[ Upstream commit 6862fdf2201ab67cd962dbf0643d37db909f4860 ]
"S3C2410 PM Suspend Memory CRC" feature (controlled by
SAMSUNG_PM_CHECK config option) is incompatible with highmem
(uses phys_to_virt() instead of proper mapping) which is used by
the majority of Exynos boards. The issue manifests itself in OOPS
on affected boards, i.e. on Odroid-U3 I got the following one:
Unable to handle kernel paging request at virtual address f0000000
pgd = 1c0f9bb4
[f0000000] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[<c0458034>] (crc32_le) from [<c0121f8c>] (s3c_pm_makecheck+0x34/0x54)
[<c0121f8c>] (s3c_pm_makecheck) from [<c0121efc>] (s3c_pm_run_res+0x74/0x8c)
[<c0121efc>] (s3c_pm_run_res) from [<c0121ecc>] (s3c_pm_run_res+0x44/0x8c)
[<c0121ecc>] (s3c_pm_run_res) from [<c01210b8>] (exynos_suspend_enter+0x64/0x148)
[<c01210b8>] (exynos_suspend_enter) from [<c018893c>] (suspend_devices_and_enter+0x9ec/0xe74)
[<c018893c>] (suspend_devices_and_enter) from [<c0189534>] (pm_suspend+0x770/0xc04)
[<c0189534>] (pm_suspend) from [<c0186ce8>] (state_store+0x6c/0xcc)
[<c0186ce8>] (state_store) from [<c09db434>] (kobj_attr_store+0x14/0x20)
[<c09db434>] (kobj_attr_store) from [<c02fa63c>] (sysfs_kf_write+0x4c/0x50)
[<c02fa63c>] (sysfs_kf_write) from [<c02f97a4>] (kernfs_fop_write+0xfc/0x1e4)
[<c02f97a4>] (kernfs_fop_write) from [<c027b198>] (__vfs_write+0x2c/0x140)
[<c027b198>] (__vfs_write) from [<c027b418>] (vfs_write+0xa4/0x160)
[<c027b418>] (vfs_write) from [<c027b5d8>] (ksys_write+0x40/0x8c)
[<c027b5d8>] (ksys_write) from [<c0101000>] (ret_fast_syscall+0x0/0x28)
Add PLAT_S3C24XX, ARCH_S3C64XX and ARCH_S5PV210 dependencies to
SAMSUNG_PM_CHECK config option to hide it on Exynos platforms.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Currently there is no user of DMC and CMU SFR offsets so we can safely
remove mapping of their SFR address space and cleanup related offset
macros from mach-exynos.
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Pull ARM SoC platform updates from Olof Johansson:
"Improved and new platform support for various SoCs:
New SoC support:
- Broadcom BCM23550
- Freescale i.MX7Solo
- Qualcomm MDM9615
- Renesas r8a7792
Improvements:
- convert clps711x to multiplatform
- debug uart improvements for Atmel platforms
- Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram
- OMAP tweaks and improvements to hwmod
- OMAP support for kexec on SMP"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: davinci: fix build break because of undeclared dm365_evm_snd_data
ARM: s3c64xx: smartq: Avoid sparse warnings
ARM: sti: Implement dummy L2 cache's write_sec
ARM: STi: Update machine _namestr to be more generic.
arm: meson: explicitly select clk drivers
ARM: tango: add Suspend-to-RAM support
ARM: hisi: consolidate the hisilicon machine entries
ARM: tango: fix CONFIG_HOTPLUG_CPU=n build
MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry
MAINTAINERS: Update BCM63XX entry
MAINTAINERS: Add NS2 entry
MAINTAINERS: Fix nsp false-positives
MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries
ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs
ARM: clps711x: Switch to MULTIPLATFORM
ARM: clps711x: Remove boards support
ARM: clps711x: Add basic DT support
ARM: clps711x: Reduce static map size
ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu
ARM: oxnas: Change OX810SE default driver config
Pull ARM SoC cleanups from Olof Johansson:
"The cleanup branch keeps going down in size as we've completed a lot
of the major legacy platform removals and conversions.
