path: root/arch/arm/vfp
2012-05-21ARM: vfp: ensure preemption is disabled when enabling VFP accessWill Deacon
The vfp_enable function enables access to the VFP co-processor register space (cp10 and cp11) on the current CPU and must be called with preemption disabled. Unfortunately, the vfp_init late initcall does not disable preemption and can lead to an oops during boot if thread migration occurs at the wrong time and we end up attempting to access the FPSID on a CPU with VFP access disabled. This patch fixes the initcall to call vfp_enable from a non-preemptible context on each CPU and adds a BUG_ON(preemptible) to ensure that any similar problems are easily spotted in the future. originally from http://git.kernel.org/?p=linux/kernel/git/will/linux.git;a=commit;h=468c963e0210bf8108b17cf75066f25f39cabb56 Change-Id: I26fff8abe4c18bd3291613f70d0228aa2313811a Reported-by: Hyungwoo Yang <hwoo.yang@gmail.com> Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Reviewed-on: http://git-master/r/102315 GVS: Gerrit_Virtual_Submit Reviewed-by: Thomas Cherry <tcherry@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-05-21Revert "ARM: vfp: Prevent process migration"Hyungwoo Yang
This reverts commit 68667feb8eae225f1293a7044c989ab0bba8dbd1. Change-Id: I59023f2d83392465f7a989693b67cef96d565ed9 Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com> Reviewed-on: http://git-master/r/102314 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-04-25ARM: vfp: Prevent process migrationHyungwoo Yang
System crashes if there is process migration during vfp_init() call. During vfp_init(), if a process which called vfp_enable() is migrated just after the call, then the process executing the rest of code will access a VFP unit which is not ENABLED and also smp_call_function() will not work as it is expected. This patch prevents process migration during vfp_init(). Bug 968524 Bug 961609 Bug 957974 Bug 958581 Bug 959838 Bug 946739 Change-Id: I18c0ff3af490578afd5add7a1d64cab8c8ebf487 Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com> Reviewed-on: http://git-master/r/98029 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Karan Jhavar <kjhavar@nvidia.com> Reviewed-by: Thomas Cherry <tcherry@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2011-11-30HACK merge fixups for compileDan Willemsen
Rebase-Id: Rbc628711479b187a90437bea94776066c7a58b54
2011-11-30Merge branch 'korg-android-3.1' into korg-android+linux-tegra-3.1Dan Willemsen
Conflicts: arch/arm/mm/cache-l2x0.c drivers/misc/Kconfig drivers/misc/Makefile Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2011-11-30Revert "ARM: vfp: fix a hole in VFP thread migration"Colin Cross
This reverts commit c0822d4f0bcccf227b751cfe1c047f3bdae0f1ce.
2011-11-30Revert "ARM: vfp: ensure that thread flushing works if preempted"Colin Cross
This reverts commit 4f77fd436e53acf5bc0a06a24331f64b07fb33ec.
2011-11-30ARM: vfp: Always save VFP state in vfp_pm_suspendColin Cross
vfp_pm_suspend should save the VFP state in suspend after any lazy context switch. If it only saves when the VFP is enabled, the state can get lost when, on a UP system: Thread 1 uses the VFP Context switch occurs to thread 2, VFP is disabled but the VFP context is not saved Thread 2 initiates suspend vfp_pm_suspend is called with the VFP disabled, and the unsaved VFP context of Thread 1 in the registers Modify vfp_pm_suspend to save the VFP context whenever vfp_current_hw_state is not NULL. Change-Id: I91f29722d256a3afc1cc04df8b227541434ccffb Cc: Russell King <linux@arm.linux.org.uk> Cc: Barry Song <bs14@csr.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Colin Cross <ccross@android.com>
2011-11-30ARM: vfp: Move exception address fixup into vfphw.SColin Cross
If the PC on the stack is updated in entry-armv.S, do_undefinstr can get called after the fixup. do_undefinstr does its own fixup, and doing both causes the PC to point to half way through an instruction. Instead, do the fixup in do_vfp, where only the vfp code can get called. Change-Id: I6d966887adc8ed58d88bfe0cb3c0ba29213be488 Signed-off-by: Colin Cross <ccross@android.com>
vfp_pm_suspend should save the VFP state any time there is a last_VFP_context. If it only saves when the VFP is enabled, the state can get lost when, on a UP system: Thread 1 uses the VFP Context switch occurs to thread 2, VFP is disabled but the VFP context is not saved to allow lazy save and restore Thread 2 initiates suspend vfp_pm_suspend is called with the VFP disabled, but the context has not been saved. Modify vfp_pm_suspend to save the VFP context whenever last_VFP_context is set. Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Colin Cross <ccross@android.com>
2011-11-30ARM: vfp: Use cpu pm notifiers to save vfp stateColin Cross
2011-07-22Merge branch 'devel-stable' into for-nextRussell King
Conflicts: arch/arm/kernel/entry-armv.S
