Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
We are still using custom SRAM code for some SoCs and are not marking
the PM code mapped to SRAM as read-only and executable after we're
done. With CONFIG_DEBUG_WX=y, we will get "Found insecure W+X mapping
at address" warning.
Let's fix this issue the same way as commit 728bbe75c82f ("misc: sram:
Introduce support code for protect-exec sram type") is doing for
drivers/misc/sram-exec.c.
On omap3, we need to restore SRAM when returning from off mode after
idle, so init time configuration is not enough.
And as we no longer have users for omap_sram_push_address() we can
make it static while at it.
Note that eventually we should be using sram-exec.c for all SoCs.
Cc: stable@vger.kernel.org # v4.12+
Cc: Dave Gerlach <d-gerlach@ti.com>
Reported-by: Pavel Machek <pavel@ucw.cz>
Commit bb77209432873214a796a70a4539e4ebdf3feb54 ("ARM: OMAP: Move
omap2+ specific parts of sram.c to mach-omap2") adds some new sparse
warnings:
arch/arm/plat-omap/sram.c:43:6: warning: symbol 'omap_sram_push_address' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:65:6: warning: symbol 'omap_sram_reset' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:73:13: warning: symbol 'omap_map_sram' was not declared. Should it be static?
This second version fixes the warnings by including <plat/sram.h>, at
Tony's request.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Tony Lindgren <tony@atomide.com>
Let's make the omap2+ specific parts private to mach-omap2.
This leaves just a minimal shared code into plat-omap like
it should be.
Let's make the omap1 specific parts private to mach-omap1.
These should not be in the shared code.
This will allow us to separate out omap1 and omap2+ specific
code in the later patches.
Most of the defines are specific to omap1 and omap2+,
and should be in the local headers. Only minimal function
prototypes need to be shared.
As discussed on linux-arm-kernel, we want to avoid
relative includes for the arch/arm/*omap* shared code:
http://www.spinics.net/lists/linux-omap/msg80520.html
So this patch re-adds a minimal plat/sram.h.
The new plat/sram.h must not be included from drivers,
that will break build for omap2+ CONFIG_MULTIPLATFORM.
Note that this patch temporarily adds two more
relative includes; Those will be removed in the
following patch.
We want to remove plat/cpu.h. To do this, let's first split
it to private soc.h to mach-omap1 and mach-omap2. We have to
keep plat/cpu.h around until the remaining drivers are fixed,
so let's include the local soc.h in plat/cpu.h and for drivers
still including plat/cpu.h.
Once the drivers are fixed not to include plat/cpu.h, we
can remove the file.
This is needed for the ARM common zImage support.
[tony@atomide.com: updated to not print a warning]
We can move this from plat to be local to plat-omap
for common ARM zImage support.
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/cleanup
ARM: tegra: switch to dmaengine
The Tegra code-base has contained both a legacy DMA and a dmaengine
driver since v3.6-rcX. This series flips Tegra's defconfig to enable
dmaengine rather than the legacy driver, and removes the legacy driver
and all client code.
* tag 'tegra-for-3.7-dmaengine' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra:
ASoC: tegra: remove support of legacy DMA driver based access
spi: tegra: remove support of legacy DMA driver based access
ARM: tegra: apbio: remove support of legacy DMA driver based access
ARM: tegra: dma: remove legacy APB DMA driver
ARM: tegra: config: enable dmaengine based APB DMA driver
+ sync to 3.6-rc6
plat/board.h file is now empty - remove it.
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: linux-mmc@vger.kernel.org
Cc: linux-mtd@lists.infradead.org
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Chris Ball <cjb@laptop.org>
In some OMAP3 HS devices (at least Nokia N9 and N950), the public SRAM
seems to conflict with secure portition of SRAM. When booting the 3.6-rc3
kernel (and also earlier) on these devices, the kernel gets tainted with
tons of the following warnings:
[ 6.894348] In-band Error seen by MPU at address 0
[ 6.894378] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:162
Fix this by skipping the first 16K of the public SRAM. (Note that the
mapping could not be changed, as it resulted in secure monitor call
failure in save_secure_sram().)
This will leave 12K SRAM available that should be still sufficient. The
patch has been boot tested with vanilla 3.6-rc3 on N900, N950 and N9.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
OMAP4-specific code should be executed only if we are running on
OMAP4. Otherwise it may break multi-OMAP kernels. Found by reading
the code.
OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP
architecture. It's a dual core SOC with GIC used for interrupt
handling and with an integrated L2 cache controller.