A handful of changes this time around, some of the themes or larger
sets are:
- A bunch of i.MX cleanups around platform detection, init call cleanups
- Misc fixes of missing/implicit includes
- Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
ARM: mps2: fix typo
ARM: s3c64xx: avoid warning about 'struct device_node'
bus: mvebu-mbus: make mvebu_mbus_syscore_ops static
bus: mvebu-mbus: fix __iomem on register pointers
ARM: tegra: Remove board_init_funcs array
ARM: iop: Fix indentation
ARM: imx: remove cpu_is_mx*()
ARM: imx: remove last call to cpu_is_mx5*
ARM: imx: rework mx27_pm_init() call
ARM: imx: deconstruct mx3_idle
ARM: imx: deconstruct mxc_rnga initialization
ARM: imx: remove cpu_is_mx1 check
ARM: i.MX: Do not explicitly call l2x0_of_init()
ARM: i.MX: system.c: Tweak prefetch settings for performance
ARM: i.MX: system.c: Replace magic numbers
ARM: i.MX: system.c: Remove redundant errata 752271 code
ARM: i.MX: system.c: Convert goto to if statement
ARM: Kirkwood: fix kirkwood_pm_init() declaration/type
ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static
ARM: orion5x: make orion5x_legacy_handle_irq static
The iomem passed to s5p_init_cpu is used as read-only.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The declaration of s5p_init_cpu() in arch/arm/mach-exynos/common.h
is not included in the platform file arch/arm/plat-samsung/cpu.c
which generates a warning.
Fix the following warning by moving the declaration to somewhere
both the machine and platform code can get to it, and including
the right files as necessary:
arch/arm/plat-samsung/cpu.c:47:13: warning: symbol 's5p_init_cpu' was not declared. Should it be static?
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Fix the use of __raw accesors in pm-common.c to use the _relaxed
variants to deal with any issues due to endian related fetches.
If the system is built for big endian, then the CPU identificaiton register
will be read in the wrong order. Fix this by using readl_relaxed() on the
register.
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into fixes
Two fixes for v4.7 cycle for build issues:
1. Fix samsung-keypad build error if INPUT is selected as module.
The error though depends on some uncommon build settings so it
is not as easy to trigger.
2. Get rid of 'samsung_device_dma_mask' defined but not used warning.
* tag 'samsung-fixes-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: exynos: don't select keyboard driver
ARM: samsung: improve static dma_mask definition
Fix some language typos in comments.
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
When no DMA master devices are part of the kernel configuration,
we get a warning about the unused dma mask definition:
arch/arm/plat-samsung/devs.c:71:12: error: 'samsung_device_dma_mask' defined but not used [-Werror=unused-variable]
static u64 samsung_device_dma_mask = DMA_BIT_MASK(32);
We could simply mark this as __maybe_unused to shut up that warning,
but a nicer solution seems to be to have a separate mask for each
device. The advantage is that a driver that happens to call
dma_set_mask() on one device doesn't implicitly change the mask
for the other devices as well. This is more of a theoretical
problem, as obviously nothing does it for the devices in this
file (or they would have always been broken), but it feels
cleaner that way.
The definition works by creating an array in place so we can take
the address of it and let the compiler generate a hidden symbol
for it at compile time.
