[ Upstream commit 9ee8578d953023cc57e7e736ae48502c707c0210 ]
Since commit 1c459de1e645 ("ARM: pxa: ssp: use devm_ functions")
kfree, iounmap, clk_put etc are not needed anymore in remove path.
Fixes: 1c459de1e645 ("ARM: pxa: ssp: use devm_ functions")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ commit message spelling fix ]
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
[ Upstream commit ba16adeb346387eb2d1ada69003588be96f098fa ]
devm_ allocated data will be automatically freed. The free
of devm_ allocated data is invalid.
Signed-off-by: Peng Hao <peng.hao2@zte.com.cn>
[title's prefix changed]
As the last pxa related driver was converted to dmaengine, it's time to
kill the legacy dma code, which is not used anymore.
This finishes the pxa dmaengine transition.
Declare the number of DMA requestor lines per platform :
- for pxa25x: 40 requestor lines
- for pxa27x: 75 requestor lines
- for pxa3xx: 100 requestor lines
This information will be used to activate the DMA flow control or not.
With all dependencies taken care of, this enables building
the Marvell mmp platform as part of ARCH_MULTIPLATFORM, along
with other ARMv5 and ARMv7 platforms.
Acked-by: Andrew Lunn <andrew@lunn.ch>
The ssp.c driver in plat-pxa is the only remaining file including a
mach/*.h header from mmp. It actually doesn't need mach/hardware.h at
all, so we can remove the #include.
All drivers have stopped using this code, so we can just
as well stop initializing it.
Commit 03fbf488cece ("spi: pxa2xx: Differentiate Intel LPSS types") caused
build error here because it removed the type LPSS_SSP and I didn't notice
the type was used here too.
I believe commit a6e56c28a178 ("ARM: pxa: ssp: add DT bindings") added it
accidentally by copying all enum pxa_ssp_type types from
include/linux/pxa2xx_ssp.h even LPSS_SSP was for Intel LPSS SPI devices.
Fix the build error by removing this incorrect binding.
Fixes: 03fbf488cece ("spi: pxa2xx: Differentiate Intel LPSS types")
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Reported-by: Axel Lin <axel.lin@ingics.com>
Cc: <stable@vger.kernel.org> # 4.2
In order to slowly transition pxa to dmaengine, the legacy code will now
rely on dmaengine to request a channel.
This implies that PXA architecture selects DMADEVICES and PXA_DMA,
which is not pretty. Yet it enables PXA drivers to be ported one by one,
with part of them using dmaengine, and the other part using the legacy
code.
The seq_printf return value, because it's frequently misused,
(as it is here, it doesn't return # of chars emitted) will
eventually be converted to void.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Provide an explicit match string for PXA3xx SSP ports.
Without this match string, SSP0/SSP1/SSP2 in PXA3xxx will be consided as
PXA27x SSP Port.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
This flag is a NOOP since 2.6.35 and can be removed.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
[olof: Fixed compilation failure for pcm990-baseboard]
Commit a6e56c28a178cef5f (ARM: pxa: ssp: add DT bindings) causes warnings
when built:
arch/arm/plat-pxa/ssp.c: In function 'pxa_ssp_probe':
arch/arm/plat-pxa/ssp.c:145:17: warning: 'dma_spec.args[0]' may be used
uninitialized in this function [-Wmaybe-uninitialized]
Resolve by checking return values and aborting when lookups fail.
Cc: Daniel Mack <zonque@gmail.com>
Cc: Mark Brown <broonie@linaro.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Add a function to lookup ssp devices from device tree. This way, users
can reference the ssp devices in order to register to them.
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Use devm_ functions to allocate memory, ioremap, clk_get etc to clean up
the error unwind path.
This patch contains an ugly hack for looking up the the DMA request
number. The problem here is that the implementation as it stands will
allocate the DMA channel from the user of the ssp port, and hence we
cannot allocate a real channel here.
No functional change, just a cosmetic cleanup.
The memory subsystem will already complain loudly enough in such cases.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
PXA95x isn't widely used. And it adds the effort on supporting
multiple platform. So remove it.
The assumption is that nobody will miss this support. If you are
reading this text because you actually require pxa95x support on
a new kernel, we can work out a way to revert this patch or add
support to the mmp platform.
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the pxa include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Acked-By: Stefan Schmidt <stefan@openezx.org>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
Cc: Harald Welte <laforge@openezx.org>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Tomas Cech <sleep_walker@suse.cz>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Dan Williams <djbw@fb.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: openezx-devel@lists.openezx.org
Pull PWM subsystem from Thierry Reding:
"The new PWM subsystem aims at collecting all implementations of the
legacy PWM API and to eventually replace it completely.
The subsystem has been in development for over half a year now and
many drivers have already been converted. It has been in linux-next
for a couple of weeks and there have been no major issues so I think
it is ready for inclusion in your tree."
Arnd Bergmann <arnd@arndb.de>:
"Very much Ack on the new subsystem. It uses the interface
declarations as the previously separate pwm drivers, so nothing
changes for now in the drivers using it, although it enables us to
change those more easily in the future if we want to.
This work is also one of the missing pieces that are required to
eventually build ARM kernels for multiple platforms, which is
currently prohibited (amongs other things) by the fact that you cannot
have more than one driver exporting the pwm functions."
Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms
Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX
Acked-by: Sachin Kamat <sachin.kamat@linaro.org>
Fix up trivial conflicts with other cleanups and DT updates.
