path: root/arch/arm/plat-s5p
2011-10-21ARM: S5P: fix offset calculation on gpio-interruptMarek Szyprowski
Offsets of the irq controller registers were calculated correctly only for first GPIO bank. This patch fixes calculation of the register offsets for all GPIO banks. Reported-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-26ARM: S5P: fix incorrect loop iterator usage on gpio-interruptMarek Szyprowski
Loop iterator value after terminating list_for_each_entry() is not NULL. This patch fixes incorrect iterator usage in GPIO interrupt code for SAMSUNG S5P platforms. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: S5P: fix bug in spdif_clk_get_rateNaveen Krishna Chatradhi
Should be passing the parent clk object when calling for parent rate. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: S5P: add required chained_irq_enter/exit to gpio-int codeMarek Szyprowski
This patch adds chained IRQ enter/exit functions to gpio interrupt handler in order to function correctly on primary controllers with different methods of flow control. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-21ARM: S5P: Add support for MFC deviceKamil Debski
Add support for MFC device to plat-s5p, mach-exynos4, mach-s5pv210: - clock support - memory mapping and reserving - s5p_device_mfc platform device Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add platform device and helper functions for FIMDJonghun Han
This patch adds platform device s5p_device_fimd0 for EXYNOS4 FIMD0. EXYNOS4 has two FIMDs(FIMD0, FIMD1). FIMD1 will be added later. Some definitions used to enable EXYNOS4 FIMD0 are added. Signed-off-by: Jonghun Han <jonghun.han@samsung.com> Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21Merge branch 'next-samsung-clkdev-fix' into next-samsung-develKukjin Kim
2011-07-21clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0Chanwoo Choi
Convert the S5PV210/S5P64X0 32-bit down-counting clocksource to the generic mmio clocksource infrastructure Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: SAMSUNG: Move duplicate code for SPDIF opsNaveen Krishna Chatradhi
Move the duplicated code for SPDIF ops from S5PV210 and S5PC100. So, the same can be used in EXYNOS4. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21Merge branch 'next-samsung-clkdev-fix' into next-samsung-cleanupKukjin Kim
2011-07-20ARM: EXYNOS4: Add external GIC io memory mappingChanghwan Youn
This patch adds external GIC io memory mapping to support external GIC on EXYNOS4. Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: S5P: Added selection DEV_PWM for HRTKukjin Kim
Basically, the SAMSUNG_DEV_PWM is required to use s5p-time.c for HRT. Reported-by: Marek Szyprowski<m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: S5P64X0: Add clkdev supportThomas Abraham
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-12Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: pcmcia: pxa2xx/vpac270: free gpios on exist rather than requesting ARM: pxa/raumfeld: fix device name for codec ak4104 ARM: pxa/raumfeld: display initialisation fixes ARM: pxa/raumfeld: adapt to upcoming hardware change ARM: pxa: fix gpio_to_chip() clash with gpiolib namespace genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd) arm: mach-vt8500: add forgotten irq_data conversion ARM: pxa168: correct nand pmu setting ARM: pxa910: correct nand pmu setting ARM: pxa: fix PGSR register address calculation
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-07genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd)Simon Guinot
This fixes a regression introduced by e59347a "arm: orion: Use generic irq chip". Depending on the device, interrupts acknowledgement is done by setting or by clearing a dedicated register. Replace irq_gc_ack() with some {set,clr}_bit variants allows to handle both cases. Note that this patch affects the following SoCs: Davinci, Samsung and Orion. Except for this last, the change is minor: irq_gc_ack() is just renamed into irq_gc_ack_set_bit(). For the Orion SoCs, the edge GPIO interrupts support is currently broken. irq_gc_ack() try to acknowledge a such interrupt by setting the corresponding cause register bit. The Orion GPIO device expect the opposite. To fix this issue, the irq_gc_ack_clr_bit() variant is used. Tested on Network Space v2. Reported-by: Joey Oravec <joravec@drewtech.com> Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-07-06ARM: S5P: Fix bug on init of PWMTimers for HRTimerSangbeom Kim
This patch fixes following. <6>[ 0.000000] sched_clock: 32 bits at 33MHz, ... <6>[ 128.651309] Calibrating delay loop... There is a big jump. The reason is that PWM Timer which is for HRTimer was used before its initialization. So this patch changes its order and following is kernel boot log message after this. <6>[ 0.000000] sched_clock: 32 bits at 33MHz, ... <6>[ 0.000088] Calibrating delay loop... Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-03ARM: SAMSUNG: Remove unused onenand plat functionsKyungmin Park
There's no place to use these functions. and actually no need to set the platform data. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-01ARM: S5P: Should be S3C_VA_USB_HSPHY instead of S5P_VA_XXKukjin Kim
Basically, other S3C SoCs and S5PC100 use 'S3C_VA_USB_HSPHY' commonly. It should be changed to 'S3C_VA_USB_HSPHY' for common usage and others. Now happens build error on S5PC100. Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-05-25Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/Kconfig arch/arm/mach-exynos4/mach-nuri.c
2011-05-23Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (137 commits) ARM: bcmring: convert to use sp804 clockevents ARM: bcmring: convert to sp804 clocksource ARM: 6912/1: bcmring: Add clkdev table in init_early clockevents: ARM sp804: obtain sp804 timer rate via clks clockevents: ARM sp804: allow clockevent name to be specified clocksource: ARM sp804: obtain sp804 timer rate via clks clocksource: ARM sp804: allow clocksource name to be specified clocksource: convert OMAP1 to 32-bit down counting clocksource clocksource: convert MXS timrotv2 to 32-bit down counting clocksource clocksource: convert SPEAr platforms 16-bit up counting clocksource clocksource: convert Integrator/AP 16-bit down counting clocksource clocksource: convert W90x900 24-bit down counting clocksource clocksource: convert ARM 32-bit down counting clocksources clocksource: convert ARM 32-bit up counting clocksources clocksource: add common mmio clocksource ARM: update sa1100 to reflect PXA updates ARM: omap1: convert to using readl/writel instead of volatile struct ARM: omap1: delete useless interrupt handler ARM: s5p: consolidate selection of timer register ARM: 6939/1: fix missing 'cpu_relax()' declaration ...