As now we have dedicated driver for SROM controller, it will take care
of saving register banks during S2R so we can safely remove these
settings from mach-exynos.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
[k.kozlowski: Need to select also SAMSUNG_MC]
Pull MTD updates from Brian Norris:
"NAND:
- Add sunxi_nand randomizer support
- begin refactoring NAND ecclayout structs
- fix pxa3xx_nand dmaengine usage
- brcmnand: fix support for v7.1 controller
- add Qualcomm NAND controller driver
SPI NOR:
- add new ls1021a, ls2080a support to Freescale QuadSPI
- add new flash ID entries
- support bottom-block protection for Winbond flash
- support Status Register Write Protect
- remove broken QPI support for Micron SPI flash
JFFS2:
- improve post-mount CRC scan efficiency
General:
- refactor bcm63xxpart parser, to later extend for NAND
- add writebuf size parameter to mtdram
Other minor code quality improvements"
* tag 'for-linus-20160324' of git://git.infradead.org/linux-mtd: (72 commits)
mtd: nand: remove kerneldoc for removed function parameter
mtd: nand: Qualcomm NAND controller driver
dt/bindings: qcom_nandc: Add DT bindings
mtd: nand: don't select chip in nand_chip's block_bad op
mtd: spi-nor: support lock/unlock for a few Winbond chips
mtd: spi-nor: add TB (Top/Bottom) protect support
mtd: spi-nor: add SPI_NOR_HAS_LOCK flag
mtd: spi-nor: use BIT() for flash_info flags
mtd: spi-nor: disallow further writes to SR if WP# is low
mtd: spi-nor: make lock/unlock bounds checks more obvious and robust
mtd: spi-nor: silently drop lock/unlock for already locked/unlocked region
mtd: spi-nor: wait for SR_WIP to clear on initial unlock
mtd: nand: simplify nand_bch_init() usage
mtd: mtdswap: remove useless if (!mtd->ecclayout) test
mtd: create an mtd_oobavail() helper and make use of it
mtd: kill the ecclayout->oobavail field
mtd: nand: check status before reporting timeout
mtd: bcm63xxpart: give width specifier an 'int', not 'size_t'
mtd: mtdram: Add parameter for setting writebuf size
mtd: nand: pxa3xx_nand: kill unused field 'drcmr_cmd'
Pull ARM SoC platform updates from Arnd Bergmann:
"Newly added support for additional SoCs:
- Axis Artpec-6 SoC family
- Allwinner A83T SoC
- Mediatek MT7623
- NXP i.MX6QP SoC
- ST Microelectronics stm32f469 microcontroller
New features:
- SMP support for Mediatek mt2701
- Big-endian support for NXP i.MX
- DaVinci now uses the new DMA engine dma_slave_map
- OMAP now uses the new DMA engine dma_slave_map
- earlyprintk support for palmchip uart on mach-tango
- delay timer support for orion
Other:
- Exynos PMU driver moved out to drivers/soc/
- Various smaller updates for Renesas, Xilinx, PXA, AT91, OMAP,
uniphier"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: uniphier: rework SMP code to support new System Bus binding
ARM: uniphier: add missing of_node_put()
ARM: at91: avoid defining CONFIG_* symbols in source code
ARM: DRA7: hwmod: Add data for eDMA tpcc, tptc0, tptc1
ARM: imx: Make reset_control_ops const
ARM: imx: Do L2 errata only if the L2 cache isn't enabled
ARM: imx: select ARM_CPU_SUSPEND only for imx6
dmaengine: pxa_dma: fix the maximum requestor line
ARM: alpine: select the Alpine MSI controller driver
ARM: pxa: add the number of DMA requestor lines
dmaengine: mmp-pdma: add number of requestors
dma: mmp_pdma: Add the #dma-requests DT property documentation
ARM: OMAP2+: Add rtc hwmod configuration for ti81xx
ARM: s3c24xx: Avoid warning for inb/outb
ARM: zynq: Move early printk virtual address to vmalloc area
ARM: DRA7: hwmod: Add custom reset handler for PCIeSS
ARM: SAMSUNG: Remove unused register offset definition
ARM: EXYNOS: Cleanup header files inclusion
drivers: soc: samsung: Enable COMPILE_TEST
MAINTAINERS: Add maintainers entry for drivers/soc/samsung
This patch cleans up various map.h under mach-exynos, mach-s3c24xx and
plat-samsung by removing unused register offset. This patch also does a
minor nitpick of changing EXYNOS4 to EXYNOS from comment section of
header file "mach-exynos/include/mach/map.h".
