path: root/arch/arm/plat-s3c
2007-07-22[ARM] 4518/1: S3C: Rename watchdog configuration optionsBen Dooks
Rename the S3C24XX configuration options for the watchdog boot controls for moving to the arch/arm/plat-s3c moves. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORTBen Dooks
Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT to be CONFIG_S3C_LOWLEVEL_UART_PORT as we move to using plat-s3c for base of S3C operations. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4511/1: S3C: updated LLSERIAL Kconfig defines for CPU supportBen Dooks
Update the Kconfig to create configuration options based on which CPUs are supported for the low level serial code. This means that the debug macros can be optimised for the type(s) of CPU that are being used. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4509/1: S3C: Create initial arch/arm/plat-s3cBen Dooks
Create the initial arch/arm/plat-s3c directory and start linking it into the arch/arm build heirarchy ready to receive the generic parts of the S3C24XX support to be used when adding S3C6400 devices. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
