path: root/arch/arm/plat-omap
2012-10-28Merge tag 'fixes-for-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull arm-soc fixes from Arnd Bergmann: "Bug fixes for a number of ARM platforms, mostly OMAP, imx and at91. These come a little later than I had hoped but unfortunately we had a few of these patches cause regressions themselves and had to work out how to deal with those in the meantime." * tag 'fixes-for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits) Revert "ARM i.MX25: Fix PWM per clock lookups" ARM: versatile: fix versatile_defconfig ARM: mvebu: update defconfig with 3.7 changes ARM: at91: fix at91x40 build ARM: socfpga: Fix socfpga compilation with early_printk() enabled ARM: SPEAr: Remove unused empty files MAINTAINERS: Add arm-soc tree entry ARM: dts: mxs: add the "clock-names" for gpmi-nand ARM: ux500: Correct SDI5 address and add some format changes ARM: ux500: Specify AMBA Primecell IDs for Nomadik I2C in DT ARM: ux500: Fix build error relating to IRQCHIP_SKIP_SET_WAKE ARM: at91: drop duplicated config SOC_AT91SAM9 entry ARM: at91/i2c: change id to let i2c-at91 work ARM: at91/i2c: change id to let i2c-gpio work ARM: at91/dts: at91sam9g20ek_common: Fix typos in buttons labels. ARM: at91: fix external interrupt specification in board code ARM: at91: fix external interrupts in non-DT case ARM: at91: at91sam9g10: fix SOC type detection ARM: at91/tc: fix typo in the DT document ARM: AM33XX: Fix configuration of dmtimer parent clock by dmtimer driverDate:Wed, 17 Oct 2012 13:55:55 -0500 ...
2012-10-24Revert "serial: omap: fix software flow control"Felipe Balbi
This reverts commit 957ee7270d632245b43f6feb0e70d9a5e9ea6cf6 (serial: omap: fix software flow control). As Russell has pointed out, that commit isn't fixing Software Flow Control at all, and it actually makes it even more broken. It was agreed to revert this commit and use Russell's latest UART patches instead. Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Felipe Balbi <balbi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22ARM: OMAP2+: Fix location of select PINCTRLTony Lindgren
Commit 8f31cefe (ARM: OMAP2+: select PINCTRL in Kconfig) added select PINCTRL, but accdentally added it to a wrong location. We want to select if for ARCH_OMAP2PLUS, not for ARCH_OMAP2PLUS_TYPICAL. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-16ARM: OMAP: resolve sparse warning concerning debug_card_init()Paul Walmsley
Commit 801475ccb2b2c1928b22aec4b9e5285d9e347602 ("ARM: OMAP: move debug_card_init() function") results in the following new sparse warning: arch/arm/plat-omap/debug-devices.c:71:12: warning: symbol 'debug_card_init' was not declared. Should it be static? Fix by implementing Tony's suggestion to add a "sideways include" to the new location of the debug-devices.h file in arch/arm/mach-omap2/. Signed-off-by: Paul Walmsley <paul@pwsan.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-13ARM: config: sort select statements alphanumericallyRussell King
As suggested by Andrew Morton: This is a pet peeve of mine. Any time there's a long list of items (header file inclusions, kconfig entries, array initalisers, etc) and someone wants to add a new item, they *always* go and stick it at the end of the list. Guys, don't do this. Either put the new item into a randomly-chosen position or, probably better, alphanumerically sort the list. lets sort all our select statements alphanumerically. This commit was created by the following perl: while (<>) { while (/\\\s*$/) { $_ .= <>; } undef %selects if /^\s*config\s+/; if (/^\s+select\s+(\w+).*/) { if (defined($selects{$1})) { if ($selects{$1} eq $_) { print STDERR "Warning: removing duplicated $1 entry\n"; } else { print STDERR "Error: $1 differently selected\n". "\tOld: $selects{$1}\n". "\tNew: $_\n"; exit 1; } } $selects{$1} = $_; next; } if (%selects and (/^\s*$/ or /^\s+help/ or /^\s+---help---/ or /^endif/ or /^endchoice/)) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } undef %selects; } print; } if (%selects) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } } It found two duplicates: Warning: removing duplicated S5P_SETUP_MIPIPHY entry Warning: removing duplicated HARDIRQS_SW_RESEND entry and they are identical duplicates, hence the shrinkage in the diffstat of two lines. We have four testers reporting success of this change (Tony, Stephen, Linus and Sekhar.) Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-10-11Merge branch 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linuxLinus Torvalds
Pull i2c-embedded changes from Wolfram Sang: "The changes for i2c-embedded include: - massive rework of the omap driver - massive rework of the at91 driver. In fact, the old driver gets removed; I am okay with this approach since the old driver was depending on BROKEN and its limitations made it practically unusable, so people used bitbanging instead. But even if there are users, there is no platform_data or module parameter which would need to be converted. It is just another driver doing I2C transfers, just way better. Modifications of arch/arm/at91 related files have proper acks from the maintainer. - new driver for R-Car I2C - devicetree and generic_clock conversions and fixes - usual driver fixes and changes. The rework patches have come a long way and lots of people have been involved in creating/testing them. Most patches have been in linux-next at least since 3.6-rc5. A few have been added in the last week, I have to admit. An unexpected (but welcome :)) peak in private life is the cause for that. The "late" patches shouldn't cause any merge conflicts and I will have a special eye on them during the stabilization phase. This is an exception and I want to have the patches in place properly in time again for the next kernels." * 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (44 commits) MXS: Implement DMA support into mxs-i2c i2c: add Renesas R-Car I2C driver i2c: s3c2410: use clk_prepare_enable and clk_disable_unprepare ARM: OMAP: convert I2C driver to PM QoS for MPU latency constraints i2c: nomadik: Add Device Tree support to the Nomadik I2C driver i2c: algo: pca: Fix chip reset function for PCA9665 i2c: mpc: Wait for STOP to hit the bus i2c: davinci: preparation for switch to common clock framework omap-i2c: fix incorrect log message when using a device tree i2c: omap: sanitize exit path i2c: omap: switch over to autosuspend API i2c: omap: remove unnecessary pm_runtime_suspended check i2c: omap: switch to threaded IRQ support i2c: omap: remove redundant status read i2c: omap: get rid of the "complete" label i2c: omap: resize fifos before each message i2c: omap: simplify IRQ exit path i2c: omap: always return IRQ_HANDLED i2c: omap: simplify errata check i2c: omap: bus: add a receiver flag ...