OMAP5432 is another variant of OMAP5430, with a
memory controller supporting DDR3 and SATA.
Patch includes:
- The machine specific headers and sources updates.
- Platform header updates.
- Minimum initialisation support for serial.
- IO table init
Signed-off-by: R Sricharan <r.sricharan@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
As per recent discussion on the linux-omap list, we are
moving in the direction where, we will have only architecture,
ARCH_OMAP2PLUS and all devices/platforms will be treated
as a SoC underneath.
So the first step in this direction is to adopt this change
for all new devices getting in, converting
cpu_is_am33xx/335x() ==> soc_is_am33xx/335x()
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Initially, we decided to make am33xx family of device to fall
under omap3 class (cpu_is_omap34xx() = true), since it carries
Cortex-A8 core. But while adding complete baseport support
(like, clock, power and hwmod) support, it is observed that,
we are creating more and more problems by treating am33xx device
as omap3 family, as nothing matches between them
(except cortex-A8 mpu).
So, after long discussion we have came to the conclusion that,
we should not consider am33xx device as omap3 family, instead
create separate class (SOC_AM33XX) under OMAP2PLUS.
This means, for am33xx device, cpu_is_omap34xx() will return false,
and only cpu_is_am33xx() will be true.
Please refer to the link below, for mailing-list discussion on this -
http://www.spinics.net/lists/linux-omap/msg69439.html
Cc: Kevin Hilman <khilman@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
[tony@atomide.com: fixed typo, updated for soc_is changes]
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
Sparse and cppcheck warning fixes
By Paul Walmsley
via Paul Walmsley (1) and Tony Lindgren (1)
* tag 'omap-cleanup-sparse-for-v3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: clean up some cppcheck warnings
ARM: OMAP1: board files: deduplicate and clean some NAND-related code
ARM: OMAP: USB: remove unnecessary sideways include
ARM: OMAP: DMA: use constant array maximum, drop some LCD DMA code
ARM: OMAP: OCM RAM: use memset_io() when clearing SRAM
ARM: OMAP: fix 'using plain integer as NULL pointer' sparse warnings
ARM: OMAP2+: GPMC: resolve type-conversion warning from sparse
ARM: OMAP1: OHCI: use platform_data fn ptr to enable OCPI bus
ARM: OMAP1: OCPI: move to mach-omap1/
ARM: OMAP: add includes for missing prototypes
ARM: OMAP2+: declare file-local functions as static
_omap3_sram_configure_core_dpll is called when SDRC is reprogrammed,
which is done regardless of CONFIG_PM setting, so we always need it's
setup code too. Without this, we hit a BUG() on OMAP3 when kernel is
built without CONFIG_PM:
Reprogramming SDRC clock to 332000000 Hz
kernel BUG at arch/arm/plat-omap/sram.c:342!
Internal error: Oops - BUG: 0 [#1] ARM
[<c001c694>] (omap3_configure_core_dpll+0x68/0x6c) from [<c001b2dc>] (omap3_core_dpll_m2_set_rate+0x1)
[<c001b2dc>] (omap3_core_dpll_m2_set_rate+0x138/0x1b0) from [<c001a478>] (omap2_clk_set_rate+0x14/0x2)
[<c001a478>] (omap2_clk_set_rate+0x14/0x20) from [<c001c9dc>] (clk_set_rate+0x54/0x74)
[<c001c9dc>] (clk_set_rate+0x54/0x74) from [<c022b9c8>] (omap_sdrc_init+0x70/0x90)
[<c022b9c8>] (omap_sdrc_init+0x70/0x90) from [<c022f178>] (omap3pandora_init+0x11c/0x164)
[<c022f178>] (omap3pandora_init+0x11c/0x164) from [<c022849c>] (customize_machine+0x20/0x28)
[<c022849c>] (customize_machine+0x20/0x28) from [<c0225810>] (do_one_initcall+0xa0/0x16c)
[<c0225810>] (do_one_initcall+0xa0/0x16c) from [<c02259e0>] (kernel_init+0x104/0x1ac)
[<c02259e0>] (kernel_init+0x104/0x1ac) from [<c0009cec>] (kernel_thread_exit+0x0/0x8)
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
We currently treat the OCM RAM memory as memory that hangs off an
I/O bus, so use memset_io() to clear it rather than memset().
