path: root/arch/arm/plat-omap
2019-08-09ARM: OMAP: dma: Mark expected switch fall-throughsGustavo A. R. Silva
Mark switch cases where we are expecting to fall through. This patch fixes the following warnings: arch/arm/plat-omap/dma.c: In function 'omap_set_dma_src_burst_mode': arch/arm/plat-omap/dma.c:384:6: warning: this statement may fall through [-Wimplicit-fallthrough=] if (dma_omap2plus()) { ^ arch/arm/plat-omap/dma.c:393:2: note: here case OMAP_DMA_DATA_BURST_16: ^~~~ arch/arm/plat-omap/dma.c:394:6: warning: this statement may fall through [-Wimplicit-fallthrough=] if (dma_omap2plus()) { ^ arch/arm/plat-omap/dma.c:402:2: note: here default: ^~~~~~~ arch/arm/plat-omap/dma.c: In function 'omap_set_dma_dest_burst_mode': arch/arm/plat-omap/dma.c:473:6: warning: this statement may fall through [-Wimplicit-fallthrough=] if (dma_omap2plus()) { ^ arch/arm/plat-omap/dma.c:481:2: note: here default: ^~~~~~~ Notice that, in this particular case, the code comment is modified in accordance with what GCC is expecting to find. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 156Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not write to the free software foundation inc 59 temple place suite 330 boston ma 02111 1307 usa extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 1334 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Richard Fontana <rfontana@redhat.com> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-07Remove MODULE_ALIAS() calls that take undefined macroMasahiro Yamada
These files do not define (USBHS_)DRIVER_NAME. Yet, they can be successfully compiled because they are never built as a module by anyone, i.e, the MODULE_ALIAS() calls are always no-op. A problem showed up when a patch "moduleparam: Save information about built-in modules in separate file" was applied. With this new feature, MODULE_*() will be populated even if the callers are built-in. To avoid the build errors, the lines referencing to the undefined macro must be removed. The complete fix is to remove all MODULE_* and #include <linux/module.h> like many "make ... explicitly non-modular" commits did. For now, I am touching only the offending lines. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com>
2018-11-08ARM: Kconfig: remove useless "default n"Russell King
The default for Kconfig options is always n, so there's no need to explicitly state a "n" default. Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-07-20ARM/time: Remove read_boot_clock64()Pavel Tatashin
read_boot_clock64() is deleted, and replaced with read_persistent_wall_and_boot_offset(). The default implementation of read_persistent_wall_and_boot_offset() provides a better fallback than the current stubs for read_boot_clock64() that arm has with no users, so remove the old code. Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: steven.sistare@oracle.com Cc: daniel.m.jordan@oracle.com Cc: linux@armlinux.org.uk Cc: schwidefsky@de.ibm.com Cc: heiko.carstens@de.ibm.com Cc: john.stultz@linaro.org Cc: sboyd@codeaurora.org Cc: hpa@zytor.com Cc: douly.fnst@cn.fujitsu.com Cc: peterz@infradead.org Cc: prarit@redhat.com Cc: feng.tang@intel.com Cc: pmladek@suse.com Cc: gnomes@lxorguk.ukuu.org.uk Cc: linux-s390@vger.kernel.org Cc: boris.ostrovsky@oracle.com Cc: jgross@suse.com Cc: pbonzini@redhat.com Link: https://lkml.kernel.org/r/20180719205545.16512-19-pasha.tatashin@oracle.com
2018-04-16ARM: OMAP2+: Drop unused pm-noopTony Lindgren
Looks like these functions don't do anything in the mainline kernel so we can just drop it. Note that we must now also remove ir-rx51 pdata as it relies on the dummy platform data that does not do anything. And ir-rx51 is calling a pdata callback that doesn't do anything without checking if it exists first. For configuring device specific minimal latencies, the interface to use is pm_qos_add_request(). For an example, see what was done in commit 9834ffd1ecc3 ("ASoC: omap-mcbsp: Add PM QoS support for McBSP to prevent glitches"). I've added some comments to ir-rx51 so people using it can add pm_qos support and test it. Cc: Ivaylo Dimitrov <ivo.g.dimitrov.75@gmail.com> Cc: Kevin Hilman <khilman@kernel.org> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-04-05Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "This