
needs a better fix with a fixed i/o address mapping, but for now we just
restore things to the previous behavior.
This fixes at91, omap1, pxa and sa11xx. pxa needs io.h if PCI is enabled,
but PCMCIA is not. sa11xx already has IO_SPACE_LIMIT set to 0xffffffff,
so it doesn't need an io.h.
Cc: Joachim Eastwood <joachim.eastwood@jotron.com>
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Tested-by: Paul Parsons <lost.distance@yahoo.com> (pxa270)
Pull "ARM: device tree work" from Arnd Bergmann:
"Most of these patches convert code from using static platform data to
describing the hardware in the device tree. This is only the first
half of the changes for v3.4 because a lot of patches for this topic
came in the last week before the merge window.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fix up trivial conflicts in arch/arm/mach-vexpress/{Kconfig,core.h}
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (86 commits)
Document: devicetree: add OF documents for arch-mmp
ARM: dts: append DTS file of pxa168
ARM: mmp: append OF support on pxa168
ARM: mmp: enable rtc clk in pxa168
i2c: pxa: add OF support
serial: pxa: add OF support
arm/dts: mt_ventoux: very basic support for TeeJet Mt.Ventoux board
ARM: OMAP2+: Remove extra ifdefs for board-generic
ARM: OMAP2+: Fix build error when only ARCH_OMAP2/3 or 4 is selected
ASoC: DT: Add digital microphone binding to PAZ00 board.
ARM: dt: Add ARM PMU to tegra*.dtsi
ARM: at91: at91sam9x5cm/dt: add leds support
ARM: at91: usb_a9g20/dt: add gpio-keys support
ARM: at91: at91sam9m10g45ek/dt: add gpio-keys support
ARM: at91: at91sam9m10g45ek/dt: add leds support
ARM: at91: usb_a9g20/dt: add leds support
ARM: at91/pio: add new PIO3 features
ARM: at91: add sam9_smc.o to at91sam9x5 build
ARM: at91/tc/clocksource: Add 32 bit variant to Timer Counter
ARM: at91/tc: add device tree support to atmel_tclib
In order to consolidate the McBSP driver move it out from
arch/arm/plat-omap directory under sound/soc/omap/
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
Otherwise we get:
warning: (ARCH_OMAP2PLUS) selects PROC_DEVICETREE which has
unmet direct dependencies (OF && PROC_FS && !SPARC)
git://git.kernel.org/pub/scm/linux/kernel/git/bcousson/linux-omap-dt into dt
The devices that can act as an interrupt controller like the
GPIO are going to be handled using the IRQ domain mechanism
in order to avoid the static IRQ mapping done so far inside
plat-omap/irqs.h.
Enable IRQ_DOMAIN by default to allow the drivers shared with
OMAP2+ to compile properly on OMAP1 platforms.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Tony Lindgren <tony@atomide.com>
devicetree will become the mandatory boot method for OMAP2+.
In order to avoid cluttering the OMAP code with #ifdef CONFIG_OF,
select USE_OF by default for every OMAP2+ systems.
Enable PROC_DEVICETREE as well.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (33 commits)
iommu/core: Remove global iommu_ops and register_iommu
iommu/msm: Use bus_set_iommu instead of register_iommu
iommu/omap: Use bus_set_iommu instead of register_iommu
iommu/vt-d: Use bus_set_iommu instead of register_iommu
iommu/amd: Use bus_set_iommu instead of register_iommu
iommu/core: Use bus->iommu_ops in the iommu-api
iommu/core: Convert iommu_found to iommu_present
iommu/core: Add bus_type parameter to iommu_domain_alloc
Driver core: Add iommu_ops to bus_type
iommu/core: Define iommu_ops and register_iommu only with CONFIG_IOMMU_API
iommu/amd: Fix wrong shift direction
iommu/omap: always provide iommu debug code
iommu/core: let drivers know if an iommu fault handler isn't installed
iommu/core: export iommu_set_fault_handler()
iommu/omap: Fix build error with !IOMMU_SUPPORT
iommu/omap: Migrate to the generic fault report mechanism
iommu/core: Add fault reporting mechanism
iommu/core: Use PAGE_SIZE instead of hard-coded value
iommu/core: use the existing IS_ALIGNED macro
iommu/msm: ->unmap() should return order of unmapped page
Fixup trivial conflicts in drivers/iommu/Makefile: "move omap iommu to
dedicated iommu folder" vs "Rename the DMAR and INTR_REMAP config
options" just happened to touch lines next to each other.
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
Given that we want the default to not have any <mach/memory.h> and given
that there are now fewer cases where it is still provided than the cases
where it is not at this point, this makes sense to invert the logic and
just identify the exception cases.
