path: root/arch/arm/plat-versatile
2011-05-23ARM: consolidate SMP cross call implementationRussell King
Rather than having each platform class provide a mach/smp.h header for smp_cross_call(), arrange for them to register the function with the core ARM SMP code instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-23ARM: 6759/1: smp: Select local timers vs broadcast timer support runtimeSantosh Shilimkar
The current code support of dummy timers in absence of local timer is compile time. This is an attempt to convert it to runtime so that on few SOC version if the local timers aren't supported kernel can switch to dummy timers. OMAP4430 ES1.0 does suffer from this limitation. This patch should not have any functional impact on affected files. Cc: Daniel Walker <dwalker@codeaurora.org> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: David Brown <davidb@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: integrator: add Integrator/CP sched_clock supportRussell King
Integrator/CP has the 24MHz counter which Versatile and later platforms also have, which we use for sched_clock support. Allow this counter to be used when building a kernel targetting Integrator/CP alone. Integrator/AP does not have this counter, so we must exclude support for the Integrator family when this is enabled. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: realview/vexpress: consolidate SMP bringup codeRussell King
Realview and Versatile Express share the same SMP bringup code, so consolidate the two implementations. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: realview/vexpress: consolidate localtimer supportRussell King
Realview and Versatile Express local timer support is identical, so consolidate the implementations. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: integrator/versatile: consolidate FPGA IRQ handling codeRussell King
Consolidate the FPGA IRQ handling code. Integrator/AP and Versatile have one FPGA-based IRQ handler each. Integrator/CP has three. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: rationalize versatile family Kconfig/MakefileRussell King
Move leds and sched_clock build conditionals out of the Makefile into the Kconfig file. Move selection of HAVE_SCHED_CLOCK into the platform Kconfig rather than duplicating it three times in the main architecture Kconfig. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: add versatile family consolidated CLCD supportRussell King
This consolidates the CLCD panel definitions and memory allocation into one location. Rename the Sanyo 2.5in and Epson 2.2in displays after their respective part numbers. Rather than using a general "Sanyo 2.5in" and "Epson 2.2in" description of the display panel, use the manufacturers part number to be more specific. This helps people identify what the timings actually refer to, which are panel specific. While here, add CLCD capability information to each panel definition, which has no effect until we add the board-level capabilities. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-05Merge branch 'clksrc' into develRussell King
Conflicts: arch/arm/mach-vexpress/v2m.c arch/arm/plat-omap/counter_32k.c arch/arm/plat-versatile/Makefile
2011-01-05ARM: vexpress: add sched_clock() for Versatile ExpressRussell King
Add a sched_clock() implementation to Versatile Express using the new sched_clock() infrastructure for extending 32bit counters to full 64-bit nanoseconds. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: versatile: convert sched_clock() to use new infrastructureRussell King
Convert versatile platforms to use the new sched_clock() infrastructure for extending 32bit counters to full 64-bit nanoseconds. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: ensure all sched_clock() implementations are notrace markedRussell King
ftrace requires sched_clock() to be notrace. Ensure that all implementations are so marked. Also make sure that they include linux/sched.h Also ensure OMAP clocksource read functions are marked notrace as they're used for sched_clock() too. Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Eric Miao <eric.y.miao@gmail.com> Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: realview/versatile: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-19ARM: versatile: ensure sched_clock() is notraceRabin Vincent
Include sched.h to ensure sched_clock() has the notrace annotation. Signed-off-by: Rabin Vincent <rabin@rab.in>
2010-11-04ARM: 6432/1: move timer-sp.c from versatile to commonRob Herring
From: Rob Herring <rob.herring@smooth-stone.com> The timer-sp h/w used on versatile platforms can also be used for other platforms, so move it to a common location. Signed-off-by: Rob Herring <rob.herring@smooth-stone.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-26ARM: 6264/1: fix Versatile Express LED oversightLinus Walleij
My attempt to make the LEDs only compile for RealView and Versatile was futile: I missed the Versatile Express. So invert the logic and explicitly include the platforms to compile for. Signed-off-by: Linus Walleij <triad@df.lth.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-26ARM: 6235/2: driver for the LEDs found in the later ARM refdesignsLinus Walleij
This adds a simple driver supporting the new LED framework with triggers and all for the RealView and Versatile platforms. The RealView and Versatile platform drivers were arranged to compile for all-but-integrator as a side effect since the Integrator has a different LED driver. Signed-off-by: Linus Walleij <triad@df.lth.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: Indirect round/set_rate operations through clk structureRussell King
2010-05-02ARM: Realview/Versatile: separate out common sched_clock()Russell King
Provide a common sched_clock() implementation for Versatile and Realview. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: Realview/Versatile: don't use magic numbers for timer frequencyRussell King
2010-05-02ARM: Realview/Versatile: remove useless TIMER_RELOAD calculationsRussell King
Realview/Versatile copied the Integrator timer code, including the calculations for ensuring that the reload value fits into the 16-bit counter. However, these platforms have a 32-bit counter which is clocked at a slower rate. The result is that the preprocessor conditions are never triggered: TICKS_PER_uSEC = 1, mSEC_10 = 10000, which is 0x2710 - less than 0x10000. So, remove the unnecessary complexity, reducing the TIMER_RELOAD calculation to just: TICKS_PER_uSEC * mSEC_10 Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: Realview/Versatile: separate out common SP804 timer codeRussell King
2010-05-02ARM: Realview/Versatile/Integrator: separate out common clock codeRussell King