2012-10-09Merge tag 'omap-for-v3.7-rc1/fixes-pm-signed' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes From Kevin Hilman <khilman@deeprootsystems.com> via Tony Lindgren: OMAP PM related fixes for v3.7-rc * tag 'omap-for-v3.7-rc1/fixes-pm-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP: SmartReflex: fix error path in init function ARM: OMAP: SmartReflex: select CONFIG_POWER_SUPPLY in Kconfig ARM: OMAP2+: PM: fix return value check in omap2_set_init_voltage() ARM: OMAP2+: SmartReflex: fix return value check in sr_dev_init() ARM: OMAP: omap_device: fix return value check in omap_device_build_ss() ARM: OMAP: fix return value check in beagle_opp_init()
2012-10-08arch/arm/plat-omap/omap-pm-noop.c: Remove unecessary semicolonPeter Senna Tschudin
Found by http://coccinelle.lip6.fr/ Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-08Merge tag 'for_3.7-fixes-pm' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-v3.7-rc1/fixes-pm OMAP PM related fixes for v3.7-rc
2012-10-08ARM: OMAP: OMAP_DEBUG_LEDS needs to select LEDS_CLASSAxel Lin
This fixes below build error when CONFIG_LEDS_CLASS is not set. LD init/built-in.o arch/arm/plat-omap/built-in.o: In function `fpga_probe': arch/arm/plat-omap/debug-leds.c:113: undefined reference to `led_classdev_register' make: *** [vmlinux] Error 1 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-08ARM: OMAP: counter: add locking to read_persistent_clockColin Cross
read_persistent_clock uses a global variable, use a spinlock to ensure non-atomic updates to the variable don't overlap and cause time to move backwards. Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: R Sricharan <r.sricharan@ti.com> Cc: stable@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-08Merge tag 'v3.6-rc7' into i2c-embedded/for-nextWolfram Sang
Linux 3.6-rc7 Needed to get updates from i2c-embedded/for-current into i2c-embedded/for-next
2012-10-07Merge tag 'soc-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull late ARM soc platform updates from Olof Johansson: "This branch contains updates to OMAP and Marvell platforms (kirkwood, dove, mvebu) that came in after we had done the big multiplatform merges, so they were kept separate from the rest, and not separated into the traditional topics of cleanup/driver/platform features. For OMAP, the updates are: - Runtime PM conversions for the GPMC and RNG IP blocks - Preparation patches for the OMAP common clock framework conversion - clkdev alias additions required by other drivers - Performance Monitoring Unit (PMU) support for OMAP2, 3, and non-4430 OMAP4 - OMAP hwmod code and data improvements - Preparation patches for the IOMMU runtime PM conversion - Preparation patches for OMAP4 full-chip retention support For Kirkwood/Dove/mvebu: - New driver for "address decoder controller" for mvebu, which is a piece of hardware that configures addressable devices and peripherals. First user is the boot rom aperture on armada XP since it is needed for SMP support. - New device tree bindings for peripherals such as gpio-fan, iconnect nand, mv_cesa and the above address decoder controller. - Some defconfig updates, mostly to enable new DT boards and a few drivers. - New drivers using the pincontrol subsystem for dove, kirkwood and mvebu - New clean gpio driver for mvebu" * tag 'soc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (98 commits) ARM: mvebu: fix build breaks from multi-platform conversion ARM: OMAP4460/4470: PMU: Enable PMU for OMAP4460/70 ARM: OMAP2+: PMU: Add runtime PM support ARM: OMAP4430: PMU: prepare to create PMU device via HWMOD ARM: OMAP2+: PMU: Convert OMAP2/3 devices to use HWMOD ARM: OMAP3: hwmod data: Add debugss HWMOD data ARM: OMAP2+: clockdomain/hwmod: add workaround for EMU clockdomain idle problems ARM: OMAP: Add a timer attribute for timers that can interrupt the DSP hwrng: OMAP: remove SoC restrictions from driver registration ARM: OMAP: split OMAP1, OMAP2+ RNG device registration hwrng: OMAP: convert to use runtime PM hwrng: OMAP: store per-device data in per-device variables, not file statics ARM: OMAP2xxx: hwmod/CM: add RNG integration data ARM: OMAP2+: gpmc: minimal driver support ARM: OMAP2+: gpmc: Adapt to HWMOD ARM: OMAP2/3: hwmod data: add gpmc ARM: OMAP4: hwmod data: add mmu hwmod for ipu and dsp ARM: OMAP3: hwmod data: add mmu data for iva and isp ARM: OMAP: iommu: fix including iommu.h without IOMMU_API selected ARM: OMAP4: hwmod data: add missing HWMOD_NO_IDLEST flags to some PRCM IP blocks ...