Use to_platform_device() instead of open-coding it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Change s3c_pm_run_res() to check with IORESOURCE_SYSTEM_RAM,
instead of strcmp() with "System RAM", to walk through System
RAM ranges in the iomem table.
No functional change is made to the interface.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: linux-mm <linux-mm@kvack.org>
Cc: linux-samsung-soc@vger.kernel.org
Link: http://lkml.kernel.org/r/1453841853-11383-12-git-send-email-bp@alien8.de
The s3c2410 is allowing board data to overload the default ECC layout
defined inside the driver, but this feature is not used by board
specific definitions.
Kill this field so that we can easily move to a model where ecclayout
are dynamically allocated by the NAND controller driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Pull ARM SoC multiplatform code updates from Arnd Bergmann:
"This branch is the culmination of 5 years of effort to bring the ARMv6
and ARMv7 platforms together such that they can all be enabled and
boot the same kernel. It has been a tremendous amount of cleanup and
refactoring by a huge number of people, and creation of several new
(and major) subsystems to better abstract out all the platform details
in an appropriate manner.
The bulk of this branch is a large patchset from Arnd that brings
several of the more minor and older platforms we have closer to
multiplatform support. Among these are MMP, S3C64xx, Orion5x, mv78xx0
and realview Much of this is moving around header files from old mach
directories, but there are also some cleanup patches of debug_ll
(lowlevel debug per-platform options) and other parts.
Linus Walleij also has some patchs to clean up the older ARM Realview
platforms by finally introducing DT support, and Rob Herring has some
for ARM Versatile which is now DT-only. Both of these platforms are
now multiplatform.
Finally, a couple of patches from Russell for Dove PMU, and a fix from
Valentin Rothberg for Exynos ADC, which were rebased on top of the
series to avoid conflicts"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: realview: don't select SMP_ON_UP for UP builds
ARM: s3c: simplify s3c_irqwake_{e,}intallow definition
ARM: s3c64xx: fix pm-debug compilation
iio: exynos-adc: fix irqf_oneshot.cocci warnings
ARM: realview: build realview-dt SMP support only when used
ARM: realview: select apropriate targets
ARM: realview: clean up header files
ARM: realview: make all header files local
ARM: no longer make CPU targets visible separately
ARM: integrator: use explicit core module options
ARM: realview: enable multiplatform
ARM: make default platform work for NOMMU
ARM: debug-ll: move DEBUG_LL_UART_EFM32 to correct Kconfig location
ARM: defconfig: use correct debug_ll settings
ARM: versatile: convert to multi-platform
ARM: versatile: merge mach code into a single file
ARM: versatile: switch to DT only booting and remove legacy code
ARM: versatile: add DT based PCI detection
ARM: pxa: mark ezx structures as __maybe_unused
ARM: pxa: mark raumfeld init functions as __maybe_unused
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"We've had quite busy weeks in this cycle. Looking at ALSA core, the
significant changes are a few fixes wrt timer and sequencer ioctls
that have been revealed by fuzzer recently. Other than that, ASoC
core got a few updates about DAI link handling, but these are rather
straightforward refactoring.
In drivers scene, ASoC received quite lots of new drivers in addition
to bunch of updates for still ongoing Intel Skylake support and
topology API. HD-audio gained a new HDMI/DP hotplug notification via
component. FireWire got a pile of code refactoring/updates with
SCS.1x driver integration.
More highlights are shown below.
