path: root/arch/arm/plat-omap/sram.c
2013-01-01ARM: OMAP: SRAM: resolve sparse warningsPaul Walmsley
Commit bb77209432873214a796a70a4539e4ebdf3feb54 ("ARM: OMAP: Move omap2+ specific parts of sram.c to mach-omap2") adds some new sparse warnings: arch/arm/plat-omap/sram.c:43:6: warning: symbol 'omap_sram_push_address' was not declared. Should it be static? arch/arm/plat-omap/sram.c:65:6: warning: symbol 'omap_sram_reset' was not declared. Should it be static? arch/arm/plat-omap/sram.c:73:13: warning: symbol 'omap_map_sram' was not declared. Should it be static? This second version fixes the warnings by including <plat/sram.h>, at Tony's request. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com>
2012-10-31ARM: OMAP: Move omap2+ specific parts of sram.c to mach-omap2Tony Lindgren
Let's make the omap2+ specific parts private to mach-omap2. This leaves just a minimal shared code into plat-omap like it should be. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-31ARM: OMAP: Move omap1 specific code to local sram.cTony Lindgren
Let's make the omap1 specific parts private to mach-omap1. These should not be in the shared code. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-31ARM: OMAP: Introduce common omap_map_sram() and omap_sram_reset()Tony Lindgren
This will allow us to separate out omap1 and omap2+ specific code in the later patches. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-31ARM: OMAP: Split sram.h to local headers and minimal shared headerTony Lindgren
Most of the defines are specific to omap1 and omap2+, and should be in the local headers. Only minimal function prototypes need to be shared. As discussed on linux-arm-kernel, we want to avoid relative includes for the arch/arm/*omap* shared code: http://www.spinics.net/lists/linux-omap/msg80520.html So this patch re-adds a minimal plat/sram.h. The new plat/sram.h must not be included from drivers, that will break build for omap2+ CONFIG_MULTIPLATFORM. Note that this patch temporarily adds two more relative includes; Those will be removed in the following patch. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-18ARM: OMAP: Split plat/cpu.h into local soc.h for mach-omap1 and mach-omap2Tony Lindgren
We want to remove plat/cpu.h. To do this, let's first split it to private soc.h to mach-omap1 and mach-omap2. We have to keep plat/cpu.h around until the remaining drivers are fixed, so let's include the local soc.h in plat/cpu.h and for drivers still including plat/cpu.h. Once the drivers are fixed not to include plat/cpu.h, we can remove the file. This is needed for the ARM common zImage support. [tony@atomide.com: updated to not print a warning] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-17ARM: OMAP: Make plat/sram.h local to plat-omapTony Lindgren
We can move this from plat to be local to plat-omap for common ARM zImage support. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-20Merge tag 'tegra-for-3.7-dmaengine' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/cleanup ARM: tegra: switch to dmaengine The Tegra code-base has contained both a legacy DMA and a dmaengine driver since v3.6-rcX. This series flips Tegra's defconfig to enable dmaengine rather than the legacy driver, and removes the legacy driver and all client code. * tag 'tegra-for-3.7-dmaengine' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra: ASoC: tegra: remove support of legacy DMA driver based access spi: tegra: remove support of legacy DMA driver based access ARM: tegra: apbio: remove support of legacy DMA driver based access ARM: tegra: dma: remove legacy APB DMA driver ARM: tegra: config: enable dmaengine based APB DMA driver + sync to 3.6-rc6
2012-09-10ARM: OMAP: remove plat/board.h fileIgor Grinberg
plat/board.h file is now empty - remove it. Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Chris Ball <cjb@laptop.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: linux-mmc@vger.kernel.org Cc: linux-mtd@lists.infradead.org Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-08-30ARM: OMAP: sram: skip the first 16K on OMAP3 HSAaro Koskinen
In some OMAP3 HS devices (at least Nokia N9 and N950), the public SRAM seems to conflict with secure portition of SRAM. When booting the 3.6-rc3 kernel (and also earlier) on these devices, the kernel gets tainted with tons of the following warnings: [ 6.894348] In-band Error seen by MPU at address 0 [...] [ 6.894378] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:162 Fix this by skipping the first 16K of the public SRAM. (Note that the mapping could not be changed, as it resulted in secure monitor call failure in save_secure_sram().) This will leave 12K SRAM available that should be still sufficient. The patch has been boot tested with vanilla 3.6-rc3 on N900, N950 and N9. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-08-30ARM: OMAP: sram: fix OMAP4 errata handlingAaro Koskinen
