As suggested by Arnd, move platform data to include/linux/platform_data
in order to improve build coverage for the driver.
Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
sdhci-pltfm driver for PXAV3 SoCs, such as MMP2.
Signed-off-by: Philip Rakity <prakity@marvell.com>
Acked-by: Philip Rakity <prakity@marvell.com>
Acked-by: Mark F. Brown <mark.brown314@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits)
[media] rc: update for bitop name changes
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
lib, arch: add filter argument to show_mem and fix private implementations
SLUB: Write to per cpu data when allocating it
slub: Fix debugobjects with lockless fastpath
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
NOTE!
This merge commit was created to fix compilation error. The block
tree was merged upstream and removed the 'elv_queue_empty()'
function which the new 'mtdswap' driver is using. So a simple
merge of the mtd tree with upstream does not compile. And the
mtd tree has already be published, so re-basing it is not an option.
To fix this unfortunate situation, I had to merge upstream into the
mtd-2.6.git tree without committing, put the fixup patch on top of
this, and then commit this. The result is that we do not have commits
which do not compile.
In other words, this merge commit "merges" 3 things: the MTD tree, the
upstream tree, and the fixup patch.
This patch moves the platform data definition from
arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so
it can be accessed from x86 the same way as on ARM.
This change should make no functional change to the PXA code. The move
is verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig
pxa910_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Use nand_scan_ident to unify the need of mtd member initilization
for both normal detection and keep configuration method.
Signed-off-by: Lei Wen <leiwen@marvell.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits)
spi/omap: Fix DMA API usage in OMAP MCSPI driver
spi/imx: correct the test on platform_get_irq() return value
spi/topcliff: Typo fix threhold to threshold
spi/dw_spi Typo change diable to disable.
spi/fsl_espi: change the read behaviour of the SPIRF
spi/mpc52xx-psc-spi: move probe/remove to proper sections
spi/dw_spi: add DMA support
spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs
spi/dw_spi: Fix too short timeout in spi polling loop
spi/pl022: convert running variable
spi/pl022: convert busy flag to a bool
spi/pl022: pass the returned sglen to the DMA engine
spi/pl022: map the buffers on the DMA engine
spi/topcliff_pch: Fix data transfer issue
spi/imx: remove autodetection
spi/pxa2xx: pass of_node to spi device and set a parent device
spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes.
spi/pxa2xx: Add chipselect support for Sodaville
spi/pxa2xx: Consider CE4100's FIFO depth
spi/pxa2xx: Add CE4100 support
* 'spi' of git://git.linutronix.de/users/bigeasy/soda into spi/next
spi/pxa2xx: register driver properly
spi/pxa2xx: add support for shared IRQ handler
spi/pxa2xx: Use define for SSSR_TFL_MASK instead of plain numbers
arm/pxa2xx: reorgazine SSP and SPI header files
The core of PXA955 is PJ4. Add new PJ4 support. And add new macro
CONFIG_PXA95x.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The PXA-SPI driver relies on some files / defines which are arm specific
and are within the ARM tree. The CE4100 SoC which is x86 has also the
SPI core.
This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to
include/linux where the CE4100 can access them.
This move got verified by building the following defconfigs:
We now:
* check for a v3 controller before setting 8-bit bus width
* offer a callback for platform code to switch to 8-bit mode, which
allows non-v3 controllers to support it
* rely on mmc->caps |= MMC_CAP_8_BIT_DATA; in platform code to specify
that the board designers have indeed brought out all the pins for
8-bit to the slot.
We were previously relying only on whether the *controller* supported
8-bit, which doesn't tell us anything about the pin configuration in
the board design.
This fixes the MMC card regression reported by Maxim Levitsky here:
http://thread.gmane.org/gmane.linux.kernel.mmc/4336
by no longer assuming that 8-bit works by default.
