path: root/arch/arm/plat-orion/common.c
2013-05-20ARM: plat-orion: Fix num_resources and id for ge10 and ge11Gregory CLEMENT
When platform data were moved from arch/arm/mach-mv78xx0/common.c to arch/arm/plat-orion/common.c with the commit "7e3819d ARM: orion: Consolidate ethernet platform data", there were few typo made on gigabit Ethernet interface ge10 and ge11. This commit writes back their initial value, which allows to use this interfaces again. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Cc: <stable@vger.kernel.org> # v3.0.x Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-03-22mv643xx_eth: convert to use the Marvell Orion MDIO driverFlorian Fainelli
This patch converts the Marvell MV643XX ethernet driver to use the Marvell Orion MDIO driver. As a result, PowerPC and ARM platforms registering the Marvell MV643XX ethernet driver are also updated to register a Marvell Orion MDIO driver. This driver voluntarily overlaps with the Marvell Ethernet shared registers because it will use a subset of this shared register (shared_base + 0x4 to shared_base + 0x84). The Ethernet driver is also updated to look up for a PHY device using the Orion MDIO bus driver. For ARM and PowerPC we register a single instance of the "mvmdio" driver in the system like it used to be done with the use of the "shared_smi" platform_data cookie on ARM. Note that it is safe to register the mvmdio driver only for the "ge00" instance of the driver because this "ge00" interface is guaranteed to always be explicitely registered by consumers of arch/arm/plat-orion/common.c and other instances (ge01, ge10 and ge11) were all pointing their shared_smi to ge00. For PowerPC the in-tree Device Tree Source files mention only one MV643XX ethernet MAC instance so the MDIO bus driver is registered only when id == 0. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-20dma: mv_xor: remove the pool_size from platform_dataThomas Petazzoni
The pool_size is always PAGE_SIZE, and since it is a software configuration paramter (and not a hardware description parameter), we cannot make it part of the Device Tree binding, so we'd better remove it from the platform_data as well. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20dma: mv_xor: remove hw_id field from platform_dataThomas Petazzoni
There is no need for the platform_data to give this ID, it is simply the channel number, so we can compute it inside the driver when registering the channels. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20dma: mv_xor: change the driver name to 'mv_xor'Thomas Petazzoni
Since we got rid of the per-XOR channel 'mv_xor' driver, now the per-XOR engine driver that used to be called 'mv_xor_shared' can simply be named 'mv_xor'. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20dma: mv_xor: rename mv_xor_shared_platform_data to mv_xor_platform_dataThomas Petazzoni
'struct mv_xor_shared_platform_data' used to be the platform_data structure for the 'mv_xor_shared', but this driver is going to be renamed simply 'mv_xor', so also rename its platform_data structure accordingly. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20dma: mv_xor: rename mv_xor_platform_data to mv_xor_channel_dataThomas Petazzoni
mv_xor_platform_data used to be the platform_data structure associated to the 'mv_xor' driver. This driver no longer exists, and this data structure really contains the properties of each XOR channel part of a given XOR engine. Therefore 'struct mv_xor_channel_data' is a more appropriate name. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20dma: mv_xor: remove 'shared' from mv_xor_platform_dataThomas Petazzoni
This member of the platform_data structure is no longer used, so get rid of it. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20arm: plat-orion: remove unused orion_xor_init_channels()Thomas Petazzoni
Now that xor0 and xor1 are registered in a single driver manner, the orion_xor_init_channels() function has become useless. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20arm: plat-orion: convert the registration of the xor1 engine to the single ↵Thomas Petazzoni
driver Instead of registering one 'mv_xor_shared' device for the XOR engine, and then two 'mv_xor' devices for the XOR channels, pass the channels properties as platform_data for the main 'mv_xor_shared' device. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20arm: plat-orion: convert the registration of the xor0 engine to the single ↵Thomas Petazzoni
2012-09-22Merge branch 'kirkwood/addr_decode' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into late/kirkwood * 'kirkwood/addr_decode' of git://git.infradead.org/users/jcooper/linux: arm: mvebu: add address decoding controller to the DT arm: mvebu: add basic address decoding support to Armada 370/XP arm: plat-orion: make bridge_virt_base non-const to support DT use case arm: plat-orion: introduce PLAT_ORION_LEGACY hidden config option arm: plat-orion: use void __iomem pointers for addr-map functions arm: plat-orion: use void __iomem pointers for time functions arm: plat-orion: use void __iomem pointers for MPP functions arm: plat-orion: use void __iomem pointers for UART registration functions arm: mach-mvebu: use IOMEM() for base address definitions arm: mach-orion5x: use IOMEM() for base address definitions arm: mach-mv78xx0: use IOMEM() for base address definitions arm: mach-kirkwood: use IOMEM() for base address definitions arm: mach-dove: use IOMEM() for base address definitions arm: mach-orion5x: use plus instead of or for address definitions arm: mach-mv78xx0: use plus instead of or for address definitions arm: mach-kirkwood: use plus instead of or for address definitions arm: mach-dove: use plus instead of or for address definitions This branch had quite a few conflicts, in particular with the PCI static map rework from Rob Herring, and a few other context conflicts due to changes in Kconfig, etc. I fixed up conflicts in: arch/arm/Kconfig arch/arm/mach-dove/common.c arch/arm/mach-dove/include/mach/dove.h arch/arm/mach-kirkwood/common.c arch/arm/mach-kirkwood/include/mach/kirkwood.h arch/arm/mach-mv78xx0/common.c arch/arm/mach-mv78xx0/include/mach/mv78xx0.h arch/arm/mach-orion5x/common.c arch/arm/mach-orion5x/include/mach/orion5x.h Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'multiplatform/platform-data' into next/multiplatformOlof Johansson