This also takes care of this sparse warning:
arch/arm/plat-omap/sram.c:199:9: warning: cast removes address space of expression
There is still one SRAM-related sparse warning, but it appears that
fixing it correctly will take some time and thought.
N.B., at some point, the OCM RAM IP block interface code should probably
be reimplemented as an MTD device or something similar under drivers/.
Pull "ARM: global cleanups" from Arnd Bergmann:
"Quite a bit of code gets removed, and some stuff moved around, mostly
the old samsung s3c24xx stuff. There should be no functional changes
in this series otherwise. Some cleanups have dependencies on other
arm-soc branches and will be sent in the second round.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up trivial conflicts mainly due to #include's being changes on
both sides.
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits)
ep93xx: Remove unnecessary includes of ep93xx-regs.h
ep93xx: Move EP93XX_SYSCON defines to SoC private header
ep93xx: Move crunch code to mach-ep93xx directory
ep93xx: Make syscon access functions private to SoC
ep93xx: Configure GPIO ports in core code
ep93xx: Move peripheral defines to local SoC header
ep93xx: Convert the watchdog driver into a platform device.
ep93xx: Use ioremap for backlight driver
ep93xx: Move GPIO defines to gpio-ep93xx.h
ep93xx: Don't use system controller defines in audio drivers
ep93xx: Move PHYS_BASE defines to local SoC header file
ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver
ARM: EXYNOS: add clock registers for exynos4x12-cpufreq
PM / devfreq: update the name of EXYNOS clock registers that were omitted
ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock
ARM: EXYNOS: use static declaration on regarding clock
ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs
ARM: OMAP2+: Fix build error after merge
ARM: S3C24XX: remove call to s3c24xx_setup_clocks
Update SRAM start & size for am33xx SoC's.
Note: cpu_is_34xx() is true for am33xx also. Doing
cpu_is_am33xx() check after cpu_is_34xx() will not
achieve what we want due to the above reason.
Hence cpu_is_am33xx() is done before cpu_is_34xx()
Signed-off-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
Signed-off-by: Afzal Mohammed <afzal@ti.com>
There's no need to have these defines in plat/io.h.
Note that we now need to ifdef omap_read/write calls
as they will be available for omap1 only.
While at it, clean up the includes to group them like
they typically are grouped.
power management changes for omap and imx
A significant part of the changes for these two platforms went into
power management, so they are split out into a separate branch.
* tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (65 commits)
ARM: imx6: remove __CPUINIT annotation from v7_invalidate_l1
ARM: imx6: fix v7_invalidate_l1 by adding I-Cache invalidation
ARM: imx6q: resume PL310 only when CACHE_L2X0 defined
ARM: imx6q: build pm code only when CONFIG_PM selected
ARM: mx5: use generic irq chip pm interface for pm functions on
ARM: omap: pass minimal SoC/board data for UART from dt
arm/dts: Add minimal device tree support for omap2420 and omap2430
omap-serial: Add minimal device tree support
omap-serial: Use default clock speed (48Mhz) if not specified
omap-serial: Get rid of all pdev->id usage
ARM: OMAP2+: hwmod: Add a new flag to handle hwmods left enabled at init
ARM: OMAP4: PRM: use PRCM interrupt handler
ARM: OMAP3: pm: use prcm chain handler
ARM: OMAP: hwmod: add support for selecting mpu_irq for each wakeup pad
ARM: OMAP2+: mux: add support for PAD wakeup interrupts
ARM: OMAP: PRCM: add suspend prepare / finish support
ARM: OMAP: PRCM: add support for chain interrupt handler
ARM: OMAP3/4: PRM: add functions to read pending IRQs, PRM barrier
ARM: OMAP2+: hwmod: Add API to enable IO ring wakeup
ARM: OMAP2+: mux: add wakeup-capable hwmod mux entries to dynamic list
According to comments in omap1_select_table_rate(), reprogramming dpll1
is tricky, and should always be done from SRAM.
While being at it, move OMAP730 special case handling inside
omap_sram_reprogram_clock().
Created on top of version 2 of the series "ARM: OMAP1: Fix dpll1
reprogramming related issues", which it depends on.
Tested on Amstrad Delta.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Now that we're always reprogramming the core clock we must make
sure SRAM works. It seems that neither omap1621 or omap1623
has 256K of SRAM. Set the SRAM size to safe value of 16K.
On OMAP4 SOC, intecronnects has many write buffers in the async bridges
and they need to be drained before CPU enters into standby state.