2011-07-09ARM: vfp: ensure that thread flushing works if preemptedRussell King
Prevent a preemption event causing the initialized VFP state being overwritten by ensuring that the VFP hardware access is disabled prior to starting initialization. We can then do this in safety while still allowing preemption to occur. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-09ARM: vfp: fix a hole in VFP thread migrationRussell King
Fix a hole in the VFP thread migration. Lets define two threads. Thread 1, we'll call 'interesting_thread' which is a thread which is running on CPU0, using VFP (so vfp_current_hw_state[0] = &interesting_thread->vfpstate) and gets migrated off to CPU1, where it continues execution of VFP instructions. Thread 2, we'll call 'new_cpu0_thread' which is the thread which takes over on CPU0. This has also been using VFP, and last used VFP on CPU0, but doesn't use it again. The following code will be executed twice: cpu = thread->cpu; /* * On SMP, if VFP is enabled, save the old state in * case the thread migrates to a different CPU. The * restoring is done lazily. */ if ((fpexc & FPEXC_EN) && vfp_current_hw_state[cpu]) { vfp_save_state(vfp_current_hw_state[cpu], fpexc); vfp_current_hw_state[cpu]->hard.cpu = cpu; } /* * Thread migration, just force the reloading of the * state on the new CPU in case the VFP registers * contain stale data. */ if (thread->vfpstate.hard.cpu != cpu) vfp_current_hw_state[cpu] = NULL; The first execution will be on CPU0 to switch away from 'interesting_thread'. interesting_thread->cpu will be 0. So, vfp_current_hw_state[0] points at interesting_thread->vfpstate. The hardware state will be saved, along with the CPU number (0) that it was executing on. 'thread' will be 'new_cpu0_thread' with new_cpu0_thread->cpu = 0. Also, because it was executing on CPU0, new_cpu0_thread->vfpstate.hard.cpu = 0, and so the thread migration check is not triggered. This means that vfp_current_hw_state[0] remains pointing at interesting_thread. The second execution will be on CPU1 to switch _to_ 'interesting_thread'. So, 'thread' will be 'interesting_thread' and interesting_thread->cpu now will be 1. The previous thread executing on CPU1 is not relevant to this so we shall ignore that. We get to the thread migration check. Here, we discover that interesting_thread->vfpstate.hard.cpu = 0, yet interesting_thread->cpu is now 1, indicating thread migration. We set vfp_current_hw_state[1] to NULL. So, at this point vfp_current_hw_state[] contains the following: [0] = &interesting_thread->vfpstate [1] = NULL Our interesting thread now executes a VFP instruction, takes a fault which loads the state into the VFP hardware. Now, through the assembly we now have: [0] = &interesting_thread->vfpstate [1] = &interesting_thread->vfpstate CPU1 stops due to ptrace (and so saves its VFP state) using the thread switch code above), and CPU0 calls vfp_sync_hwstate(). if (vfp_current_hw_state[cpu] == &thread->vfpstate) { vfp_save_state(&thread->vfpstate, fpexc | FPEXC_EN); BANG, we corrupt interesting_thread's VFP state by overwriting the more up-to-date state saved by CPU1 with the old VFP state from CPU0. Fix this by ensuring that we have sane semantics for the various state describing variables: 1. vfp_current_hw_state[] points to the current owner of the context information stored in each CPUs hardware, or NULL if that state information is invalid. 2. thread->vfpstate.hard.cpu always contains the most recent CPU number which the state was loaded into or NR_CPUS if no CPU owns the state. So, for a particular CPU to be a valid owner of the VFP state for a particular thread t, two things must be true: vfp_current_hw_state[cpu] == &t->vfpstate && t->vfpstate.hard.cpu == cpu. and that is valid from the moment a CPU loads the saved VFP context into the hardware. This gives clear and consistent semantics to interpreting these variables. This patch also fixes thread copying, ensuring that t->vfpstate.hard.cpu is invalidated, otherwise CPU0 may believe it was the last owner. The hole can happen thus: - thread1 runs on CPU2 using VFP, migrates to CPU3, exits and thread_info freed. - New thread allocated from a previously running thread on CPU2, reusing memory for thread1 and copying vfp.hard.cpu. At this point, the following are true: new_thread1->vfpstate.hard.cpu == 2 &new_thread1->vfpstate == vfp_current_hw_state[2] Lastly, this also addresses thread flushing in a similar way to thread copying. Hole is: - thread runs on CPU0, using VFP, migrates to CPU1 but does not use VFP. - thread calls execve(), so thread flush happens, leaving vfp_current_hw_state[0] intact. This vfpstate is memset to 0 causing thread->vfpstate.hard.cpu = 0. - thread migrates back to CPU0 before using VFP. At this point, the following are true: thread->vfpstate.hard.cpu == 0 &thread->vfpstate == vfp_current_hw_state[0] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-09ARM: vfp: rename check_exception to vfp_hw_state_validRussell King