* 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits)
pwm: pwm-tiehrpwm: PWM driver support for EHRPWM
pwm: pwm-tiecap: PWM driver support for ECAP APWM
pwm: fix used-uninitialized warning in pwm_get()
pwm: add lpc32xx PWM support
pwm_backlight: pass correct brightness to callback
pwm: Use pr_* functions in pwm-samsung.c file
pwm: Convert pwm-samsung to use devm_* APIs
pwm: Convert pwm-tegra to use devm_clk_get()
pwm: pwm-mxs: Return proper error if pwmchip_remove() fails
pwm: pwm-bfin: Return proper error if pwmchip_remove() fails
pwm: pxa: Propagate pwmchip_remove() error
pwm: Convert pwm-pxa to use devm_* APIs
pwm: Convert pwm-vt8500 to use devm_* APIs
pwm: Convert pwm-imx to use devm_* APIs
pwm: Conflict with legacy PWM API
pwm: pwm-mxs: add pinctrl support
pwm: pwm-mxs: use devm_* managed functions
pwm: pwm-mxs: use global reset function stmp_reset_block
pwm: pwm-mxs: encode soc name in compatible string
pwm: Take over maintainership of the PWM subsystem
This commit moves the PXA PWM driver to the drivers/pwm subdirectory and
converts it to use the new PWM framework.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
add pxa910-ssp into ssp_id_table, and fix pxa-ssp compiling issue
under mach-mmp architect.
Signed-off-by: Qiao Zhou <zhouqiao@marvell.com>
Direct keys usage may not start from KP_DKIN0, add a msk option
to configure the specifics for platforms that can skip some keys.
Signed-off-by: Chao Xie <chao.xie@marvell.com>
KPDK_DK only indicates the pin level of direct key.
So it is related to board, and low level may be active which
indicates that a key is pressed.
Disintegrate asm/system.h for ARM.
cc: Russell King <linux@arm.linux.org.uk>
cc: linux-arm-kernel@lists.infradead.org
Remove most gpio macros and change gpio driver to platform driver.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
NR_BUILTIN_GPIO is both defined in arch-pxa and arch-mmp. Now replace it
with PXA_NR_BUILTIN_GPIO and MMP_NR_BUILTIN_GPIO.
Avoid to define gpio_to_irq() and irq_to_gpio() for potential name
confliction since multiple architecture will be built together.
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
This sorts out merge conflicts with the arm/gpio branch that
already got merged into mainline Linux.
This tries to clear up the confusion between integers and iomem pointers
in the marvell pxa platform. MMIO addresses are supposed to be __iomem*
values, in order to let the Linux type checking work correctly. This
patch moves the cast to __iomem as far back as possible, to the place
where the MMIO virtual address windows are defined.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The <mach/gpio.h> file is included from upper directories
and deal with generic GPIO and gpiolib stuff. Break out the
platform and driver specific defines and functions into its own
header file.
As per example from the other ARM boards, push the PXA
GPIO driver down to the GPIO subsystem so it can be consolidated.
Current pxa3xx_nand controller has two chip select which
both be workable. This patch enable this feature.
Update platform driver to support this feature.
Another notice should be taken that:
When you want to use this feature, you should not enable the
keep configuration feature, for two chip select could be
attached with different nand chip. The different page size
and timing requirement make the keep configuration impossible.
Signed-off-by: Lei Wen <leiwen@marvell.com>
Rather than marking the mach/gpio.h header files which want to use the
trivial GPIOLIB implementation, mark those which do not want to use it
instead. This means that by default, you get the trivial implementation
and only have to do something extra if you need to. This should
encourage the use of the trivial default implementation.
As an additional bonus, several gpio.h header files become empty.
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Tested-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
As suggested by Arnd, move platform data to include/linux/platform_data
in order to improve build coverage for the driver.
Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
sdhci-pltfm driver for PXAV3 SoCs, such as MMP2.
Signed-off-by: Philip Rakity <prakity@marvell.com>
Acked-by: Philip Rakity <prakity@marvell.com>
Acked-by: Mark F. Brown <mark.brown314@gmail.com>
The PXA platform code has a static inline helper called
gpio_to_chip which clashes with the gpiolib namespace if we
try to expose the function with the same name from gpiolib,
and it's still confusing even if we don't do that. So rename
it to gpio_to_pxachip().
Reported-by: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Eric Miao <eric.miao@linaro.org>
Replace sysdev classes and struct sys_device objects used for "core"
power management by the PXA platform code with struct syscore_ops
objects that are simpler.
This reduces the code size and the kernel memory footprint. It also
is necessary for removing sysdevs entirely from the kernel in the
future.
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Convert to the new function names. Automated with coccinelle.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits)
[media] rc: update for bitop name changes
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
lib, arch: add filter argument to show_mem and fix private implementations
SLUB: Write to per cpu data when allocating it
slub: Fix debugobjects with lockless fastpath
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
NOTE!
This merge commit was created to fix compilation error. The block
tree was merged upstream and removed the 'elv_queue_empty()'
function which the new 'mtdswap' driver is using. So a simple
merge of the mtd tree with upstream does not compile. And the
mtd tree has already be published, so re-basing it is not an option.
To fix this unfortunate situation, I had to merge upstream into the
mtd-2.6.git tree without committing, put the fixup patch on top of
this, and then commit this. The result is that we do not have commits
which do not compile.
In other words, this merge commit "merges" 3 things: the MTD tree, the
upstream tree, and the fixup patch.
This patch moves the platform data definition from
arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so
it can be accessed from x86 the same way as on ARM.
This change should make no functional change to the PXA code. The move
is verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig
pxa910_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Use nand_scan_ident to unify the need of mtd member initilization
for both normal detection and keep configuration method.