Patch 'OMAP4: PM: Add CPUX OFF mode support' added CPU PM support
but OMAP errata i688 (Async Bridge Corruption) needs to be taken
care to avoid issues like system freeze, CPU deadlocks, random
crashes with register accesses, synchronisation loss on initiators
operating on both interconnect port simultaneously.
As per the errata, if a data is stalled inside asynchronous bridge
because of back pressure, it may be accepted multiple times, creating
pointer misalignment that will corrupt next transfers on that data
path until next reset of the system (No recovery procedure once
the issue is hit, the path remains consistently broken).
Async bridge can be found on path between MPU to EMIF and
MPU to L3 interconnect. This situation can happen only when the
idle is initiated by a Master Request Disconnection (which is
trigged by software when executing WFI on CPU).
The work-around for this errata needs all the initiators
connected through async bridge must ensure that data path
is properly drained before issuing WFI. This condition will be
met if one Strongly ordered access is performed to the
target right before executing the WFI. In MPU case, L3 T2ASYNC
FIFO and DDR T2ASYNC FIFO needs to be drained. IO barrier ensure
that there is no synchronisation loss on initiators operating
Thanks to Russell for a tip to conver assembly function to
C fuction there by reducing 40 odd lines of code from the patch.
Signed-off-by: Richard Woodruff <r-woodruff2@ti.com>
Acked-by: Jean Pihet <j-pihet@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Tested-by: Vishwanath BS <vishwanath.bs@ti.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
This allows us to remove omap hacks for map_io.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
This assumes fixed mappings which will not work once we move
to use ioremap_exec(). It seems that these are currently
not in use, or in use for some out of tree corner cases.
If SRAM support for framebuffer is wanted, it should be done
with ioremap in the driver.
Note that further removal of the code can now be done,
but that can be done seprately by the driver maintainers.
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Most of the ASM sleep code (in arch/arm/mach-omap2/sleep34xx.S)
is copied to internal SRAM at boot and after wake-up from CORE OFF
mode. However only a small part of the code really needs to run from
internal SRAM.
This fix lets most of the ASM idle code run from the DDR in order to
minimize the SRAM usage and the overhead in the code copy.
The only pieces of code that are mandatory in SRAM are:
- the i443 erratum WA,
- the i581 erratum WA,
- the security extension code.
SRAM usage:
- original code:
. 560 bytes for omap3_sram_configure_core_dpll (used by DVFS),
. 852 bytes for omap_sram_idle (used by suspend/resume in RETention),
. 124 bytes for es3_sdrc_fix (used by suspend/resume in OFF mode on ES3.x),
. 108 bytes for save_secure_ram_context (used on HS parts only).
With this fix the usage for suspend/resume in RETention goes down 288
bytes, so the gain in SRAM usage for suspend/resume is 564 bytes.
Also fixed the SRAM initialization sequence to avoid an unnecessary
copy to SRAM at boot time and for readability.
Tested on Beagleboard (ES2.x) in idle with full RET and OFF modes.
Kevin Hilman tested retention and off on 3430/n900, 3530/Overo and
3630/Zoom3
Signed-off-by: Jean Pihet <j-pihet@ti.com>
Tested-by: Kevin Hilman <khilman@ti.com>
Fix below build warning.
CC arch/arm/plat-omap/sram.o
arch/arm/plat-omap/sram.c: In function 'omap_map_sram':
arch/arm/plat-omap/sram.c:224: warning: format '%08lx' expects
type 'long unsigned int', but argument 2 has type 'unsigned int'
While at this, convert SRAM printk(* "") to pr_*("").
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits)
omap: zoom: host should not pull up wl1271's irq line
arm: plat-omap: iommu: fix request_mem_region() error path
OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430
omap4: mux: Remove duplicate mux modes
omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag
omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set
omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected
omap4: board-omap4panda: Initialise the serial pads
omap3: board-3430sdp: Initialise the serial pads
omap4: board-4430sdp: Initialise the serial pads
omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init
omap2+: mux: Remove the use of IDLE flag
omap2+: Add separate list for dynamic pads to mux
perf: add OMAP support for the new power events
OMAP4: Add IVA OPP enteries.
