Follow the example set by x86 in commit 9ccaf77cf05915f5 ("x86/mm:
Always enable CONFIG_DEBUG_RODATA and remove the Kconfig option"), and
make these protections a fundamental security feature rather than an
opt-in. This also results in a minor code simplification.
For those rare cases when users wish to disable this protection (e.g.
for debugging), this can be done by passing 'rodata=off' on the command
line.
As DEBUG_RODATA_ALIGN is only intended to address a performance/memory
tradeoff, and does not affect correctness, this is left user-selectable.
DEBUG_MODULE_RONX is also left user-selectable until the core code
provides a boot-time option to disable the protection for debugging
use-cases.
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
The SET_MODULE_RONX protections are effectively the same as the
DEBUG_RODATA protections we enabled by default back in commit
57efac2f7108e325 ("arm64: enable CONFIG_DEBUG_RODATA by default"). It
seems unusual to have one but not the other.
As evidenced by the help text, the rationale appears to be that
SET_MODULE_RONX interacts poorly with tracing and patching, but both of
these make use of the insn framework, which takes SET_MODULE_RONX into
account. Any remaining issues are bugs which should be fixed regardless
of the default state of the option.
This patch enables DEBUG_SET_MODULE_RONX by default, and replaces the
help text with a new wording derived from the DEBUG_RODATA help text,
which better describes the functionality. Previously, the DEBUG_RODATA
entry was inconsistently indented with spaces, which are replaced with
tabs as with the other Kconfig entries.
Additionally, the wording of recommended defaults is made consistent for
all options. These are placed in a new paragraph, unquoted, as a full
sentence (with a period/full stop) as this appears to be the most common
form per $(git grep 'in doubt').
Cc: Laura Abbott <labbott@fedoraproject.org>
The mapping of the kernel consist of four segments, each of which is mapped
with different permission attributes and/or lifetimes. To optimize the TLB
and translation table footprint, we define various opaque constants in the
linker script that resolve to different aligment values depending on the
page size and whether CONFIG_DEBUG_ALIGN_RODATA is set.
Considering that
- a 4 KB granule kernel benefits from a 64 KB segment alignment (due to
the fact that it allows the use of the contiguous bit),
- the minimum alignment of the .data segment is THREAD_SIZE already, not
PAGE_SIZE (i.e., we already have padding between _data and the start of
the .data payload in many cases),
- 2 MB is a suitable alignment value on all granule sizes, either for
mapping directly (level 2 on 4 KB), or via the contiguous bit (level 3 on
16 KB and 64 KB),
- anything beyond 2 MB exceeds the minimum alignment mandated by the boot
protocol, and can only be mapped efficiently if the physical alignment
happens to be the same,
we can simplify this by standardizing on 64 KB (or 2 MB) explicitly, i.e.,
regardless of granule size, all segments are aligned either to 64 KB, or to
2 MB if CONFIG_DEBUG_ALIGN_RODATA=y. This also means we can drop the Kconfig
dependency of CONFIG_DEBUG_ALIGN_RODATA on CONFIG_ARM64_4K_PAGES.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
In spite of its name, CONFIG_DEBUG_RODATA is an important hardening feature
for production kernels, and distros all enable it by default in their
kernel configs. However, since enabling it used to result in more granular,
and thus less efficient kernel mappings, it is not enabled by default for
performance reasons.
However, since commit 2f39b5f91eb4 ("arm64: mm: Mark .rodata as RO"), the
various kernel segments (.text, .rodata, .init and .data) are already
mapped individually, and the only effect of setting CONFIG_DEBUG_RODATA is
that the existing .text and .rodata mappings are updated late in the boot
sequence to have their read-only attributes set, which means that any
performance concerns related to enabling CONFIG_DEBUG_RODATA are no longer
valid.
So from now on, make CONFIG_DEBUG_RODATA default to 'y'
Acked-by: Mark Rutland <mark.rutland@arm.com>
Let all the archs that implement devmem_is_allowed() opt-in to a common
definition of CONFIG_STRICT_DEVM in lib/Kconfig.debug.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
[heiko: drop 'default y' for s390]
Acked-by: Ingo Molnar <mingo@redhat.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
FRAME_POINTER is defined in lib/Kconfig.debug, it is unnecessary to redefine it
in arch/arm64/Kconfig.debug.
ARM64 depends on frame pointer to get correct stack trace (also selecting
ARCH_WANT_FRAME_POINTERS). However, the lib/Kconfig.debug definition allows
such option to be disabled. This patch forces FRAME_POINTER always on on arm64.