OMAP4-specific code should be executed only if we are running on OMAP4. Otherwise it may break multi-OMAP kernels. Found by reading the code. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-07-09ARM: OMAP5: Add minimal support for OMAP5430 SOCR Sricharan
OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP architecture. It's a dual core SOC with GIC used for interrupt handling and with an integrated L2 cache controller. OMAP5432 is another variant of OMAP5430, with a memory controller supporting DDR3 and SATA. Patch includes: - The machine specific headers and sources updates. - Platform header updates. - Minimum initialisation support for serial. - IO table init Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2012-07-05ARM: OMAP2+: am33xx: Change cpu_is_am33xx to soc_is_am33xxVaibhav Hiremath
As per recent discussion on the linux-omap list, we are moving in the direction where, we will have only architecture, ARCH_OMAP2PLUS and all devices/platforms will be treated as a SoC underneath. So the first step in this direction is to adopt this change for all new devices getting in, converting cpu_is_am33xx/335x() ==> soc_is_am33xx/335x() Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-07-05ARM: OMAP2+: am33xx: Make am33xx as a separate classVaibhav Hiremath
Initially, we decided to make am33xx family of device to fall under omap3 class (cpu_is_omap34xx() = true), since it carries Cortex-A8 core. But while adding complete baseport support (like, clock, power and hwmod) support, it is observed that, we are creating more and more problems by treating am33xx device as omap3 family, as nothing matches between them (except cortex-A8 mpu). So, after long discussion we have came to the conclusion that, we should not consider am33xx device as omap3 family, instead create separate class (SOC_AM33XX) under OMAP2PLUS. This means, for am33xx device, cpu_is_omap34xx() will return false, and only cpu_is_am33xx() will be true. Please refer to the link below, for mailing-list discussion on this - http://www.spinics.net/lists/linux-omap/msg69439.html Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Kevin Hilman <khilman@ti.com> Cc: Paul Walmsley <paul@pwsan.com> [tony@atomide.com: fixed typo, updated for soc_is changes] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-09Merge tag 'omap-cleanup-sparse-for-v3.5' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup Sparse and cppcheck warning fixes By Paul Walmsley via Paul Walmsley (1) and Tony Lindgren (1) * tag 'omap-cleanup-sparse-for-v3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP2+: clean up some cppcheck warnings ARM: OMAP1: board files: deduplicate and clean some NAND-related code ARM: OMAP: USB: remove unnecessary sideways include ARM: OMAP: DMA: use constant array maximum, drop some LCD DMA code ARM: OMAP: OCM RAM: use memset_io() when clearing SRAM ARM: OMAP: fix 'using plain integer as NULL pointer' sparse warnings ARM: OMAP2+: GPMC: resolve type-conversion warning from sparse ARM: OMAP1: OHCI: use platform_data fn ptr to enable OCPI bus ARM: OMAP1: OCPI: move to mach-omap1/ ARM: OMAP: add includes for missing prototypes ARM: OMAP2+: declare file-local functions as static Signed-off-by: Olof Johansson <olof@lixom.net>
2012-04-17ARM: OMAP: sram: fix BUG in dpll code for !PM caseGrazvydas Ignotas
_omap3_sram_configure_core_dpll is called when SDRC is reprogrammed, which is done regardless of CONFIG_PM setting, so we always need it's setup code too. Without this, we hit a BUG() on OMAP3 when kernel is built without CONFIG_PM: Reprogramming SDRC clock to 332000000 Hz ------------[ cut here ]------------ kernel BUG at arch/arm/plat-omap/sram.c:342! Internal error: Oops - BUG: 0 [#1] ARM ... [<c001c694>] (omap3_configure_core_dpll+0x68/0x6c) from [<c001b2dc>] (omap3_core_dpll_m2_set_rate+0x1) [<c001b2dc>] (omap3_core_dpll_m2_set_rate+0x138/0x1b0) from [<c001a478>] (omap2_clk_set_rate+0x14/0x2) [<c001a478>] (omap2_clk_set_rate+0x14/0x20) from [<c001c9dc>] (clk_set_rate+0x54/0x74) [<c001c9dc>] (clk_set_rate+0x54/0x74) from [<c022b9c8>] (omap_sdrc_init+0x70/0x90) [<c022b9c8>] (omap_sdrc_init+0x70/0x90) from [<c022f178>] (omap3pandora_init+0x11c/0x164) [<c022f178>] (omap3pandora_init+0x11c/0x164) from [<c022849c>] (customize_machine+0x20/0x28) [<c022849c>] (customize_machine+0x20/0x28) from [<c0225810>] (do_one_initcall+0xa0/0x16c) [<c0225810>] (do_one_initcall+0xa0/0x16c) from [<c02259e0>] (kernel_init+0x104/0x1ac) [<c02259e0>] (kernel_init+0x104/0x1ac) from [<c0009cec>] (kernel_thread_exit+0x0/0x8) Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-04-13ARM: OMAP: OCM RAM: use memset_io() when clearing SRAMPaul Walmsley