OMAP4: Update Voltage Rail Values for MPU, IVA and CORE
OMAP4: Enable 800 MHz and 1 GHz MPU-OPP
OMAP3+: OPP: Replace voltage values with Macros
OMAP3: wdtimer: Fix CORE idle transition
Watchdog: omap_wdt: add fine grain runtime-pm
Fix up various conflicts in
- arch/arm/mach-omap2/board-omap3evm.c
- arch/arm/mach-omap2/clock3xxx_data.c
- arch/arm/mach-omap2/usb-musb.c
- arch/arm/plat-omap/include/plat/usb.h
- drivers/usb/musb/musb_core.h
The omap44xx_sram_init() implements functionality to push some
code on SRAM whenever the code can't be executed from external
memory. The low power and DVFS code can be executed from
external DDR itself thanks to OMAP4 memory controller hardware
support. So on OMAP4, sram_push kind of functionality isn't needed.
Hence remove the FIXME warning added for implementing sram push
feature on OMAP4.
The new fncpy API is better suited* for copying some
code to SRAM at runtime. This patch changes the ad-hoc
code to the more generic fncpy API.
*: 1. fncpy ensures that the thumb mode bit is propagated,
2. fncpy provides the security of type safety between the
original function and the sram function pointer.
Tested OK on OMAP3 in low power modes (RET/OFF)
using omap2plus_defconfig with !CONFIG_THUMB2_KERNEL.
Compile tested on OMAP1/2 using omap1_defconfig.
Boot tested on OMAP1 & OMAP2
Tested OK with suspend/resume on OMAP2420/n810
Boots fine on osk5912 and n800
Acked-by: Kevin Hilman <khilman@ti.com>
Reviewed-by: Dave Martin <dave.martin@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
We want to have just CONFIG_ARCH_OMAP2, 3 and 4. The rest
are nowadays just subcategories of these.
Search and replace the following:
ARCH_OMAP2420 SOC_OMAP2420
ARCH_OMAP2430 SOC_OMAP2430
ARCH_OMAP3430 SOC_OMAP3430
No functional changes.
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Sourav Poddar <sourav.poddar@ti.com>
In preparation for adding OMAP4-specific PRCM accessor/mutator
functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific
files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been
moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was
OMAP2xxx/3xxx-specific.
This process also requires the #includes in each of these files to be
changed to reference the new file name. As part of doing so, add some
comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use
"sideways includes", to indicate that these users of the PRM/CM includes
should not be doing so.
Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this
patch.
Cc: Jarkko Nikula <jhnikula@gmail.com>
Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Acked-by: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Tested-by: Rajendra Nayak <rnayak@ti.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
The SRAM PA addresses are locally defined and used at
different places, i.e. SRAM management code and idle sleep code.
The macros are now defined at a centralized place, for
easier maintenance.
Tested on N900 and Beagleboard with full RET and OFF modes,
using cpuidle and suspend.
Tested-by: Nishanth Menon<nm@ti.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Kernel was failing to boot on omap1611 based OSK boards due to
mis-configured SRAM size. Existing code was using a hard-coded value
for 250k, which was then rounded down by PAGE_SIZE. Increasing this to
256k allows kernel to boot on omap1611 SoCs.
Problem reported by and initial fix suggested by Tim Bird.
Thanks to Tony Lindgren for helping diagnose the problem to being
specific to OMAP1611 and not affecting OMAP1610/OMAP1623.
Reported-by: Tim Bird <tim.bird@am.sony.com>
Make some functions static to get rid of the following sparse warnings:
arch/arm/mach-omap1/mcbsp.c:177:12: warning: symbol 'omap1_mcbsp_init' was not declared. Should it be static?
arch/arm/mach-omap1/mux.c:346:22: warning: symbol 'omap1_cfg_reg' was not declared. Should it be static?
arch/arm/plat-omap/dma.c:177:5: warning: symbol 'omap_dma_in_1510_mode' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:273:12: warning: symbol 'omap1_sram_init' was not declared. Should it be static?
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits)
omap: complete removal of machine_desc.io_pg_offst and .phys_io
omap: UART: fix wakeup registers for OMAP24xx UART2
omap: Fix spotty MMC voltages
ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h
serial: omap-serial: fix signess error
OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish
omap: dma: Fix buffering disable bit setting for omap24xx
omap: serial: Fix the boot-up crash/reboot without CONFIG_PM
OMAP3: PM: fix scratchpad memory accesses for off-mode
omap4: pandaboard: enable the ehci port on pandaboard
omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set
omap4: pandaboard: remove unused hsmmc definition
OMAP: McBSP: Remove null omap44xx ops comment
OMAP: McBSP: Swap CLKS source definition
OMAP: McBSP: Fix CLKR and FSR signal muxing
OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks
OMAP: control: move plat-omap/control.h to mach-omap2/control.h
OMAP: split plat-omap/common.c
OMAP: McBSP: implement functional clock switching via clock framework
OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c
Fixed up trivial conflicts in arch/arm/mach-omap2/
{board-zoom-peripherals.c,devices.c} as per Tony
Split plat-omap/common.c into three pieces:
1. the 32KiHz sync timer and clocksource code, which now lives in
plat-omap/counter_32k.c;
2. the OMAP2+ common code, which has been moved to mach-omap2/common.c;
3. and the remainder of the OMAP-wide common code, which includes the
deprecated ATAGs code and a deprecated video RAM reservation function.