release brings up a new platform based on the old ARM9 core: the Nuvoton NPCM is used as a baseboard management controller, competing with the better known ASpeed AST2xx series. Another important change is the addition of ARMv7-A based chips in mach-stm32. The older parts in this platform are ARMv7-M based microcontrollers, now they are expanding to general-purpose workloads. The other changes are the usual defconfig updates to enable additional drivers, lesser bugfixes. The largest updates as often are the ongoing OMAP cleanups, but we also have a number of changes for the older PXA and davinci platforms this time. For the Renesas shmobile/r-car platform, some new infrastructure is needed to make the watchdog work correctly. Supporting Multiprocessing on Allwinner A80 required a significant amount of new code, but is not doing anything unexpected" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (179 commits) arm: npcm: modify configuration for the NPCM7xx BMC. MAINTAINERS: update entry for ARM/berlin ARM: omap2: fix am43xx build without L2X0 ARM: davinci: da8xx: simplify CFGCHIP regmap_config ARM: davinci: da8xx: fix oops in USB PHY driver due to stack allocated platform_data ARM: multi_v7_defconfig: add NXP FlexCAN IP support ARM: multi_v7_defconfig: enable thermal driver for i.MX devices ARM: multi_v7_defconfig: add RN5T618 PMIC family support ARM: multi_v7_defconfig: add NXP graphics drivers ARM: multi_v7_defconfig: add GPMI NAND controller support ARM: multi_v7_defconfig: add OCOTP driver for NXP SoCs ARM: multi_v7_defconfig: configure I2C driver built-in arm64: defconfig: add CONFIG_UNIPHIER_THERMAL and CONFIG_SNI_AVE ARM: imx: fix imx6sll-only build ARM: imx: select ARM_CPU_SUSPEND for CPU_IDLE as well ARM: mxs_defconfig: Re-sync defconfig ARM: imx_v4_v5_defconfig: Use the generic fsl-asoc-card driver ARM: imx_v4_v5_defconfig: Re-sync defconfig arm64: defconfig: enable stmmac ethernet to defconfig ARM: EXYNOS: Simplify code in coupled CPU idle hot path ...
2018-03-21ARM: OMAP: Fix SRAM W+X mappingTony Lindgren
We are still using custom SRAM code for some SoCs and are not marking the PM code mapped to SRAM as read-only and executable after we're done. With CONFIG_DEBUG_WX=y, we will get "Found insecure W+X mapping at address" warning. Let's fix this issue the same way as commit 728bbe75c82f ("misc: sram: Introduce support code for protect-exec sram type") is doing for drivers/misc/sram-exec.c. On omap3, we need to restore SRAM when returning from off mode after idle, so init time configuration is not enough. And as we no longer have users for omap_sram_push_address() we can make it static while at it. Note that eventually we should be using sram-exec.c for all SoCs. Cc: stable@vger.kernel.org # v4.12+ Cc: Dave Gerlach <d-gerlach@ti.com> Reported-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-02-22ARM: OMAP: Move dmtimer driver out of plat-omap to drivers under clocksourceKeerthy
Move the dmtimer driver out of plat-omap to clocksource. So that non-omap devices also could use this. No Code changes done to the driver file only renamed to timer-ti-dm.c. Also removed the config dependencies for OMAP_DM_TIMER. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Tested-by: Ladislav Michl <ladis@linux-mips.org> [tony@atomide.com: add select omap_dm_timer for omap16xx] Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-02-22ARM: OMAP: Move dmtimer.h out of plat-omapKeerthy
The header file is currently under plat-omap directory under arch/omap. Move this out to an accessible place. No Code changes done to the header file and renamed to timer-ti-dm.h. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Tested-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-02-22ARM: OMAP: timer: Wrap the inline functions under OMAP2PLUS defineKeerthy
Wrap the inline functions under OMAP2PLUS/OMAP1 defines. This patch also inlines omap_dm_timer_get_fclk function for non OMAP1 Config. Signed-off-by: Keerthy <j-keerthy@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org> Reviewed-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-02-22ARM: OMAP: dmtimer: Remove all the exportsKeerthy
