Now that we have OPP layer, and OMAP CPUfreq driver is using it, we no
longer need/use the clock framework code for filling up CPUfreq
tables. Remove it.
Removing this code also eliminates build errors when CPU_FREQ_TABLE
support is not enabled.
Thanks to Russell King for pointing out the parts I missed under
plat-omap in the original version and also pointing out the build
errors when CPUFREQ_TABLE support was not enabled.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Kevin Hilman <khilman@ti.com>
Acked-by: Paul Walmsley <paul@pwsan.com>
clk_disable_unused is invoked when CONFIG_OMAP_RESET_CLOCKS=y.
Since clk_disable_unused is called as lateinitcall, there can
be more than a few workqueues executing off secondary CPU(s).
The current code does the following:
a) checks if clk is unused
b) holds lock
c) disables clk
d) unlocks
Between (a) and (b) being executed on CPU0, It is possible to
have a driver executing on CPU1 which could do a get_sync->clk_get
(and increase the use_count) of the clock which was just about
to be disabled by clk_disable_unused.
We ensure instead that the entire list traversal is protected by
the lock allowing for parent child clock traversal which could be
potentially be done by runtime operations to be safe as well.
Reported-by: Todd Poynor <toddpoynor@google.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
arch/arm/plat-omap/clock.c: included 'linux/debugfs.h' twice,
remove the duplicate.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
These files all make use of one of the EXPORT_SYMBOL variants
or the THIS_MODULE macro. So they will need <linux/export.h>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits)
OMAP: Add debugfs node to show the summary of all clocks
OMAP2+: hwmod: Follow the recommended PRCM module enable sequence
OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code
OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming
OMAP2+: PM: idle clkdms only if already in idle
OMAP2+: clockdomain: add clkdm_in_hwsup()
OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework
OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition()
OMAP4: hwmod: Introduce the module control in hwmod control
OMAP4: cm: Add two new APIs for modulemode control
OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure
OMAP4: hwmod data: Add PRM context register offset
OMAP4: prm: Remove deprecated functions
OMAP4: prm: Replace warm reset API with the offset based version
OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros
OMAP: hwmod: Wait the idle status to be disabled
OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros
OMAP2+: hwmod: Init clkdm field at boot time
OMAP4: hwmod data: Add clock domain attribute
OMAP4: clock data: Add missing divider selection for auxclks
its first argument is const char * and it's really not modified...
Add a debugfs node called "summary" to /sys/kernel/debug/clock/
that displays a quick summary of all clocks registered in the
"clocks" structure. The format of the output from this node is:
<clock-name> <parent-name> <rate> <usecount>
This debugfs node was very helpful for taking a quick snapshot of
the linux clock tree for OMAP and ensuring clock frequencies
calculated by the kernel were indeed correct. This patch helped
uncover some bugs in the linux clock tree for OMAP4.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Bail out before we take the clockfw_lock spinlock if the corresponding
OMAP1 or OMAP2+ clock function is not defined. The intention is to
reduce and simplify the work that is done inside the spinlock.
Attempt to enable autoidle for as many clocks as possible in the
OMAP2+-common CONFIG_OMAP_RESET_CLOCKS code. Currently, this only
enables DPLL autoidle for OMAP3/4 DPLLs; but future patches will
enable autoidle for other clocks and the OMAP2 DPLL/APLLs.
In the long run, we should probably get rid of
CONFIG_OMAP_RESET_CLOCKS, and unconditionally run the code that it
selects. Otherwise, the state of the clock tree won't match the
hardware state - this could result in clocks being enabled or disabled
unpredictably.
Based on a patch by Rajendra Nayak <rnayak@ti.com> that did this in
the pm34xx.c/pm44xx.c code.
Cc: Rajendra Nayak <rnayak@ti.com>
On OMAP various clock nodes (dpll's, mx post dividers, interface clocks)
support hardware level autogating which can be controlled from
software.
Support such functionality by adding two new function pointer
allow_idle and deny_idle in the clkops structure.
These function pointers can be populated for any clock
node which supports hardware level autogating.
Also add 2 new functions (omap_clk_enable_autoidle_all and
omap_clk_disable_autoidle_all) which can be called from
architecture specific PM core code, if hardware level
autogating (for all supported clock nodes) is to be
enabled or disabled.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
[paul@pwsan.com: use spinlock rather than mutex due to race; renamed functions;
functions now return ints]
unused clocks
Reduce the amount of debugging generated by default when unused clocks
are being disabled by the clock code. The previous code would only
generate debug-level messages, but some people who wished to run
production kernels with debug-level messages enabled reported that the
large number of clock disable messages were slowing boot. Now to
enable clock-by-clock disable messages, DEBUG needs to be defined in
mach-omap2/clock.c.