Tested-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
* git://git.infradead.org/mtd-2.6: (82 commits)
mtd: fix build error in m25p80.c
mtd: Remove redundant mutex from mtd_blkdevs.c
MTD: Fix wrong check register_blkdev return value
Revert "mtd: cleanup Kconfig dependencies"
mtd: cfi_cmdset_0002: make sector erase command variable
mtd: cfi_cmdset_0002: add CFI detection for SST 38VF640x chips
mtd: cfi_util: add support for switching SST 39VF640xB chips into QRY mode
mtd: cfi_cmdset_0001: use defined value of P_ID_INTEL_PERFORMANCE instead of hardcoded one
block2mtd: dubious assignment
P4080/mtd: Fix the freescale lbc issue with 36bit mode
P4080/eLBC: Make Freescale elbc interrupt common to elbc devices
mtd: phram: use KBUILD_MODNAME
mtd: OneNAND: S5PC110: Fix double call suspend & resume function
mtd: nand: fix MTD_MODE_RAW writes
jffs2: use kmemdup
mtd: sm_ftl: cosmetic, use bool when possible
mtd: r852: remove useless pci powerup/down from suspend/resume routines
mtd: blktrans: fix a race vs kthread_stop
mtd: blktrans: kill BKL
mtd: allow to unload the mtdtrans module if its block devices aren't open
Fix up trivial whitespace-introduced conflict in drivers/mtd/mtdchar.c
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git
drivers/mtd/mtd_blkdevs.c
Merge Grant's device-tree bits so that we can apply the subsequent fixes.
Support Marvell PXA168/PXA910/MMP2 SD Host Controller.
Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Adding a new flash definition would need less code.
Keep the platform passing flash definition method.
If one flash is both defined in platform data and builtin table,
driver would select the one from platform data first.
By this way, platform could select the timing most suit for itself,
not need to follow the common settings.
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
mach-mmp needs to clear wake event in order to clear the keypad interrupt
Signed-off-by: Mark F. Brown <mark.brown314@gmail.com>
mach-mmp utilizes pxa27x_keypad code so we need to move header to
platform pxa directory.
In order to prevent code ambiguous, add namespace on functions in ssp driver.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Update mfp setting for mmp2.
Support ssp devices in PXA168. PXA168 could reuse the code of PXA SSP.
Try to keep minimum ifdef in ssp.h. Some of the definitions are valid
only to specific SoCs, and device drivers should be responsible to take
care of these difference.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Since the same nand controller is shared between ARCH_PXA and ARCH_MMP. Move
the pxa3xx_nand.h from mach directory to plat directoy.
Cc: David Woodhouse <david.woodhouse@intel.com>
Since MFP_PIN_GPIO* now includes 128-255, mfp_to_gpio() is no longer
valid for those additional pins, fix it.
Add and initialize the mfp setting of pxa935 chip.
There is currently an uncovered case for MFP configuration on PXAs which
is selected by setting the PULL_SEL bit but none of the PULL{UP,DOWN}_EN
bits. This case is needed to explicitly let pins float, even if the
selected alternate function would default to a configuration with a pull
resistor enabled.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Paul Shen <paul.shen@marvell.com>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Signed-off-by: Bin Yang <bin.yang@marvell.com>
1. add common GPIO handling code into [arch/arm/plat-pxa]
2. common code in <mach/gpio.h> moved into <plat/gpio.h>, new processors
should implement its own <mach/gpio.h>, provide the following required
definitions and '#include <plat/gpio.h>' in the end:
- GPIO_REGS_VIRT for mapped virtual address of the GPIO registers'
physical I/O memory
- macros of GPLR(), GPSR(), GPDR() for constant optimization for
functions gpio_{set,get}_value() (so that bit-bang code can still
have tolerable performance)
- NR_BUILTIN_GPIO for the number of onchip GPIO
- definitions of __gpio_is_inverted() and __gpio_is_occupied(), they
can be either macros or inlined functions
1. introduce folder of 'arch/arm/plat-pxa' for common code across different
PXA processor families
2. initially moved DMA code into plat-pxa
3. common code in <mach/dma.h> moved into <plat/dma.h>, new processors
should implement its own <mach/dma.h>, provide the following required
definitions and '#include <plat/dma.h>' in the end:
- DMAC_REGS_VIRT for mapped virtual address of the DMA registers'
physical I/O memory
