path: root/arch/arm/plat-samsung
2011-06-03ARM: SAMSUNG: Remove unused onenand plat functionsKyungmin Park
There's no place to use these functions. and actually no need to set the platform data. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-01ARM: S5P64X0: Fix SPI platform device namePadmavathi Venna
Changed the SPI platform device name from S5P6450 to S5P64x0 as it is defined common for both S5p6440 and S5P6450 in dev-spi.c of S5P64x0. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-05-28Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: gpio/pch_gpio: Support new device ML7223 gpio: make gpio_{request,free}_array gpio array parameter const GPIO: OMAP: move to drivers/gpio GPIO: OMAP: move register offset defines into <plat/gpio.h> gpio: Convert gpio_is_valid to return bool gpio: Move the s5pc100 GPIO to drivers/gpio gpio: Move the s5pv210 GPIO to drivers/gpio gpio: Move the exynos4 GPIO to drivers/gpio gpio: Move to Samsung common GPIO library to drivers/gpio gpio/nomadik: add function to read GPIO pull down status gpio/nomadik: show all pins in debug gpio: move Nomadik GPIO driver to drivers/gpio gpio: move U300 GPIO driver to drivers/gpio langwell_gpio: add runtime pm support gpio/pca953x: Add support for pca9574 and pca9575 devices gpio/cs5535: Show explicit dependency between gpio_cs5535 and mfd_cs5535
2011-05-26gpio: Move to Samsung common GPIO library to drivers/gpioKyungmin Park
It's common gpiolib for recent Samsung SoCs. Move to drivers/gpio Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-25Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/Kconfig arch/arm/mach-exynos4/mach-nuri.c
2011-05-23Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (137 commits) ARM: bcmring: convert to use sp804 clockevents ARM: bcmring: convert to sp804 clocksource ARM: 6912/1: bcmring: Add clkdev table in init_early clockevents: ARM sp804: obtain sp804 timer rate via clks clockevents: ARM sp804: allow clockevent name to be specified clocksource: ARM sp804: obtain sp804 timer rate via clks clocksource: ARM sp804: allow clocksource name to be specified clocksource: convert OMAP1 to 32-bit down counting clocksource clocksource: convert MXS timrotv2 to 32-bit down counting clocksource clocksource: convert SPEAr platforms 16-bit up counting clocksource clocksource: convert Integrator/AP 16-bit down counting clocksource clocksource: convert W90x900 24-bit down counting clocksource clocksource: convert ARM 32-bit down counting clocksources clocksource: convert ARM 32-bit up counting clocksources clocksource: add common mmio clocksource ARM: update sa1100 to reflect PXA updates ARM: omap1: convert to using readl/writel instead of volatile struct ARM: omap1: delete useless interrupt handler ARM: s5p: consolidate selection of timer register ARM: 6939/1: fix missing 'cpu_relax()' declaration ...
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-23Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ns9xxx/include/mach/uncompress.h
2011-05-20ARM: 6915/1: SAMSUNG: Depend on IRQ_GENERIC_CHIPMark Brown
The generic chip infrastructure has had a Kconfig symbol added so we need to select that for the kernel to link now we're using the generic IRQ chip infrastructure. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: S5P6442: Removing ARCH_S5P6442Kukjin Kim
2011-05-11Merge branch 'samsung-irq' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc-2.6 into devel-stable
2011-05-10ARM: S3C24XX: Add plaform device definition for USB High-Speed gadget ↵Thomas Abraham
controller. S3C2416, S3C2443 and S3C2450 includes a USB High-Speed Gadget controller module. This patch adds the following for supporting this controller. 1. Definition for USB High-Speed controller base address. 2. Platform device instantiation. 3. Declaration for platform data structure. 4. Functionality to setup platform data for the controller. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09ARM: SAMSUNG: Convert irq-uart to generic irq chipThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-09ARM: SAMSUNG: Convert irq-vic-timer to generic irq chipThomas Gleixner
2011-05-07Merge branch 'zImage_fixes' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-05-07ARM: zImage: remove the static qualifier from global data variablesNicolas Pitre
To be able to relocate the .bss section at run time independently from the rest of the code, we must make sure that no GOTOFF relocations are used with .bss symbols. This usually means that no global variables can be marked static unless they're also const. Let's remove the static qualifier from current offenders, or turn them into const variables when possible. Next commit will ensure the build fails if one of those is reintroduced due to otherwise enforced coding standards for the kernel. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com>
2011-04-24ARM / Samsung: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by Samsung platforms with struct syscore_ops objects that are simpler. This generally reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com>
2011-04-19Merge 2.6.39-rc4 into usb-nextGreg Kroah-Hartman
This is needed to help resolve some xhci issues and other minor differences. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14ARM: SAMSUNG: Fix warning 's3c_pm_show_resume_irqs' defined but not usedMaurus Cuelenaere
s3c_pm_show_resume_irqs() is used by some s3c_pm_arch_show_resume_irqs() implementations, which get included through mach/pm-core.h. Add __maybe_unused to silence warnings when it isn't used (e.g. on S3C64XX platforms). Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-04-14ARM: SAMSUNG: Fix build failure in PM CRC check codeAbhilash Kesavan