2012-10-06ARM: OMAP: convert I2C driver to PM QoS for MPU latency constraintsJean Pihet
Convert the driver from the outdated omap_pm_set_max_mpu_wakeup_lat API to the new PM QoS API. Since the constraint is on the MPU subsystem, use the PM_QOS_CPU_DMA_LATENCY class of PM QoS. The resulting MPU constraints are used by cpuidle to decide the next power state of the MPU subsystem. The I2C device latency timing is derived from the FIFO size and the clock speed and so is applicable to all OMAP SoCs. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Shubhrajyoti D <shubhrajyoti@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-10-04Merge branch 'late/kirkwood' into late/socOlof Johansson
Merge in the late Kirkwood branch with the OMAP late branch for upstream submission. Final contents described in shared tag. Fixup remove/change conflicts in arch/arm/mach-omap2/devices.c and drivers/spi/spi-omap2-mcspi.c. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-10-05Merge tag 'mfd-3.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: "MFD bits for the 3.7 merge window. As usual we have a few new drivers: - TI LP8788 - TI OMAP USB TLL - Maxim MAX8907 - SMSC ECE1099 - Dialog Semiconductor DA9055 - A simpler syscon driver that allow us to get rid of the anatop one. Drivers are also gradually getting Device Tree and IRQ domain support. The following drivers got DT support: - palmas, 88pm860x, tc3589x and twl4030-audio And those ones now use the IRQ domain APIs: - 88pm860x, tc3589x, db8500_prcmu Also some other interesting changes: - Intel's ICH LPC now supports Lynx Point - TI's twl4030-audio added a GPO child - tps6527 enabled its backlight subdevice - The twl6030 pwm driver moved to the new PWM subsystem And finally a bunch of cleanup and casual fixes for mc13xxx, 88pm860x, palmas, ab8500, wm8994, wm5110, max8907 and the tps65xxx family." Fix up various annoying conflicts: the DT and IRQ domain support came in twice and was already in 3.6. And then it was apparently rebased. Guys, DON'T REBASE! * tag 'mfd-3.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (89 commits) ARM: dts: Enable 88pm860x pmic mfd: 88pm860x: Move gpadc init into touch mfd: 88pm860x: Device tree support mfd: 88pm860x: Use irqdomain mfd: smsc: Add support for smsc gpio io/keypad driver backlight: tps65217_bl: Add missing platform_set_drvdata in tps65217_bl_probe mfd: DA9055 core driver mfd: tps65910: Add alarm interrupt of TPS65910 RTC to mfd device list mfd: wm5110: Add register patches for revision B mfd: wm5110: Disable control interface error report for WM5110 rev B mfd: max8907: Remove regulator-compatible from DT docs backlight: Add TPS65217 WLED driver mfd: Add backlight as subdevice to the tps65217 mfd: Provide the PRCMU with its own IRQ domain mfd: Fix max8907 sparse warning mfd: Add lp8788 mfd driver mfd: dbx500: Provide a more accurate smp_twd clock mfd: rc5t583: Fix warning messages regulator: palmas: Add DT support mfd: palmas: Change regulator defns to better suite DT ...
