path: root/arch/arm/plat-tcc
2011-07-19ARM: Consolidate the clkdev header filesKyungmin Park
Now most of ARM machines has the alsmot same __clk_get/put() macro So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config Now there are only 3 caese. 1) define the clk structure with clkdev macro => Need to move clk structure to proper header file arch/arm/mach-versatile/include/mach/clkdev.h arch/arm/mach-realview/include/mach/clkdev.h arch/arm/mach-vexpress/include/mach/clkdev.h arch/arm/mach-integrator/include/mach/clkdev.h 2) export the __clk_get/put function at clock.c arch/arm/mach-shmobile/include/mach/clkdev.h 3) demuxing the clk source arch/arm/mach-u300/include/mach/clkdev.h Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-17ARM: Basic IO mappings for mach-tcc8kHans J. Koch
Map the IO ranges of TCC8xxx peripherals. Signed-off-by: "Hans J. Koch" <hjk@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-17ARM: Add TCC8xxx system timerHans J. Koch
Add the system timer using clockevents with the internal TC32 timer. This also adds a clocksource using the same timer. Signed-off-by: "Hans J. Koch" <hjk@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-17ARM: Introduce plat-tcc irq frameworkHans J. Koch
Introduce lowlevel interrupt routines. Signed-off-by: "Hans J. Koch" <hjk@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-17ARM: Add the clock framework for Telechips TCC8xxx processors.Hans J. Koch
This adds definitions and low-level functions to handle clocks in TCC8xxx processors. Signed-off-by: "Hans J. Koch" <hjk@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-17ARM: Introduce plat-tccHans J. Koch
This patch introduces support for the tcc platform by creating an arch/arm/plat-tcc and arch/arm/mach-tcc8k directories and adding basic include files plus Kconfig and Makefile. Signed-off-by: "Hans J. Koch" <hjk@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
