path: root/arch/arm/plat-s3c24xx
2011-07-25Merge branch 'next/deletion' of ↵Linus Torvalds
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/deletion' of git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: mach-loki: delete ARM: mach-s3c2400: delete ARM: mach-s3c24a0: delete
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-22Merge branches 'btc', 'dma', 'entry', 'fixes', 'linker-layout', 'misc', ↵Russell King
'mmci', 'suspend' and 'vfp' into for-next
2011-07-21ARM: S3C24XX: Use generic s3c_set_platdata for devicesBanajit Goswami
Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21Merge branch 'next-samsung-clkdev-fix' into next-samsung-cleanupKukjin Kim
2011-07-21ARM: SAMSUNG: Added mach/clkdev.hThomas Abraham
This is temporary patch for building with clkdev. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: S3C24XX: Add clkdev supportThomas Abraham
2011-07-18ARM: mach-s3c2400: deleteNicolas Pitre
On Tue, 28 Jun 2011, Ben Dooks wrote: > On Tue, Jun 28, 2011 at 11:22:57PM +0200, Arnd Bergmann wrote: > > > On a related note, what about mach-s3c2400? It seems to be even more > > incomplete. > > Probably the same fate awaits that. It is so old that there's little > incentive to do anything with it. So out it goes as well. The PORT_S3C2400 definition in include/linux/serial_core.h is left there to prevent a reuse of the same number for another port type. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-18ARM: mach-s3c24a0: deleteNicolas Pitre
Commit bcae8aeb32 "[ARM] S3C24A0: Initial architecture support files" brought in a bunch of files while explicitly leaving out the corresponding Kconfig entry, stating that the series is not complete. More than 2.5 years later, the support for this has not seen any progress. This is therefore dead code. If someone wants to revive this code, it is always possible to retrieve it from the Git repository. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-16ARM: SAMSUNG: DMA Cleanup as per sparseSangwook Lee
Function declaration differs between file: dma.c and file:dma.h and SPARSE (Documentation/sparse.txt) gives error messages All dma channels are members of 'enum dma_ch' and not 'unsigned int' Please have a look at channel definitions in: arch/arm/mach-s3c64xx/include/mach/dma.h arch/arm/plat-samsung/include/plat/s3c-dma-pl330.h arch/arm/mach-s3c2410/include/mach/dma.h So all arguments should be of type 'enum dma_ch' Signed-off-by: Sangwook Lee <sangwook.lee@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-08ARM: S3C24XX: drop return codes in void function of dma.cWolfram Sang
Commit bb072c3c (ARM / Samsung: Use struct syscore_ops for "core" power management) turned s3c2410_dma_resume_chan() from int to void. So, drop the actual return values, too. Fixes: arch/arm/plat-s3c24xx/dma.c: In function 's3c2410_dma_resume_chan': arch/arm/plat-s3c24xx/dma.c:1238:3: warning: 'return' with a value, in function returning void arch/arm/plat-s3c24xx/dma.c:1250:2: warning: 'return' with a value, in function returning void Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-08ARM: S3C24XX: don't use uninitialized variable in dma.cWolfram Sang
Commit 8970ef47 (S3C24XX: Remove hardware specific registers from DMA calls) removed the parameter dcon in s3c2410_dma_config() and calculates it on its own. So the debug-output for the old parameter can go, too. Fixes: arch/arm/plat-s3c24xx/dma.c: In function 's3c2410_dma_config': arch/arm/plat-s3c24xx/dma.c:1030:2: warning: 'dcon' is used uninitialized in this function Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-24ARM: pm: samsung: move cpu_suspend into C codeRussell King
Move the call to cpu_suspend into C code, and noticing that all the s3c_cpu_save implementations are now identical, we can move this into the common samsung code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-24ARM: pm: plat-s3c24xx: cleanup s3c_cpu_saveRussell King
s3c_cpu_save does not need to save any registers with the new cpu_suspend calling convention. Remove these redundant instructions. Tested-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-24ARM: pm: convert cpu_suspend() to a normal functionRussell King
cpu_suspend() has a weird calling method which makes it only possible to call from assembly code: it returns with a modified stack pointer to finish the suspend, but on resume, it 'returns' via a provided pointer. We can make cpu_suspend() appear to be a normal function merely by swapping the resume pointer argument and the link register. Do so, and update all callers to take account of this more traditional behaviour. Acked-by: Frank Hofmann <frank.hofmann@tomtom.com> Tested-by: Kevin Hilman <khilman@ti.com> Acked-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-03ARM: S3C24XX: Move s3c24xx_irq_syscore_ops to plat-s3c24xx/irq.cHeiko Stuebner