2012-10-02ARM: OMAP: SmartReflex: select CONFIG_POWER_SUPPLY in KconfigJean Pihet
Select POWER_SUPPLY from POWER_AVS_OMAP entry in Kconfig. This avoids the following build problems using a randconfig that has CONFIG_POWER_SUPPLY not set: LD init/built-in.o arch/arm/mach-omap2/built-in.o: In function `sr_class3_configure': arch/arm/mach-omap2/smartreflex-class3.c:44: undefined reference to `sr_configure_errgen' arch/arm/mach-omap2/built-in.o: In function `sr_class3_disable': arch/arm/mach-omap2/smartreflex-class3.c:33: undefined reference to `sr_disable_errgen' arch/arm/mach-omap2/smartreflex-class3.c:35: undefined reference to `sr_disable' arch/arm/mach-omap2/built-in.o: In function `sr_class3_enable': arch/arm/mach-omap2/smartreflex-class3.c:28: undefined reference to `sr_enable' arch/arm/mach-omap2/built-in.o: In function `sr_class3_init': arch/arm/mach-omap2/smartreflex-class3.c:59: undefined reference to `sr_register_class' make: *** [vmlinux] Error 1 Signed-off-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-10-02ARM: OMAP: omap_device: fix return value check in omap_device_build_ss()Wei Yongjun
In case of error, the function omap_device_alloc() returns ERR_PTR() and never returns NULL pointer. The NULL test in the return value check should be replaced with IS_ERR(). dpatch engine is used to auto generated this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-10-02Merge branch 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "This is workqueue updates for v3.7-rc1. A lot of activities this round including considerable API and behavior cleanups. * delayed_work combines a timer and a work item. The handling of the timer part has always been a bit clunky leading to confusing cancelation API with weird corner-case behaviors. delayed_work is updated to use new IRQ safe timer and cancelation now works as expected. * Another deficiency of delayed_work was lack of the counterpart of mod_timer() which led to cancel+queue combinations or open-coded timer+work usages. mod_delayed_work[_on]() are added. These two delayed_work changes make delayed_work provide interface and behave like timer which is executed with process context. * A work item could be executed concurrently on multiple CPUs, which is rather unintuitive and made flush_work() behavior confusing and half-broken under certain circumstances. This problem doesn't exist for non-reentrant workqueues. While non-reentrancy check isn't free, the overhead is incurred only when a work item bounces across different CPUs and even in simulated pathological scenario the overhead isn't too high. All workqueues are made non-reentrant. This removes the distinction between flush_[delayed_]work() and flush_[delayed_]_work_sync(). The former is now as strong as the latter and the specified work item is guaranteed to have finished execution of any previous queueing on return. * In addition to the various bug fixes, Lai redid and simplified CPU hotplug handling significantly. * Joonsoo introduced system_highpri_wq and used it during CPU hotplug. There are two merge commits - one to pull in IRQ safe timer from tip/timers/core and the other to pull in CPU hotplug fixes from wq/for-3.6-fixes as Lai's hotplug restructuring depended on them." Fixed a number of trivial conflicts, but the more interesting conflicts were silent ones where the deprecated interfaces had been used by new code in the merge window, and thus didn't cause any real data conflicts. Tejun pointed out a few of them, I fixed a couple more. * 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits) workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending() workqueue: use cwq_set_max_active() helper for workqueue_set_max_active() workqueue: introduce cwq_set_max_active() helper for thaw_workqueues() workqueue: remove @delayed from cwq_dec_nr_in_flight() workqueue: fix possible stall on try_to_grab_pending() of a delayed work item workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback() workqueue: use __cpuinit instead of __devinit for cpu callbacks workqueue: rename manager_mutex to assoc_mutex workqueue: WORKER_REBIND is no longer necessary for idle rebinding workqueue: WORKER_REBIND is no longer necessary for busy rebinding workqueue: reimplement idle worker rebinding workqueue: deprecate __cancel_delayed_work() workqueue: reimplement cancel_delayed_work() using try_to_grab_pending() workqueue: use mod_delayed_work() instead of __cancel + queue workqueue: use irqsafe timer for delayed_work workqueue: clean up delayed_work initializers and add missing one workqueue: make deferrable delayed_work initializer names consistent workqueue: cosmetic whitespace updates for macro definitions workqueue: deprecate system_nrt[_freezable]_wq workqueue: deprecate flush[_delayed]_work_sync() ...
2012-10-01Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc driver specific changes from Olof Johansson: - A long-coming conversion of various platforms to a common LED infrastructure - AT91 is moved over to use the newer MCI driver for MMC - Pincontrol conversions for samsung platforms - DT bindings for gscaler on samsung - i2c driver fixes for tegra, acked by i2c maintainer Fix up conflicts as per Olof. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) drivers: bus: omap_l3: use resources instead of hardcoded irqs pinctrl: exynos: Fix wakeup IRQ domain registration check pinctrl: samsung: Uninline samsung_pinctrl_get_soc_data pinctrl: exynos: Correct the detection of wakeup-eint node pinctrl: exynos: Mark exynos_irq_demux_eint as inline pinctrl: exynos: Handle only unmasked wakeup interrupts pinctrl: exynos: Fix typos in gpio/wkup _irq_mask pinctrl: exynos: Set pin function to EINT in irq_set_type of GPIO EINTa drivers: bus: Move the OMAP interconnect driver to drivers/bus/ i2c: tegra: dynamically control fast clk i2c: tegra: I2_M_NOSTART functionality not supported in Tegra20 ARM: tegra: clock: remove unused clock entry for i2c ARM: tegra: clock: add connection name in i2c clock entry i2c: tegra: pass proper name for getting clock ARM: tegra: clock: add i2c fast clock entry in clock table ARM: EXYNOS: Adds G-Scaler device from Device Tree ARM: EXYNOS: Add clock support for G-Scaler ARM: EXYNOS: Enable pinctrl driver support for EXYNOS4 device tree enabled platform ARM: dts: Add pinctrl node entries for SAMSUNG EXYNOS4210 SoC ARM: EXYNOS: skip wakeup interrupt setup if pinctrl driver is used ...
