path: root/arch/arm/tools
2013-01-24tegra: apalis_t30: initial Toradex Apalis T30 L4T supportMarcel Ziswiler
Tested on early prototype Apalis T30 V1.0a module. Known issues: - ADC not integrated yet. - HDA not integrated yet. - CEC not integrated yet. - IrDA not integrated yet. - Keys not integrated yet therefore no way to wake from suspend. - 8-bit MMC1 slot card detection interrupt not working despite detection GPIO successfully being tested with GPIOConfig. Note: even 8-bit cards work fine if already plugged-in during boot. - PCIe limited to internal Gigabit Ethernet chip for now due to our proprietary way of resetting other ports which requires further integration into NVIDIA's driver.
2013-01-11colibri_t30: migrate to proper machine typeMarcel Ziswiler
After having registered the following proper machine type migrate to actually using it. http://www.arm.linux.org.uk/developer/machines/list.php?id=4493
2012-11-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: arch/arm/mach-tegra/tegra3_usb_phy.c arch/arm/mach-tegra/usb_phy.c drivers/usb/gadget/tegra_udc.c drivers/usb/otg/Makefile drivers/video/tegra/fb.c sound/soc/tegra/tegra_pcm.c
2012-10-03tegra: colibri_t30: initial Toradex Colibri T30 L4T R16 supportMarcel Ziswiler
Tested on early prototype Colibri T30 V1.0a eMMC module. Known issues: - spurious boot hang after following kernel message [ 5.595219] Timed out waiting for lock bit on pll pll_a - no audio (SGTL5000) support integrated yet - NAND detection/support disabled for now due to boot hang - USB OTG support disabled for now due to boot hang - trying to spawn L4T R16 X driver seems to hang Note: requires uImage with adjusted entry point/load address as follows mkimage -A arm -C none -O linux -T kernel -a 0x82008000 -e 0x82008000 -n 'Linux-3.1.10-colibri_t30' -d zImage uImage
2012-08-29ARM: tegra: tai: Add tai machine numSeema Khowala
http://www.arm.linux.org.uk/developer/machines/list.php?id=4311 Bug 1002637 Change-Id: Id52214c1780294e4e4a6607b954c05e9be950fdd Signed-off-by: Seema Khowala <seemaj@nvidia.com> Reviewed-on: http://git-master/r/127978 Reviewed-by: Lokesh Pathak <lpathak@nvidia.com> Tested-by: Lokesh Pathak <lpathak@nvidia.com>
2012-08-08ARM: tegra: e1853: Add board support for e1853Ashwin Joshi
E1853 is T30 based Automotive platform. Changes done: 1. New board specific files added 2. Added new machine number for E1853 3. Added pinmux configuration for E1853 Bug 966833 Bug 1018258 Signed-off-by: Ashwin Joshi <asjoshi@nvidia.com> Change-Id: Ibf1093f59e10a0a5cfa42a177c21c0db01983196 Reviewed-on: http://git-master/r/118000 Tested-by: Ashwin Joshi <asjoshi@nvidia.com> Reviewed-by: Sandeep Trasi <strasi@nvidia.com> (cherry picked from commit ad9dd1b3242f23c0f46eaf92ab49f495c06f330f) Reviewed-on: http://git-master/r/119580 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-08Initial Toradex Colibri T20 L4T R15 support.Marcel Ziswiler
2012-01-30arm: tegra: kai: create board filesJohnny Qiu
Create initial board files and config files for Kai. Reviewed-on: http://git-master/r/74441 Change-Id: I4b07607da85fe4bcb00e5fce2ddbc2a83471b1de Signed-off-by: Johnny Qiu <joqiu@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/77296 Reviewed-by: Automatic_Commit_Validation_User
2012-01-19arm: tegra: p1852: Add machine number for p1852Manoj Chourasia
bug 871603 Reviewed-on: http://git-master/r/45808 (cherry picked from commit 84766f94eec3eb9d3e430e0f8b31594c2a4079a9) Change-Id: Ife06b5e1ca5d4df776e647fffb654a7e43ae4432 Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com> Reviewed-on: http://git-master/r/72255 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com> Reviewed-on: http://git-master/r/75543 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2011-11-30tegra: p852: Add Machine no. for p852Manoj Chourasia
Registered number of p852 platform on arm-linux forum is 3667. This patch adds p852 machine number to mach-types bug 872849 Reviewed-on: http://git-master/r/46385 (cherry picked from commit 418b55a780649ce355bd0f8c2a423b11b10c110f) Change-Id: I6c62e6c69bffbf634ca17e418a197b01df137a85 Reviewed-on: http://git-master/r/56896 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> Tested-by: Manoj Chourasia <mchourasia@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Rebase-Id: R3c7e29f06d1f60cfaeae44d4c8fd40046cc9e1d6