[ NOTE: this contains also many commits for DRM. This is due to the
pull of drm stable branch into sound tree, as the base of i915 audio
component work for HD-audio. The highlights below don't contain
these DRM changes, as these are supposed to be pulled via drm tree
in anyway sooner or later. ]
Core:
- Handful fixes to harden ALSA timer and sequencer ioctls against
races reported by syzkaller fuzzer
- Irq description string can be unique to each card; only for
HD-audio for now
ASoC:
- Conversion of the array of DAI links to a list for supporting
dynamically adding and removing DAI links
- Topology API enhancements to make everything more component based
and being able to specify PCM links via topology
- Some more fixes for the topology code, though it is still not final
and ready for enabling in production; we really need to get to the
point where that can be done
- A pile of changes for Intel SkyLake drivers which hopefully deliver
some useful initial functionality for systems with this chipset,
though there is more work still to come
- Lots of new features and cleanups for the Renesas drivers
- ANC support for WM5110
- New drivers: Imagination Technologies IPs, Atmel class D speaker,
Cirrus CS47L24 and WM1831, Dialog DA7128, Realtek RT5659 and
RT56156, Rockchip RK3036, TI PC3168A, and AMD ACP
- Rename PCM1792a driver to be generic pcm179x
HD-Audio:
- Use audio component for i915 HDMI/DP hotplug handling
- On-demand binding with i915 driver
- bdl_pos_adj parameter adjustment for Baytrail controllers
- Enable power_save_node for CX20722; this shouldn't lead to
regression, hopefully
- Kabylake HDMI/DP codec support
- Quirks for Lenovo E50-80, Dell Latitude E-series, and other Dell
machines
- A few code refactoring
FireWire:
- Lots of code cleanup and refactoring
- Integrate the support of SCS.1x devices into snd-oxfw driver;
snd-scs1x driver is obsoleted
USB-audio:
- Fix possible NULL dereference at disconnection
- A regression fix for Native Instruments devices
Misc:
- A few code cleanups of fm801 driver"
* tag 'sound-4.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (722 commits)
ALSA: timer: Code cleanup
ALSA: timer: Harden slave timer list handling
ALSA: hda - Add fixup for Dell Latitidue E6540
ALSA: timer: Fix race among timer ioctls
ALSA: hda - add codec support for Kabylake display audio codec
ALSA: timer: Fix double unlink of active_list
ALSA: usb-audio: Fix mixer ctl regression of Native Instrument devices
ALSA: hda - fix the headset mic detection problem for a Dell laptop
ALSA: hda - Fix white noise on Dell Latitude E5550
ALSA: hda_intel: add card number to irq description
ALSA: seq: Fix race at timer setup and close
ALSA: seq: Fix missing NULL check at remove_events ioctl
ALSA: usb-audio: Avoid calling usb_autopm_put_interface() at disconnect
ASoC: hdac_hdmi: remove unused hdac_hdmi_query_pin_connlist
ASoC: AMD: Add missing include file
ALSA: hda - Fixup inverted internal mic for Lenovo E50-80
ALSA: usb: Add native DSD support for Oppo HA-1
ASoC: Make aux_dev more like a generic component
ASoC: bcm2835: cleanup includes by ordering them alphabetically
ASoC: AMD: Manage ACP 2.x SRAM banks power
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi updates from Mark Brown:
"A quiet release for SPI, not even many driver updates:
- Add a dummy loopback driver for use in exercising framework
features during development.
- Move the test utilities to tools/ and add support for transferring
data to and from a file instead of stdin and stdout to spidev_test.
- Support for Mediatek MT2701 and Renesas AG5 deices"
* tag 'spi-v4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (69 commits)
spi: loopback: fix typo in MODULE_PARM_DESC
spi: sun4i: Prevent chip-select from being activated twice before a transfer
spi: loopback-test: spi_check_rx_ranges can get always done
spi: loopback-test: rename method spi_test_fill_tx to spi_test_fill_pattern
spi: loopback-test: write rx pattern also when running without tx_buf
spi: fsl-espi: expose maximum transfer size limit
spi: expose master transfer size limitation.