We currently treat the OCM RAM memory as memory that hangs off an I/O bus, so use memset_io() to clear it rather than memset(). This also takes care of this sparse warning: arch/arm/plat-omap/sram.c:199:9: warning: cast removes address space of expression There is still one SRAM-related sparse warning, but it appears that fixing it correctly will take some time and thought. N.B., at some point, the OCM RAM IP block interface code should probably be reimplemented as an MTD device or something similar under drivers/. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-03-27Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: global cleanups" from Arnd Bergmann: "Quite a bit of code gets removed, and some stuff moved around, mostly the old samsung s3c24xx stuff. There should be no functional changes in this series otherwise. Some cleanups have dependencies on other arm-soc branches and will be sent in the second round. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial conflicts mainly due to #include's being changes on both sides. * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits) ep93xx: Remove unnecessary includes of ep93xx-regs.h ep93xx: Move EP93XX_SYSCON defines to SoC private header ep93xx: Move crunch code to mach-ep93xx directory ep93xx: Make syscon access functions private to SoC ep93xx: Configure GPIO ports in core code ep93xx: Move peripheral defines to local SoC header ep93xx: Convert the watchdog driver into a platform device. ep93xx: Use ioremap for backlight driver ep93xx: Move GPIO defines to gpio-ep93xx.h ep93xx: Don't use system controller defines in audio drivers ep93xx: Move PHYS_BASE defines to local SoC header file ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver ARM: EXYNOS: add clock registers for exynos4x12-cpufreq PM / devfreq: update the name of EXYNOS clock registers that were omitted PM / devfreq: update the name of EXYNOS clock register ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock ARM: EXYNOS: use static declaration on regarding clock ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs ARM: OMAP2+: Fix build error after merge ARM: S3C24XX: remove call to s3c24xx_setup_clocks ...
2012-03-05ARM: OMAP: sram: Add am33xx SRAM support (minimal)Vaibhav Bedia
Update SRAM start & size for am33xx SoC's. Note: cpu_is_34xx() is true for am33xx also. Doing cpu_is_am33xx() check after cpu_is_34xx() will not achieve what we want due to the above reason. Hence cpu_is_am33xx() is done before cpu_is_34xx() Signed-off-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Signed-off-by: Afzal Mohammed <afzal@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-02-24ARM: OMAP2+: Move most of plat/io.h into local iomap.hTony Lindgren
There's no need to have these defines in plat/io.h. Note that we now need to ifdef omap_read/write calls as they will be available for omap1 only. While at it, clean up the includes to group them like they typically are grouped. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-01-09Merge tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
power management changes for omap and imx A significant part of the changes for these two platforms went into power management, so they are split out into a separate branch. * tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (65 commits) ARM: imx6: remove __CPUINIT annotation from v7_invalidate_l1 ARM: imx6: fix v7_invalidate_l1 by adding I-Cache invalidation ARM: imx6q: resume PL310 only when CACHE_L2X0 defined ARM: imx6q: build pm code only when CONFIG_PM selected ARM: mx5: use generic irq chip pm interface for pm functions on ARM: omap: pass minimal SoC/board data for UART from dt arm/dts: Add minimal device tree support for omap2420 and omap2430 omap-serial: Add minimal device tree support omap-serial: Use default clock speed (48Mhz) if not specified omap-serial: Get rid of all pdev->id usage ARM: OMAP2+: hwmod: Add a new flag to handle hwmods left enabled at init ARM: OMAP4: PRM: use PRCM interrupt handler ARM: OMAP3: pm: use prcm chain handler ARM: OMAP: hwmod: add support for selecting mpu_irq for each wakeup pad ARM: OMAP2+: mux: add support for PAD wakeup interrupts ARM: OMAP: PRCM: add suspend prepare / finish support ARM: OMAP: PRCM: add support for chain interrupt handler ARM: OMAP3/4: PRM: add functions to read pending IRQs, PRM barrier ARM: OMAP2+: hwmod: Add API to enable IO ring wakeup ARM: OMAP2+: mux: add wakeup-capable hwmod mux entries to dynamic list ...
