path: root/arch/arm/plat-samsung/dev-i2c3.c
2011-07-21ARM: SAMSUNG: Cleanup I2C code in plat-samsungNaveen Krishna Chatradhi
Removes the duplication of default info structure in dev-i2c[0 ~ 7].c files Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: SAMSUNG: Use generic set_plat_data functionNaveen Krishna Chatradhi
Calls the generic s3c_set_platdata function instead. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PV310: Add I2C channel 3, 4, 5, 6, and 7 device supportKyungmin Park
S5PV310 and S5PC210 support more I2C devices than previous SoCs. Add the device support code for them. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