The word "need" instead of "have" was chosen to construct the config
symbol so not to suggest that having a mach/memory.h file is actually
a feature that one should aim for.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Support for IDE drivers should not be automatic, since most platforms
cannot actually support any IDE low-level drivers. This partly
reverts 2064c946e "ARM: always select HAVE_IDE" to set this symbol
only when either a PC-style bus (PCI, ISA, PCMCIA) is enabled or
a platform is used that is known to have an existing driver in
drivers/ide.
New platforms should not need this option and just use CONFIG_ATA
with drivers/ata/.
Move OMAP's iommu drivers to the dedicated iommu drivers folder.
While OMAP's iovmm (virtual memory manager) driver does not strictly
belong to the iommu drivers folder, move it there as well, because
it's by no means OMAP-specific (in concept. technically it is still
coupled with OMAP's iommu).
Eventually, iovmm will be completely replaced with the generic,
iommu-based, dma-mapping API.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Migrate OMAP's iommu driver to the generic IOMMU API, so users can stay
generic, and any generic IOMMU functionality can be developed once
in the generic framework.
Migrate omap's iovmm (virtual memory manager) to the generic IOMMU API,
and adapt omap3isp as needed, so the latter won't break.
The plan is to eventually remove iovmm completely by replacing it
with the (upcoming) IOMMU-based DMA-API.
Tested on OMAP3 (with omap3isp) and OMAP4 (with rpmsg/remoteproc).
OMAP1 needs this also since GPIO driver (common for all OMAPs) is
being converted to use generic IRQ chip.
Signed-off-by: Kevin Hilman <khilman@ti.com>
The current code base is not linking with the OMAP_PM_NONE
option set.
Since the option OMAP_PM_NOOP provides a no-op/debug layer,
OMAP_PM_NONE can be removed.
OMAP_PM_NOOP is enabled by default by Kconfig.
Signed-off-by: Jean Pihet <j-pihet@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
arch/arm/Kconfig
arch/arm/mach-ns9xxx/include/mach/uncompress.h
Convert the OMAP1 32-bit down counting clocksource to the generic
clocksource infrastructure.
Tested-by: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
As a result of c42321c (genirq: Make generic irq chip depend on
CONFIG_GENERIC_IRQ_CHIP), we now need those platforms using this in
my tree to select this symbol.
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Kevin Hilman <khilman@ti.com>
The patch below removes an extra "l" in the word.
For omap15xx and 730 we need to use the MPU timer
as the 32K timer is not available. For omap16xx
we want to use the 32K timer because of PM. Fix this
by allowing to build in both timers.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (243 commits)
omap2: Make OMAP2PLUS select OMAP_DM_TIMER
OMAP4: hwmod data: Fix alignment and end of line in structurefields
OMAP4: hwmod data: Move the DMA structures
OMAP4: hwmod data: Move the smartreflex structures
OMAP4: hwmod data: Fix missing SIDLE_SMART_WKUP in smartreflexsysc
arm: omap: tusb6010: add name for MUSB IRQ
arm: omap: craneboard: Add USB EHCI support
omap2+: Initialize serial port for dynamic remuxing for n8x0
omap2+: Add struct omap_board_data and use it for platform level serial init
omap2+: Allow hwmod state changes to mux pads based on the state changes
omap2+: Add support for hwmod specific muxing of devices
omap2+: Add omap_mux_get_by_name
OMAP2: PM: fix compile error when !CONFIG_SUSPEND
MAINTAINERS: OMAP: hwmod: update hwmod code, data maintainership
OMAP4: Smartreflex framework extensions
OMAP4: hwmod: Add inital data for smartreflex modules.
OMAP4: PM: Program correct init voltages for scalable VDDs
OMAP4: Adding voltage driver support
OMAP4: Register voltage PMIC parameters with the voltage layer
OMAP3: PM: Program correct init voltages for VDD1 and VDD2
Fix up trivial conflict in arch/arm/plat-omap/Kconfig
It appears that arch/arm/mach-omap2/timer-gp.o is needed by OMAP2PLUS.
Since timer-gp.o has direct dependencies on omap_dm_timer_*, it seems
correct for the architecture to depend upon OMAP_DM_TIMER, otherwise
unsuspecting integrators will be faced with a whole bunch of linker
errors at the end of their kernel build:
arch/arm/mach-omap2/built-in.o: In function `omap2_gp_timer_set_mode':
/home/bgamari/trees/linux-2.6/arch/arm/mach-omap2/timer-gp.c:84: undefined reference to `omap_dm_timer_stop'
/home/bgamari/trees/linux-2.6/arch/arm/mach-omap2/timer-gp.c:88: undefined reference to `omap_dm_timer_get_fclk'
/home/bgamari/trees/linux-2.6/arch/arm/mach-omap2/timer-gp.c:90: undefined reference to `omap_dm_timer_set_load_start'
Signed-off-by: Ben Gamari <bgamari.foss@gmail.com>
This patch extends the smartreflex framework to support
OMAP4. The changes are minor like compiling smartreflex Kconfig
option for OMAP4 also, and a couple of OMAP4 checks in
the smartreflex framework.