2012-10-01Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc device tree updates from Olof Johansson: "Device tree conversion and enablement branch. Mostly a bunch of new bindings and setup for various platforms, but the Via/Winchip VT8500 platform is also converted over from being 100% legacy to now use device tree for probing. More of that will come for 3.8." Trivial conflicts due to removal of vt8500 files, and one documentation file that was added with slightly different contents both here and in the USb tree. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (212 commits) arm: vt8500: Fixup for missing gpio.h ARM: LPC32xx: LED fix in PHY3250 DTS file ARM: dt: mmp-dma: add binding file arm: vt8500: Update arch-vt8500 to devicetree support. arm: vt8500: gpio: Devicetree support for arch-vt8500 arm: vt8500: doc: Add device tree bindings for arch-vt8500 devices arm: vt8500: clk: Add Common Clock Framework support video: vt8500: Add devicetree support for vt8500-fb and wm8505-fb serial: vt8500: Add devicetree support for vt8500-serial rtc: vt8500: Add devicetree support for vt8500-rtc arm: vt8500: Add device tree files for VIA/Wondermedia SoC's ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support ARM: tegra: Add Avionic Design Medcom-Wide support ARM: tegra: Add Avionic Design Plutux support ARM: tegra: Add Avionic Design Tamonten support ARM: tegra: dts: Add pwm label ARM: ux500: Fix SSP register address format ARM: ux500: Apply tc3589x's GPIO/IRQ properties to HREF's DT ARM: ux500: Remove redundant #gpio-cell properties from Snowball DT ARM: ux500: Add all encompassing sound node to the HREF Device Tree ...
2012-10-01Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc-specific updates from Olof Johansson: "Most notable here is probably the addition of basic support for the BCM2835, an SoC used in some of the Roku 2 players as well as the much-hyped Raspberry Pi, cleaned up and contributed by Stephen Warren. It's still early days on mainline support, with just the basics working. But it has to start somewhere! Beyond that there's some conversions of clock infrastructure on tegra to common clock, misc updates for several other platforms, and OMAP now has its own bus (under drivers/bus) to manage its devices through. This branch adds two new directories outside of arch/arm: drivers/irqchip for new irq controllers, and drivers/bus for the above OMAP bus. It's expected that some of the other platforms will migrate parts of their platforms to those directories over time as well." Fix up trivial conflicts with the clk infrastructure changes. * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (62 commits) ARM: shmobile: add new __iomem annotation for new code ARM: LPC32xx: Support GPI 28 ARM: LPC32xx: Platform update for devicetree completion of spi-pl022 ARM: LPC32xx: Board cleanup irqchip: fill in empty Kconfig ARM: SAMSUNG: Add check for NULL in clock interface ARM: EXYNOS: Put PCM, Slimbus, Spdif clocks to off state ARM: EXYNOS: Add bus clock for FIMD ARM: SAMSUNG: Fix HDMI related warnings ARM: S3C24XX: Add .get_rate callback for "camif-upll" clock ARM: EXYNOS: Fix incorrect help text ARM: EXYNOS: Turn off clocks for NAND, OneNAND and TSI controllers ARM: OMAP: AM33xx hwmod: fixup SPI after platform_data move MAINTAINERS: add an entry for the BCM2835 ARM sub-architecture ARM: bcm2835: instantiate console UART ARM: bcm2835: add stub clock driver ARM: bcm2835: add system timer ARM: bcm2835: add interrupt controller driver ARM: add infra-structure for BCM2835 and Raspberry Pi ARM: tegra20: add CPU hotplug support ...