s3c24xx_irq_syscore_ops was only defined for s3c2410 cpus leading to compile errors on for example 2412 and 2416. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-03ARM: S3C24xx: Fix missing struct for s3c2410_dma_chanHeiko Stuebner
s3c2410_dma_chan is not a type itself, so struct is required. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-10ARM: S3C24XX: Add plaform device definition for USB High-Speed gadget ↵Thomas Abraham
controller. S3C2416, S3C2443 and S3C2450 includes a USB High-Speed Gadget controller module. This patch adds the following for supporting this controller. 1. Definition for USB High-Speed controller base address. 2. Platform device instantiation. 3. Declaration for platform data structure. 4. Functionality to setup platform data for the controller. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-24ARM / Samsung: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by Samsung platforms with struct syscore_ops objects that are simpler. This generally reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] pcc-cpufreq: remove duplicate statements [CPUFREQ] Remove the pm_message_t argument from driver suspend [CPUFREQ] Remove unneeded locks [CPUFREQ] Remove old, deprecated per cpu ondemand/conservative sysfs files [CPUFREQ] Remove deprecated sysfs file sampling_rate_max [CPUFREQ] powernow-k8: The table index is not worth displaying [CPUFREQ] calculate delay after dbs_check_cpu [CPUFREQ] Add documentation for sampling_down_factor [CPUFREQ] drivers/cpufreq: Remove unnecessary semicolons
2011-03-16Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (91 commits) ARM: 6806/1: irq: introduce entry and exit functions for chained handlers ARM: 6781/1: Thumb-2: Work around buggy Thumb-2 short branch relocations in gas ARM: 6747/1: P2V: Thumb2 support ARM: 6798/1: aout-core: zero thread debug registers in a.out core dump ARM: 6796/1: Footbridge: Fix I/O mappings for NOMMU mode ARM: 6784/1: errata: no automatic Store Buffer drain on Cortex-A9 ARM: 6772/1: errata: possible fault MMU translations following an ASID switch ARM: 6776/1: mach-ux500: activate fix for errata 753970 ARM: 6794/1: SPEAr: Append UL to device address macros. ARM: 6793/1: SPEAr: Remove unused *_SIZE macros from spear*.h files ARM: 6792/1: SPEAr: Replace SIZE macro's with SZ_4K macros ARM: 6791/1: SPEAr3xx: Declare device structures after shirq code ARM: 6790/1: SPEAr: Clock Framework: Rename usbd clock and align apb_clk entry ARM: 6789/1: SPEAr3xx: Rename sdio to sdhci ARM: 6788/1: SPEAr: Include mach/hardware.h instead of mach/spear.h ARM: 6787/1: SPEAr: Reorder #includes in .h & .c files. ARM: 6681/1: SPEAr: add debugfs support to clk API ARM: 6703/1: SPEAr: update clk API support ARM: 6679/1: SPEAr: make clk API functions more generic ARM: 6737/1: SPEAr: formalized timer support ...
2011-03-16[CPUFREQ] Remove the pm_message_t argument from driver suspendRafael J. Wysocki
None of the existing cpufreq drivers uses the second argument of its .suspend() callback (which isn't useful anyway), so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Dave Jones <davej@redhat.com>
2011-03-07USB: s3c2410_udc: Add common implementation for GPIO controlled pullupsLars-Peter Clausen
Currently all boards using the s3c2410_udc driver use a GPIO to control the state of the pullup, as a result the same code is reimplemented in each board file. This patch adds support for using a GPIO to control the pullup state to the udc driver, so the boards can use a common implementation. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-03ARM: SAMSUNG: Move PWM device definition from plat-s3c24xx to plat-samsungBanajit Goswami
This patch does the following:- 1. It moves file pwm.c from plat-s3c24xx to plat-samsung. This will enable all machines with Samsung SoCs to make use of the same code. 2. The device definitions have been separated to a new file dev-pwm.c for better clarity and structure. 3. It will enable all Samsung S3C and S5P series SoC's to use common PWM Kconfig definition. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: pm: convert samsung platforms to generic suspend/resume supportRussell King
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-15Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
2011-01-13Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-01-10headers: kobject.h reduxAlexey Dobriyan
Remove kobject.h from files which don't need it, notably, sched.h and fs.h. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-06Merge branch 'next-s3c24xx' into for-nextKukjin Kim
2011-01-06ARM: SAMSUNG: Don't export __init functions to modulesYauhen Kharuzhy