Cc: Tuukka Tikkanen <tuukka.tikkanen@nokia.com>
Cc: Tim Bird <tim.bird@am.sony.com>
Remove the hack put in place while clock framework was still not in
place for OMAP4.
Clean up comment style, remove unnecessary includes, and resolve some
checkpatch warnings in plat-omap/clock.c.
On OMAP4 platform the iclk control is completly under hardware control
and no software control is available.
This difference w.r.t previous OMAP's needs all the common driver
accross OMAP's , cpu_is_xxxx() checks. To avoid poulluting the
drivers dummy clock nodes are created (The autogeneration
script has been updated accordingly).
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
[paul@pwsan.com: made OMAP1 dummy_ck common and edited patch to reuse that]
The OMAP hwmod core code is intended to use SoC IP block description
structures that are autogenerated from TI's OMAP hardware database.
Currently the hwmod code uses clkdev device + connection addressing to
identify clocks. This causes problems in the hwmod autogeneration
process, since the TI hardware database doesn't use platform_device or
clkdev addressing; it uses a single clock signal name string, which
tends to bear some resemblance to what is used in the OMAP TRMs. This
patch adds a non-exported function to the OMAP clock code,
omap_clk_get_by_name(). A subsequent patch will convert the hwmod
code to use this function.
This function is for use only by core code, and practically, no other
code outside the hwmod code should need it. Device driver code in the
kernel must not use this function, which is why it is not exported.
Drivers should use the appropriate clock alias provided by the clkdev
data structures, so driver code can be completely SoC-independent.
Cc: Benoît Cousson <b-cousson@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
After the clkdev conversion, the struct clk.id field became
superfluous, so, drop it. Bring the clock names closer to the TRMs
and ensure they are unique for debugfs.
I have found an access to already released memory in
clk_debugfs_register_one() function.
Signed-off-by: Marek Skuczynski <mareksk7@gmail.com>
Resolve all remaining sparse warnings in the OMAP clock code.
One of the OMAP1 clocks can use the fixed divisor recalculation code
introduced in the OMAP2 clock code, so rename the
omap2_fixed_divisor_recalc() function to omap_fixed_divisor_recalc()
and make it available to all OMAPs. A followup patch converts the OMAP1
clock.
A subsequent patch adds code on OMAP2xxx to dynamically allocate the
CPUFreq frequency table in clk_init_cpufreq_table(), so for it to
avoid a leak, it will need a corresponding function to free the
memory. This patch adds clk_exit_cpufreq_table() with generic
code to call a chip-specific variant inside the clockfw_lock spinlock via
struct clk_functions.
The only symbols that should be exported are symbols that are to be
called from loadable kernel modules, e.g., device drivers. In the
context of plat-omap/clock.c, these should only be the Linux clock
interface symbols as defined by include/linux/clk.h. Core code
doesn't need these symbols to be exported. Also, clean up an old
comment while here.
This patch adds dummy hooks for OMAP4 dpll api's. Removes
dummy hooks for clkdev api's and enables CLKDEV
for OMAP4.
Also comments clockdomain calls from within the clock
framework as its not supported yet for OMAP4.
Cc: Benoit Cousson <b-cousson@ti.com>
This patch fixes the PRM and CM base addresses and adds
a new CM2 base address for OMAP4
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
Rewinding each debugfs entries to unregister if an error happens.
Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
This patch update the common clock.c file for OMAP4. The clk_get() and
clk_put() functions are moved to common place in arch/arm/common/clkdev.c
Since on current OMAP4 platform clk management is still not supported, the
platform file is stubbed with those functions.
Once the framework is ready, this WILL be replaced with a full
clkdev implementation.
Rename clk_init_one() to clk_preinit() to distinguish its function
from clk_init() and the individual struct clk init functions.
Commit 3f0a820c4c0b4670fb5f164baa5582e23c2ef118 breaks OMAP2xxx boot
during initial propagate_rate() on osc_ck and sys_ck. Fix by
pre-initializing all struct clks before running any other clock init
code. Incorporates review comments from Russell King
<rmk+kernel@arm.linux.org.uk>.