2011-11-30remove placeholdersDan Willemsen
Rebase-Id: R1dbf37d34132ebe69f0c250a9457a7c5096e3d31
2011-11-30mach-types: Official tegra_enterprise machine numDan Willemsen
http://www.arm.linux.org.uk/developer/machines/list.php?id=3512 Change-Id: I432bd8512025c6f3ff312b8e120df37c68aa1153 Reviewed-on: http://git-master/r/31409 Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com> Tested-by: Daniel Willemsen <dwillemsen@nvidia.com> Rebase-Id: R99e43dbe2f73e9b3e2d9d78a8c0c543bc2a93969
2011-11-30arm: tegra: tegra_enterprise: Creating board filesKasoju Mallikarjun
Creating initial board files and config files for tegra_enterprise board. Original-Change-Id: I77dcd612421167b9c6441d5d6fb779bb51491efa Reviewed-on: http://git-master/r/20852 Reviewed-by: Niket Sirsi <nsirsi@nvidia.com> Tested-by: Niket Sirsi <nsirsi@nvidia.com> Change-Id: I498fe3cde454657c22fb1c1bc2212eb5e2f7fd6e Rebase-Id: Rcf164609f08780297a383d040e934a1ecd3c86b5
2011-11-30placeholders for mergingDan Willemsen
Rebase-Id: R177e2f8e2b79f789558d19e4b17863c9b29fab9e
2011-08-22ARM: 7051/1: cpuimx* boards: fix mach-types errorsEric Bénard
I made some changes to the entry in the ARM Machine Registry after submission which was the wrong thing to do. This patch should help to fix this error. Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-10Update Nook Color machine 3284 to common Encore nameOleg Drokin
Machine database already updated: http://www.arm.linux.org.uk/developer/machines/list.php?id=3284 Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-14ARM: Update mach-typesRussell King
2011-03-20ARM: Update (and cut down) mach-typesRussell King
As many entries have never been submitted to mainline, there's no point them existing in this file. So remove the entries which aren't relevant for mainline. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-07ARM: Update mach-typesRussell King
2010-12-12ARM: Update mach-typesRussell King
2010-09-09ARM: Update mach-typesRussell King
2010-07-12ARM: Update mach-typesRussell King
2010-05-01ARM: Update mach-typesRussell King
2010-03-20ARM: Update mach-typesRussell King
2010-02-20ARM: Update mach-typesRussell King
2010-01-28[ARM] Update mach-typesRussell King
2009-12-17Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: PCMCIA: fix pxa2xx_lubbock modular build error [ARM] Update mach-types [ARM] pxa: fix no reference of cpu_is_pxa25x() in devices.c [ARM] pxa/cm-x300: add PWM backlight support revert "[ARM] pxa/cm-x300: add PWM backlight support" ARM: use flush_kernel_dcache_area() for dmabounce ARM: add size argument to __cpuc_flush_dcache_page ARM: 5848/1: kill flush_ioremap_region() ARM: cache-l2x0: make better use of background cache handling ARM: cache-l2x0: avoid taking spinlock for every iteration [ARM] Kirkwood: Add LaCie Network Space v2 support ARM: dove: fix the mm mmu flags of the pj4 procinfo
2009-12-16[ARM] Update mach-typesRussell King
2009-12-12arm: move mach-types to include/generatedSam Ravnborg
Simplified arch/arm/Makefile by dropping the maketools target It was undocumented and not needed Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-11-25[ARM] Update mach-typesRussell King
2009-09-18[ARM] Update mach-typesRussell King
2009-09-12[ARM] Update mach-typesRussell King
2009-08-01[ARM] Update mach-typesRussell King
2009-07-09[ARM] Update mach-typesRussell King
2009-06-20[ARM] Update mach-typesRussell King
2009-05-29[ARM] update mach-typesRussell King
2009-03-23[ARM] update mach-typesNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-03-12[ARM] update mach-typesRussell King
2008-11-30[ARM] Update mach-typesRussell King
2008-09-25[ARM] Update mach-typesRussell King
2008-08-16[ARM] update mach-typesRussell King
2008-08-07[ARM] Add support for arch/arm/mach-*/include and arch/arm/plat-*/includeRussell King
2008-07-13[ARM] Update mach-typesRussell King
This update is required for Tavor and SAAR Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-07[ARM] mach-types updateRussell King
Update mach-types. Remove invalid or incorrect entries. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] Update mach-typesRussell King
2008-01-26[ARM] Update mach-typesRussell King
2007-05-11[ARM] Update mach-typesRussell King
2007-04-16[ARM] Update mach-typesRussell King
2007-01-24[ARM] Update mach-typesRussell King
2006-12-07[ARM] Update mach-typesRussell King