spi: zynq: use to_platform_device()
spi: cadence: use to_platform_device()
spi: mediatek: Add spi support for mt2701 IC
spi: mediatek: merge all identical compat to mtk_common_compat
spi: mtk: Add bindings for mediatek MT2701 soc platform
spi: mediatek: Prevent overflows in FIFO transfers
spi: s3c64xx: Remove unused platform_device_id entries
spi: use to_spi_device
spi: dw: Use SPI_TMOD_TR rather than magic const 0 to set tmode
spi: imx: defer spi initialization, if DMA engine is
spi: imx: return error from dma channel request
spi: imx: enable loopback only for ECSPI controller family
spi: imx: fix loopback mode setup after controller reset
For a long time, gcc has warned about odd configurations on s3c64xx:
In file included from arch/arm/plat-samsung/pm.c:34:0:
arch/arm/mach-s3c64xx/include/mach/pm-core.h:61:0: warning: "s3c_irqwake_eintallow" redefined
#define s3c_irqwake_eintallow ((1 << 28) - 1)
In file included from arch/arm/plat-samsung/pm.c:33:0:
arch/arm/plat-samsung/include/plat/pm.h:49:0: note: this is the location of the previous definition
#define s3c_irqwake_eintallow 0
The definitions of s3c_irqwake_intallow and s3c_irqwake_eintallow are a
bit consistent between the various platforms. Things have become easier
now that it's only s3c24xx and s3c64xx that use them at all, so I've tried
to rearrange the definitions to make it more obvious what is going on.
Most of the code for the s3c64xx platform is only used when booting
with ATAGS based board files, but not when using device-tree.
This tries to identify all the s3c64xx specific code that is
unneeded when CONFIG_ATAGS is not set, so we can build a smaller
DT-only kernel if configured that way.
All board support is still left intact but now depends on the
CONFIG_ATAGS symbol that users may intentionally disable.
After all preparation work is done, we can finally move the Kconfig
option for s3c64xx into ARCH_MULTIPLATFORM. This implies allowing
SAMSUNG_ATAGS for multiplatform again, but now disallowing the
ADC driver below it, as that still has dependencies on header files.
The old ADC and touchscreen drivers are not compatible with
multiplatform support, but we can use the exynos-adc driver
as a replacement.
This changes the common device creation functions for s3c64xx
(but not s3c24xx for now) to use the new driver. To do this,
we have to pass the interrupt resources in the opposite order
and pass the platform data in the adc device node.
This is another prerequisite for enabling multiplatform
support, and it is the part I am least certain about.
I assume it will cause the extra boot message "Cannot
allocate irq_descs @ IRQ%d, assuming pre-allocated" to
be printed, but otherwise work ok. This definitely needs
to be tested on real hardware to see if it works.
In a multiplatform kernel, each initcall is run regardless
of the platform it is meant for, so it must not attempt to
access SoC-specific registers.
This adds 'if (soc_is_s3c64xx)' to all initcalls that are
specific to the s3c64xx platform, to prevent them from breaking
other platforms once we can build them into a combined kernel.
The gpio-samsung driver is special in the sense that it
interacts directly in multiple ways with the legacy platform
code for the s3c24xx and s3c64xx platforms. In contrast,
all devicetree based machines for Samsung, including the
ones on those two SoC families use a different driver.
The header files that define the interface between the platform
code and the gpio driver are not visible when building a
kernel for ARCH_MULTIPLATFORM, which prevents us from
turning on this option for s3c64xx.
To work around this, we now move the driver back into platform
code, from where it was originally moved to as part of commit
1b39d5f2cc5c28 ("gpio/samsung: gpio-samsung.c to support
Samsung GPIOs").
The long-term plan for this driver would be to remove it
entirely, after all Samsung machines have been converted
over to boot from DT, but there is currently no timeline
for when that might happen.
As we are now passing the filter data as pointers to the drivers,
we can take the final step and also pass the filter function the
same way. I'm keeping this change separate, as there it's less
obvious that this is a net win.
Upsides of this are:
- The ASoC drivers are completely independent from the DMA engine
implementation, which simplifies the Kconfig logic and in theory
allows the same sound drivers to be built in a kernel that supports
different kinds of dmaengine drivers.