2012-09-29Merge tag 'omap-devel-board-late-v3-for-v3.7' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup From Tony Lindgren: These board and platform related patches have been posted quite a while ago but have somehow fallen though the cracks as most of the focus has been making things to work with device tree. As the first patch depends on sparse IRQ related removal of irqs.h and related header moves, these are based on omap-cleanup-local-headers-for-v3.7 tag. * tag 'omap-devel-board-late-v3-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6 ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus
2012-09-24ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6AnilKumar Ch
Extends the maximum number of UART ports to 6 from 4 because AM335X device have six UART ports. Signed-off-by: AnilKumar Ch <anilkumar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-23ARM: OMAP: Add a timer attribute for timers that can interrupt the DSPJon Hunter
Some instances of the DMTIMER peripheral on OMAP devices have the ability to interrupt the on-chip DSP in addition to the ARM CPU. Add a DMTIMER attribute to indicate which timers can interrupt the DSP. By using the omap_dm_timer_request_by_cap() API, driver will now be able to allocate a DMTIMER that can interrupt the DSP based upon this attribute and not require the driver to know which instance has this capability. DMTIMERs that have the ability to interrupt the DSP on OMAP devices are as follows ... - OMAP1 (OMAP5912/16xx/17xx) devices - All 8 DMTIMERs - OMAP2/3/4 devices - DMTIMERs 5-8 Please note that for OMAP3+, timer8 has the ability to interrupt the DSP and generate a PWM output. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-23ARM: OMAP3: hwmod data: add mmu data for iva and ispPaul Walmsley
Add mmu hwmod data for iva and isp. Due to compatibility an ifdef CONFIG_OMAP_IOMMU_IVA2 needs to be propagated (previously on iommu resource info) to hwmod data in OMAP3, so users of iommu and tidspbridge can avoid issues of two modules managing mmu data/irqs/resets; this until tidspbridge can be migrated to iommu framework. Cc: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Omar Ramirez Luna <omar.luna@linaro.org> [paul@pwsan.com: fixed some kerneldoc and whitespace; ISP MMUs not present on AM35xx so restricted these hwmods to 34xx/36xx] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-23ARM: OMAP: iommu: fix including iommu.h without IOMMU_API selectedOmar Ramirez Luna
If included without IOMMU_API being selected it will break compilation: arch/arm/plat-omap/include/plat/iommu.h: In function 'dev_to_omap_iommu': arch/arm/plat-omap/include/plat/iommu.h:148: error: 'struct dev_archdata' has no member named 'iommu' This will be seen when hwmod includes iommu.h to get the structure for attributes. Also needed for tidspbridge incremental migration to use iommu code. Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Omar Ramirez Luna <omar.luna@linaro.org> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-23ARM: OMAP4: hwmod: flag hwmods/modules not supporting module level context ↵Tero Kristo
status On OMAP4 most modules/hwmods support module level context status. On OMAP3 and earlier, we relied on the power domain level context status. Identify all modules that don't support 'context_offs' by adding a flag bit, HWMOD_OMAP4_NO_CONTEXT_LOSS_BIT. Rest have a valid 'context_offs' populated in .prcm structure already. Signed-off-by: Tero Kristo <t-kristo@ti.com> [paul@pwsan.com: add flag bit rather than overloading .context_offs; update changelog message] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-23ARM: OMAP4: hwmod data: add support for lostcontext_maskTero Kristo
Currently hwmod only provides the offset for the context lose register, and if we attempt to share the same register between two or more hwmods, the resulting context loss counts get wrong. Thus, we need a way to specify which bits are used for the context loss information for each. This is accomplished by adding a new field to the omap4 prcm struct, 'lostcontext_mask', which specifies a bit-mask to use for filtering the register. Mark the affected hwmods appropriately. 'l4_abe' hwmod uses the LOSTMEM_AESSMEM bit of RM_ABE_AESS_CONTEXT register, as l4_abe doesn't have its own dedicated register for this purpose. This register is shared with 'aess' hwmod, thus both hwmods must also specify which bits of the register are used for them. This patch only adds the hwmod data, but a future patch should add code support such that only the specified bits are read and cleared by the context lose counter update code. If a hwmod doesn't specify 'lostcontext_mask' (default behavior), the whole contents of the context register should be used without any filtering. Signed-off-by: Tero Kristo <t-kristo@ti.com> [paul@pwsan.com: updated to apply after conversion to use flag bit for missing module context-loss register; combined data and code patches; dropped code change due to serial driver breakage] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-23ARM: OMAP2+: omap_device: expose hwmod assert/deassert to omap devicesOmar Ramirez Luna
This API is meant to be an interface to hwmod assert/deassert function, omap devices can call them through their platform data to control their reset lines, they are expected to know the name of the reset line they are trying to control. Signed-off-by: Omar Ramirez Luna <omar.luna@linaro.org> [paul@pwsan.com: tweaked some documentation; fixed CodingStyle issue] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-23ARM: OMAP: hwmod code: remove unused hwmod function prototypesIgor Grinberg
Several hwmod function prototypes appear to not have an implementation because the corresponding functions were removed or renamed. Those prototypes are unneeded anymore - remove them. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> [paul@pwsan.com: tweaked subject] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-23Merge branch 'clock_devel_3.7' into hwmod_prcm_clock_a_3.7Paul Walmsley
Conflicts: arch/arm/mach-omap2/clkt34xx_dpll3m2.c arch/arm/mach-omap2/clkt_clksel.c arch/arm/mach-omap2/clock.c
2012-09-23Merge tag 'omap-devel-am33xx-for-v3.7' into test_v3.6-rc6_ocb3.7_cff3.7_odaf3.7Paul Walmsley
From Paul Walmsley <paul@pwsan.com>: AM33xx hwmod data and miscellaneous clock and hwmod fixes. AM33xx should now boot on mainline after this is applied, according to Vaibhav.
2012-09-23Merge tag 'cleanup-fixes-for-v3.7' into test_v3.6-rc6_ocb3.7_cff3.7_odaf3.7Paul Walmsley
These fixes are needed to fix non-omap build breakage for twl-core driver and to fix omap1_defconfig compile when led driver changes and omap sparse IRQ changes are merged together. Also fix warnings for omaps not using pinctrl framework yet.