2011-12-08ARM: OMAP1: Update dpll1 default rate reprogramming methodJanusz Krzysztofik
According to comments in omap1_select_table_rate(), reprogramming dpll1 is tricky, and should always be done from SRAM. While being at it, move OMAP730 special case handling inside omap_sram_reprogram_clock(). Created on top of version 2 of the series "ARM: OMAP1: Fix dpll1 reprogramming related issues", which it depends on. Tested on Amstrad Delta. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-12-08ARM: OMAP1: Set the omap1623 sram size to 16KTony Lindgren
Now that we're always reprogramming the core clock we must make sure SRAM works. It seems that neither omap1621 or omap1623 has 256K of SRAM. Set the SRAM size to safe value of 16K. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-12-08ARM: OMAP4: Fix errata i688 with MPU interconnect barriers.Santosh Shilimkar
On OMAP4 SOC, intecronnects has many write buffers in the async bridges and they need to be drained before CPU enters into standby state. Patch 'OMAP4: PM: Add CPUX OFF mode support' added CPU PM support but OMAP errata i688 (Async Bridge Corruption) needs to be taken care to avoid issues like system freeze, CPU deadlocks, random crashes with register accesses, synchronisation loss on initiators operating on both interconnect port simultaneously. As per the errata, if a data is stalled inside asynchronous bridge because of back pressure, it may be accepted multiple times, creating pointer misalignment that will corrupt next transfers on that data path until next reset of the system (No recovery procedure once the issue is hit, the path remains consistently broken). Async bridge can be found on path between MPU to EMIF and MPU to L3 interconnect. This situation can happen only when the idle is initiated by a Master Request Disconnection (which is trigged by software when executing WFI on CPU). The work-around for this errata needs all the initiators connected through async bridge must ensure that data path is properly drained before issuing WFI. This condition will be met if one Strongly ordered access is performed to the target right before executing the WFI. In MPU case, L3 T2ASYNC FIFO and DDR T2ASYNC FIFO needs to be drained. IO barrier ensure that there is no synchronisation loss on initiators operating on both interconnect port simultaneously. Thanks to Russell for a tip to conver assembly function to C fuction there by reducing 40 odd lines of code from the patch. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Richard Woodruff <r-woodruff2@ti.com> Acked-by: Jean Pihet <j-pihet@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Tested-by: Vishwanath BS <vishwanath.bs@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-10-19ARM: OMAP: Map SRAM later on with ioremap_exec()Tony Lindgren
This allows us to remove omap hacks for map_io. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-10-19ARM: OMAP: Remove calls to SRAM allocations for framebufferTony Lindgren
This assumes fixed mappings which will not work once we move to use ioremap_exec(). It seems that these are currently not in use, or in use for some out of tree corner cases. If SRAM support for framebuffer is wanted, it should be done with ioremap in the driver. Note that further removal of the code can now be done, but that can be done seprately by the driver maintainers. Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-06-29ARM: pm: omap3: run the ASM sleep code from DDRJean Pihet
Most of the ASM sleep code (in arch/arm/mach-omap2/sleep34xx.S) is copied to internal SRAM at boot and after wake-up from CORE OFF mode. However only a small part of the code really needs to run from internal SRAM. This fix lets most of the ASM idle code run from the DDR in order to minimize the SRAM usage and the overhead in the code copy. The only pieces of code that are mandatory in SRAM are: - the i443 erratum WA, - the i581 erratum WA, - the security extension code. SRAM usage: - original code: . 560 bytes for omap3_sram_configure_core_dpll (used by DVFS), . 852 bytes for omap_sram_idle (used by suspend/resume in RETention), . 