The change in sr_device.c where new logic has to be introduced
for reading the efuse registers is due to the fact that in OMAP4
the efuse registers are 24 bit aligned. A __raw_readl will
fail for non-32 bit aligned address and hence the 8-bit read
and shift.
Signed-off-by: Thara Gopinath <thara@ti.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Smartreflex Class3 implementation continuously monitors
silicon performance and instructs the Voltage Processors
to increase or decrease the voltage.
This patch adds smartreflex class 3 driver. This driver hooks
up with the generic smartreflex driver smartreflex.c to abstract
out class specific implementations out of the generic driver.
Class3 driver is chosen as the default class driver for smartreflex.
If any other class driver needs to be implemented, the init of that
driver should be called from the board file. That way the new class driver
will over-ride the Class3 driver.
SmartReflex modules do adaptive voltage control for real-time
voltage adjustments. With Smartreflex the power supply voltage
can be adapted to the silicon performance(manufacturing process,
temperature induced performance, age induced performance etc).
There are differnet classes of smartreflex implementation.
Class-0: Manufacturing Test Calibration
Class-1: Boot-Time Software Calibration
Class-2: Continuous Software Calibration
Class-3: Continuous Hardware Calibration
Class-4: Fully Integrated Power Management
OMAP3 has two smartreflex modules one associated with VDD MPU and the
other associated with VDD CORE.
This patch adds support for smartreflex driver. The driver is designed
for Class-1 , Class-2 and Class-3 support and is a platform driver.
Smartreflex driver can be enabled through a Kconfig option
"SmartReflex support" under "System type"->"TI OMAP implementations" menu.
Smartreflex autocompensation feature can be enabled runtime through
a debug fs option.
To enable smartreflex autocompensation feature
echo 1 > /debug/voltage/vdd_<X>/smartreflex/autocomp
To disable smartreflex autocompensation feature
echo 0 > /debug/voltage/vdd_<X>/smartreflex/autocomp
where X can be mpu, core , iva etc.
This patch contains code originally in linux omap pm branch.
Major contributors to this driver are
Lesly A M, Rajendra Nayak, Kalle Jokiniemi, Paul Walmsley,
Nishant Menon, Kevin Hilman.
It seems dsp-link will do this, and tidspbridge too at some point, but
right now it's not possible to select CONFIG_MPU_BRIDGE_IOMMU.
Cc: Fernando Guzman Lugo <fernando.lugo@ti.com>
Cc: Yogesh Marathe <yogesh_marathe@ti.com>
Signed-off-by: Felipe Contreras <felipe.contreras@nokia.com>
factorise some generic infrastructure to assist looking up struct clks
for the ARM & SH architecture.
as the code is identical at 99%
put the arch specific code for allocation as example in asm/clkdev.h
Acked-by: Paul Mundt <lethal@linux-sh.org>
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits)
omap: complete removal of machine_desc.io_pg_offst and .phys_io
omap: UART: fix wakeup registers for OMAP24xx UART2
omap: Fix spotty MMC voltages
ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h
serial: omap-serial: fix signess error
OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish
omap: dma: Fix buffering disable bit setting for omap24xx
omap: serial: Fix the boot-up crash/reboot without CONFIG_PM
OMAP3: PM: fix scratchpad memory accesses for off-mode
omap4: pandaboard: enable the ehci port on pandaboard
omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set
omap4: pandaboard: remove unused hsmmc definition
OMAP: McBSP: Remove null omap44xx ops comment
OMAP: McBSP: Swap CLKS source definition
OMAP: McBSP: Fix CLKR and FSR signal muxing
OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks
OMAP: control: move plat-omap/control.h to mach-omap2/control.h
OMAP: split plat-omap/common.c
OMAP: McBSP: implement functional clock switching via clock framework
OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c
Fixed up trivial conflicts in arch/arm/mach-omap2/
{board-zoom-peripherals.c,devices.c} as per Tony
update OMAP Kconfig help texts for all supported SoC models
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
If we LEDS_CLASS is not selected, we will get undefined reference
to `led_classdev_register'.
git://gitorious.org/~doyu/lk/mainline into omap-for-linus
arch/arm/mach-omap1/devices.c
The underlying buffering implementation of mailbox
is converted from block API to kfifo due to the simplicity
and speed of kfifo.
