commit 0ac569bf6a7983c0c5747d6df8db9dc05bc92b6c upstream.
commit e46daee53bb5 ("ARM: 8806/1: kprobes: Fix false positive with
FORTIFY_SOURCE") introduced a regression in optimized kprobes. It
triggers "invalid instruction" oopses when using kprobes instrumentation
through lttng and perf. This commit was introduced in kernel v4.20, and
has been backported to stable kernels 4.19 and 4.14.
This crash was also reported by Hongzhi Song on the redhat bugzilla
where the patch was originally introduced.
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1639397
Link: https://bugs.lttng.org/issues/1174
Link: https://lore.kernel.org/lkml/342740659.2887.1549307721609.JavaMail.zimbra@efficios.com
Fixes: e46daee53bb5 ("ARM: 8806/1: kprobes: Fix false positive with FORTIFY_SOURCE")
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reported-by: Robert Berger <Robert.Berger@ReliableEmbeddedSystems.com>
Tested-by: Robert Berger <Robert.Berger@ReliableEmbeddedSystems.com>
Cc: Robert Berger <Robert.Berger@ReliableEmbeddedSystems.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: William Cohen <wcohen@redhat.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: <stable@vger.kernel.org> # v4.14+
Cc: patches@armlinux.org.uk
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit e46daee53bb50bde38805f1823a182979724c229 upstream.
The arm compiler internally interprets an inline assembly label
as an unsigned long value, not a pointer. As a result, under
CONFIG_FORTIFY_SOURCE, the address of a label has a size of 4 bytes,
which was tripping the runtime checks. Instead, we can just cast the label
(as done with the size calculations earlier).
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1639397
Reported-by: William Cohen <wcohen@redhat.com>
Fixes: 6974f0c4555e ("include/linux/string.h: add the option of fortified string.h functions")
Cc: stable@vger.kernel.org
Acked-by: Laura Abbott <labbott@redhat.com>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Tested-by: William Cohen <wcohen@redhat.com>
commit 75b2f5f5911fe7a2fc82969b2b24dde34e8f820d upstream.
Fix %p uses in error messages by removing it and
using general dumper.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Jon Medhurst <tixy@linaro.org>
Cc: Thomas Richter <tmricht@linux.ibm.com>
Cc: Tobin C . Harding <me@tobin.cc>
Cc: acme@kernel.org
Cc: akpm@linux-foundation.org
Cc: brueckner@linux.vnet.ibm.com
Cc: rostedt@goodmis.org
Cc: schwidefsky@de.ibm.com
Link: https://lkml.kernel.org/lkml/152491905361.9916.15300852365956231645.stgit@devbox
commit 70948c05fdde0aac32f9667856a88725c192fa40 upstream.
Prohibit probing on optimized_callback() because
it is called from kprobes itself. If we put a kprobes
on it, that will cause a recursive call loop.
Mark it NOKPROBE_SYMBOL.
Fixes: 0dc016dbd820 ("ARM: kprobes: enable OPTPROBES for ARM 32")
commit 69af7e23a6870df2ea6fa79ca16493d59b3eebeb upstream.
Since get_kprobe_ctlblk() uses smp_processor_id() to access
per-cpu variable, it hits smp_processor_id sanity check as below.
[ 7.006928] BUG: using smp_processor_id() in preemptible [00000000] code: swapper/0/1
[ 7.007859] caller is debug_smp_processor_id+0x20/0x24
[ 7.008438] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.16.0-rc1-00192-g4eb17253e4b5 #1
[ 7.008890] Hardware name: Generic DT based system
[ 7.009917] [<c0313f0c>] (unwind_backtrace) from [<c030e6d8>] (show_stack+0x20/0x24)
[ 7.010473] [<c030e6d8>] (show_stack) from [<c0c64694>] (dump_stack+0x84/0x98)
[ 7.010990] [<c0c64694>] (dump_stack) from [<c071ca5c>] (check_preemption_disabled+0x138/0x13c)
[ 7.011592] [<c071ca5c>] (check_preemption_disabled) from [<c071ca80>] (debug_smp_processor_id+0x20/0x24)
[ 7.012214] [<c071ca80>] (debug_smp_processor_id) from [<c03335e0>] (optimized_callback+0x2c/0xe4)
[ 7.013077] [<c03335e0>] (optimized_callback) from [<bf0021b0>] (0xbf0021b0)
To fix this issue, call get_kprobe_ctlblk() right after
irq-disabled since that disables preemption.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The text patching functions which are invoked from jump_label and kprobes
code are protected against cpu hotplug at the call sites.
Use stop_machine_cpuslocked() to avoid recursion on the cpu hotplug
rwsem. stop_machine_cpuslocked() contains a lockdep assertion to catch any
unprotected callers.