124 bytes for es3_sdrc_fix (used by suspend/resume in OFF mode on ES3.x), . 108 bytes for save_secure_ram_context (used on HS parts only). With this fix the usage for suspend/resume in RETention goes down 288 bytes, so the gain in SRAM usage for suspend/resume is 564 bytes. Also fixed the SRAM initialization sequence to avoid an unnecessary copy to SRAM at boot time and for readability. Tested on Beagleboard (ES2.x) in idle with full RET and OFF modes. Kevin Hilman tested retention and off on 3430/n900, 3530/Overo and 3630/Zoom3 Signed-off-by: Jean Pihet <j-pihet@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Tested-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-31OMAP: SRAM: Fix warning: format '%08lx' expects type 'long unsigned int'Santosh Shilimkar
Fix below build warning. CC arch/arm/plat-omap/sram.o arch/arm/plat-omap/sram.c: In function 'omap_map_sram': arch/arm/plat-omap/sram.c:224: warning: format '%08lx' expects type 'long unsigned int', but argument 2 has type 'unsigned int' While at this, convert SRAM printk(* "") to pr_*(""). Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-02-17omap4: Remove 'FIXME: omap44xx_sram_init not implemented'Santosh Shilimkar
The omap44xx_sram_init() implements functionality to push some code on SRAM whenever the code can't be executed from external memory. The low power and DVFS code can be executed from external DDR itself thanks to OMAP4 memory controller hardware support. So on OMAP4, sram_push kind of functionality isn't needed. Hence remove the FIXME warning added for implementing sram push feature on OMAP4. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-04ARM: 6649/1: omap: use fncpy to copy the PM code functions to SRAMJean Pihet
The new fncpy API is better suited* for copying some code to SRAM at runtime. This patch changes the ad-hoc code to the more generic fncpy API. *: 1. fncpy ensures that the thumb mode bit is propagated, 2. fncpy provides the security of type safety between the original function and the sram function pointer. Tested OK on OMAP3 in low power modes (RET/OFF) using omap2plus_defconfig with !CONFIG_THUMB2_KERNEL. Compile tested on OMAP1/2 using omap1_defconfig. Boot tested on OMAP1 & OMAP2 Tested OK with suspend/resume on OMAP2420/n810 Boots fine on osk5912 and n800 Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Kevin Hilman <khilman@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Dave Martin <dave.martin@linaro.org> Tested-by: Kevin Hilman <khilman@ti.com> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-27omap: Start using CONFIG_SOC_OMAPTony Lindgren
We want to have just CONFIG_ARCH_OMAP2, 3 and 4. The rest are nowadays just subcategories of these. Search and replace the following: ARCH_OMAP2420 SOC_OMAP2420 ARCH_OMAP2430 SOC_OMAP2430 ARCH_OMAP3430 SOC_OMAP3430 No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Sourav Poddar <sourav.poddar@ti.com>
2010-12-21OMAP2/3: PRCM: split OMAP2/3-specific PRCM code into OMAP2/3-specific filesPaul Walmsley
In preparation for adding OMAP4-specific PRCM accessor/mutator functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was OMAP2xxx/3xxx-specific. This process also requires the #includes in each of these files to be changed to reference the new file name. As part of doing so, add some comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use "sideways includes", to indicate that these users of the PRM/CM includes should not be doing so. Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this patch. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21Merge branch 'pm-next' of ↵Tony Lindgren
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
2010-12-21OMAP2+: use global values for the SRAM PA addressesJean Pihet
The SRAM PA addresses are locally defined and used at different places, i.e. SRAM management code and idle sleep code. The macros are now defined at a centralized place, for easier maintenance. Tested on N900 and Beagleboard with full RET and OFF modes, using cpuidle and suspend. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Nishanth Menon<nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-17Merge branch 'devel-board' into omap-for-linusTony Lindgren