Rename this branch to more accurately reflect why its taken, rather than what the following code does. It is the only caller of this code. This helps to clarify following changes, yet this change results in no actual code change. Document the VFP hardware state at the target of this branch. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-09ARM: vfp: rename last_VFP_context to vfp_current_hw_stateRussell King
Rename the slightly confusing 'last_VFP_context' variable to be more descriptive of what it actually is. This variable stores a pointer to the current owner's vfpstate structure for the context held in the VFP hardware. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-07ARM: vfp: add VFPv4 capability detection and populate elf_hwcapWill Deacon
The presence of VFPv4 cannot be detected simply by looking at the FPSID subarchitecture field, as a value >= 2 signifies the architecture as VFPv3 or later. This patch reads from MVFR1 to check whether or not the fused multiply accumulate instructions are supported. Since these are introduced with VFPv4, this tells us what we need to know. Signed-off-by: Will Deacon <will.deacon@arm.com>
2011-04-24ARM: Use struct syscore_ops instead of sysdevs for PM in common codeRafael J. Wysocki
Convert some ARM architecture's common code to using struct syscore_ops objects for power management instead of sysdev classes and sysdevs. This simplifies the code and reduces the kernel's memory footprint. It also is necessary for removing sysdevs from the kernel entirely in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-10ARM: 6868/1: Preserve the VFP state during forkCatalin Marinas
VFP registers d16-d31 are callee saved registers and must be preserved during function calls, including fork(). The VFP configuration should also be preserved. The patch copies the full VFP state to the child process. Reported-by: Paul Wright <paul.wright@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-04-10ARM: 6867/1: Introduce THREAD_NOTIFY_COPY for copy_thread() hooksCatalin Marinas
This patch adds THREAD_NOTIFY_COPY for calling registered handlers during the copy_thread() function call. It also changes the VFP handler to use a switch statement rather than if..else and ignore this event. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17arm: change to new flag variablesmatt mooney
Replace EXTRA_CFLAGS with ccflags-y and EXTRA_AFLAGS with asflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-23ARM: vfp: improve commentry for hotplug eventsRussell King
Improve the documentation for the VFP hotplug notifier handler, so that people better understand what's going on there and what has been done for them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-23ARM: fix some sparse errors in generic ARM codeRussell King
arch/arm/kernel/return_address.c:37:6: warning: symbol 'return_address' was not declared. Should it be static? arch/arm/kernel/setup.c:76:14: warning: symbol 'processor_id' was not declared. Should it be static? arch/arm/kernel/traps.c:259:1: warning: symbol 'die_lock' was not declared. Should it be static? arch/arm/vfp/vfpmodule.c:156:6: warning: symbol 'vfp_raise_sigfpe' was not declared. Should it be static? Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2010-12-20ARM: VFP: re-initialize VFP coprocessor access enables on CPU hotplugRussell King
We can not guarantee that VFP will be enabled when CPU hotplug brings a CPU back online from a reset state. Add a hotplug CPU notifier to ensure that the VFP coprocessor access is enabled whenever a CPU comes back online. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-30ARM: 6498/1: vfp: Correct data alignment for CONFIG_THUMB2_KERNELDave Martin
Directives such as .long and .word do not magically cause the assembler location counter to become aligned in gas. As a result, using these directives in code sections can result in misaligned data words when building a Thumb-2 kernel (CONFIG_THUMB2_KERNEL). This is a Bad Thing, since the ABI permits the compiler to assume that fundamental types of word size or above are word- aligned when accessing them from C. If the data is not really word-aligned, this can cause impaired performance and stray alignment faults in some circumstances. In general, the following rules should be applied when using data word declaration directives inside code sections: * .quad and .double: .align 3 * .long, .word, .single, .float: .align (or .align 2) * .short: No explicit alignment required, since Thumb-2 instructions are always 2 or 4 bytes in size. immediately after an instruction. Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Dave Martin <dave.martin@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-09ARM: 6203/1: Make VFPv3 usable on ARMv6Tony Lindgren