Remove all the unwanted exports from the driver Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Tested-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-02-22Merge branch 'omap-for-v.16/dmtimer-fix' into omap-for-v4.17/timerTony Lindgren
2018-02-22ARM: OMAP: Fix dmtimer init for omap1Tony Lindgren
We need to enable PM runtime on omap1 also as otherwise we will get errors: omap_timer omap_timer.1: omap_dm_timer_probe: pm_runtime_get_sync failed! omap_timer: probe of omap_timer.1 failed with error -13 ... We are checking for OMAP_TIMER_NEEDS_RESET flag elsewhere so this is safe to do. Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Keerthy <j-keerthy@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-02-14ARM: OMAP: Move plat/i2c.h into mach-omap1 folderSuman Anna
The current contents of plat/i2c.h are only relevant for OMAP1 platforms, as all the equivalent functions for OMAP2 has been dropped in commit 65fa3e719f36 ("ARM: OMAP2+: Remove legacy i2c.c platform init code"), and which has also moved the left-over code from plat-omap into mach-omap1. The hwmod is a concept only applicable for OMAP2 platforms, and the omap_i2c_reset() is already declared in mach-omap2/i2c.h. So, move the current plat/i2c.h header file into the mach-omap1 folder, and adjust the header usage accordingly. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-02-14ARM: OMAP2+: Cleanup omap_timer_capability_dev_attr usageSuman Anna
The omap_timer_capability_dev_attr data was used to supply instance specific capabilities (like always-on, PWM functionality or ability to interrupt DSP cores) for legacy non-DT devices. These capabilities are now provided through device-tree properties. The legacy device support has been cleaned up in commit 8d39ff3d1696 ("ARM: OMAP2+: Remove unused legacy code for timer") and this data is therefore no longer needed. So, cleanup the structure and all the associated data in various hwmod data files. While at this, remove the stale header in hwmod data files that already do not have any timer capability data. Cc: Keerthy <j-keerthy@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2017-11-16Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "Most of the commits are for defconfig changes, to enable newly added drivers or features that people have started using. For the changed lines lines, we have mostly cleanups, the affected platforms are OMAP, Versatile, EP93xx, Samsung, Broadcom, i.MX, and Actions. The largest single change is the introduction of the TI "sysc" bus driver, with the intention of cleaning up more legacy code. Two new SoC platforms get added this time: - Allwinner R40 is a modernized version of the A20 chip, now with a Quad-Core ARM Cortex-A7. According to the manufacturer, it is intended for "Smart Hardware" - Broadcom Hurricane 2 (Aka Strataconnect BCM5334X) is a family of chips meant for managed gigabit ethernet switches, based around a Cortex-A9 CPU. Finally, we gain SMP support for two platforms: Renesas R-Car E2 and Amlogic Meson8/8b, which were previously added but only supported uniprocessor operation" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (118 commits) ARM: multi_v7_defconfig: Select RPMSG_VIRTIO as module ARM: multi_v7_defconfig: enable CONFIG_GPIO_UNIPHIER arm64: defconfig: enable CONFIG_GPIO_UNIPHIER ARM: meson: enable MESON_IRQ_GPIO in Kconfig for meson8b ARM: meson: Add SMP bringup code for Meson8 and Meson8b ARM: smp_scu: allow the platform code to read the SCU CPU status ARM: smp_scu: add a helper for powering on a specific CPU dt-bindings: Amlogic: Add Meson8 and Meson8b SMP related documentation ARM: OMAP3: Delete an unnecessary variable initialisation in omap3xxx_hwmod_init() ARM: OMAP3: Use common error handling code in omap3xxx_hwmod_init() ARM: defconfig: select the right SX150X driver arm64: defconfig: Enable QCOM_IOMMU arm64: Add ThunderX drivers to defconfig arm64: defconfig: Enable Tegra PCI controller cpufreq: imx6q: Move speed grading check to cpufreq driver arm64: defconfig: re-enable Qualcomm DB410c USB ARM: configs: stm32: Add MDMA support in STM32 defconfig ARM: imx: Enable cpuidle for i.MX6DL starting at 1.1 bus: ti-sysc: Fix unbalanced pm_runtime_enable by adding remove bus: ti-sysc: mark PM functions as __maybe_unused ...