2012-09-23Merge tag 'omap-cleanup-b-for-3.7' into test_v3.6-rc6_ocb3.7_cff3.7_odaf3.7Paul Walmsley
smatch and string-wrapping cleanups for the OMAP subarch code. These changes fix some of the more meaningful warnings that smatch returns for the OMAP subarch code, and unwraps strings that are wrapped at the 80-column boundary, to conform with the current practice. Basic build, boot, and PM logs are available here: http://www.pwsan.com/omap/testlogs/warnings_a_cleanup_3.7/20120912025927/
2012-09-22Merge branch 'for-arm-soc-next' of ↵Olof Johansson
git://git.linaro.org/people/ljones/linux-3.0-ux500 into next/dt * 'for-arm-soc-next' of git://git.linaro.org/people/ljones/linux-3.0-ux500: ARM: ux500: Fix SSP register address format ARM: ux500: Apply tc3589x's GPIO/IRQ properties to HREF's DT ARM: ux500: Remove redundant #gpio-cell properties from Snowball DT ARM: ux500: Add all encompassing sound node to the HREF Device Tree ARM: ux500: Add nodes for the MSP into the HREF Device Tree ARM: ux500: Add all known I2C sub-device nodes to the HREF DT ARM: ux500: Stop registering I2C sub-devices for HREF when DT is enabled ARM: ux500: Stop registering Audio devices for HREF when DT is enabled ARM: ux500: Add all encompassing sound node to the Snowball Device Tree ARM: ux500: Add nodes for the MSP into Device Tree ARM: ux500: Rename MSP board file to something more meaningful ARM: ux500: Remove platform registration of MSP devices ARM: ux500: Stop registering the MOP500 Audio driver from platform code ARM: ux500: Pass MSP DMA platform data though AUXDATA ARM: ux500: Fork MSP platform registration for step-by-step DT enablement ARM: ux500: Add AB8500 CODEC node to DB8500 Device Tree ARM: ux500: Clean-up MSP platform code ARM: ux500: Pass SDI DMA information though AUX_DATA to MMCI ARM: ux500: Add UART support to the HREF Device Tree ARM: ux500: Add skeleton Device Tree for the HREF reference board ... + sync to v3.6-rc6
2012-09-22ARM: OMAP2+: clock: Remove all direct dereferencing of struct clkRajendra Nayak
While we move to Common Clk Framework (CCF), direct deferencing of struct clk wouldn't be possible anymore. Hence get rid of all such instances in the current clock code and use macros/helpers similar to the ones that are provided by CCF. While here also concatenate some strings split across multiple lines which seem to be needed anyway. Signed-off-by: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: simplified some compound expressions; reformatted some messages] Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Mike Turquette <mturquette@linaro.org>
2012-09-22ARM: OMAP2+: hwmod: get rid of all omap_clk_get_by_name usageRajendra Nayak
Moving to Common clk framework for OMAP would mean we no longer use internal lookup mechanism like omap_clk_get_by_name(). get rid of all its usage mostly from hwmod and omap_device code. Moving to clk_get() also means the respective platforms need the clkdev tables updated with an entry for all clocks used by hwmod to have clock name same as the alias. Based on original changes from Mike Turquette. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> [paul@pwsan.com: removed IS_ERR_OR_NULL() conversion (rmk comment); restricted omap_96m_alwon_fck_3630 to OMAP36xx; added missing AM35xx clock aliases for emac_fck, emac_ick, vpfe_ick, vpfe_fck; added aliases rng_ick and several emulation clocks] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-22Merge tag 'omap-devel-am33xx-for-v3.7' into test_v3.6-rc6_cff3.7_odaf3.7Paul Walmsley
2012-09-22Merge tag 'cleanup-fixes-for-v3.7' into test_v3.6-rc6_cff3.7_odaf3.7Paul Walmsley
2012-09-21Merge branch 'next/devel-samsung' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc Misc SoC-related fixes/cleanups for Samsung platforms * 'next/devel-samsung' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: SAMSUNG: Add check for NULL in clock interface ARM: EXYNOS: Put PCM, Slimbus, Spdif clocks to off state ARM: EXYNOS: Add bus clock for FIMD ARM: SAMSUNG: Fix HDMI related warnings ARM: S3C24XX: Add .get_rate callback for "camif-upll" clock ARM: EXYNOS: Fix incorrect help text ARM: EXYNOS: Turn off clocks for NAND, OneNAND and TSI controllers + sync to 3.6-rc6
2012-09-21mfd: omap-usb-host: Invoke the TLL driver from USB HS core driverKeshava Munegowda
The usbhs driver invokes the enable/disable APIs of the usb tll driver in the runtime resume/suspend callbacks of the runtime get sync and put sync of the usbhs driver. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Reviewed-by: Partha Basak <parthab@india.ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-21mfd: omap-usb-tll: HOST TLL platform driverKeshava Munegowda