Signed-off-by: Yang Shi <yang.shi@linaro.org>
We use !CONFIG_ARM64_64K_PAGES for CONFIG_ARM64_4K_PAGES
(and vice versa) in code. It all worked well, so far since
we only had two options. Now, with the introduction of 16K,
these cases will break. This patch cleans up the code to
use the required CONFIG symbol expression without the assumption
that !64K => 4K (and vice versa)
Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com>
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Keeping drivers related to HW tracing on ARM, i.e coresight,
under "drivers/coresight" doesn't make sense when other
architectures start rolling out technologies of the same
nature.
As such creating a new "drivers/hwtracing" directory where all
drivers of the same kind can reside, reducing namespace
pollution under "drivers/".
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Most CoreSight blocks are 64-bit ready. As such move configuration
entries from "arch/arm/Kconfig.config" to the driver's subdirectory
and source the newly created Kconfig from architecture specific
Kconfig.debug files.
Add page protections for arm64 similar to those in arm.
This is for security reasons to prevent certain classes
of exploits. The current method:
- Map all memory as either RWX or RW. We round to the nearest
section to avoid creating page tables before everything is mapped
- Once everything is mapped, if either end of the RWX section should
not be X, we split the PMD and remap as necessary
- When initmem is to be freed, we change the permissions back to
RW (using stop machine if necessary to flush the TLB)
- If CONFIG_DEBUG_RODATA is set, the read only sections are set
read only.
Tested-by: Kees Cook <keescook@chromium.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
In a similar manner to arm, it's useful to be able to dump the page
tables to verify permissions and memory types. Add a debugfs file
to check the page tables.
Acked-by: Steve Capper <steve.capper@linaro.org>
Tested-by: Steve Capper <steve.capper@linaro.org>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
[will: s/BUFFERABLE/NORMAL-NC/]
In a similar fashion to other architecture, add the infrastructure
and Kconfig to enable DEBUG_SET_MODULE_RONX support. When
enabled, module ranges will be marked read-only/no-execute as
appropriate.
[will: fixed off-by-one in module end check]
The arm64 Image header contains a text_offset field which bootloaders
are supposed to read to determine the offset (from a 2MB aligned "start
of memory" per booting.txt) at which to load the kernel. The offset is
not well respected by bootloaders at present, and due to the lack of
variation there is little incentive to support it. This is unfortunate
for the sake of future kernels where we may wish to vary the text offset
(even zeroing it).
This patch adds options to arm64 to enable fuzz-testing of text_offset.
CONFIG_ARM64_RANDOMIZE_TEXT_OFFSET forces the text offset to a random
16-byte aligned value value in the range [0..2MB) upon a build of the
kernel. It is recommended that distribution kernels enable randomization
to test bootloaders such that any compliance issues can be fixed early.
Acked-by: Tom Rini <trini@ti.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Now that we have equivalent earlycon support, arm64's earlyprintk code
can be removed.
Signed-off-by: Rob Herring <robh@kernel.org>
The Kconfig for CONFIG_STRICT_DEVMEM is missing despite being
used in mmap.c. Add it.
This config item already exists generically in lib/Kconfig.debug.
Remove the duplicate config in arm64.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
The Kconfig entry for DEBUG_ERRORS is a verbatim copy of the former arm
entry for that symbol. It got removed in v2.6.39 because it wasn't
actually used anywhere. There are still no users of DEBUG_ERRORS so
remove this entry too.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
[catalin.marinas@arm.com: removed option from defconfig]
This patch is a port of 575320d62 ("ARM: 7445/1: mm: update CONTEXTIDR
register to contain PID of current process") from ARM that introduces a
new Kconfig option which, when enabled, causes the kernel to write the
PID of the current task into the CONTEXTIDR register on context switch.
This is useful when analysing hardware trace, since writes to this
register can be configured to emit an event into the trace stream.
[catalin.marinas@arm.com: contextidr_thread_switch() moved to mmu_context.h]
This patch adds support for "earlyprintk=" parameter on the kernel
command line. The format is:
earlyprintk=<name>[,<addr>][,<options>]
where <name> is the name of the (UART) device, e.g. "pl011", <addr> is
the I/O address. The <options> aren't currently used.
The mapping of the earlyprintk device is done very early during kernel
boot and there are restrictions on which functions it can call. A
special early_io_map() function is added which creates the mapping from
the pre-defined EARLY_IOBASE to the device I/O address passed via the
kernel parameter. The pgd entry corresponding to EARLY_IOBASE is
pre-populated in head.S during kernel boot.
Only PL011 is currently supported and it is assumed that the interface
is already initialised by the boot loader before the kernel is started.
This patch adds Makefile and Kconfig files required for building an
AArch64 kernel.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
