Fix CLINK mask, clear spurious interrupt.
Signed-off-by: Gadiyar, Anand <gadiyar@ti.com>
Signed-off-by: Kevin Hilman <khilman@mvista.com>
This patch changes the return value of omap_dma_chain_a_transfer
to 0 on success instead of the flag 'start_dma', which wasn't really useful
for anything.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
* omap-fixes:
ARM: OMAP2: Register the L4 io bus to boot OMAP2
ARM: OMAP1: Compile in other 16xx boards to OSK defconfig
ARM: OMAP1: Refresh H2 defconfig
ARM: OMAP1: Refresh OSK defconfig
ARM: OMAP: gpio lockdep updates
ARM: OMAP1: omap1/pm.c build fix
ARM: OMAP1: omap h2 regression fix
ARM: OMAP1: Fix compile for boards depending on old gpio expander
ARM: OMAP1: omap h3 regression and build fix
ARM: OMAP: Remove compiler warning when i2c is not set
ARM: OMAP: fix omap i2c init (regression)
ARM: OMAP: fix false lockdep warnings
ARM: OMAP: Fix sleep under spinlock for cpufreq
ARM: OMAP: Pass logical DMA channel number always to callback handlers
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This makes parameter passing to DMA handlers uniform between non-chained
and chained transfers and makes debugging easier. Additional data like
chain_id can be always passed to handlers via callback data if needed.
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
Add DMA support for chaining and 3430.
Also remove old DEBUG_PRINTS as noted by Russell King.
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The SoSSI driver should already take care of this by enabling / disabling
its clock when necessary, so this legacy callout from the PM idle code
is not needed any more.
Signed-off-by: Imre Deak <imre.deak@solidboot.com>
Spelling fixes in arch/arm/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Fix warning: 'offset' might be uninitialized
Add DMA IRQ sanity checks
Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com>
The register bits are reset by writing one. Remove the unneeded reads and
fix writes to not clear too many bits.
Signed-off-by: Timo Teras <timo.teras@solidboot.com>
Untested, but this should fix up the bulk of the totally mechanical
issues, and should make the actual detail fixing easier.
This patch syncs OMAP DMA code with linux-omap tree.
Mostly allow changing DMA callback function and set
OMAP2 specific transfer mode.
Also export some omap24xx specific DMA functions.
We have to make sure that the LCD DMA external destination bit is
cleared by default, otherwise OMAP won't sleep.
The irgflags consolidation did conflict with the ARM to generic IRQ
conversion and was not applied for ARM. Fix it up.
Use the new IRQF_ constants and remove the SA_INTERRUPT define
* 'genirq' of master.kernel.org:/home/rmk/linux-2.6-arm: (24 commits)
[ARM] 3683/2: ARM: Convert at91rm9200 to generic irq handling
[ARM] 3682/2: ARM: Convert ixp4xx to generic irq handling
[ARM] 3702/1: ARM: Convert ixp23xx to generic irq handling
[ARM] 3701/1: ARM: Convert plat-omap to generic irq handling
[ARM] 3700/1: ARM: Convert lh7a40x to generic irq handling
[ARM] 3699/1: ARM: Convert s3c2410 to generic irq handling
[ARM] 3698/1: ARM: Convert sa1100 to generic irq handling
[ARM] 3697/1: ARM: Convert shark to generic irq handling
[ARM] 3696/1: ARM: Convert clps711x to generic irq handling
[ARM] 3694/1: ARM: Convert ecard driver to generic irq handling
[ARM] 3693/1: ARM: Convert omap1 to generic irq handling
[ARM] 3691/1: ARM: Convert imx to generic irq handling
[ARM] 3688/1: ARM: Convert clps7500 to generic irq handling
[ARM] 3687/1: ARM: Convert integrator to generic irq handling
[ARM] 3685/1: ARM: Convert pxa to generic irq handling
[ARM] 3684/1: ARM: Convert l7200 to generic irq handling
[ARM] 3681/1: ARM: Convert ixp2000 to generic irq handling
[ARM] 3680/1: ARM: Convert footbridge to generic irq handling
[ARM] 3695/1: ARM drivers/pcmcia: Fixup includes
[ARM] 3689/1: ARM drivers/input/touchscreen: Fixup includes
Manual conflict resolved in kernel/irq/handle.c (butt-ugly ARM tickless
code).
Patch from Thomas Gleixner
Fixup the conversion to generic irq subsystem.
- DMA CSR register is cleared by reading on omap1, but on
omap2 it is cleard by writing to it.
- DMA TOUT interrupt does not exist on omap24xx, rename it
- Add SECURE and MISALIGNED errors by default for omap24xx
- Add defines for external DMA request lines
OMAP2 DMA burst setting support
Fix for re-using OMAP DMA channel with different transfer parameters.
Bits in the CCR register need to be cleaned as well in some cases.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Patch from Tony Lindgren
Update OMAP framebuffer low-level init code from linux-omap tree
by Imre Deak.
ICC likes to complain about storage class not being first, GCC doesn't
care much (except for cases like "inline static").
have a hard time seeing how it could break anything.
Thanks to Gabriel A. Devenyi for pointing out
http://linuxicc.sourceforge.net/ which is what made me create this patch.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
This patch syncs the mainline kernel with linux-omap tree.
The highlights of the patch are:
- Serial port and framebuffer init improvments by Imre Deak
- Common omap pin mux framework by Tony Lindgren
- Common omap clock framework by Tony Lindren
- Clock updates by Tuukka Tikkanen, Juha Yrjola,
Daniel Petrini and Tony Lindgren
- DMA fixes by Imre Deak, Juha Yrjola and Daniel Petrini
- Add support to dual-mode hardware timers by Lauri Leukkunen
- GPIO support for 24xx by Paul Mundt
- GPIO wake-up support by Tony Lindgren
- Better GPIO interrupt handler to not lose interrupts by
Ralph Walden and Ladislav Michl
- Power Management updates by Tuukka Tikkanen
- Make Power Management code use new SRAM functions by
Tony Lindgren
This patch by various OMAP developers syncs the OMAP
specific arch files with the linux-omap tree.
This patch move common OMAP code from arch-omap to plat-omap
directory.
