Add mmu hwmod data for iva and isp.
Due to compatibility an ifdef CONFIG_OMAP_IOMMU_IVA2 needs to be
propagated (previously on iommu resource info) to hwmod data in OMAP3,
so users of iommu and tidspbridge can avoid issues of two modules
managing mmu data/irqs/resets; this until tidspbridge can be migrated
to iommu framework.
Cc: Benoit Cousson <b-cousson@ti.com>
Signed-off-by: Omar Ramirez Luna <omar.luna@linaro.org>
[paul@pwsan.com: fixed some kerneldoc and whitespace; ISP MMUs not present
on AM35xx so restricted these hwmods to 34xx/36xx]
Signed-off-by: Paul Walmsley <paul@pwsan.com>
If included without IOMMU_API being selected it will break
compilation:
arch/arm/plat-omap/include/plat/iommu.h:
In function 'dev_to_omap_iommu':
arch/arm/plat-omap/include/plat/iommu.h:148:
error: 'struct dev_archdata' has no member named 'iommu'
This will be seen when hwmod includes iommu.h to get the
structure for attributes. Also needed for tidspbridge
incremental migration to use iommu code.
Cc: Tony Lindgren <tony@atomide.com>
Eliminate the public omap_find_iommu_device() method, and don't
expect clients to provide the omap_iommu handle anymore.
Instead, OMAP's iommu driver now utilizes dev_archdata's private iommu
extension to be able to access the required iommu information.
This way OMAP IOMMU users are now able to use the generic IOMMU API without
having to call any omap-specific binding method.
Update omap3isp appropriately.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Hiroshi Doyu <hdoyu@nvidia.com>
Declare an omap iommu private struct, which binds an iommu user
to its iommu device. This struct should be placed at the iommu user's
dev_archdata so generic IOMMU API can be used without having to
utilize omap-specific plumbing anymore.
While at it, provide an accessor method to ease the retrieval of the
omap_iommu handle from a user device.
Start using the generic fault report mechanism, as provided by
the IOMMU core, and remove its now-redundant omap_iommu_set_isr API.
Currently we're only interested in letting upper layers know about the
fault, so in case the faulting device is a remote processor, they could
restart it.
Dynamic PTE/TLB loading is not supported.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Prepend 'omap_' to OMAP's 'struct iommu' and exposed API, to prevent
namespace pollution and generally to improve readability of the code
that still uses the driver directly.
Update the users as needed as well.
Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
Remove unused public APIs from OMAP's iommu driver.
IOMMU functionality should be exposed only via the generic IOMMU API;
this way drivers stay generic, and different IOMMU drivers
don't need to duplicate similar functionalities.
The rest of the API still exposed by OMAP's iommu will be evaluated
and eventually either added to the generic IOMMU API (if relevant),
or completely removed.
The intention is that OMAP's iommu driver will eventually not expose
any public API.
Stop exporting functions that are used only within the iommu
driver itself.
Eventually OMAP's iommu driver should only expose API via the generic
IOMMU framework.
Migrate OMAP's iommu driver to the generic IOMMU API, so users can stay
generic, and any generic IOMMU functionality can be developed once
in the generic framework.
Migrate omap's iovmm (virtual memory manager) to the generic IOMMU API,
and adapt omap3isp as needed, so the latter won't break.
The plan is to eventually remove iovmm completely by replacing it
with the (upcoming) IOMMU-based DMA-API.
Tested on OMAP3 (with omap3isp) and OMAP4 (with rpmsg/remoteproc).
Add support to register an isr for IOMMU fault situations and adapt it
to allow such (*isr)() to be used as fault callback. Drivers using IOMMU
module might want to be informed when errors happen in order to debug it
or react.
Signed-off-by: David Cohen <dacohen@gmail.com>
Declaration of exported function 'iopgtable_lookup_entry' is missing from
header file. Currently we have a sparse warning as it's not being used
externally. Adding its declaration to avoid such warning and allow its usage
in future.
Some IOMMUs cannot use the whole 0x0 - 0xFFFFFFFF range.
With this new API the valid range can be set.
Signed-off-by: Fernando Guzman Lugo <x0095840@ti.com>
In order to enable TLB miss interrupt, the TWL should be
disabled. This patch provides the functionality to get the
MMU fault interrupt for a TLB miss in the cases where the
users are working with the locked TLB entries and with TWL
disabled.
New interface is added to select twl and to enable TLB miss
interrupt.
Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com>
Signed-off-by: Ramesh Gupta <grgupta@ti.com>
Signed-off-by: Hiroshi Doyu <Hiroshi.DOYU@nokia.com>
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