2010-12-09OMAP1: SRAM: fix size for OMAP1611 SoCsKevin Hilman
Kernel was failing to boot on omap1611 based OSK boards due to mis-configured SRAM size. Existing code was using a hard-coded value for 250k, which was then rounded down by PAGE_SIZE. Increasing this to 256k allows kernel to boot on omap1611 SoCs. Problem reported by and initial fix suggested by Tim Bird. Thanks to Tony Lindgren for helping diagnose the problem to being specific to OMAP1611 and not affecting OMAP1610/OMAP1623. Reported-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-11-24arm: omap1: make some functions staticAaro Koskinen
Make some functions static to get rid of the following sparse warnings: arch/arm/mach-omap1/mcbsp.c:177:12: warning: symbol 'omap1_mcbsp_init' was not declared. Should it be static? arch/arm/mach-omap1/mux.c:346:22: warning: symbol 'omap1_cfg_reg' was not declared. Should it be static? arch/arm/plat-omap/dma.c:177:5: warning: symbol 'omap_dma_in_1510_mode' was not declared. Should it be static? arch/arm/plat-omap/sram.c:273:12: warning: symbol 'omap1_sram_init' was not declared. Should it be static? Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-25Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits) omap: complete removal of machine_desc.io_pg_offst and .phys_io omap: UART: fix wakeup registers for OMAP24xx UART2 omap: Fix spotty MMC voltages ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h serial: omap-serial: fix signess error OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish omap: dma: Fix buffering disable bit setting for omap24xx omap: serial: Fix the boot-up crash/reboot without CONFIG_PM OMAP3: PM: fix scratchpad memory accesses for off-mode omap4: pandaboard: enable the ehci port on pandaboard omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set omap4: pandaboard: remove unused hsmmc definition OMAP: McBSP: Remove null omap44xx ops comment OMAP: McBSP: Swap CLKS source definition OMAP: McBSP: Fix CLKR and FSR signal muxing OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks OMAP: control: move plat-omap/control.h to mach-omap2/control.h OMAP: split plat-omap/common.c OMAP: McBSP: implement functional clock switching via clock framework OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c ... Fixed up trivial conflicts in arch/arm/mach-omap2/ {board-zoom-peripherals.c,devices.c} as per Tony
2010-10-08OMAP: split plat-omap/common.cPaul Walmsley
Split plat-omap/common.c into three pieces: 1. the 32KiHz sync timer and clocksource code, which now lives in plat-omap/counter_32k.c; 2. the OMAP2+ common code, which has been moved to mach-omap2/common.c; 3. and the remainder of the OMAP-wide common code, which includes the deprecated ATAGs code and a deprecated video RAM reservation function. The primary motivation for doing this is to move the OMAP2+-specific parts into an OMAP2+-specific file, so that build breakage related to the System Control Module code can be resolved. Benoît Cousson <b-cousson@ti.com> suggested a new filename and found some bugs in the counter_32k.c comments - thanks Benoît. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com>
2010-10-08OMAP: plat-omap: Fix static function warningsManjunath Kondaiah G
This patch fixes sparse warnings due non declarations of static functions. arch/arm/plat-omap/sram.c:130:13: warning: symbol 'omap_detect_sram' was not declared. Should it be static? arch/arm/plat-omap/sram.c:216:13: warning: symbol 'omap_map_sram' was not declared. Should it be static? arch/arm/plat-omap/sram.c:450:12: warning: symbol 'omap_sram_init' was not declared. Should it be static? arch/arm/plat-omap/sram.c:348:12: warning: symbol 'omap242x_sram_init' was not declared. Should it be static? arch/arm/plat-omap/sram.c:369:12: warning: symbol 'omap243x_sram_init' was not declared. Should it be static? arch/arm/plat-omap/sram.c:425:12: warning: symbol 'omap34xx_sram_init' was not declared. Should it be static? arch/arm/plat-omap/sram.c:441:12: warning: symbol 'omap44xx_sram_init' was