The primary motivation for doing this is to move the OMAP2+-specific parts
into an OMAP2+-specific file, so that build breakage related to the
System Control Module code can be resolved.
Benoît Cousson <b-cousson@ti.com> suggested a new filename and found
some bugs in the counter_32k.c comments - thanks Benoît.
Cc: Benoît Cousson <b-cousson@ti.com>
This patch fixes sparse warnings due non declarations of static functions.
arch/arm/plat-omap/sram.c:130:13: warning: symbol 'omap_detect_sram' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:216:13: warning: symbol 'omap_map_sram' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:450:12: warning: symbol 'omap_sram_init' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:348:12: warning: symbol 'omap242x_sram_init' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:369:12: warning: symbol 'omap243x_sram_init' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:425:12: warning: symbol 'omap34xx_sram_init' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:441:12: warning: symbol 'omap44xx_sram_init' was not declared. Should it be static
arch/arm/plat-omap/mcbsp.c:36:6: warning: symbol 'omap_mcbsp_write' was not declared. Should it be static?
arch/arm/plat-omap/mcbsp.c:50:5: warning: symbol 'omap_mcbsp_read' was not declared. Should it be static?
arch/arm/plat-omap/mcbsp.c:65:6: warning: symbol 'omap_mcbsp_st_write' was not declared. Should it be static?
arch/arm/plat-omap/mcbsp.c:70:5: warning: symbol 'omap_mcbsp_st_read' was not declared. Should it be static?
arch/arm/plat-omap/mcbsp.c:1648:15: warning: symbol 'omap_st_add' was not declared. Should it be static?
arch/arm/plat-omap/fb.c:414:15: warning: symbol 'omapfb_reserve_sram' was not declared. Should it be static?
arch/arm/plat-omap/cpu-omap.c:43:5: warning: symbol 'omap_verify_speed' was not declared. Should it be static?
arch/arm/plat-omap/cpu-omap.c:61:14: warning: symbol 'omap_getspeed' was not declared. Should it be static?
Signed-off-by: Manjunath Kondaiah G <manjugk@ti.com>
Cc: Nishanth Menon <nm@ti.com>
Currently we map 1 MB section while setting up SRAM on OMAPs
Regardless of the actual memory. The physical OCM RAM available
on OMAP SOCs is in order of KBs. This patch maps only available
sram and cleans up some un-necessary cpu_is_xxx checks.
Mapping un-available or non-accessible(secure) memory on the newer ARM
processor is dangerous. Because ARM CPUs can now speculatively prefetch,
we should avoid mapping any no-existing or secure memory.
On OMAP4 there is no need to have SRAM_BOOTLOADER_SZ provision
Hence put this macro under CONFIG_ARCH_OMAP2PLUS check
Signed-off-by: Vikram Pandita <vikram.pandita@ti.com>
For OMAP24xx/34xx/44xx: omap_type() returns the correct type:
OMAP2_DEVICE_TYPE_TEST
OMAP2_DEVICE_TYPE_EMU
OMAP2_DEVICE_TYPE_SEC
OMAP2_DEVICE_TYPE_GP
OMAP2_DEVICE_TYPE_BAD
In current implementation there are two problems:
Problem 1:
For 34xx, the current if check will never return true.
Problem 2:
For 24xx the correct type check should be with omap_type() function
Verified by checking the TRM 24xx for CONTROL_STATUS register bits
We cannot use the omap34xx_sram_init(). It needs to be implemented
for omap4. Otherwise we get an error and the system won't boot:
Unhandled fault: imprecise external abort (0x1406) at 0xea963e94
Fix this by adding a dummy omap44xx_sram_init().
Replace ARCH_OMAP34XX with ARCH_OMAP3
Convert ARCH_OMAP24XX to ARCH_OMAP2
This patch fixes the public sram base address and available
size on OMAP4430.