Resolves
<1>Unable to handle kernel NULL pointer dereference at virtual address 00000000
<1>pgd = c0004000
<1>[00000000] *pgd=00000000
Internal error: Oops: 5 [#1]
Modules linked in:
CPU: 0 Not tainted (2.6.29-omap1 #37)
PC is at propagate_rate+0x10/0x60
LR is at omap2_clk_init+0x30/0x218
Tested-by: Jarkko Nikula <jarkko.nikula@nokia.com>
Richard Woodruff writes:
| The historic usage of this has been against single use leaf clocks
| (1st instance of gptimer). When it was used it did:
| clk_get()
| clk_set_parent()
| clk_enable()
| This usage was ok for that. Use on a disabled clock is needed.
| If there are multiple users on the clock or it is enabled there are
| problems.
| The call can still be unfriendly if 2 different drivers are using the
| clock with their own clock get/enable. It might be the function should
| return an error if usecount != 0 to stop surprises. It is all around
| better if the parenting is done when the clock is off.
This is a good reason to ensure that the clock is not enabled when
clk_set_parent() is called.
Acked-by: Richard Woodruff <r-woodruff2@ti.com>
linux-omap source commit 33d000c99ee393fe2042f93e8422f94976d276ce
introduces a way to "dry run" clock changes before they're committed.
However, this involves putting logic to handle this into each and
every recalc function, and unfortunately due to the caching, led to
some bugs.
Solve both of issues by making the recalc methods always return the
clock rate for the clock, which the caller decides what to do with.
This function is race-prone and mistakenly conveys the impression to
drivers that it is part of the clock interface. Get rid of it: core
code that absolutely needs this can just check clk->usecount. Drivers
should not use it at all.
linux-omap source commit is 5df9e4adc2f6a6d55aca53ee27b8baad18897c05.
Traditionally, we've tracked the parent/child relationships between
clk structures by setting the child's parent member to point at the
upstream clock. As a result, when decending the tree, we have had
to scan all clocks to find the children.
Avoid this wasteful scanning by keeping a list of the clock's children.
This implements the remainder of:
OMAP clock: move rate recalc, propagation code up to plat-omap/clock.c
from Paul Walmsley which is not covered by the previous:
[ARM] omap: move clock propagation into core omap clock code
[ARM] omap: remove unnecessary calls to propagate_rate()
[ARM] omap: move propagate_rate() calls into generic omap clock code
commits.
This stops things blowing up if a 'struct clk' to be passed more
than once to clk_register(), which will be required when we decouple
struct clk's from their names.
propagate_rate() is recursive, so it makes sense to minimise the
amount of stack which is used for each recursion. So, rather than
recursing back into it from the ->recalc functions if RATE_PROPAGATES
is set, do that test at the higher level.
Move the clock propagation calls for set_parent and set_rate into
the core omap clock code, rather than having these calls scattered
throughout the OMAP1 and OMAP2 implementations.
which only has to return clk->parent.
Nothing makes any use of these functions, so there's little point in
providing them.
clk->owner is always NULL, so its existence doesn't serve any useful
function other than bloating the kernel by 992 bytes. Remove it.
... and use it for clocks which are ALWAYS_ENABLED. These clocks
use a non-NULL enable_reg pointer for other purposes (such as
selecting clock rates.)
debugfs_create_*() returns NULL if an error occurs, returns -ENODEV
when debugfs is not enabled in the kernel.
Comparing to PATCH v1, because clk_debugfs_init is included in
"#if defined CONFIG_DEBUG_FS", we only need to check NULL return.
Thanks Li Zefan <lizf@cn.fujitsu.com>
debugfs_create_u8() and other function's return value's checking method are
also fixed in this patch.
Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com>
This patch lets the files using linux/version.h match the files that
#include it.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This just leaves include/asm-arm/plat-* to deal with.
debugfs can provide the infrastructure to trace the dependencies of
clock tree hierarchy quite visibly. This patch enables to keep track
of clock tree hierarchy and expose their attributes under each clock
directry as below:
omap:~# tree -d -L 2 /debug/clock/omap_32k_fck/
|-- gpt10_fck
|-- gpt11_fck
|-- gpt1_fck
|-- per_32k_alwon_fck
| |-- gpio2_fck
| |-- gpio3_fck
| |-- gpio4_fck
| |-- gpio5_fck
| |-- gpio6_fck
| `-- wdt3_fck
|-- ts_fck
`-- wkup_32k_fck
|-- gpio1_fck
`-- wdt2_fck
14 directories
omap:~# tree /debug/clock/omap_32k_fck/gpt10_fck/
|-- flags
|-- rate
`-- usecount
0 directories, 3 files
Although, compared with David Brownell's small patch, this may look
bit overkilling, I expect that this debugfs can deal with other PRCM
complexities at the same time. For example, powerdomain dependencies
can be expressed by using symbolic links of these clocks if
powerdomain supports dubgfs as well.