not declared. Should it be static arch/arm/plat-omap/mcbsp.c:36:6: warning: symbol 'omap_mcbsp_write' was not declared. Should it be static? arch/arm/plat-omap/mcbsp.c:50:5: warning: symbol 'omap_mcbsp_read' was not declared. Should it be static? arch/arm/plat-omap/mcbsp.c:65:6: warning: symbol 'omap_mcbsp_st_write' was not declared. Should it be static? arch/arm/plat-omap/mcbsp.c:70:5: warning: symbol 'omap_mcbsp_st_read' was not declared. Should it be static? arch/arm/plat-omap/mcbsp.c:1648:15: warning: symbol 'omap_st_add' was not declared. Should it be static? arch/arm/plat-omap/fb.c:414:15: warning: symbol 'omapfb_reserve_sram' was not declared. Should it be static? arch/arm/plat-omap/cpu-omap.c:43:5: warning: symbol 'omap_verify_speed' was not declared. Should it be static? arch/arm/plat-omap/cpu-omap.c:61:14: warning: symbol 'omap_getspeed' was not declared. Should it be static? Signed-off-by: Manjunath Kondaiah G <manjugk@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-09-25ARM: 6408/1: omap: Map only available sram memorySantosh Shilimkar
Currently we map 1 MB section while setting up SRAM on OMAPs Regardless of the actual memory. The physical OCM RAM available on OMAP SOCs is in order of KBs. This patch maps only available sram and cleans up some un-necessary cpu_is_xxx checks. Mapping un-available or non-accessible(secure) memory on the newer ARM processor is dangerous. Because ARM CPUs can now speculatively prefetch, we should avoid mapping any no-existing or secure memory. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-24omap4: sram: Fix start addressVikram Pandita
On OMAP4 there is no need to have SRAM_BOOTLOADER_SZ provision Hence put this macro under CONFIG_ARCH_OMAP2PLUS check Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-09-24omap: sram: fix is_sram_locked checkVikram Pandita
For OMAP24xx/34xx/44xx: omap_type() returns the correct type: OMAP2_DEVICE_TYPE_TEST OMAP2_DEVICE_TYPE_EMU OMAP2_DEVICE_TYPE_SEC OMAP2_DEVICE_TYPE_GP OMAP2_DEVICE_TYPE_BAD In current implementation there are two problems: Problem 1: For 34xx, the current if check will never return true. Problem 2: For 24xx the correct type check should be with omap_type() function Verified by checking the TRM 24xx for CONTROL_STATUS register bits Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-05-04omap4: Fix multiboot with CONFIG_PM and CONFIG_ARCH_OMAP3 selectedTony Lindgren
We cannot use the omap34xx_sram_init(). It needs to be implemented for omap4. Otherwise we get an error and the system won't boot: Unhandled fault: imprecise external abort (0x1406) at 0xea963e94 ... Fix this by adding a dummy omap44xx_sram_init(). Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap3: Replace ARCH_OMAP34XX with ARCH_OMAP3Tony Lindgren
Replace ARCH_OMAP34XX with ARCH_OMAP3 Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2: Convert ARCH_OMAP24XX to ARCH_OMAP2Tony Lindgren
Convert ARCH_OMAP24XX to ARCH_OMAP2 Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11OMAP4: Fix SRAM base and sizeSantosh Shilimkar
This patch fixes the public sram base address and available size on OMAP4430. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-09OMAP: Add VRAM managerTomi Valkeinen
Add a Video RAM manager for OMAP 2 and 3 platforms. VRAM manager is used to allocate large continuous blocks of SDRAM or SRAM. The features VRAM manager has that are missing from dma_alloc_* functions are: - Support for OMAP2's SRAM - Allocate without ioremapping - Allocate at defined physical addresses - Allows larger VRAM area and larger allocations The upcoming DSS2 uses VRAM manager. VRAM area size can be defined in kernel config, board file or with kernel boot parameters. Board file definition overrides kernel config, and boot parameter overrides kernel config and board file. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2009-11-11OMAP3: PM: restore SRAM functions after off-mode.Rajendra Nayak
Generalize the copy of SRAM functions into omap_push_sram_idle() so it can be used on init but also after off-mode transitions. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
