[ Upstream commit ba16adeb346387eb2d1ada69003588be96f098fa ]
devm_ allocated data will be automatically freed. The free
of devm_ allocated data is invalid.
Fixes: 1c459de1e645 ("ARM: pxa: ssp: use devm_ functions")
Signed-off-by: Peng Hao <peng.hao2@zte.com.cn>
[title's prefix changed]
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
The ssp.c driver in plat-pxa is the only remaining file including a
mach/*.h header from mmp. It actually doesn't need mach/hardware.h at
all, so we can remove the #include.
Commit 03fbf488cece ("spi: pxa2xx: Differentiate Intel LPSS types") caused
build error here because it removed the type LPSS_SSP and I didn't notice
the type was used here too.
I believe commit a6e56c28a178 ("ARM: pxa: ssp: add DT bindings") added it
accidentally by copying all enum pxa_ssp_type types from
include/linux/pxa2xx_ssp.h even LPSS_SSP was for Intel LPSS SPI devices.
Fix the build error by removing this incorrect binding.
Fixes: 03fbf488cece ("spi: pxa2xx: Differentiate Intel LPSS types")
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Reported-by: Axel Lin <axel.lin@ingics.com>
Cc: <stable@vger.kernel.org> # 4.2
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Provide an explicit match string for PXA3xx SSP ports.
Without this match string, SSP0/SSP1/SSP2 in PXA3xxx will be consided as
PXA27x SSP Port.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Commit a6e56c28a178cef5f (ARM: pxa: ssp: add DT bindings) causes warnings
when built:
arch/arm/plat-pxa/ssp.c: In function 'pxa_ssp_probe':
arch/arm/plat-pxa/ssp.c:145:17: warning: 'dma_spec.args[0]' may be used
uninitialized in this function [-Wmaybe-uninitialized]
Resolve by checking return values and aborting when lookups fail.
Cc: Daniel Mack <zonque@gmail.com>
Cc: Mark Brown <broonie@linaro.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Add a function to lookup ssp devices from device tree. This way, users
can reference the ssp devices in order to register to them.
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Use devm_ functions to allocate memory, ioremap, clk_get etc to clean up
the error unwind path.
This patch contains an ugly hack for looking up the the DMA request
number. The problem here is that the implementation as it stands will
allocate the DMA channel from the user of the ssp port, and hence we
cannot allocate a real channel here.
No functional change, just a cosmetic cleanup.
The memory subsystem will already complain loudly enough in such cases.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
add pxa910-ssp into ssp_id_table, and fix pxa-ssp compiling issue
under mach-mmp architect.
Signed-off-by: Qiao Zhou <zhouqiao@marvell.com>
The PXA-SPI driver relies on some files / defines which are arm specific
and are within the ARM tree. The CE4100 SoC which is x86 has also the
SPI core.
This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to
include/linux where the CE4100 can access them.
This move got verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
In order to prevent code ambiguous, add namespace on functions in ssp driver.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The assignments of res to the results of the two calls to
platform_get_resource make it impossible to use res in the error handling
code in the arguments to release_mem_region.
The semantic match that finds the former problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
expression E, E1;
identifier f;
statement S1,S3;
iterator iter;
if ((E == NULL && ...) || ...)
... when != false ((E == NULL && ...) || ...)
when != true ((E != NULL && ...) || ...)
when != iter(E,...) S1
when != E = E1
sizeof(E->f)
* E->f
... when any
return ...;
else S3
// </smpl>
Support ssp devices in PXA168. PXA168 could reuse the code of PXA SSP.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