- Consistency with other subsystems and drivers
On the other hand, we have a few downsides:
- The s3c24xx-dma driver now needs to be built-in for the ac97 platform
device to be instantiated on s3c2440.
- samsung_dmaengine_pcm_config cannot be marked 'const' any more
because the filter function pointer needs to be set at runtime.
This is safe as long we don't have multiple different DMA engines
in thet same system at runtime, but is nonetheless ugly.
Signed-off-by: Mark Brown <broonie@kernel.org>
The s3c64xx platform data already contains a pointer to the
DMA filter function, but not to the associated data.
This simplifies the code and makes it more generic by
passing the data along with the filter function like
we do for other drivers.
This is a minor cleanup to make the s3c2412-i2s and s3c24xx-i2s
drivers independent of the mach/dma.h header file and to allow
removing the dependency on the specific dmaengine driver in the
next patch.
As a side not, only the s3c24xx-i2s driver seems to still be
used, while the definition of the s3c2412-i2s platform device was
removed in commit 6d259a25b56d ("ARM: SAMSUNG: use static
declaration when it is not used in other files") after it had
never been referenced since its introduction in f0fba2ad1b6b
("ASoC: multi-component - ASoC Multi-Component Support").
Apparently it should have been used by mach-jive.c, but that
never happened. My patch at this point leaves the current state
unchanged, we can decide whether to fix or delete the jive
driver and s3c2412-i2s another time.
ARM64 allmodconfig produces a bunch of warnings when building the
samsung ASoC code:
sound/soc/samsung/dmaengine.c: In function 'samsung_asoc_init_dma_data':
sound/soc/samsung/dmaengine.c:53:32: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
playback_data->filter_data = (void *)playback->channel;
sound/soc/samsung/dmaengine.c:60:31: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
capture_data->filter_data = (void *)capture->channel;
We could easily shut up the warning by adding an intermediate cast,
but there is a bigger underlying problem: The use of IORESOURCE_DMA
to pass data from platform code to device drivers is dubious to start
with, as what we really want is a pointer that can be passed into
a filter function.
Note that on s3c64xx, the pl08x DMA data is already a pointer, but
gets cast to resource_size_t so we can pass it as a resource, and it
then gets converted back to a pointer. In contrast, the data we pass
for s3c24xx is an index into a device specific table, and we artificially
convert that into a pointer for the filter function.
Let's not mix platform_data headers with the core headers. Instead, let's
create a subdir at linux/platform_data and move the headers to that
common place, adding it to MAINTAINERS.
The headers were moved with:
mkdir include/linux/platform_data/media/; git mv include/media/gpio-ir-recv.h include/media/ir-rx51.h include/media/mmp-camera.h include/media/omap1_camera.h include/media/omap4iss.h include/media/s5p_hdmi.h include/media/si4713.h include/media/sii9234.h include/media/smiapp.h include/media/soc_camera.h include/media/soc_camera_platform.h include/media/timb_radio.h include/media/timb_video.h include/linux/platform_data/media/
And the references fixed with this script:
MAIN_DIR="linux/platform_data/"
PREV_DIR="media/"
DIRS="media/"
echo "Checking affected files" >&2
for i in $DIRS; do
for j in $(find include/$MAIN_DIR/$i -type f -name '*.h'); do
n=`basename $j`
git grep -l $n
done
done|sort|uniq >files && (
echo "Handling files..." >&2;
echo "for i in \$(cat files|grep -v Documentation); do cat \$i | \\";
cd include/$MAIN_DIR;
for j in $DIRS; do
for i in $(ls $j); do
echo "perl -ne 's,(include [\\\"\\<])$PREV_DIR($i)([\\\"\\>]),\1$MAIN_DIR$j\2\3,; print \$_' |\\";
done;
done;
echo "cat > a && mv a \$i; done";
echo "Handling documentation..." >&2;
echo "for i in MAINTAINERS \$(cat files); do cat \$i | \\";
for j in $DIRS; do
echo " perl -ne 's,include/$PREV_DIR($i)\b,include/$MAIN_DIR$j\1,; print \$_' |\\";
done;
done;
) >script && . ./script
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
this driver has long ago became dwc2.ko with
both peripheral and host roles, there's no point
in keeping the old function names.