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-11ARM: OMAP: Fix typos in two comment lines in _omap_dm_timer_request()Markus Elfring
Adjust three words in this description. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2017-10-11ARM: OMAP: Use kcalloc() in omap_system_dma_probe()Markus Elfring
* A multiplication for the size determination of a memory allocation indicated that an array data structure should be processed. Thus use the corresponding function "kcalloc". This issue was detected by using the Coccinelle software. * Replace the specification of a data type by a pointer dereference to make the corresponding size determination a bit safer according to the Linux coding style convention. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2017-10-11ARM: OMAP: Improve a size determination in two functionsMarkus Elfring
Replace the specification of data structures by pointer dereferences as the parameter for the operator "sizeof" to make the corresponding size determination a bit safer according to the Linux coding style convention. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2017-10-11ARM: OMAP: Delete an error message for a failed memory allocation in two ↵Markus Elfring
functions Omit extra messages for a memory allocation failure in these functions. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-11-10ARM: OMAP2+: Remove legacy mux codeTony Lindgren
All the boards booting with device tree use drivers/pinctrl-single.c instead. Note that mach-omap1 is still using the legacy mux, so let's move the related Kconfig options from plat-omap to mach-omap1. Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-11-10ARM: OMAP2+: Remove legacy i2c.c platform init codeTony Lindgren
We can now initialize I2C for mach-omap2 using device tree. And we can move the remaining code in plat-omap/i2c.c into mach-omap1/i2c.c. Note that we cannot remove some of the I2C bus reset functions as they are being used by hwmod code. Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-11-30ARM: OMAP: dmtimer: check for fixed timers during configSuman Anna
The omap_dm_timer_set_source() function provides a means for client users to configure the mux parent for a GPTimer's functional clock. However, not all timers are configurable (Eg: Timer12 on DRA7 is fed by an internal 32k oscillator clock, and does not have configurable parent clocks). So, check for such cases and proceed with out throwing an error. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-11-30ARM: OMAP: add DT support for ti,dm816-timerNeil Armstrong
Adds ti,dm816-timer to the dmtimer OF match table. Cc: Brian Hutchinson <b.hutchman@gmail.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-11-30ARM: OMAP: dmtimer: Add clock source from DTNeil Armstrong
Add a function which sets the timer source from the clocks binding on dm_timer_prepare call. In case the clocks property is not valid, it falls back to the set_source() with 32_KHZ clock as default. Suggested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-05-20ARM: OMAP1: Change interrupt numbering for sparse IRQTony Lindgren
Change interrupt numbering for sparse IRQ. We do this using a fixed offset until we can drop irqs.h once all it's users have been updated. Note that this depends on the GPIO fix for the MPUIO IRQs "gpio: omap: Fix regression for MPUIO interrupts". Also note that this patch adds some extra irq alloc warnings that will go away when we stop calling irq_alloc_descs in gpio-omap.c with a follow-up patch. Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-04-03ARM, clocksource/drivers: Provide read_boot_clock64() and ↵Xunlei Pang
read_persistent_clock64() and use them As part of addressing "y2038 problem" for in-kernel uses, this patch converts read_boot_clock() to read_boot_clock64() and read_persistent_clock() to read_persistent_clock64() using timespec64 by converting clock_access_fn to use timespec64. Signed-off-by: Xunlei Pang <pang.xunlei@linaro.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Thierry Reding <treding@nvidia.com> (for tegra part) Cc: Russell King <rmk@dyn-67.arm.linux.org.uk> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1427945681-29972-7-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-03ARM: OMAP: 32k counter: Provide y2038-safe omap_read_persistent_clock() ↵Xunlei Pang
replacement As part of addressing "y2038 problem" for in-kernel uses, this patch adds the y2038-safe omap_read_persistent_clock64() using timespec64. Because we rely on some subsequent changes to convert arm multiarch support, omap_read_persistent_clock() will be removed then. Also remove the needless spinlock, because read_persistent_clock() doesn't run simultaneously. Signed-off-by: Xunlei Pang <pang.xunlei@linaro.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1427945681-29972-5-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-03-31Merge tag 'v4.0-rc6' into timers/core, before applying new patchesIngo Molnar