There are few functions marked as __init, but exported to modules in devices declaration files. s3c_nand_set_platdata() and s3c24xx_ts_set_platdata() are used only by boards init code now, so remove EXPORT_SYMBOL() for them. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-06ARM: S3C24XX: Add address map and clock definitions for HSMMC0Yauhen Kharuzhy
Define maps for HSMMC devices. S3C2443 has one HSMMC device with base address 0x4A800000. S3C2416 has HSMMC0 at 0x4AC00000 and HSMMC1 at 0x4A800000. So suppose that S3C2443 has only HSMMC1. Define clock for hsmmc0 device and register it. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-03ARM: S3C24XX: irq_data conversionLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> [kgene.kim@samsung.com: coding-style fixes] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30ARM: SAMSUNG: Convert s3c_irqext_wake() to new irq_ interrupt methodsMark Brown
Kernel 2.6.37 adds new interrupt methods which take a struct irq_data rather than an irq number. Begin converting Samsung platforms over to these methods by converting s3c_irqext_wake() with a simple textual substitution. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-17ARM: S3C24XX: Fix CONFIG_S3C_DEV_NAND Kconfig entryKukjin Kim
Should be CONFIG_S3C_DEV_NAND instead of CONFIG_S3C_DEVICE_NAND. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-13Merge branch 'topic/workq-update' into topic/asocTakashi Iwai
Conflicts: sound/soc/codecs/wm8350.c sound/soc/codecs/wm8753.c sound/soc/sh/fsi.c sound/soc/soc-core.c
2010-12-08ARM: S3C24XX: Fix mess with gpio {set,get}_pull callbacksVasily Khoruzhick
Currently the {set,get}_pull callbacks of the s3c24xx_gpiocfg_default structure are initalized via s3c_gpio_{get,set}pull_1up. This results in a linker error when only CONFIG_CPU_S3C2442 is selected: arch/arm/plat-s3c24xx/built-in.o:(.data+0x13f4): undefined reference to `s3c_gpio_getpull_1up' arch/arm/plat-s3c24xx/built-in.o:(.data+0x13f8): undefined reference to `s3c_gpio_setpull_1up' The s3c2442 has pulldowns instead of pullups compared to the s3c2440. The method of controlling them is the same though. So this patch modifies the existing s3c_gpio_{get,set}pull_1up helper functions to take an additional parameter deciding whether the pin has a pullup or pulldown. The s3c_gpio_{get,set}pull_1{down,up} functions then wrap that functions passing either S3C_GPIO_PULL_UP or S3C_GPIO_PULL_DOWN. Furthermore this patch sets up the s3c24xx_gpiocfg_default.{get,set}_pull fields in the s3c244{0,2}_map_io function to the new pulldown helper functions. Based on patch from "Lars-Peter Clausen" <lars@metafoo.de> Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-11-25ARM: S3C24XX: Fix wrong s3c_gpio_cfgpullKukjin Kim
This patch fixes wrong s3c_gpio_cfgpull with s3c_gpio_setpull. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-11-23ASoC: Samsung: Rename AC97 platform deviceJassi Brar
Call the AC97 controller devices found in S3C, S5P and newer SoCs as 'samsung-ac97' rather than 's3c-ac97'. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ARM: Samsung: Define common audio-dma deviceJassi Brar
The ASoC uses common DMA driver for Audio devices. So it makes sense to a common audio-dma device shared across all platforms. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Rename DMA deviceJassi Brar
Some Samsung SoCs have a PCM(DSP) controller. So the name s3c24xx-pcm-audio for DMA driver is not very appropraite. This patch moves :- s3c24xx-pcm-audio -> samsung-audio Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (215 commits) ARM: memblock: setup lowmem mappings using memblock ARM: memblock: move meminfo into find_limits directly ARM: memblock: convert free_highpages() to use memblock ARM: move freeing of highmem pages out of mem_init() ARM: memblock: convert memory detail printing to use memblock ARM: memblock: use memblock to free memory into arm_bootmem_init() ARM: memblock: use memblock when initializing memory allocators ARM: ensure membank array is always sorted ARM: 6466/1: implement flush_icache_all for the rest of the CPUs ARM: 6464/2: fix spinlock recursion in adjust_pte() ARM: fix memblock breakage ARM: 6465/1: Fix data abort accessing proc_info from __lookup_processor_type ARM: 6460/1: ixp2000: fix type of ixp2000_timer_interrupt ARM: 6449/1: Fix for compiler warning of uninitialized variable. ARM: 6445/1: fixup TCM memory types ARM: imx: Add wake functionality to GPIO ARM: mx5: Add gpio-keys to mx51 babbage board ARM: imx: Add gpio-keys to plat-mxc mx31_3ds: Fix spi registration mx31_3ds: Fix the logic for detecting the debug board ...
2010-10-30ARM: Merge for-2637/s3c24xx/miscBen Dooks
2010-10-30ARM: Merge for-2637/s3c24xx/h1940Ben Dooks