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Russell King <linux@armlinux.org.uk>
Link: http://lkml.kernel.org/r/20170524081549.275871311@linutronix.de
kprobes test cases need to have a stack that is aligned to an 8-byte
boundary because they call other functions (and the ARM ABI mandates
that alignment) and because test cases include 64-bit accesses to the
stack. Unfortunately, GCC doesn't ensure this alignment for inline
assembler and for the code in question seems to always misalign it by
pushing just the LR register onto the stack. We therefore need to
explicitly perform stack alignment at the start of each test case.
Without this fix, some test cases will generate alignment faults on
systems where alignment is enforced. Even if the kernel is configured to
handle these faults in software, triggering them is ugly. It also
exposes limitations in the fault handling code which doesn't cope with
writes to the stack. E.g. when handling this instruction
strd r6, [sp, #-64]!
the fault handling code will write to a stack location below the SP
value at the point the fault occurred, which coincides with where the
exception handler has pushed the saved register context. This results in
corruption of those registers.
Signed-off-by: Jon Medhurst <tixy@linaro.org>
This is arm port of commit 737480a0d525 ("kprobes/x86:
Fix the return address of multiple kretprobes").
Fix the return address of subsequent kretprobes when multiple
kretprobes are set on the same function.
For example:
# cd /sys/kernel/debug/tracing
# echo "r:event1 sys_symlink" > kprobe_events
# echo "r:event2 sys_symlink" >> kprobe_events
# echo 1 > events/kprobes/enable
# ln -s /tmp/foo /tmp/bar
(without this patch)
# cat trace | grep -v ^#
ln-82 [000] dn.2 68.446525: event1: (kretprobe_trampoline+0x0/0x18 <- SyS_symlink)
ln-82 [000] dn.2 68.447831: event2: (ret_fast_syscall+0x0/0x1c <- SyS_symlink)
(with this patch)
ln-81 [000] dn.1 39.463469: event1: (ret_fast_syscall+0x0/0x1c <- SyS_symlink)
ln-81 [000] dn.1 39.464701: event2: (ret_fast_syscall+0x0/0x1c <- SyS_symlink)
Cc: KUMANO Syuhei <kumano.prog@gmail.com>
Kprobes/arm skips single-stepping (moreover handling the event)
if the conditional instruction must not be executed. This
also apply the rule when we hit the recursing kprobe, so
that kprobe does not count nmissed up in that case.
This is arm port of commit 6a5022a56ac3 ("kprobes/x86: Allow to
handle reentered kprobe on single-stepping")
Since the FIQ handlers can interrupt in the single stepping
(or preparing the single stepping, do_debug etc.), we should
consider a kprobe is hit in the NMI handler. Even in that
case, the kprobe is allowed to be reentered as same as the
kprobes hit in kprobe handlers
(KPROBE_HIT_ACTIVE or KPROBE_HIT_SSDONE).
The real issue will happen when a kprobe hit while another
reentered kprobe is processing (KPROBE_REENTER), because
we already consumed a saved-area for the previous kprobe.
<linux/sched/debug.h>
We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/debug.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched/clock.h>
We are going to split <linux/sched/clock.h> out of <linux/sched.h>, which
will have to be picked up from other headers and .c files.
Create a trivial placeholder <linux/sched/clock.h> file that just
bisectable.
Often all is needed is these small helpers, instead of compiler.h or a
full kprobes.h. This is important for asm helpers, in fact even some
asm/kprobes.h make use of these helpers... instead just keep a generic
asm file with helpers useful for asm code with the least amount of
clutter as possible.
Likewise we need now to also address what to do about this file for both
when architectures have CONFIG_HAVE_KPROBES, and when they do not. Then
for when architectures have CONFIG_HAVE_KPROBES but have disabled
CONFIG_KPROBES.
Right now most asm/kprobes.h do not have guards against CONFIG_KPROBES,
this means most architecture code cannot include asm/kprobes.h safely.
Correct this and add guards for architectures missing them.
Additionally provide architectures that not have kprobes support with
the default asm-generic solution. This lets us force asm/kprobes.h on
the header include/linux/kprobes.h always, but most importantly we can
now safely include just asm/kprobes.h on architecture code without
bringing the full kitchen sink of header files.
Two architectures already provided a guard against CONFIG_KPROBES on its
kprobes.h: sh, arch. The rest of the architectures needed gaurds added.
We avoid including any not-needed headers on asm/kprobes.h unless
kprobes have been enabled.
In a subsequent atomic change we can try now to remove compiler.h from
include/linux/kprobes.h.
During this sweep I've also identified a few architectures defining a
common macro needed for both kprobes and ftrace, that of the definition
of the breakput instruction up. Some refer to this as
BREAKPOINT_INSTRUCTION. This must be kept outside of the #ifdef
CONFIG_KPROBES guard.
