path: root/arch/arm/plat-omap/ocpi.c
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3455/1: ARM: OMAP: 7/8 Misc updates, take 2Tony Lindgren
Patch from Tony Lindgren Update misc OMAP core code from linux-omap tree: - McBSP updates by Samuel Ortiz, Andrzej Zaborowski - Whitespace cleanups by Ladislav Michl - Other fixes by various linux-omap developers Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-17ARM: OMAP: 4/4 Fix clock framework to use clk_enable/disable miscTony Lindgren
This patch fixes OMAP clock framework to use clk_enable/disable instead of clk_use/unuse as specified in include/linux/clk.h. Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-01-07[ARM] Move asm/hardware/clock.h to linux/clk.hRussell King
This is needs to be visible to other architectures using the AMBA bus and peripherals. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-16[ARM] Include asm/hardware.h instead of asm/arch/hardware.hRussell King
Rationalise hardware.h include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[ARM] 2887/1: OMAP 2/4: Update files common to omap1 and omap2, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Clock updates by Tuukka Tikkanen, Juha Yrjola, Daniel Petrini and Tony Lindgren - DMA fixes by Imre Deak, Juha Yrjola and Daniel Petrini - Add support to dual-mode hardware timers by Lauri Leukkunen - GPIO support for 24xx by Paul Mundt - GPIO wake-up support by Tony Lindgren - Better GPIO interrupt handler to not lose interrupts by Ralph Walden and Ladislav Michl - Power Management updates by Tuukka Tikkanen - Make Power Management code use new SRAM functions by Tony Lindgren Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-11[PATCH] ARM: remove linux/version.h include from arch/armOlaf Hering
Changing CONFIG_LOCALVERSION rebuilds too much, for no appearent reason. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2812/1: OMAP update 7c/11: Move arch-omap to plat-omapTony Lindgren
Patch from Tony Lindgren This patch move common OMAP code from arch-omap to plat-omap directory. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