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-23Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ns9xxx/include/mach/uncompress.h
2011-05-23ARM: s5p: consolidate selection of timer registerRussell King
s5p duplicates the runtime selection of the timer register three times. Move this out into a separate function. FIXME: It is unclear whether this code needs to support true runtime selection of the timer register, or whether it can be selected once at init time. Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: S5P6442: Removing ARCH_S5P6442Kukjin Kim
2011-05-09ARM: SAMSUNG: Convert irq-vic-timer to generic irq chipThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-09ARM: SAMSUNG: S5P: Convert irq-gpioint to generic irq chipThomas Gleixner
2011-04-24ARM / Samsung: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by Samsung platforms with struct syscore_ops objects that are simpler. This generally reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com>
2011-04-19Merge 2.6.39-rc4 into usb-nextGreg Kroah-Hartman
This is needed to help resolve some xhci issues and other minor differences. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14ARM: S5P: Remove unused s3c_pm_check_resume_pinAbhilash Kesavan
The s3c_pm_check_resume_pin() is not being used and can be safely removed to fix the build warning. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-04-13ARM: EXYNOS4: Add usb host phy controlJoonyoung Shim
EXYNOS4 has 2 phys for usb host and usb device. This patch supports to control usb host phy of EXYNOS4. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13ARM: S5P: Add usb ehci deviceJoonyoung Shim
This patch adds usb ehci device definition for samsung s5p cpus. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28ARM: SAMSUNG: Fix CPU idmaskKukjin Kim
This patch fixes CPU idmask of S5P64X0 and EXYNOS4210 and its comparison method because just want to use CPU id for it. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-15ARM: EXYNOS4: Implement Clock gating for System MMUKyongHo Cho
This patch includes the implementation of the clock gating for System MMU. Initially, all System MMUs are not asserted the system clock. Asserting the system clock to a System MMU is enabled only when s5p_sysmmu_enable() is called. Likewise, it is disabled only when s5p_sysmmu_disable() is called. Therefore, clock gating on System MMUs are still invisible to the outside of the System MMU driver. Signed-off-by: KyongHo Cho <pullip.cho@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-15ARM: EXYNOS4: Enhancement of System MMU driverKyongHo Cho
This patch includes the following enhancements for System MMU: - Enhanced readability - Removal of unused data structures or their members - Simplified function definitions - Corrections of some logical errors - Full compliance with Linux coding style - Simpler way of registering callback functions of System MMU faults Signed-off-by: KyongHo Cho <pullip.cho@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-15ARM: S5P: Add function to register gpio interrupt bank dataMarek Szyprowski
This patch removes all global data from common s5p gpio interrupt handler code. This enables to reuse this code on EXYNOS4 platform. Instead of global data (IRQ_GPIOINT interrupt number, S5P_GPIOINT_GROUP_MAXNR groups count), a s5p_register_gpioint_bank() function is introduced. It is aimed to be called from gpiolib init. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-15ARM: S5P: Cleanup S5P gpio interrupt codeMarek Szyprowski
This patch performs a global cleanup in s5p gpio interrupt support code. The code is prepared for upcoming support for gpio interrupts on EXYNOS4 platform, which has 2 gpio banks (regions) instead of one (like on S5PC110 and S5PC100). Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12ARM: S5P: Add platform definitions for FIMC3Sylwester Nawrocki
Add support for fourth FIMC platform device definition and define resources for FIMC modules on EXYNOS4 machines. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12ARM: S5P: Update defconfig for HRT supportSangbeom Kim
This patch updates s5pv210_defconfig and s5p64x0_defconfig for HRT support and CONFIG_S5P_HRT is used for its configuration. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12ARM: S5P: HRT supportSangbeom Kim
This patch adds support HR-Timer(High Resolution Timer) and dynamic tick system for S5P SoCs. There are many clock sources for HR-Timer on S5P SoCs. The PWM timer, RTC, System Timer, and MCT can be used for clock source. This patch can only support PWM timer for clock source of S5P64X0 and S5PV210. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11ARM: S5P: Add support for common MIPI CSIS/DSIM D-PHY controlSylwester Nawrocki
Add common code for MIPI-CSIS and MIPI-DSIM drivers to support their corresponding D-PHY's enable and reset control. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11ARM: S5P: Extend MIPI-CSIS platform_data with the PHY control callbackSylwester Nawrocki
Extend MIPI-CSIS driver's platform data structure with a callback for D-PHY enable and reset control. Also add a flag indicating whether the external MIPI-CSI (VDD18_MIPI) power supply should be managed in the driver through the "vdd" power supply. On some boards this regulator may be a fixed voltage regulator without an inhibit function. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11ARM: S5P: Rename MIPI-CSIS driver header and update CopyrightSylwester Nawrocki