The platform driver for the TLL component of the OMAP USB host controller is implemented. Depending on the TLL hardware revision , the TLL channels are configured. The USB HS core driver uses this driver through exported APIs from the TLL platform driver. usb_tll_enable and usb_tll_disble are the exported APIs of the USB TLL platform driver. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Reviewed-by: Partha Basak <parthab@india.ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-20Merge branch 'next/soc' into next/multiplatformOlof Johansson
* next/soc: (50 commits) ARM: OMAP: AM33xx hwmod: fixup SPI after platform_data move MAINTAINERS: add an entry for the BCM2835 ARM sub-architecture ARM: bcm2835: instantiate console UART ARM: bcm2835: add stub clock driver ARM: bcm2835: add system timer ARM: bcm2835: add interrupt controller driver ARM: add infra-structure for BCM2835 and Raspberry Pi ARM: tegra20: add CPU hotplug support ARM: tegra30: add CPU hotplug support ARM: tegra: clean up the common assembly macros into sleep.h ARM: tegra: replace the CPU CAR access code by tegra_cpu_car_ops ARM: tegra: introduce tegra_cpu_car_ops structures ARM: Tegra: Add smp_twd clock for Tegra20 ARM: AM33XX: clock: Add dcan clock aliases for device-tree ARM: OMAP2+: dpll: Add missing soc_is_am33xx() check for common functions ARM: OMAP: omap_device: idle devices with no driver bound ARM: OMAP: omap_device: don't attempt late suspend if no driver bound ARM: OMAP: omap_device: keep track of driver bound status ARM: OMAP3+: hwmod: Add AM33XX HWMOD data ARM: OMAP2+: hwmod: Hook-up am33xx support in omap_hwmod framework ... Change/remove conflict in arch/arm/mach-ux500/clock.c resolved. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-20Merge branch 'next/dt' into next/multiplatformOlof Johansson
* next/dt: (182 commits) ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support ARM: tegra: Add Avionic Design Medcom-Wide support ARM: tegra: Add Avionic Design Plutux support ARM: tegra: Add Avionic Design Tamonten support ARM: tegra: dts: Add pwm label ARM: dt: tegra: whistler: configure power off ARM: mxs: m28evk: Disable OCOTP OUI loading ARM: imx6q: use pll2_pfd2_396m as the enfc_sel's parent ARM: dts: imx6q-sabrelite: add usbotg pinctrl support ARM: dts: imx23-olinuxino: Add USB host support ARM: dts: imx6q-sabrelite: add usbmisc device ARM: dts: mx23: Add USB resources ARM: dts: mxs: Add ethernetX to macX aliases ARM: msm: Remove non-DT targets from 8960 ARM: msm: Add DT support for 8960 ARM: msm: Move io mapping prototypes to common.h ARM: msm: Rename board-msm8x60 to signify its DT only status ARM: msm: Make 8660 a DT only target ARM: msm: Move 8660 to DT timer ARM: msm: Add DT support to msm_timer ...
2012-09-20Merge tag 'omap-cleanup-local-headers-for-v3.7' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup From Tony Lindgren: This branch contains mostly scripted changes to make omap header files local where possible to get us closer to supporting the ARM single zImage. After these changes mach includes are pretty much out of the way for omap2+, but still lots of manual work remains to sort through the remaining plat includes. * tag 'omap-cleanup-local-headers-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (26 commits) ARM: OMAP2+: Make omap4-keypad.h local ARM: OMAP2+: Make l4_3xxx.h local ARM: OMAP2+: Make l4_2xxx.h local ARM: OMAP2+: Make l3_3xxx.h local ARM: OMAP2+: Make l3_2xxx.h local ARM: OMAP1: Move irda.h from plat to mach ARM: OMAP2+: Make hdq1w.h local ARM: OMAP2+: Make gpmc-smsc911x.h local ARM: OMAP2+: Make gpmc-smc91x.h local ARM: OMAP1: Move flash.h from plat to mach ARM: OMAP2+: Make debug-devices.h local ARM: OMAP1: Move board-voiceblue.h from plat to mach ARM: OMAP1: Move board-sx1.h from plat to mach ARM: OMAP2+: Make omap-wakeupgen.h local ARM: OMAP2+: Make omap-secure.h local ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local ARM: OMAP2+: Make ctrl_module_pad_wkup_44xx.h local ARM: OMAP2+: Make ctrl_module_pad_core_44xx.h local ARM: OMAP2+: Make ctrl_module_core_44xx.h local ARM: OMAP2+: Make board-rx51.h local ...
2012-09-20Merge tag 'tegra-for-3.7-dmaengine' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/cleanup ARM: tegra: switch to dmaengine The Tegra code-base has contained both a legacy DMA and a dmaengine driver since v3.6-rcX. This series flips Tegra's defconfig to enable dmaengine rather than the legacy driver, and removes the legacy driver and all client code. * tag 'tegra-for-3.7-dmaengine' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra: ASoC: tegra: remove support of legacy DMA driver based access spi: tegra: remove support of legacy DMA driver based access ARM: tegra: apbio: remove support of legacy DMA driver based access ARM: tegra: dma: remove legacy APB DMA driver ARM: tegra: config: enable dmaengine based APB DMA driver + sync to 3.6-rc6
2012-09-20ARM: OMAP2+: Make omap4-keypad.h localTony Lindgren
This can be local to mach-omap2. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-20ARM: OMAP2+: Make l4_3xxx.h localTony Lindgren
2012-09-20ARM: OMAP2+: Make l4_2xxx.h localTony Lindgren