This patch fixes build error that occurs on enabling the Samsung specific PM CRC check code. Missed removing this reference of s3c_sleep_save_phys during move to generic cpu suspend/resume support. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-04-13ARM: S5P: Add usb ehci deviceJoonyoung Shim
This patch adds usb ehci device definition for samsung s5p cpus. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Reorder irq_set_ function callsThomas Gleixner
Reorder irq_set_chip() irq_set_chip_data() irq_set_handler() to irq_set_chip() irq_set_handler() irq_set_chip_data() so the next patch can combine irq_set_chip() and irq_set_handler() to irq_set_chip_and_handler(). Automated conversion with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: plat-samsung: Use proper irq accessor functionsThomas Gleixner
2011-03-28ARM: SAMSUNG: Fix CPU idmaskKukjin Kim
This patch fixes CPU idmask of S5P64X0 and EXYNOS4210 and its comparison method because just want to use CPU id for it. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-16Merge branches 'at91', 'ep93xx', 'errata', 'footbridge', 'fncpy', 'gemini', ↵Russell King
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
2011-03-15ARM: S5P: Add function to register gpio interrupt bank dataMarek Szyprowski
This patch removes all global data from common s5p gpio interrupt handler code. This enables to reuse this code on EXYNOS4 platform. Instead of global data (IRQ_GPIOINT interrupt number, S5P_GPIOINT_GROUP_MAXNR groups count), a s5p_register_gpioint_bank() function is introduced. It is aimed to be called from gpiolib init. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-15ARM: EXYNOS4: Add support for SATA on ARMLEX4210Abhilash Kesavan
Adds the device definitions, platform specific initialization and clocks for SATA on ARMLEX4210. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12Merge branch 'next-exynos4-pm' into for-nextKukjin Kim
Conflicts: arch/arm/mach-exynos4/include/mach/regs-pmu.h
2011-03-12ARM: EXYNOS4: Suspend to RAM SupportJaecheol Lee
This patch adds support suspend to ram for EXYNOS4210. As a note, this includes function of outer cache flush because it is used before entering PM. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12Merge branch 'next-exynos4' into next-exynos4-pmKukjin Kim
2011-03-12ARM: S5P: Add platform definitions for FIMC3Sylwester Nawrocki
Add support for fourth FIMC platform device definition and define resources for FIMC modules on EXYNOS4 machines. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11Merge branch 'dev/pwm-backlight' into for-nextKukjin Kim
Conflicts: arch/arm/mach-s3c64xx/mach-smdk6410.c
2011-03-11Merge branch 'next-exynos4' into for-nextKukjin Kim
2011-03-04ARM: SAMSUNG: Include devs.h in dev-uart.c to prototype devicesMark Brown
Ensures that the declaration agrees with the definition and makes sparse happy. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-03ARM: SAMSUNG: Move PWM device definition from plat-s3c24xx to plat-samsungBanajit Goswami
This patch does the following:- 1. It moves file pwm.c from plat-s3c24xx to plat-samsung. This will enable all machines with Samsung SoCs to make use of the same code. 2. The device definitions have been separated to a new file dev-pwm.c for better clarity and structure. 3. It will enable all Samsung S3C and S5P series SoC's to use common PWM Kconfig definition. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: pm: convert samsung platforms to generic suspend/resume supportRussell King
Tested-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-22ARM: EXYNOS4: Update device supportKukjin Kim
This patch updates device support of EXYNOS4 according to the change of ARCH name, EXYNOS4. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-18ARM: SAMSUNG: Drop exporting s3c24xx_ts_set_platdataAxel Lin
s3c24xx_ts_set_platdata is annotated __init and not used by any module, thus don't export it. This patch fixes below warning: WARNING: arch/arm/plat-samsung/built-in.o(__ksymtab+0x90): Section mismatch in reference from the variable __ksymtab_s3c24xx_ts_set_platdata to the function .init.text:s3c24xx_ts_set_platdata() The symbol s3c24xx_ts_set_platdata is exported and annotated __init Fix this by removing the __init annotation of s3c24xx_ts_set_platdata or drop the export. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-11ARM: SAMSUNG: Ensure struct sys_device is declared in plat/pm.hMark Brown
Previously we were relying on it being pulled in by other headers for the prototype of s3c24xx_irq_suspend() and s3c24xx_irq_resume(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
2011-01-13Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-01-13ARM: S5PV310: Add Support System MMUDonguk Ryu
This patch adds support System MMU for S5PV310 and S5PC210. Signed-off-by: Donguk Ryu <du.ryu@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> [kgene.kim@samsung.com: changed SYSMMU config name] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-12ARM: SAMSUNG: Add support for clock debugging through debug-fs interfaceAmit Daniel Kachhap
This patch adds support for clock information exposed to debug-fs interface. Signed-off-by: Amit Daniel Kachhap <amit.daniel@samsung.com> [kgene.kim@samsung.com: removed useless empty lines] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-06Merge branch 'next-s3c24xx' into for-nextKukjin Kim
2011-01-06ARM: SAMSUNG: Don't export __init functions to modulesYauhen Kharuzhy
There are few functions marked as __init, but exported to modules in devices declaration files. s3c_nand_set_platdata() and s3c24xx_ts_set_platdata() are used only by boards init code now, so remove EXPORT_SYMBOL() for them. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