* multiplatform/platform-data: ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: nomadik: move platform_data definitions ARM: w90x900: move platform_data definitions ARM: vt8500: move platform_data definitions ARM: tegra: move sdhci platform_data definition ARM: sa1100: move platform_data definitions ARM: pxa: move platform_data definitions ARM: netx: move platform_data definitions ARM: msm: move platform_data definitions ARM: imx: move platform_data definitions ARM: ep93xx: move platform_data definitions ARM: davinci: move platform_data definitions ARM: at91: move platform_data definitions Conflicts due to removed files: arch/arm/mach-tegra/board-harmony.c arch/arm/mach-tegra/board-trimslice.c Conflicts due to code removal: arch/arm/mach-tegra/board-paz00.c Context conflicts in: drivers/mmc/host/sdhci-tegra.c drivers/net/irda/pxaficp_ir.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-21arm: plat-orion: use void __iomem pointers for UART registration functionsThomas Petazzoni
The registration functions for UARTs now take void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/common.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-19ARM: orion: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the orion include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <djbw@fb.com> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de>
2012-08-15ARM: Orion: Set eth packet size csum offload limitArnaud Patard (Rtp)
The mv643xx ethernet controller limits the packet size for the TX checksum offloading. This patch sets this limits for Kirkwood and Dove which have smaller limits that the default. As a side note, this patch is an updated version of a patch sent some years ago: http://lists.infradead.org/pipermail/linux-arm-kernel/2010-June/017320.html which seems to have been lost. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Cc: <stable@vger.kernel.org>
2012-07-27ARM: Orion: Add arch support needed for I2C via DT.Andrew Lunn
The MV64XXX I2C driver needs a clock in order to calculate the baud rate factors. So add an clk to the clk tree. Also add the base DT properties for kirkwood devices. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Conflicts: arch/arm/mach-kirkwood/common.c
2012-06-23ARM: Orion: Fix Virtual/Physical mixup with watchdogAndrew Lunn
The orion watchdog is expecting to be passed the physcial address of the hardware, and will ioremap() it to give a virtual address it will use as the base address for the hardware. However, when creating the platform resource record, a virtual address was being used. Add the necassary #define's so we can pass the physical address as expected. Tested on Kirkwood and Orion5x. Cc: stable <stable@vger.kernel.org> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-05-08ARM: Orion: UART: Get the clock rate via clk_get_rate().Andrew Lunn
Let the machine pass to the platform which clock is used by the uart. Enable the clock and use clk_get_rate() to determine its rate. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: WDT: Add clk/clkdev supportAndrew Lunn
Remove tclk from platform data. This makes the platform data structure empty, so remove it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: Eth: Add clk/clkdev support.Andrew Lunn
The t_clk is moved from the shared part of the ethernet driver into the per port section. Each port can have its own gated clock, which it needs to enable/disable, as oppossed to there being one clock shared by all ports. In practice, only kirkwood supports this at the moment. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: SPI: Add clk/clkdev support.Andrew Lunn
Remove now redundant tclk from SPI platform data. This makes the platform data empty, so remove it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: Add clocks using the generic clk infrastructure.Andrew Lunn
Add tclk as a fixed rate clock for all platforms. In addition, on kirkwood, add a gated clock for most of the clocks which can be gated. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> [mturquette@linaro.org: removed redundant CLKDEV_LOOKUP from Kconfig] [mturquette@linaro.org: removed redundant clk.h from mach-dove/common.c] Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-03-16ARM: orion: wdt: use resource vice direct accessJason Cooper
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-02-09ARM: orion: Fix USB phy for orion5x.Andrew Lunn
The patch "ARM: orion: Consolidate USB platform setup code.", commit 4fcd3f374a928081d391cd9a570afe3b2c692fdc broke USB on TS-7800 and other orion5x boards, because the wrong type of PHY was being passed to the EHCI driver in the platform data. Orion5x needs EHCI_PHY_ORION and all the others want EHCI_PHY_NA. Allow the mach- code to tell the generic plat-orion code which USB PHY enum to place into the platform data. Version 2: Rebase to v3.3-rc2. Reported-by: Ambroz Bizjak <ambrop7@gmail.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Ambroz Bizjak <ambrop7@gmail.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-13ARM: Orion: Remove address map info from all platform data structuresAndrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Michael Walle <michael@walle.cc> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate setup of the crypto engine.Andrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate SATA platform setup.Andrew Lunn
2011-05-16ARM: orion: Consolidate USB platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the XOR platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the platform data setup for the watchdog.Andrew Lunn
2011-05-16ARM: orion: Consolidate SPI initialization.Andrew Lunn
This change removes the interrupt resource. The driver does not use it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate I2C initialization.Andrew Lunn
2011-05-16ARM: orion: Consolidate ethernet platform dataAndrew Lunn
2011-05-16ARM: orion: Consolidate the creation of the RTC platform data.Andrew Lunn
2011-05-16ARM: orion: Consolidate the creation of the uart platform data.Andrew Lunn