The default size of the kfifo buffer is set to 256 bytes.
This value is configurable at compile time (via
CONFIG_OMAP_MBOX_KFIFO_SIZE), and can be changed at
runtime (via the mbox_kfifo_size module parameter).
Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com>
Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
LEDS_OMAP_DEBUG doesn't exist in Kconfig, therefore replacing all
references for it with OMAP_DEBUG_LEDS from the source code.
Signed-off-by: Christoph Egger <siccegge@cs.fau.de>
Move omap2/3/4 specific Kconfig options to mach-omap2/Kconfig
This will make Kconfig look nicer for selecting omap processor type
Use 32KiHZ timer by default as this is available on all omaps
except 15xx based systems.
This CONFIG_OMAP_IOMMU_DEBUG option cannot be selected because it's
not visible on menu. Make this option selectable.
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Kconfig
Add ARM_L1_CACHE_SHIFT_6 to arch/arm/Kconfig to allow CPUs with
L1 cache lines which are 64bytes to indicate this without having to
alter the arch/arm/mm/Kconfig entry each time.
Update the mm Kconfig so that ARM_L1_CACHE_SHIFT default value
uses this and change OMAP3 and S5PC1XX to select ARM_L1_CACHE_SHIFT_6.
Acked-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch adds a save and restore mechanism for ARM L2 auxiliary control
register. The feature is enabled by default for GP devices, but for HS/EMU
devices the user must enable the service and define the PPA service ID to
be used for setting L2 aux ctrl, as this is not currently supported by the
bootloader. If nobody alters the contents of L2 aux ctrl from its reset
value, this feature is not needed.
Kconfig option to enable HS/EMU L2 aux save and restore:
- OMAP3_L2_AUX_SECURE_SAVE_RESTORE
Kconfig option to select HS/EMU PPA service for setting L2 aux ctrl:
- OMAP3_L2_AUX_SECURE_SERVICE_SET_ID
Signed-off-by: Tero Kristo <tero.kristo@nokia.com>
omap: Replace orred CONFIG_ARCH_OMAP2/3/4 with CONFIG_ARCH_OMAP2PLUS
Replace ARCH_OMAP34XX with ARCH_OMAP3
Convert ARCH_OMAP24XX to ARCH_OMAP2
Allows compiling in omap2 and omap3.
These are no longer needed. Note that zoom boards
should now set their own function in uncompress.h
and debug-macro.S for the external UART.
This patch adds dummy hooks for OMAP4 dpll api's. Removes
dummy hooks for clkdev api's and enables CLKDEV
for OMAP4.
Also comments clockdomain calls from within the clock
framework as its not supported yet for OMAP4.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Cc: Benoit Cousson <b-cousson@ti.com>
Avoid cluttering the Kconfig space with debug options that are rarely
used. These can now be enabled and disabled by patching the "#undef DEBUG"
in the source files with "#define DEBUG", conforming to the practice for
the rest of the linux-omap code.
Also, while we're here, some lines in plat-omap/Kconfig use sets of
leading spaces when those lines should start with tabs. Convert most
of them to use tabs.
Zoom2/Zoom3 kind of boards do not use omap uarts for console.
These use external debug board for console.
So these boards should not have "Uncompressing Kernel...."
log put on omap uarts.
By interoducing OMAP_LL_DEBUG_NONE option,
unnecessary writes to omap uarts is avoided.
In future, the DEBUG_LL interface will be enhanced
to use external debug board.
Signed-off-by: Vikram Pandita <vikram.pandita@ti.com>
The interface provides device drivers, CPUFreq, and DSPBridge with a
means of controlling OMAP power management parameters that are not yet
supported by the Linux PM PMQoS interface. Copious documentation is
in the patch in Documentation/arm/OMAP/omap_pm and the interface
header file, arch/arm/plat-omap/include/mach/omap-pm.h.
Thanks to Rajendra Nayak <rnayak@ti.com> for adding CORE (VDD2) OPP
support and moving the OPP table initialization earlier in the event
that the clock code needs them. Thanks to Tero Kristo
<tero.kristo@nokia.com> for fixing the parameter check in
omap_pm_set_min_bus_tput(). Jouni signed off on Tero's patch.
Signed-off-by: Jouni Högander <jouni.hogander@nokia.com>
Cc: Igor Stoppa <igor.stoppa@nokia.com>
Cc: Richard Woodruff <r-woodruff2@ti.com>
Cc: Anand Sawant <sawant@ti.com>
Cc: Sakari Poussa <sakari.poussa@nokia.com>
Cc: Veeramanikandan Raju <veera@ti.com>
Cc: Karthik Dasu <karthik-dp@ti.com>