MVFR0 and MVFR1 are only available starting with ARM1136 r1p0 release according to "B.5 VFP changes" in DDI0211F_arm1136_r1p0_trm.pdf. This is also when TLS register got added, so we can use HAS_TLS also to test for MVFR0 and MVFR1. Otherwise VFPFMRX and VFPFMXR access fails and we get: Internal error: Oops - undefined instruction: 0 [#1] PC is at no_old_VFP_process+0x8/0x3c LR is at __und_svc+0x48/0x80 ... Signed-off-by: Tony Lindgren <tony@atomide.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-27ARM: VFP: Fix vfp_put_double() for d16-d31Russell King
vfp_put_double() takes the double value in r0,r1 not r1,r2. Reported-by: Tarun Kanti DebBarma <tarun.kanti@ti.com> Cc: <stable@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-14ARM: 6050/1: VFP: fix the SMP versions of vfp_{sync,flush}_hwstateImre Deak
From: Imre Deak <imre.deak@nokia.com> Recently the UP versions of these functions were refactored and as a side effect it became possible to call them for the current thread. This isn't true for the SMP versions however, so fix this up. Signed-off-by: Imre Deak <imre.deak@nokia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-28ARM: 5997/1: ARM: Correct the VFPv3 detectionCatalin Marinas
A CPU has VFPv3 hardware if the FPSID[19:16] bits are 2 or more. Currently Linux was only checking for 3 or more. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-15ARM: vfp ptrace: no point flushing hw context for PTRACE_GETVFPREGSRussell King
If we're only reading the VFP context via the ptrace call, there's no need to invalidate the hardware context - we only need to do that on PTRACE_SETVFPREGS. This allows more efficient monitoring of a traced task. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: vfp: fix vfp_sync_state()Russell King
The more I look at vfp_sync_state(), the more I believe it's trying to do its job in a really obscure way. Essentially, last_VFP_context[] tracks who owns the state in the VFP hardware. If last_VFP_context[] is the context for the thread which we're interested in, then the VFP hardware has context which is not saved in the software state - so we need to bring the software state up to date. If last_VFP_context[] is for some other thread, we really don't care what state the VFP hardware is in; it doesn't contain any information pertinent to the thread we're trying to deal with - so don't touch the hardware. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-01ARM: 5909/1: ARM: Correct the FPSCR bits setting when raising exceptionsCatalin Marinas
Commit c98929c07a removed the clearing of the FPSCR[31:28] bits from the vfp_raise_exceptions() function and the new bits are or'ed with the old FPSCR bits leading to unexpected results (the original commit was referring to the cumulative bits - FPSCR[4:0]). Reported-by: Tom Hameenanttila <tmhameen@marvell.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-18ARM: Convert VFP/Crunch/XscaleCP thread_release() to exit_thread()Russell King
This avoids races in the VFP code where the dead thread may have state on another CPU. By moving this code to exit_thread(), we will be running as the thread, and therefore be running on the current CPU. This means that we can ensure that the only local state is accessed in the thread notifiers. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-13ARM: VFP: fix vfp thread init bug and document vfp notifier entry conditionsRussell King
When the VFP notifier is called for flush_thread(), we may be preemptible, meaning we might migrate to another CPU, which means referencing the current CPU number without some form of locking is invalid, and can cause data corruption. For the most cases, this isn't a problem since atomic notifiers are run under rcu lock, which for most configurations results in preemption being disabled - except when the preemptable tree-based rcu implementation is selected. Let's make it safe anyway. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-24Thumb-2: Implement the unified VFP supportCatalin Marinas
This patch modifies the VFP files for the ARM/Thumb-2 unified assembly syntax. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-07-24Thumb-2: Add some .align statements to the .S filesCatalin Marinas
Since the Thumb-2 instructions can be 16-bit wide, data in the .text sections may not be aligned to a 32-bit word and this leads to unaligned exceptions. This patch does not affect the ARM code generation. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-05-30Fix the VFP handling on the Feroceon CPUCatalin Marinas
This CPU generates synchronous VFP exceptions in a non-standard way - the FPEXC.EX bit set but without the FPSCR.IXE bit being set like in the VFP subarchitecture 1 or just the FPEXC.DEX bit like in VFP subarchitecture 2. The main problem is that the faulty instruction (which needs to be emulated in software) will be restarted several times (normally until a context switch disables the VFP). This patch ensures that the VFP exception is treated as synchronous. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Nicolas Pitre <nico@cam.org>