[mcgrof@kernel.org: fix arm64 build]
Link: http://lkml.kernel.org/r/CAB=NE6X1WMByuARS4mZ1g9+W=LuVBnMDnh_5zyN0CLADaVh=Jw@mail.gmail.com
[sfr@canb.auug.org.au: fixup for kprobes declarations moving]
Link: http://lkml.kernel.org/r/20170214165933.13ebd4f4@canb.auug.org.au
Link: http://lkml.kernel.org/r/20170203233139.32682-1-mcgrof@kernel.org
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
There is a superfluous '*' in the definition of kprobe_decode_insn_t
which on older versions of GCC (4.2.4) causes the compilation error:
In file included from arch/arm/probes/kprobes/core.c:37:
arch/arm/probes/kprobes/core.h:43: error: '[*]' not allowed in other than a declaration
Fix this by removing the unneeded character.
Reported-by: Janusz Użycki <j.uzycki@elproma.com.pl>
Non-T variants of ARMv4 CPUs don't support the BX instruction so
eliminate its use.
This patch removes software emulation or simulation for most of probed
instructions. If the instruction doesn't use PC relative addressing,
it will be translated into following instructions in the restore code
in code template:
ldmia {r0 - r14} // restore all instruction except PC
<instruction> // direct execute the probed instruction
b next_insn // branch to next instruction.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
This patch utilizes the previously introduced checker to check
register usage for probed ARM instruction and saves it in a mask.
A further patch will use such information to avoid simulation or
emulation.
Reviewed-by: Jon Medhurst <tixy@linaro.org>
For the instruction 'mrs Rn, cpsr' the resulting value of Rn can vary due to
external factors we can't control. So get the test code to mask out these
indeterminate bits.
This patch introduce kprobeopt for ARM 32.
Limitations:
- Currently only kernel compiled with ARM ISA is supported.
- Offset between probe point and optinsn slot must not larger than
32MiB. Masami Hiramatsu suggests replacing 2 words, it will make
things complex. Futher patch can make such optimization.
Kprobe opt on ARM is relatively simpler than kprobe opt on x86 because
ARM instruction is always 4 bytes aligned and 4 bytes long. This patch
replace probed instruction by a 'b', branch to trampoline code and then
calls optimized_callback(). optimized_callback() calls opt_pre_handler()
to execute kprobe handler. It also emulate/simulate replaced instruction.
When unregistering kprobe, the deferred manner of unoptimizer may leave
branch instruction before optimizer is called. Different from x86_64,
which only copy the probed insn after optprobe_template_end and
reexecute them, this patch call singlestep to emulate/simulate the insn
directly. Futher patch can optimize this behavior.
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Reviewed-by: Jon Medhurst (Tixy) <tixy@linaro.org>
These have extra 'checker' functions associated with them so lets make
sure those get covered by testing. As they may create uninitialised
space on the stack we also update the test code to ensure such space is
consistent between test runs. This is done by disabling interrupts in
setup_test_context().
This patch prohibits probing instructions for which the stack
requirements are unable to be determined statically. Some test cases
are found not work again after the modification, this patch also
removes them.
This patch uses the previously introduced checker functionality on
store instructions to record their stack consumption information to
arch_probes_insn.
This patch introdces 'checker' to decoding phase, and calls checkers
when instruction decoding. This allows further decoding for specific
instructions. This patch introduces a stub call of checkers in kprobe
arch_prepare_kprobe() as an example and for further expansion.
This doesn't correct any bugs when probing these instructions but makes
MOVW slightly faster and makes everything more symmetric with the Thumb
instruction cases.
We can also remove the now redundant PROBES_EMULATE_NONE and
PROBES_SIMULATE_NOP actions.
In discussion on LKML (https://lkml.org/lkml/2014/11/28/158), Russell
King suggests to move all probe related code to arch/arm/probes. This
patch does the work. Due to dependency on 'arch/arm/kernel/patch.h', this
patch also moves patch.h to 'arch/arm/include/asm/patch.h', and related
'#include' directives are also midified to '#include <asm/patch.h>'.
Following is an overview of this patch:
./arch/arm/kernel/ ./arch/arm/probes/
|-- Makefile |-- Makefile
|-- probes-arm.c ==> |-- decode-arm.c
|-- probes-arm.h ==> |-- decode-arm.h
|-- probes-thumb.c ==> |-- decode-thumb.c
|-- probes-thumb.h ==> |-- decode-thumb.h
|-- probes.c ==> |-- decode.c
|-- probes.h ==> |-- decode.h
| |-- kprobes
| | |-- Makefile
|-- kprobes-arm.c ==> | |-- actions-arm.c
|-- kprobes-common.c ==> | |-- actions-common.c
|-- kprobes-thumb.c ==> | |-- actions-thumb.c
|-- kprobes.c ==> | |-- core.c
|-- kprobes.h ==> | |-- core.h
|-- kprobes-test-arm.c ==> | |-- test-arm.c
|-- kprobes-test.c ==> | |-- test-core.c
|-- kprobes-test.h ==> | |-- test-core.h
|-- kprobes-test-thumb.c ==> | `-- test-thumb.c
| `-- uprobes
| |-- Makefile
|-- uprobes-arm.c ==> |-- actions-arm.c
|-- uprobes.c ==> |-- core.c
|-- uprobes.h ==> `-- core.h
`-- patch.h ==> arch/arm/include/asm/patch.h