2015-03-17ARM: OMAP: dmtimer: disable pm runtime on removeSuman Anna
Disable the pm_runtime of the device upon remove. This is added to balance the pm_runtime_enable() invoked in the probe. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-17ARM: OMAP: dmtimer: check for pm_runtime_get_sync() failureSuman Anna
The current OMAP dmtimer probe does not check for the return status of pm_runtime_get_sync() before initializing the timer registers. Any timer with missing hwmod data would return a failure here, and the access of registers without enabling the clocks for the timer would trigger a l3_noc interrupt and a kernel boot hang. Add proper checking so that the probe would return a failure graciously without hanging the kernel boot. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-13clocksource: Rename __clocksource_updatefreq_*() to ↵John Stultz
__clocksource_update_freq_*() Ingo requested this function be renamed to improve readability, so I've renamed __clocksource_updatefreq_scale() as well as the __clocksource_updatefreq_hz/khz() functions to avoid squishedtogethernames. This touches some of the sh clocksources, which I've not tested. The arch/arm/plat-omap change is just a comment change for consistency. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1426133800-29329-13-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-01-07ARM: OMAP: dma.c: Remove unused functionRickard Strandqvist
Remove the function get_gdma_dev() that is not used anywhere. This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-10-14Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - fix for handling dependencies of *-objs targets by Masahiro Yamada - lots of cleanups in the kbuild machinery, also by Masahiro - fixes for the kconfig build to use an UTF-8 capable ncurses library if possible and to build on not-so-standard installs - some more minor fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Do not reference *-n variables in the Makefile kbuild: simplify build, clean, modbuiltin shorthands kbuild: arm: Do not define "comma" twice kbuild: remove obj-n and lib-n handling kbuild: remove unnecessary variable initializaions kbuild: remove unnecessary "obj- := dummy.o" trick kbuild: handle C=... and M=... after entering into build directory kbuild: use $(Q) for sub-make target kbuild: fake the "Entering directory ..." message more simply kconfig/lxdialog: get ncurses CFLAGS with pkg-config kconfig: nconfig: fix multi-byte UTF handling kconfig: lxdialog: fix spelling kbuild: Make scripts executable kbuild: remove redundant clean-files from scripts/kconfig/Makefile kbuild: refactor script/kconfig/Makefile kbuild: handle the dependency of multi-objs hostprogs appropriately kbuild: handle multi-objs dependency appropriately
2014-10-08Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "This time around, the cleanup branch contains mostly code removal. A number of board files for at91, imx and msm have become obsolete because of the DT conversion and are now ready to be removed. The OMAP platform has traditionally had its own DMA engine abstraction and as this is being phased out, a lot of the original code is now unused and can be removed as well. S3C24xx can be simplified now that the restart code is a proper device driver. Finally, a number of cleanups in shmobile are done to prepare for the addition of new code in other branches" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits) ARM: at91: Remove the support for the RSI EWS board arm: mach-omap2: Convert pr_warning to pr_warn ARM: OMAP: Remove unused pieces of legacy DMA API ARM: at91: remove board file for Acme Systems Fox G20 ARM: orion5x: Convert pr_warning to pr_warn ARM: S3C24XX: remove separate restart code ARM: EXYNOS: Do not calculate boot address twice ARM: sunxi: Remove sun4i reboot code from mach directory ARM: imx: Remove mach-mxt_td60 board file ARM: shmobile: armadillo800eva legacy: Use rmobile_add_devices_to_domains() ARM: shmobile: r8a7740: Clean up pm domain table ARM: shmobile: r8a7740: Use rmobile_add_devices_to_domains() ARM: shmobile: sh7372: Make domain_devices[] static __initdata ARM: shmobile: mackerel: Make domain_devices[] static __initdata clocksource: tcb_clksrc: sanitize IRQ request ARM: at91/tclib: mask interruptions at shutdown and probe ARM: at91/tclib: move initialization from alloc to probe ARM: at91/tclib: prefer using of devm_* functions ARM: clps711x: Switch CLPS711X subarch to use clk and clocksource driver ARM: shmobile: r8a7791 is now called "R-Car M2-W" ...
