This moves the Versatile-specific helper code and panel database
down into the drivers/video folder next to the CLCD driver
itself, preserving the config symbol but also moving the header
to platform data.
This is necessary to rid the Integrator of this final <plat/*>
inclusion dependency and get us one less user of the
plat-versatile folder.
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: linux-fbdev@vger.kernel.org
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
This moves the Versatile FPGA interrupt controller driver, used in
the Integrator/AP, Integrator/CP and some Versatile boards, out
of arch/arm/plat-versatile and down to drivers/irqchip where we
have consensus that such drivers belong. The header file is
consequently moved to <linux/platform_data/irq-versatile-fpga.h>.
Pull ARM updates from Russell King:
"This is the first chunk of ARM updates for this merge window.
Conflicts are expected in two files - asm/timex.h and
mach-integrator/integrator_cp.c. Nothing particularly stands out more
than anything else.
Most of the growth is down to the opcodes stuff from Dave Martin,
which is countered by Rob's patches to use more of the asm-generic
headers on ARM."
(A few more conflicts grew since then, but it all looked fairly trivial)
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (44 commits)
ARM: 7548/1: include linux/sched.h in syscall.h
ARM: 7541/1: Add ARM ERRATA 775420 workaround
ARM: ensure vm_struct has its phys_addr member filled in
ARM: 7540/1: kexec: Check segment memory addresses
ARM: 7539/1: kexec: scan for dtb magic in segments
ARM: 7538/1: delay: add registration mechanism for delay timer sources
ARM: 7536/1: smp: Formalize an IPI for wakeup
ARM: 7525/1: ptrace: use updated syscall number for syscall auditing
ARM: 7524/1: support syscall tracing
ARM: 7519/1: integrator: convert platform devices to Device Tree
ARM: 7518/1: integrator: convert AMBA devices to device tree
ARM: 7517/1: integrator: initial device tree support
ARM: 7516/1: plat-versatile: add DT support to FPGA IRQ
ARM: 7515/1: integrator: check PL010 base address from resource
ARM: 7514/1: integrator: call common init function from machine
ARM: 7522/1: arch_timers: register a time/cycle counter
ARM: 7523/1: arch_timers: enable the use of the virtual timer
ARM: 7531/1: mark kernelmode mem{cpy,set} non-experimental
ARM: 7520/1: Build dtb files in all target
ARM: Fix build warning in arch/arm/mm/alignment.c
This adds Device Tree probing support to the Versatile FPGA
IRQ controller.
Convert both Realview and VExpress to use struct smp_operations to
provide their SMP and CPU hotplug operation.
Acked-by: Nicolas Pitre <nico@fluxnic.net>
This does two things to the FPGA IRQ controller in the versatile
family:
- Convert to MULTI_IRQ_HANDLER so we can drop the entry macro
from the Integrator. The C IRQ handler was inspired from
arch/arm/common/vic.c, recent bug discovered in this handler was
accounted for.
- Convert to using IRQ domains so we can get rid of the NO_IRQ
mess and proceed with device tree and such stuff.
As part of the exercise, bump all the low IRQ numbers on the
Integrator PIC to start from 1 rather than 0, since IRQ 0 is
now NO_IRQ. The Linux IRQ numbers are thus entirely decoupled
from the hardware IRQ numbers in this controller.
I was unable to split this patch. The main reason is the half-done
conversion to device tree in Versatile.
Tested on Integrator/AP and Integrator/CP.
Cc: Grant Likely <grant.likely@secretlab.ca>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Consolidate the FPGA IRQ handling code. Integrator/AP and Versatile
have one FPGA-based IRQ handler each. Integrator/CP has three.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
This consolidates the CLCD panel definitions and memory allocation into
one location.
Rename the Sanyo 2.5in and Epson 2.2in displays after their respective
part numbers. Rather than using a general "Sanyo 2.5in" and "Epson
2.2in" description of the display panel, use the manufacturers part
number to be more specific. This helps people identify what the timings
actually refer to, which are panel specific.
While here, add CLCD capability information to each panel definition,
which has no effect until we add the board-level capabilities.
arch/arm/mach-vexpress/v2m.c
arch/arm/plat-omap/counter_32k.c
arch/arm/plat-versatile/Makefile
Convert versatile platforms to use the new sched_clock() infrastructure
for extending 32bit counters to full 64-bit nanoseconds.
Tested-by: Will Deacon <will.deacon@arm.com>
The timer-sp h/w used on versatile platforms can also be used for other
platforms, so move it to a common location.
Signed-off-by: Rob Herring <rob.herring@smooth-stone.com>