Acked-by: John Youn <johnyoun@synopsys.com>
Tested-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Since keypad-core header is not used, this patch removes it.
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Joonyoung Shim <jy0922.shim@samsung.com>
This patch moves watchdog-reset header file into mach-s3c64xx.
Because it is not used for others except mach-s3c64xx.
This patch moves onenand-core header file into mach-s3c64xx.
This patch moves irq-uart header file into mach-s3c64xx.
This patch moves backlight header file into mach-s3c64xx.
This patch moves ata-core header file into mach-s3c64xx.
This patch moves regs-usb-hsotg-phy header file into mach-s3c64xx.
This patch moves spi-core header file into mach-s3c24xx.
Because it is not used for others except mach-s3c24xx.
This patch moves nand-core header file into mach-s3c24xx.
This patch moves fb-core header file into mach-s3c24xx.
This patch moves regs-srom header file into mach-exynos.
Because it is not used for others except mach-exynos.
This patch moves s5p-dev-mfc from plat-samsung into mach-exynos
because it is used for only exynos no other platforms.
This patch moves dev-backlight from plat-samsung into mach-s3c64xx
because it is used for only s3c64xx no other platforms.
This patch moves setup-camif from plat-samsung into mach-s3c24xx
because it can be used only for s3c24xx no other platforms.
The platform_device_id is not modified by the driver and core
uses it as const.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Convert clk_enable/clk_disable to clk_prepare_enable/clk_disable_unprepare
calls as required by common clock framework. Removes this warning on probe:
WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:889 __clk_enable+0x28/0x9c()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 3.19.0+ #46
[<c0013a98>] (unwind_backtrace) from [<c0010d8c>] (show_stack+0x10/0x14)
[<c0010d8c>] (show_stack) from [<c001b018>] (warn_slowpath_common+0x7c/0xa4)
[<c001b018>] (warn_slowpath_common) from [<c001b0d0>] (warn_slowpath_null+0x18/0x20)
[<c001b0d0>] (warn_slowpath_null) from [<c01a5f80>] (__clk_enable+0x28/0x9c)
[<c01a5f80>] (__clk_enable) from [<c01a600c>] (clk_enable+0x18/0x2c)
[<c01a600c>] (clk_enable) from [<c001860c>] (s3c_adc_probe+0x11c/0x18c)
[<c001860c>] (s3c_adc_probe) from [<c0153a10>] (platform_drv_probe+0x30/0x78)
[<c0153a10>] (platform_drv_probe) from [<c01523e0>] (driver_probe_device+0xb0/0x1fc)
[<c01523e0>] (driver_probe_device) from [<c01525dc>] (__driver_attach+0x68/0x88)
[<c01525dc>] (__driver_attach) from [<c0150df0>] (bus_for_each_dev+0x70/0x94)
[<c0150df0>] (bus_for_each_dev) from [<c0151c80>] (bus_add_driver+0xdc/0x1c4)
[<c0151c80>] (bus_add_driver) from [<c0152ba4>] (driver_register+0x9c/0xe0)
[<c0152ba4>] (driver_register) from [<c03041cc>] (adc_init+0x10/0x34)
[<c03041cc>] (adc_init) from [<c00087fc>] (do_one_initcall+0x110/0x1cc)
[<c00087fc>] (do_one_initcall) from [<c02ffccc>] (kernel_init_freeable+0xf4/0x1ac)
[<c02ffccc>] (kernel_init_freeable) from [<c022f4fc>] (kernel_init+0x8/0xe0)
[<c022f4fc>] (kernel_init) from [<c000e098>] (ret_from_fork+0x14/0x3c)
---[ end trace f4a1ea39a114fecf ]---
Signed-off-by: Sergiy Kibrik <sakib@meta.ua>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