2014-10-02kbuild: remove unnecessary variable initializaionsMasahiro Yamada
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is a useless habit. They are non-exported variables; therefore they are always empty whenever descending into each subdirectory. (Moreorver, obj-y and obj-m are also set to empty at the beginning of scripts/Makefile.build) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-09-18ARM: OMAP: Remove unused pieces of legacy DMA APITony Lindgren
We're moving to the dmaengine API, so let's remove the unused pieces of the omap legacy DMA code to make sure we don't get any new users for these: omap_set_dma_color_mode omap_set_dma_src_index omap_set_dma_dest_index omap_dma_unlink_lch omap_clear_dma omap_dma_running omap_dma_set_prio_lch omap_set_dma_dst_endian_type omap_set_dma_src_endian_type omap_get_dma_index omap_dma_disable_irq omap_request_dma_chain omap_free_dma_chain omap_dma_chain_a_transfer omap_start_dma_chain_transfers omap_stop_dma_chain_transfers omap_get_dma_chain_index omap_get_dma_chain_dst_pos omap_get_dma_chain_src_pos omap_modify_dma_chain_params omap_dma_chain_status Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-09ARM: OMAP: Fix Kconfig warning for omap1Tony Lindgren
Commit 21278aeafbfa ("ARM: use menuconfig for sub-arch menus") improved the sub-arch menus, but accidentally caused new warnings for omap1. This was because the commit added a menu entry around config ARCH_OMAP bool entry where the menu had depends on ARCH_MULTI_V6 || ARCH_MULTI_V7. As ARCH_OMAP is shared between omap1 and omap2plus, let's fix the issue by defining ARCH_OMAP in the shared plat-omap/Kconfig. Fixes: 21278aeafbfa ("ARM: use menuconfig for sub-arch menus") Reported-by: Andreas Ruprecht <rupran@einserver.de> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-08-08Merge tag 'soc-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This is the bulk of new SoC enablement and other platform changes for 3.17: - Samsung S5PV210 has been converted to DT and multiplatform - Clock drivers and bindings for some of the lower-end i.MX 1/2 platforms - Kirkwood, one of the popular Marvell platforms, is folded into the mvebu platform code, removing mach-kirkwood - Hwmod data for TI AM43xx and DRA7 platforms - More additions of Renesas shmobile platform support - Removal of plat-samsung contents that can be removed with S5PV210 being multiplatform/DT-enabled and the other two old platforms being removed New platforms (most with only basic support right now): - Hisilicon X5HD2 settop box chipset is introduced - Mediatek MT6589 (mobile chipset) is introduced - Broadcom BCM7xxx settop box chipset is introduced + as usual a lot other pieces all over the platform code" * tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits) ARM: hisi: remove smp from machine descriptor power: reset: move hisilicon reboot code ARM: dts: Add hix5hd2-dkb dts file. ARM: debug: Rename Hi3716 to HIX5HD2 ARM: hisi: enable hix5hd2 SoC ARM: hisi: add ARCH_HISI MAINTAINERS: add entry for Broadcom ARM STB architecture ARM: brcmstb: select GISB arbiter and interrupt drivers ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs ARM: configs: enable SMP in bcm_defconfig ARM: add SMP support for Broadcom mobile SoCs Documentation: arm: misc updates to Marvell EBU SoC status Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC ARM: mvebu: fix build without platforms selected ARM: mvebu: add cpuidle support for Armada 38x ARM: mvebu: add cpuidle support for Armada 370 cpuidle: mvebu: add Armada 38x support cpuidle: mvebu: add Armada 370 support cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7 ARM: mvebu: export the SCU address ...