2009-04-01[ARM] 5440/1: Fix VFP state corruption due to preemption during VFP exceptionsGeorge G. Davis
We've observed that ARM VFP state can be corrupted during VFP exception handling when PREEMPT is enabled. The exact conditions are difficult to reproduce but appear to occur during VFP exception handling when a task causes a VFP exception which is handled via VFP_bounce and is then preempted by yet another task which in turn causes yet another VFP exception. Since the VFP_bounce code is not preempt safe, VFP state then becomes corrupt. In order to prevent preemption from occuring while handling a VFP exception, this patch disables preemption while handling VFP exceptions. Signed-off-by: George G. Davis <gdavis@mvista.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-12[ARM] 5388/1: Add hwcap bits for VFPv3 and VFPv3D16Catalin Marinas
The VFPv3D16 is a VFPv3 CPU configuration where only 16 double registers are present, as the VFPv2 configuration. This patch adds the corresponding hwcap bits so that applications or debuggers have more information about the supported features. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-12[ARM] 5387/1: Add ptrace VFP support on ARMCatalin Marinas
This patch adds ptrace support for setting and getting the VFP registers using PTRACE_SETVFPREGS and PTRACE_GETVFPREGS. The user_vfp structure defined in asm/user.h contains 32 double registers (to cover VFPv3 and Neon hardware) and the FPSCR register. Cc: Paul Brook <paul@codesourcery.com> Cc: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-18[ARM] 5349/1: VFP: Add PM code to save and restore current VFP stateBen Dooks
When CONFIG_PM is selected, the VFP code does not have any handler installed to deal with either saving the VFP state of the current task, nor does it do anything to try and restore the VFP after a resume. On resume, the VFP will have been reset and the co-processor access control registers are in an indeterminate state (very probably the CP10 and CP11 the VFP uses will have been disabled by the ARM core reset). When this happens, resume will break as soon as it tries to unfreeze the tasks and restart scheduling. Add a sys device to allow us to hook the suspend call to save the current thread state if the thread is using VFP and a resume hook which restores the CP10/CP11 access and ensures the VFP is disabled so that the lazy swapping will take place on next access. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-06ARMv7: Branch over conditional undefined instructions in vfphw.SCatalin Marinas
On ARMv7, conditional undefined instructions may generate exceptions even if the condition is not met. The vfphw.S contains the FPINST and FPINST2 access instructions which may not be present on processors with synchronous VFP exceptions. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-11-06Add HWCAP_NEON to the ARM hwcap.h fileCatalin Marinas
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-26smp_call_function: get rid of the unused nonatomic/retry argumentJens Axboe
It's never used and the comments refer to nonatomic and retry interchangably. So get rid of it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-26[ARM] 4583/1: ARMv7: Add VFPv3 supportCatalin Marinas
This patch adds the support for VFPv3 (the kernel currently supports VFPv2). The main difference is 32 double registers (compared to 16). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4582/2: Add support for the common VFP subarchitectureCatalin Marinas
This patch allows the VFP support code to run correctly on CPUs compatible with the common VFP subarchitecture specification (Appendix B in the ARM ARM v7-A and v7-R edition). It implements support for VFP subarchitecture 2 while being backwards compatible with subarchitecture 1. On VFP subarchitecture 1, the arithmetic exceptions are asynchronous (or imprecise as described in the old ARM ARM) unless the FPSCR.IXE bit is 1. The exceptional instructions can be read from FPINST and FPINST2 registers. With VFP subarchitecture 2, the arithmetic exceptions can also be synchronous and marked by the FPEXC.DEX bit (the FPEXC.EX bit is cleared). CPUs implementing the synchronous arithmetic exceptions don't have the FPINST and FPINST2 registers and accessing them would trigger and undefined exception. Note that FPEXC.EX bit has an additional meaning on subarchitecture 1 - if it isn't set, there is no additional information in FPINST and FPINST2 that needs to be saved at context switch or when lazy-loading the VFP state of a different thread. The patch also removes the clearing of the cumulative exception flags in FPSCR when additional exceptions were raised. It is up to the user application to clear these bits. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