2014-07-21ARM: OMAP2+: DMA: remove requirement of irq for platform-dma driverNishanth Menon
we have currently 2 DMA drivers that try to co-exist. drivers/dma/omap-dma.c which registers it's own IRQ and is device tree aware and uses arch/arm/plat-omap/dma.c instance created by arch/arm/mach-omap2/dma.c to maintain channel usage (omap_request_dma). Currently both try to register interrupts and mach-omap2/plat-omap dma.c attempts to use the IRQ number registered by hwmod to register it's own interrupt handler. Now, there is no reasonable way of static allocating DMA irq in GIC SPI when we use crossbar. However, since the dma_chan structure is freed as a result of IRQ not being present due to devm allocation, maintaining information of channel by platform code fails at a later point in time when that region of memory is reused. So, if hwmod does not indicate an IRQ number, then, assume that dma-engine will take care of the interrupt handling. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-01ARM: OMAP: add deprecation message for legacy OMAP DMA APIRussell King
The legacy OMAP DMA API is now deprecated; all remaining users should now convert over ASAP to using the DMA engine API instead of the OMAP private API. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-02Merge tag 'cleanup-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC cleanups from Olof Johansson: "Cleanups for 3.16. Among these are: - a bunch of misc cleanups for Broadcom platforms, mostly housekeeping - enabling Common Clock Framework on the older s3c24xx Samsung chipsets - cleanup of the Versatile Express system controller code, moving it to syscon - power management cleanups for OMAP platforms plus a handful of other cleanups across the place" * tag 'cleanup-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (87 commits) ARM: kconfig: allow PCI support to be selected with ARCH_MULTIPLATFORM clk: samsung: fix build error ARM: vexpress: refine dependencies for new code clk: samsung: clk-s3c2410-dlck: do not use PNAME macro as it declares __initdata cpufreq: exynos: Fix the compile error ARM: S3C24XX: move debug-macro.S into the common space ARM: S3C24XX: use generic DEBUG_UART_PHY/_VIRT in debug macro ARM: S3C24XX: trim down debug uart handling ARM: compressed/head.S: remove s3c24xx special case ARM: EXYNOS: Remove unnecessary inclusion of cpu.h ARM: EXYNOS: Migrate Exynos specific macros from plat to mach ARM: EXYNOS: Remove exynos_subsys registration ARM: EXYNOS: Remove duplicate lines in Makefile ARM: EXYNOS: use v7_exit_coherency_flush macro for cache disabling ARM: OMAP4: PRCM: remove references to cm-regbits-44xx.h from PRCM core files ARM: OMAP3/4: PRM: add support of late_init call to prm_ll_ops ARM: OMAP3/OMAP4: PRM: add prm_features flags and add IO wakeup under it ARM: OMAP3/4: PRM: provide io chain reconfig function through irq setup ARM: OMAP2+: PRM: remove unnecessary cpu_is_XXX calls from prm_init / exit ARM: OMAP2+: PRCM: cleanup some header includes ...
2014-05-16ARM: OMAP2+: Fix DMA hang after off-idleTony Lindgren
Commit 6ddeb6d84459 (dmaengine: omap-dma: move IRQ handling to omap-dma) added support for handling interrupts in the omap dmaengine driver instead of the legacy driver. Because of different handling for interrupts this however caused omap3 to hang eventually after hitting off-idle. Any of the virtual 32 DMA channels can be assigned to any of the four DMA interrupts. So commit 6ddeb6d84459 made the omap dmaengine driver to use the second DMA interrupt while keeping the legacy code still using the first DMA interrupt. This means we need to save and restore both IRQENABLE_L1 in addition to IRQENABLE_L0. As there is a chance that the DSP might be using IRQENABLE_L2 or IRQENABLE_L3 lines, let's not touch those until this has been confirmed. Let's just add a comment to the code for now. Fixes: 6ddeb6d84459 (dmaengine: omap-dma: move IRQ handling to omap-dma) Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-08ARM: OMAP: debug-leds: raw read and write endian fixVictor Kamensky
All OMAP IP blocks expect LE data, but CPU may operate in BE mode. Need to use endian neutral functions to read/write h/w registers. I.e instead of __raw_read[lw] and __raw_write[lw] functions code need to use read[lw]_relaxed and write[lw]_relaxed functions. If the first simply reads/writes register, the second will byteswap it if host operates in BE mode. Changes are trivial sed like replacement of __raw_xxx functions with xxx_relaxed variant. Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org> Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-08ARM: OMAP: counter-32k: raw read and write endian fixVictor Kamensky
2014-05-08ARM: OMAP: dmtimer: raw read and write endian fixVictor Kamensky
